Discourse Restricted Replies
:discourse2: Summary Discourse Restricted Replies adds a per-category setting allowing staff to restrict replies on topics to the topic creator and members of specific groups.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-restricted-replies
:open_book: Install Guide How to install plugins in Discourse
Features
This plugin adds a per-category setting allowing staff to restrict replies to the OP, and members of specific groups. This is a bolt-on to the core permissions system, and is configured using a separate UI underneath the regular category security settings.
In the regular Discourse permissions system, this might be called
Create / Reply (creator only) / View
You may want to use this to create a support category where all users can ask questions, but only users in the “Employees” group can post replies.
:exclamation: This plugin has a very specific use case. In general, we recommend keeping support categories open, so that the community can help each other answer questions.
CHANGELOG
TODO
30 Mi Piace
