Telegram Notifications Plugin (discourse-telegram-notifications)
The Discourse Telegram Notifications Plugin, developed by david, enables individual Discourse users to receive their forum notifications via Telegram bot — not for group chat sync or topic creation from chat. It’s distinct from the discourse-chat-integration plugin, which sends topic notifications to Telegram groups/channels. Both can coexist but require separate bots. Setup requires HTTPS, internet accessibility (e.g., via ngrok in dev), and BotFather configuration. Users receive a Chat ID via bot message, which they paste into their Discourse preferences. A data explorer query helps track active users. The plugin is a work in progress; david notes future goals include streamlining the user setup flow. Some users reported compatibility or SSL errors (e.g., Siddhu_Dhangar, Surendra-Patil), which david addressed with updates. Flashio noted tag-change notifications appearing as replies — a behavior mitigated in later Discourse updates, though not fully configurable. danb35 resolved a non-working setup by correcting the Chat ID. david merged a contribution from barreeeiroo. nildarar asked about using {name} instead of {username} in translations — david confirmed this requires code changes. The plugin is unofficial despite david being a Discourse team member.
This plugin allows users to receive their notifications via a Telegram bot, allowing them to turn off email notifications and still keep up-to-date. :success:
You can “like” posts, and respond to them via the bot.
Here’s a quick demo video:
Before Starting
  • Your forum must be using HTTPS, and have force_https turned on
  • Your forum must be accessible to the internet, not only an internal network (in development, give ngrok a try).
Getting the plugin setup
  1. Install the plugin using the instructions here: How to install a plugin
  2. Create a telegram bot by talking to the BotFather (instructions here)
  3. Paste the “token” into the site setting “telegram access token”
  4. Tick “telegram notifications enabled”
I strongly recommend you use the BotFather’s /setjoingroups command to disable the bot being used for group chats. It is not designed for it, and risks leaking information that users are not supposed to be able to access (e.g. you don’t want private messages being sent to a group chat).
You can set the name/picture/description of your bot using the instructions here
For users to receive notifications
  1. Send a message to the bot, you’ll receive a message back that looks like
To get notifications for Discourse, enter the ‘Chat ID’ 1234567 in your user preferences
  1. Visit your Discourse user preferences, and paste the number in the Telegram Notifications box
  2. You should now receive notifications by telegram message!
Find out who’s using telegram for notifications
Here’s a query for the data explorer plugin:
SELECT user_id, updated_at, value from user_custom_fields
WHERE name = 'telegram_chat_id'
This is still a work in progress. I think the next task would be to improve the setup flow for the user, so they don't have to copy/paste numbers between telegram and the forum.
Related discussions are: here, here, here and here
As always, suggestions and comments are very welcome :slight_smile:
71 Me gusta
Hola,
¿Cómo sincronizamos todo el chat (texto e imágenes) en un chat grupal de Telegram con un tema (enlace al tema) mediante un comentario?
¡Gracias!
Tengo otra pregunta:
¿Podemos publicar un tema en una categoría (configurada previamente), con contenido de texto, foto y etiquetas, en Discourse a través de Telegram o Slack? ¿Sincronizan el chat automáticamente sin reenviar el contenido (publicando una transcripción y configurando para publicar en Discourse)?
¡Gracias!
No es posible. La sincronización bidireccional entre el chat y Discourse no es un objetivo de este plugin (ni del plugin de integración de chat).
Puedes usar el plugin de integración de chat para enviar notificaciones basadas en nuevos temas de Discourse. No hay forma de crear temas desde el chat (excepto por la función de ‘transcripción’ que mencionaste).
1 me gusta
Hola @david
¿Puedo configurar un bot de Telegram para responder en un tema específico?
Ejemplo:
Cuando publico en un canal, ¿el bot puede crear una respuesta en un tema específico?
No, eso no es compatible. Esto está diseñado únicamente para que los usuarios individuales reciban sus notificaciones a través de Telegram.
3 Me gusta
He instalado el plugin discourse-telegram-notifications, pero no funciona. Muestra un error como “** PLUGIN INCOMPATIBLE **”. Cloné este plugin usando la URL GitHub - davidtaylorhq/discourse-telegram-notifications: A plugin for Discourse which allows users to receive their notifications by telegram message · GitHub. ¿Es esta la URL correcta de GitHub? ¿Alguien puede ayudarme a resolver este problema?
2 Me gusta
Gracias por el informe, @Siddhu_Dhangar. Acabo de publicar una actualización del complemento, así que por favor inténtalo de nuevo ahora.
6 Me gusta
Por cierto: estoy recibiendo el siguiente mensaje en el canal de TG, presumiblemente cuando hay un nuevo hilo en una categoría de subforo que estoy vigilando o suscripto.
translation missing: de.discourse_telegram_notifications.message.watching_first_post
¿Dónde puedo declarar esa cadena? ¿O tengo que ir a Transifex para eso? De ser así, por favor indícame dónde buscar.
/usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `connect_nonblock'
/usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in `ssl_socket_connect'
/usr/local/lib/ruby/2.6.0/net/http.rb:996:in `connect'
/usr/local/lib/ruby/2.6.0/net/http.rb:930:in `do_start'
/usr/local/lib/ruby/2.6.0/net/http.rb:919:in `start'
/usr/local/lib/ruby/2.6.0/net/http.rb:1470:in `request'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/net_patches.rb:9:in `block in request_with_mini_profiler'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiling_methods.rb:39:in `step'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/net_patches.rb:8:in `request_with_mini_profiler'
/var/www/discourse/plugins/discourse-telegram-notifications/services/discourse_telegram_notifications/telegram-notifier.rb:41:in `doRequest'
/var/www/discourse/plugins/discourse-telegram-notifications/services/discourse_telegram_notifications/telegram-notifier.rb:7:in `sendMessage'
/var/www/discourse/plugins/discourse-telegram-notifications/plugin.rb:122:in `hook'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/base.rb:196:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/rendering.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/callbacks.rb:135:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/callbacks.rb:41:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/rescue.rb:22:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications.rb:180:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications.rb:180:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.0/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/base.rb:136:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.0/lib/action_view/rendering.rb:39:in `process'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal.rb:191:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal.rb:252:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:51:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:33:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:49:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:837:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/engine.rb:526:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/mapper.rb:19:in `block in <class:Constraints>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/mapper.rb:48:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-protection-2.0.7/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/tempfile_reaper.rb:15:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/conditional_get.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/head.rb:12:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:274:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:232:in `context'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:226:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/cookies.rb:648:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/callbacks.rb:101:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.4.1/lib/logster/middleware/reporter.rb:43:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/rack/logger.rb:28:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:18:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/request_id.rb:27:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/method_override.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/executor.rb:14:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/sendfile.rb:111:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/host_authorization.rb:77:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiler.rb:184:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.3/lib/message_bus/rack/middleware.rb:57:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:176:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:68:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in `call'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:605:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:700:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:144:in `start'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
¿Cómo puedo solucionar este error?
[quote=“Surendra-Patil, post:121, topic:60483, full:true”]
Texto preformateado
/usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in connect_nonblock' /usr/local/lib/ruby/2.6.0/net/protocol.rb:44:in ssl_socket_connect’
/usr/local/lib/ruby/2.6.0/net/http.rb:996:in connect' /usr/local/lib/ruby/2.6.0/net/http.rb:930:in do_start’
/usr/local/lib/ruby/2.6.0/net/http.rb:919:in start' /usr/local/lib/ruby/2.6.0/net/http.rb:1470:in request’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/net_patches.rb:9:in block in request_with_mini_profiler' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiling_methods.rb:39:in step’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/patches/net_patches.rb:8:in request_with_mini_profiler' /var/www/discourse/plugins/discourse-telegram-notifications/services/discourse_telegram_notifications/telegram-notifier.rb:41:in doRequest’
/var/www/discourse/plugins/discourse-telegram-notifications/services/discourse_telegram_notifications/telegram-notifier.rb:7:in sendMessage' /var/www/discourse/plugins/discourse-telegram-notifications/plugin.rb:122:in hook’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/basic_implicit_render.rb:6:in send_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/base.rb:196:in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/rendering.rb:30:in process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/callbacks.rb:42:in block in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/callbacks.rb:135:in run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/callbacks.rb:41:in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/rescue.rb:22:in process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/instrumentation.rb:33:in block in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications.rb:180:in block in instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications/instrumenter.rb:24:in instrument’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/notifications.rb:180:in instrument' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/instrumentation.rb:32:in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal/params_wrapper.rb:245:in process_action' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.0/lib/active_record/railties/controller_runtime.rb:27:in process_action’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/abstract_controller/base.rb:136:in process' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.0/lib/action_view/rendering.rb:39:in process’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiling_methods.rb:78:in block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal.rb:191:in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_controller/metal.rb:252:in dispatch' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:51:in dispatch’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:33:in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:49:in block in serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in each' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:837:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/engine.rb:526:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in public_send' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/railtie.rb:190:in method_missing’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/mapper.rb:19:in block in <class:Constraints>' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/mapper.rb:48:in serve’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:49:in block in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/journey/router.rb:32:in serve' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/routing/route_set.rb:837:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-protection-2.0.7/lib/rack/protection/frame_options.rb:31:in call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:68:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/tempfile_reaper.rb:15:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/conditional_get.rb:38:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/head.rb:12:in call' /var/www/discourse/lib/content_security_policy/middleware.rb:12:in call’
/var/www/discourse/lib/middleware/anonymous_cache.rb:274:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:232:in context’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/session/abstract/id.rb:226:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/cookies.rb:648:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/callbacks.rb:27:in block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.0/lib/active_support/callbacks.rb:101:in run_callbacks’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/callbacks.rb:26:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/actionable_exceptions.rb:17:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/debug_exceptions.rb:32:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/logster-2.4.1/lib/logster/middleware/reporter.rb:43:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/rack/logger.rb:38:in call_app’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/rack/logger.rb:28:in call' /var/www/discourse/config/initializers/100-quiet_logger.rb:18:in call’
/var/www/discourse/config/initializers/100-silence_logger.rb:31:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/remote_ip.rb:81:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/request_id.rb:27:in call' /var/www/discourse/lib/middleware/enforce_hostname.rb:17:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/method_override.rb:22:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/executor.rb:14:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/sendfile.rb:111:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionpack-6.0.0/lib/action_dispatch/middleware/host_authorization.rb:77:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-1.1.3/lib/mini_profiler/profiler.rb:184:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/message_bus-2.2.3/lib/message_bus/rack/middleware.rb:57:in call’
/var/www/discourse/lib/middleware/request_tracker.rb:176:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/railties-6.0.0/lib/rails/engine.rb:526:in call’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:68:in block in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in each’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-2.0.7/lib/rack/urlmap.rb:53:in call' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:605:in process_client’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:700:in worker_loop' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:548:in spawn_missing_workers’
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/lib/unicorn/http_server.rb:144:in start' /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/unicorn-5.5.1/bin/unicorn:128:in <top (required)>’
/var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in load' /var/www/discourse/vendor/bundle/ruby/2.6.0/bin/unicorn:23:in ’
¿Puedes compartir lo que ves en la pestaña info del registro? Parece que solo es el backtrace
Parece que tu servidor está teniendo problemas para contactar https://api.telegram.org. ¿Estás utilizando una instalación compatible? ¿Tu servidor está dentro de una red que podría estar interfiriendo con las solicitudes salientes?
1 me gusta
Hola @david, disculpa la respuesta tardía.
Sí, el sitio es accesible (redirige a Bots: An introduction for developers).
También estoy obteniendo el siguiente error:
ActionView::MissingTemplate (Falta la plantilla discourse_telegram_notifications/telegram/hook, application/hook con {:locale=>[:en_US, :en], :formats=>[:html], :variants=>[], :handlers=>[:raw, :erb, :html, :builder, :ruby]}. Buscado en:
  * "/var/www/discourse/app/views"
  * "/var/www/discourse/plugins/docker_manager/app/views"
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/actionview-6.0.0/lib/action_view/path_set.rb:48:in `find'
Al ejecutar openssl s_client -connect api.telegram.org:443 obtuve el siguiente resultado:
CONNECTED(00000003)
write:errno=104
no peer certificate available
No client certificate CA names sent
SSL handshake has read 0 bytes and written 308 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
@codinghorror Recientemente se cambió la versión de OpenSSL en el último contenedor Docker de Discourse, lo cual está causando este problema. En la máquina anfitrión probé usando OpenSSL 1.1.1 para la API de Telegram y carga el certificado.
@david
Nuevo error: después de cambiar la etiqueta de un tema, el primer mensaje de ese tema se enviará a Telegram como notificación. Así que cada vez que cambies la etiqueta de un tema, habrá una notificación en Telegram.
NOTA: El error está activo en la versión 2.4.0.beta7 (06c2e28bbb). Para activar el error, el creador del tema debe crearlo con etiquetas, luego debe responder a ese hilo y su mensaje debe ser el último en el tema. Después, si el creador del tema cambia la etiqueta, el plugin enviará una notificación que incluirá el texto del primer mensaje.
Así es como recibirás notificaciones infinitas con el primer mensaje del tema:
  1. El creador del tema debe crear un tema.
  2. El creador del tema debe responder a este tema.
  3. El creador del tema debe cambiar la etiqueta del tema. Y ahora, cada vez que cambie la etiqueta del tema, todos los suscritos a este tema recibirán una notificación que incluirá el primer mensaje de ese tema.
Si alguien responde después de la respuesta del creador del tema y este cambia la etiqueta del tema: la notificación con el primer mensaje seguirá llegando, pero solo una vez.
Por favor, solucionen este problema, ya que estoy usando Discourse como plataforma de notificaciones. :slight_smile:
¿Los usuarios también reciben las ‘notificaciones infinitas’ en la interfaz de usuario de Discourse?
Este plugin utiliza el mismo sistema de notificaciones que el propio Discourse, por lo que me sorprendería que este problema fuera específico de las notificaciones de Telegram.
1 me gusta
Sí. Cuando el creador del tema cambia la etiqueta del tema, aparece como una notificación en Discourse (solo si el creador del tema fue el último en responder a este tema).
¿Puedo desactivarlo de alguna manera o es un error? Este error/funcionalidad llegó con la actualización 2.4.0.beta7.
Por cierto, después de la última actualización (87a298a59b) las notificaciones infinitas al cambiar la etiqueta del tema han desaparecido. Ahora solo aparece una notificación cuando se cambia la etiqueta. Pero aún así, ¿cómo desactivo la notificación al cambiar la etiqueta? La notificación aparece como una “notificación de respuesta”, pero no lo es.
Esta notificación se recibió después de que “fiss”, como creador del tema, cambiara la etiqueta.
1 me gusta
¿Tienes las etiquetas configuradas como “viendo” en tus preferencias de usuario?
1 me gusta
Lo he revisado. No. :slight_smile: Todo mi equipo solo activó “seguir” en la categoría, pero no en las etiquetas. Por cierto, no había tenido ese problema antes de la actualización.
Recibo este error:
falta la traducción: vi.discourse_telegram_notifications.message.watching_first_post
Así que no puedo recibir notificaciones.
El plugin no está traducido a tu idioma.
Puedes enviar un pull request con la traducción aquí: discourse-telegram-notifications/config/locales at main · davidtaylorhq/discourse-telegram-notifications · GitHub
1 me gusta
