PostgreSQL 15 update
:warning: WARNING! If your database is very large, you will need a lot of extra disk space (2x database size) and should be very careful with this upgrade!
We’ve just landed changes to upgrade our Docker image to PostgreSQL 15. Any site admins rebuilding Discourse from the command line will be upgraded to PostgreSQL 15 from the previous PostgreSQL 13. Note that if you held back from upgrading when the PostgreSQL 13 update happened back in 2020, you can skip that upgrade and go straight to PostgreSQL 15.
If you had held back the upgrade previously, change the PostgreSQL template in app.yml from templates/postgres.12.template.yml to templates/postgres.template.yml.
As with any upgrade, it is strongly advised to take a backup before doing anything.
Updating
Official Install Guide (single container)
On your next rebuild, you will see this message at the end:
UPGRADE OF POSTGRES COMPLETE
Old 13 database is stored at /shared/postgres_data_old
To complete the upgrade, rebuild again using:
./launcher rebuild app
That means everything went well in the upgrade! You just need to issue a new rebuild to get your site back and running.
Data Container Install
If you are running a setup with a dedicated data container based in the sample supplied in our discourse_docker repository, you want to be sure you are shutting down PostgreSQL in a safe and clean way.
Nowadays, we have background jobs running queries spanning several minutes, so shutting down the web container will help the data container be shutdown safely.
./launcher stop web_only
./launcher stop data
./launcher rebuild data
./launcher rebuild web_only
Before issuing the first rebuild to the data container, you can tail the PostgreSQL log to see if it was shutdown properly.
Running a tail -f shared/standalone/log/var-log/postgres/current should give you the following log if it was clean:
2025-01-24 09:19:06.437 UTC [37] LOG:  received smart shutdown request
2025-01-24 09:19:06.444 UTC [37] LOG:  background worker "logical replication launcher" (PID 54) exited with exit code 1
2025-01-24 09:19:06.446 UTC [49] LOG:  shutting down
2025-01-24 09:19:06.468 UTC [37] LOG:  database system is shut down
Doing a manual update / space constrained environments
:warning::warning::warning:
YOU MUST BACKUP THE POSTGRES_DATA BEFORE TRYING THIS
If you are in a constrained space environment without any way to get more space you can try the following:
./launcher stop app #(or both web_only and data if that is your case)
mkdir -p /var/discourse/shared/standalone/postgres_data_new
docker run --rm \
	--entrypoint=/bin/bash \
	-v /var/discourse/shared/standalone/postgres_data:/var/lib/postgresql/13/data \
	-v /var/discourse/shared/standalone/postgres_data_new:/var/lib/postgresql/15/data \
	tianon/postgres-upgrade:13-to-15 \
	-c "apt-get update && apt-get install -y postgresql-13-pgvector postgresql-15-pgvector &&
	docker-upgrade"
mv /var/discourse/shared/standalone/postgres_data /var/discourse/shared/standalone/postgres_data_old
mv /var/discourse/shared/standalone/postgres_data_new /var/discourse/shared/standalone/postgres_data
docker run --rm -v /var/discourse/shared/standalone:/shared local_discourse/app \
	chown -R postgres:postgres /shared/postgres_data #(or local_discourse/data)
./launcher rebuild app #(or first data and then web_only if that is your case)
On my tests this procedure requires less than 1x your current database size in free space.
If you are using a non-default locale, you can try replacing the first docker command with this:
# change 'en_US.UTF-8' to your locale
docker run --rm \
	-e LANG='en_US.UTF-8' \
	-c 'sed -i "s/^# $LANG/$LANG/" /etc/locale.gen && locale-gen &&
	docker-upgrade'
Postponing the update
If you need to postpone the update during your next rebuild, you can swap the PostgreSQL template on your app.yml file by changing "templates/postgres.template.yml" to "templates/postgres.13.template.yml".
This is not recommended, as some site admins will forget to revert the change afterwards.
Post update optional tasks
Optimizing PostgreSQL statistics
After the update, the new PostgreSQL won’t have table statistics on hand. You can generate those using:
docker exec -u postgres app \
	/usr/lib/postgresql/15/bin/vacuumdb -d discourse --analyze-in-stages
Cleaning up old data
For a standard install, you can delete the old data in PG13 format with the following command:
cd /var/discourse
./launcher cleanup
If you have a separate data container, you’ll need to remove the backup copy like this:
rm -fr /var/discourse/shared/data/postgres_data_old/
FAQ
The source cluster was not shut down cleanly
If you get a upgrade failed with the above message, you can try a simpler approach to get it back into a better state.
Restart the old container with ./launcher start app. Wait a few minutes until it is back up.
Now shut it down again with ./launcher stop app. After that tail the logs to see if it was a clean one:
If the logs do not indicate that the database is shut down, you can start the old container again, enter with ./launcher enter app, run these commands and tail the logs again once done.
export SVWAIT=300
sv stop nginx
sv stop unicorn
sv stop postgres
exit
If the logs look like above, you can now try to upgrade again using ./launcher rebuild app.
lc_collate values for database “postgres” do not match
This errors happens if you are using non-default locales for your database. It was reported that you need 3 variables for it to succeed. Ensure that the env: section of you app.yml file has the 3 lines:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
Changing en_US.UTF-8 to your locale.
Every rebuild does the upgrade again aka upgrade loop
When this happens your upgrade logs will contain
mv: cannot move '/shared/postgres_data' to '/shared/postgres_data_old/postgres_data': Directory not empty
mv: cannot move '/shared/postgres_data_new' to '/shared/postgres_data/postgres_data_new': Directory not empty
This means that there are still files from the last upgrade lingering around. Move those elsewhere before continuing.
Upgrade Complete suggestion scripts - do I need to do anything?
Once the upgrade completes, you’ll see output from the pg_upgrade message saying:
Upgrade Complete
Optimizer statistics are not transferred by pg_upgrade.
Once you start the new server, consider running:
    /usr/lib/postgresql/15/bin/vacuumdb --all --analyze-in-stages
Running this script will delete the old cluster's data files:
    ./delete_old_cluster.sh
You can safely ignore this message.
I did skip the PostgreSQL 13 update, what to do now?
You can follow the standard instructions at the top of this guide and they will upgrade from your version to 15 without issues.
If you are following the space constrained instructions, adapt the version numbers accordingly.
Rebuilding indexes can give you significant disk space savings. Follow the steps from our PostgreSQL 13 update after the upgrade.
When I visit https://community.ankihub.net/admin/update, I see the following message:
You are running an old version of the Discourse image
Updates via the web UI are disabled until you run the latest image. To do so log in to your server using SSH and run:
cd /var/discourse
git pull
After following those instructions, I get UPGRADE OF POSTGRES FAILED:
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of start.
Processing triggers for postgresql-common (267.pgdg120+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Stopping PostgreSQL 13 database server: main.
Stopping PostgreSQL 15 database server: main.
Performing Consistency Checks
Checking cluster versions                                   ok
Checking database user is the install user                  ok
Checking database connection settings                       ok
Checking for prepared transactions                          ok
Checking for system-defined composite types in user tables  ok
Checking for reg* data types in user tables                 ok
Checking for contrib/isn with bigint-passing mismatch       ok
Checking for user-defined encoding conversions              ok
Checking for user-defined postfix operators                 ok
Checking for incompatible polymorphic functions             ok
Creating dump of global objects                             ok
Creating dump of database schemas
*failure*
Consult the last few lines of "/shared/postgres_data_new/pg_upgrade_output.d/20250129T103738.877/log/pg_upgrade_dump_16384.log" for
the probable cause of the failure.
Failure, exiting
Please visit https://meta.discourse.org/t/postgresql-15-update/349515 for support.
You can run ./launcher start app to restart your app in the meanwhile
FAILED
Pups::ExecError: if [ -f /root/install_postgres ]; then
  /root/install_postgres && rm -f /root/install_postgres
elif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then
  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
fi
 failed with return #<Process::Status: pid 18 exit 1>
exec failed with the params {"tag"=>"db", "cmd"=>"if [ -f /root/install_postgres ]; then\n  /root/install_postgres && rm -f /root/install_postgres\nelif [ -e /shared/postgres_run/.s.PGSQL.5432 ]; then\n  socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1\nfi\n"}
Nothing at here or in this somewhat related topic addresses my issue, afaict.
Here are the logs from /shared/postgres_data_new/pg_upgrade_output.d/20250129T103738.877/log/pg_upgrade_dump_16384.log:
command: "/usr/lib/postgresql/15/bin/pg_dump" --host /var/lib/postgresql --port 50432 --username postgres --schema-only --quote-all-identifiers --binary-upgrade --format=custom  --file="/shared/postgres_data_new/pg_upgrade_output.d/20250129T103738.877/dump/pg_upgrade_dump_16384.custom" 'dbname=discourse' >> "/shared/postgres_data_new/pg_upgrade_output.d/20250129T103738.877/log/pg_upgrade_dump_16384.log" 2>&1
pg_dump: error: query failed: ERROR:  could not access file "$libdir/vector": No such file or directory
pg_dump: detail: Query was: SELECT t.tableoid, t.oid, i.indrelid, t.relname AS indexname, pg_catalog.pg_get_indexdef(i.indexrelid) AS indexdef, i.indkey, i.indisclustered, c.contype, c.conname, c.condeferrable, c.condeferred, c.tableoid AS contableoid, c.oid AS conoid, pg_catalog.pg_get_constraintdef(c.oid, false) AS condef, (SELECT spcname FROM pg_catalog.pg_tablespace s WHERE s.oid = t.reltablespace) AS tablespace, t.reloptions AS indreloptions, i.indisreplident, inh.inhparent AS parentidx, i.indnkeyatts AS indnkeyatts, i.indnatts AS indnatts, (SELECT pg_catalog.array_agg(attnum ORDER BY attnum)   FROM pg_catalog.pg_attribute   WHERE attrelid = i.indexrelid AND     attstattarget >= 0) AS indstatcols, (SELECT pg_catalog.array_agg(attstattarget ORDER BY attnum)   FROM pg_catalog.pg_attribute   WHERE attrelid = i.indexrelid AND     attstattarget >= 0) AS indstatvals, false AS indnullsnotdistinct FROM unnest('{16805,16813,16823,16835,16846,16858,16940,16948,16963,16973,16996,17006,17029,17061,17071,17085,17095,17101,17112,17136,17151,17159,17168,17266,17280,17321,17334,17345,17354,17368,17382,17398,17412,17420,17428,17519,17532,17543,17562,17570,17620,17687,17710,17724,17738,17754,17775,17788,17803,17824,17851,17864,17898,17917,17932,17944,17958,17980,17993,18006,18019,18030,18041,18055,18069,18092,18101,18134,18145,18166,18177,18214,18241,18263,18276,18298,18324,18338,18358,18368,18403,18426,18449,18458,18470,18496,18510,18525,18534,18543,18569,18596,18607,18625,18643,18655,18663,18676,18686,18698,18710,18719,18734,18742,18757,18768,18786,18798,18802,18806,18846,18864,18879,18891,18910,18920,18932,18946,18988,19003,19014,19039,19059,19073,19085,19097,19103,19116,19140,19192,19206,19227,19250,19266,19300,19309,19328,19343,19354,19367,19389,19402,19417,19430,19497,19521,19544,19559,19569,19597,19605,19637,19687,19703,19721,19742,19771,19807,19821,19830,19839,19862,19874,19890,19904,19917,19932,19942,19951,19960,19981,20005,20021,20044,20052,20061,20073,20082,20133,20146,20157,20178,20191,20203,20217,20231,20263,20276,20297,20309,20320,28805,28951,28964,28976,28986,28997,32824,32833,32843,32852,32862,32875,32887,32899,32910,32930,32967,35131,35141,38401,38413,38437,38445,38461,38482,38495,42870,46125,46138,130133,191445,191457,191471,191486,191497,191603,191637,243875,606663,606675,606693,606707,779182,779197,779213,779225,779237,779252,779265,968985,968993,969004,969017,969027,1004239,1004251,1004263,1004276,1004295,1091838,1091849,1091860,1336877,1336884,1336891,1566392,2169846,2169852,2169858,2169864,2169870,2169876,2169882,2169888,2169894,2169900,2169906,2169912,2169918,2169924,2169930,2169936,2169942,2169948,2169954,2169960,2169966,2169972,2169978,2169984}'::pg_catalog.oid[]) AS src(tbloid)
JOIN pg_catalog.pg_index i ON (src.tbloid = i.indrelid) JOIN pg_catalog.pg_class t ON (t.oid = i.indexrelid) JOIN pg_catalog.pg_class t2 ON (t2.oid = i.indrelid) LEFT JOIN pg_catalog.pg_constraint c ON (i.indrelid = c.conrelid AND i.indexrelid = c.conindid AND c.contype IN ('p','u','x')) LEFT JOIN pg_catalog.pg_inherits inh ON (inh.inhrelid = indexrelid) WHERE (i.indisvalid OR t2.relkind = 'p') AND i.indisready ORDER BY i.indrelid, indexname
Here is the output of ./discourse-doctor:
./discourse-doctor output
DISCOURSE DOCTOR Wed 29 Jan 2025 10:39:42 AM UTC
OS: Linux forum 5.4.0-48-generic #52-Ubuntu SMP Thu Sep 10 10:58:49 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Found containers/app.yml
==================== YML SETTINGS ====================
DISCOURSE_HOSTNAME=community.ankihub.net
SMTP_ADDRESS=smtp.mailgun.org
DEVELOPER_EMAILS=REDACTED
SMTP_PASSWORD=REDACTED
SMTP_PORT=587
SMTP_USER_NAME=postmaster@mg.ankihub.net
LETSENCRYPT_ACCOUNT_EMAIL=REDACTED
==================== DOCKER INFO ====================
DOCKER VERSION: Docker version 27.2.1, build 9e34c9b
DOCKER PROCESSES (docker ps -a)
CONTAINER ID   IMAGE                           COMMAND        CREATED         STATUS          PORTS        NAMES
37e2430e1014   local_discourse/app             "/sbin/boot"   4 months ago    Up 33 seconds   0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp   app
260f4c0ed417   local_discourse/mail-receiver   "/sbin/boot"   20 months ago   Up 4 months     0.0.0.0:25->25/tcp, :::25->25/tcp                                          mail-receiver
Discourse container app is running
==================== PLUGINS ====================
          - git clone https://github.com/discourse/discourse-assign.git
          - git clone https://github.com/discourse/discourse-templates.git
          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-reactions.git
          - git clone https://github.com/discourse/discourse-chat-integration.git
          - git clone https://github.com/discourse/discourse-code-review.git
          - git clone https://github.com/discourse/discourse-topic-voting.git
          - git clone https://github.com/discourse/discourse-automation.git
          - git clone https://github.com/discourse/discourse-bbcode-color.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/discourse/discourse-docs.git
          - git clone https://github.com/discourse/discourse-ai.git
          - git clone https://github.com/discourse/discourse-jira.git
No non-official plugins detected.
See https://github.com/discourse/discourse/blob/main/lib/plugin/metadata.rb for the official list.
Discourse version at community.ankihub.net: Discourse 3.4.0.beta2
Discourse version at localhost: Discourse 3.4.0.beta2
==================== MEMORY INFORMATION ====================
OS: Linux
RAM (MB): 4127
              total        used        free      shared  buff/cache   available
Mem:           3936        1567         158         274        2209        1802
Swap:          2047          67        1980
==================== DISK SPACE CHECK ====================
---------- OS Disk Space ----------
/dev/vda1        78G   50G   28G  65% /
---------- Container Disk Space ----------
overlay          78G   50G   28G  65% /
/dev/vda1        78G   50G   28G  65% /shared
/dev/vda1        78G   50G   28G  65% /var/log
==================== DISK INFORMATION ====================
Disk /dev/loop0: 55.68 MiB, 58363904 bytes, 113992 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/loop1: 91.85 MiB, 96292864 bytes, 188072 sectors
Disk /dev/loop2: 63.71 MiB, 66789376 bytes, 130448 sectors
Disk /dev/loop3: 63.10 MiB, 67080192 bytes, 131016 sectors
Disk /dev/loop4: 44.45 MiB, 46596096 bytes, 91008 sectors
Disk /dev/loop5: 91.9 MiB, 96346112 bytes, 188176 sectors
Disk /dev/loop7: 44.3 MiB, 46448640 bytes, 90720 sectors
Disk /dev/vda: 80 GiB, 85899345920 bytes, 167772160 sectors
Disklabel type: gpt
Disk identifier: 2ED04D82-BA1D-4A75-86B9-9553B7EA5228
Device      Start       End   Sectors  Size Type
/dev/vda1  227328 167772126 167544799 79.9G Linux filesystem
/dev/vda14   2048     10239      8192    4M BIOS boot
/dev/vda15  10240    227327    217088  106M Microsoft basic data
Partition table entries are not in disk order.
Disk /dev/loop8: 55.37 MiB, 58052608 bytes, 113384 sectors
==================== END DISK INFORMATION ====================
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Mail test skipped.
==================== DONE! ====================
Hoping someone can point me in the right direction. Thanks!
I am having same issue as you and equally looking for a solution.
How can I check the size of my instance’s database?
Thanks for the reports - we’re looking into the could not access file "$libdir/vector" issue.
On a standard install, I think you can run this:
du -sh /var/discourse/shared/standalone/postgres_data
e.g. for my test site, the result is:
# du -sh /var/discourse/shared/standalone/postgres_data
237M	/var/discourse/shared/standalone/postgres_data
(@mwaniki please correct me if there’s a better way!)
Sure, that would return the total size of all PostgreSQL data files on disk (including WAL files.)
If you’re only interested in the discourse database size, you can use the pg_database_size function or the \list+ meta-command.
docker exec -u postgres app psql -c "SELECT pg_size_pretty( pg_database_size('discourse') ) AS db_size;"
# or
docker exec -u postgres app psql -c "\list+ discourse"
Out of interest, what is the advantage to using one of your vacuum analyze forms rather than the command suggested by postgres?
Just that it’s unnecessary to generate those statistics for anything outside the discourse database? If so, would analyze-in-stages be an advantage for very large instances if this was used instead:
/var/discourse/launcher run app "/usr/lib/postgresql/15/bin/vacuumdb -d discourse --analyze-in-stages"
Hi there @aas and @NKERIFAC_CLAUD_NBAPNON ! :wave:
I was unable to reproduce the error when running launcher rebuild for a site running on the previous base image. My tests resulted in a successful upgrade, even with the discourse-ai plugin installed.
Since the error occurs when dumping the schema from the old database, we’ve just pushed an update which I suspect might fix the issue you encountered.
You can try to follow the same steps and let us know how that goes.
cd /var/discourse
git pull
If that still does not fix the issue, could you share some more details about your environment? These would be particularly helpful:
  • your current base image version
    docker image inspect --format '{{ .Config.Image }}' local_discourse/app
  • installed Discourse plugins
    cat containers/app.yml | \
    docker run --rm -i -a stdout -a stdin local_discourse/app \
    ruby -e "require 'yaml'; puts YAML.load(STDIN.readlines.join)['hooks']"
  • PostgreSQL extensions and their versions
    docker exec -u postgres app psql discourse -c "SELECT
      name,
      default_version,
      installed_version
    FROM
      pg_catalog.pg_available_extensions
    WHERE
      installed_version IS NOT NULL;"
I noticed a concerning line in postgres.template.yml:
The current logic causes the script to exit immediately if the file /shared/postgres_run/.s.PGSQL.5432 exists, regardless of whether PostgreSQL is actually running. This skips all subsequent code in /root/install_postgres, including the upgrade script. I think the first exit 0 should be removed.
Upgrade fails for me, too. The error I see seems to indicate a locale problem (which is a bit weird since the locale of the system always was de_DE.UTF-8).
root@Ubuntu-2204-jammy-amd64-base /var/discourse # ./launcher rebuild app
x86_64 arch detected.
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 600 app
app
2.0.20250129-0720: Pulling from discourse/base
Digest: sha256:01b8516e5504c0e9bc3707773015ff4407be03a89154194ff3b5b8699291bc26
Status: Image is up to date for discourse/base:2.0.20250129-0720
docker.io/discourse/base:2.0.20250129-0720
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.2.1/lib/pups.rb
/usr/local/bin/pups --stdin
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (de_DE.UTF-8)
I, [2025-01-29T21:35:58.711630 #1]  INFO -- : Reading from stdin
I, [2025-01-29T21:35:58.721321 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2025-01-29T21:35:58.726551 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2025-01-29T21:35:58.732322 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2025-01-29T21:35:58.737436 #1]  INFO -- : File > /root/install_postgres  chmod: +x  chown:
I, [2025-01-29T21:35:58.742651 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2025-01-29T21:35:58.742825 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/15/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.743394 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.743708 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.744003 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.744441 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.744734 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.745027 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.747582 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.748035 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/15/main/postgresql.conf
I, [2025-01-29T21:35:58.748263 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/15/main/pg_hba.conf
I, [2025-01-29T21:35:58.748463 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-01-29T21:35:58.748657 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/15/main/pg_hba.conf
I, [2025-01-29T21:35:58.748844 #1]  INFO -- : > if [ -f /root/install_postgres ]; then
fi
initdb: warning: enabling "trust" authentication for local connections
initdb: hint: You can change this by editing pg_hba.conf or using the option -A, or --auth-local and --auth-host, the next time you run initdb.
W: https://dl.yarnpkg.com/debian/dists/stable/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
debconf: delaying package configuration, since apt-utils is not installed
I, [2025-01-29T21:37:25.430685 #1]  INFO -- : Generating locales (this might take a while)...
  de_DE.UTF-8... done
  en_US.UTF-8... done
Generation complete.
Upgrading PostgreSQL from version 13 to 15
The files belonging to this database system will be owned by user "postgres".
This user must also own the server process.
The database cluster will be initialized with locale "de_DE.UTF-8".
The default database encoding has accordingly been set to "UTF8".
The default text search configuration will be set to "german".
Data page checksums are disabled.
fixing permissions on existing directory /shared/postgres_data_new ... ok
creating subdirectories ... ok
selecting dynamic shared memory implementation ... posix
selecting default max_connections ... 100
selecting default shared_buffers ... 128MB
selecting default time zone ... Etc/UTC
creating configuration files ... ok
running bootstrap script ... ok
performing post-bootstrap initialization ... ok
syncing data to disk ... ok
Success. You can now start the database server using:
    /usr/lib/postgresql/15/bin/pg_ctl -D /shared/postgres_data_new -l logfile start
Get:1 http://deb.debian.org/debian bookworm-backports InRelease [59,0 kB]
Get:2 http://deb.debian.org/debian bookworm InRelease [151 kB]
Get:3 http://deb.debian.org/debian bookworm-updates InRelease [55,4 kB]
Get:4 https://dl.yarnpkg.com/debian stable InRelease [17,1 kB]
Get:5 http://deb.debian.org/debian-security bookworm-security InRelease [48,0 kB]
Get:6 https://deb.nodesource.com/node_22.x nodistro InRelease [12,1 kB]
Get:7 http://deb.debian.org/debian bookworm-backports/main amd64 Packages [280 kB]
Get:8 http://deb.debian.org/debian bookworm/main amd64 Packages [8.792 kB]
Get:9 http://deb.debian.org/debian bookworm-updates/main amd64 Packages [13,5 kB]
Get:10 https://dl.yarnpkg.com/debian stable/main amd64 Packages [10,9 kB]
Get:11 https://dl.yarnpkg.com/debian stable/main all Packages [10,9 kB]
Get:12 http://deb.debian.org/debian-security bookworm-security/main amd64 Packages [243 kB]
Get:13 https://deb.nodesource.com/node_22.x nodistro/main amd64 Packages [5.274 B]
Get:14 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg InRelease [129 kB]
Get:15 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 Packages [360 kB]
Fetched 10,2 MB in 2s (6.159 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
The following additional packages will be installed:
  postgresql-client-13
Suggested packages:
  postgresql-doc-13
The following NEW packages will be installed:
  postgresql-13 postgresql-13-pgvector postgresql-client-13
0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded.
Need to get 17,3 MB of archives.
After this operation, 56,7 MB of additional disk space will be used.
Get:1 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-client-13 amd64 13.18-1.pgdg120+1 [1.523 kB]
Get:2 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-13 amd64 13.18-1.pgdg120+1 [15,4 MB]
Get:3 https://apt.postgresql.org/pub/repos/apt bookworm-pgdg/main amd64 postgresql-13-pgvector amd64 0.8.0-1.pgdg120+1 [297 kB]
Fetched 17,3 MB in 1s (32,1 MB/s)
Selecting previously unselected package postgresql-client-13.
(Reading database ... 33363 files and directories currently installed.)
Preparing to unpack .../postgresql-client-13_13.18-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-client-13 (13.18-1.pgdg120+1) ...
Selecting previously unselected package postgresql-13.
Preparing to unpack .../postgresql-13_13.18-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-13 (13.18-1.pgdg120+1) ...
Selecting previously unselected package postgresql-13-pgvector.
Preparing to unpack .../postgresql-13-pgvector_0.8.0-1.pgdg120+1_amd64.deb ...
Unpacking postgresql-13-pgvector (0.8.0-1.pgdg120+1) ...
Setting up postgresql-client-13 (13.18-1.pgdg120+1) ...
Setting up postgresql-13 (13.18-1.pgdg120+1) ...
Creating new PostgreSQL cluster 13/main ...
/usr/lib/postgresql/13/bin/initdb -D /var/lib/postgresql/13/main --auth-local peer --auth-host md5
The database cluster will be initialized with locale "C.UTF-8".
The default text search configuration will be set to "english".
fixing permissions on existing directory /var/lib/postgresql/13/main ... ok
    pg_ctlcluster 13 main start
Setting up postgresql-13-pgvector (0.8.0-1.pgdg120+1) ...
Creating dump of database schemas                           ok
lc_collate values for database "template1" do not match:  old "en_US.UTF-8", new "de_DE.UTF-8"
Failure, exiting
FAILED
fi
80933ad1f9a6809c85383c9d512c34340988ab7791b3ff57a6a563fd42fc413f
Hi @mwaniki the update you pushed worked fine for me. Thanks a lot.
Since you get the failure when dumping the old schemas, can you confirm the current locale settings?
docker exec -it -u postgres app bash
env
psql -c 'SELECT
  datname,
  datcollate,
  datctype
FROM
  pg_database;'
Indeed. Thanks for pointing that out! I’ve updated the procedure in OP. :+1:
Glad to hear! Thanks for confirming.
4 posts were split to a new topic: Problems with Discouse AI embeddings configuration
Oefhh, would’ve been great if the update script was updated with a link to this and a prompt y/N. Now I updated and not sure if I need to recover my site now due to this change.
Edit: it seems to have finished successfully :tada:
I managed to upgrade one forum (there are four on this server) went to upgrade the next one but am getting:
Caused by:
PG::ConnectionBad: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: Connection refused (PG::ConnectionBad)
I’ve had to ./launcher start app to get it back up.
I seem to recall there was an issue with the PostgreSQL 12 update and I think I had to ./launcher stop app for the other apps before trying to do the upgrade, however that’s not working this time. (The posts in that thread were auto-removed, can a mod kindly check the posts to see if that was what I did?)
Any other thoughts?
I’ve requested the discourse-ai team to chime in.
Yes, that’s exactly what you had posted. I’ll have to test using a similar setup and get back to you.
Thanks Mwaniki, I managed to sort it - I just had to enter the app and sudo service postgresql stop before doing the upgrade rebuilds.
Thanks for all your help :heart:
The environment seems to have the expected locale (output of env below, email settings redacted):
LEFTHOOK=0
HOSTNAME=Ubuntu-2204-jammy-amd64-base-app
LANGUAGE=de_DE.UTF-8
UNICORN_WORKERS=8
DISCOURSE_HOSTNAME=[..]
RUBY_GC_HEAP_INIT_SLOTS=400000
DISCOURSE_SMTP_USER_NAME=[...]
DOCKER_HOST_IP=172.17.0.1
DISCOURSE_SMTP_ADDRESS=[...]
RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR=1.5
RUBY_VERSION=3.3.6
PWD=/
DISCOURSE_DB_SOCKET=/var/run/postgresql
DISCOURSE_DEVELOPER_EMAILS=[...]
HOME=/var/lib/postgresql
LANG=de_DE.UTF-8
DISCOURSE_SMTP_PORT=587
RUBY_GC_HEAP_GROWTH_MAX_SLOTS=40000
DEBIAN_RELEASE=bookworm
DISCOURSE_SMTP_PASSWORD=[...]
DISCOURSE_NOTIFICATION_EMAIL=[...]
PG_MAJOR=13
DISCOURSE_DB_HOST=
TERM=xterm
RUBY_ALLOCATOR=/usr/lib/libjemalloc.so
SHLVL=1
DISCOURSE_DB_PORT=
DISCOURSE_SMTP_DOMAIN=[...]
UNICORN_SIDEKIQS=1
LC_ALL=de_DE.UTF-8
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
RAILS_ENV=production
_=/usr/bin/env
However, the output of the Postgres-Statement indicates a US locale:
  datname  | datcollate  |  datctype
 postgres  | en_US.UTF-8 | en_US.UTF-8
 template1 | en_US.UTF-8 | en_US.UTF-8
 template0 | en_US.UTF-8 | en_US.UTF-8
 discourse | en_US.UTF-8 | en_US.UTF-8
(4 rows)
When did you create that Discourse instance?
So far our attempts at reproducing the issue are only possible when we create a db in one locale and then attempt to migrate using a different locale, and we’d like to understand when the instance was created to look if there could be any past locale bugs around that time.
As far as I can trace it back, the initial installation happened on February 7, 2024 (I think the server was commissioned a couple of days earlier, but the OS is Ubuntu 22.04, which, just like Discourse, was continuously updated).
Edit:
Not sure if that helps, but I think warnings about locale issues showing up is a relatively recent thing. I remember seeing them the last time I rebuilt the container, but I don’t think they were there from the start.
