Bundling more popular plugins with Discourse core
Over the next few weeks, we’ll be moving a number of popular Discourse plugins into the core repository. That means that Discourse will come with a larger number of plugins by default, and it’ll be easier for us to keep them all tested & up-to-date.
All these plugins will remain disabled by default, so this won’t have any visible impact on existing communities. If you use a managed hosting service like discourse.org, you don’t need to do anything.
Self-hosted communities
If you self-host Discourse, and are already using one of these plugins, you’ll be prompted to remove the relevant line from your app.yml file before your next rebuild.
Development Environment
If you already have one of the plugins installed locally, and then pull the latest version of Discourse core, one of two things will happen.
  1. If you use symlinks for your plugins, then you’ll get an error during git pull. To resolve the issue, delete the symlink, then run git pull again
  2. If you clone plugins directly, then the git pull of core will succeed, but you will have some surprising ‘unstaged changes’ caused by the nested git repositories. The best way to proceed is to delete the affected directory, and then restore it from main. For example:
    rm -rf plugins/discourse-reactions
    git restore plugins/discourse-reactions
Affected Plugins
How plugins moving to core is communicated
Core plugins added to my updated site today
What happens next?
Discourse Patreon
Bootstrap failed with exit code 128
最新版更新出错
Discourse Templates
Discourse Gamification
Discourse Affiliate
Discourse AI
Discourse Topic Voting
Discourse Post Voting
Discourse User Notes
Discourse Chatbot :robot:
Self-Hosting Discourse Just Got a Whole Lot Easier
Unboxing Discourse 3.5
Discourse Birthdays & Anniversaries Today (Banner)
Sudden Sidekiq trend change & anomaly
Discourse Assign
What happens next?
Discourse Captcha
Discourse Data Explorer
Discourse Login with Amazon
Discourse Graphviz
Discourse Learning Management System Integration (LTI 1.3 Authentication)
Microsoft Authentication
Discourse OAuth2 Basic
Discourse OpenID Connect (OIDC)
Discourse Reactions
RSS Polling
Discourse Subscriptions Plugin
Discourse Zendesk
Discourse Apple Authentication
Math and AI workarounds
Discourse AI Topic Summary :robot:
‘Preinstalled’ plugin label on hosted sites
Discourse Solved
Discourse Advertising Plugin (Ads)
Discourse GitHub
Discourse Policy
Discourse Docker Manager
3.5.0.beta8: Bundled plugins, a new theme, better color management, powerful filtering, and advanced image controls
Discourse Solved
Discourse Assign
Discourse Graphviz
Install plugins on a self-hosted site
How do I remove the Anniversaries option from the burger menu?
Add-on suggestions for humor focused community
[Admin Notice] One of your themes or plugins contains code which needs updating. (id:discourse.user.userOptions)
Discourse Chat Integrations
Discourse Events
Suggested improvements to plugin page now that more plugins are bundled
Error 500 when moving posts
Thanks for providing the full HINT line in the first post here, this helped me diagnose a failed rebuild this morning :blush:
Thanks. With my poor knowledge of development and programming, I would still like to ask you a question. Can these plugins, which are originally components intended to be added to a basic installation may one day lose their plug-in character and become a complete part of a basic installation, without being called plug-ins at all?
They might do, yes. In particular, the authentication plugins (e.g. apple-auth) are quite likely to be absorbed into core eventually, just like our other builtin authentication methods (e.g. Google, Facebook, etc.).
Interesting move that gears up discourse by default even more and facilitates new installs.
One question regarding :
Will there also be a prompt or a warning message before/when you click on the upgrade button from the admin upgrade page?
If I recall correctly from my experience, you will only be able to update docker at first. Once you’ve updated docker, you will be shown a message in the update UI explaining that you have to update via the command line, and how to do it.
Then when you update on the ocmmand line you’ll see the HINT for each plugin you need to remove from app.yml as explained in the first post above.
This is a good update but was this really necessary? Giving a rebuild failure seems a little bit harsh to me.. a UI warning or automated update (or just ignoring them entirely) would have been nicer than putting a gun to my head and saying “remove these now”
This caught me out last week when I tried to update via cmd line and it failed (reactions plugin).
It caught me out again when my cmd line update failed again this morning (data explorer plugin).
I would very much welcome a warning on the cmd line before the update process starts, and then inevitably fails.
Twice in two weeks now my updates have failed and this has meant my Discourse is offline for the duration of time it takes me to debug the issue, edit configs, try again, etc - all while in a mild state of panic because everything is broken.
There’s another problem.
Gem dependencies.
It’s not just a case of deleting redundant core plugin clones.
We also have the issue of gem version clashes as it significantly increases the amount of dependencies.
I’m just going through a process of downgrading a specific dependency in a couple of my own plugins because a core plugin is well behind.
So this move introduces some unnecessary extra dependencies imho and makes rebuilding more fragile.
In my particular case you are using multipart-post-2.2.3 where my plugins were already on multipart-post-2.4.0
That was two failed rebuilds and far more downtime than comfortable.
2 posts were split to a new topic: Suggested improvements to plugin page, now that more plugins are bundled with core,
A move we will follow up on shortly is getting rid of gem lines in core plugins and moving to the monolith gem file
I’m curious, did you get this list of plugins from Discourse installations in the wild? It matches almost 50% of my own main install!
I’m wondering, would having all these plugins bundled in core bloat forums? As in, there’ll probably be a few plugins that admins don’t want on their forum (e.g. Discourse AI), but have no choice but to have it added. It can be disabled, of course, but I’m wondering if the added files and stuff will slow down forums?
On the client side, Discourse does not serve any javascript assets for disabled plugins, so there won’t be any impact there.
On the server side, for properly implemented plugins (which all of these are), customizations from plugins are bypassed when they’re disabled. So yes technically there might be a slight overhead to check for enabled/disabled state, but it should be miniscule.
The plugins we’re merging here are the ones which we run on every single instance of Discourse on our discourse.org hosting. So they’re all very well-tested at scale.
Got it. Thanks for clarifying!
Is there a reason why you are doing all this at once shortly before the release? For translators who do this in their spare time, 3,000 additional strings within two weeks is a lot. And even in languages where the plugins were previously translated, all 3,000 texts have to be proofread again. Every now and then, 300 would probably be more manageable than 1,500 each week.
For self-hosted communities already running one or more of these plugins, will the plugins lose config data when removed from app.yml and folded into core?
I’ve got the AI plugin set up exactly how I want it; if I need to reconfigure it (or at least write down the config options so I can re-add them), it’d be nice to know now. :+1:
We’ve been trying to make this as smooth as possible for translators by making use of the translation memory in crowdin, so that translations don’t have to be re-made from scratch. But still, I agree, there are a lot to proofread.
I wonder if there’s more we can automate here, e.g. maybe we can “auto approve” any strings from these plugins, instead of requiring a proofread :eyes:
All config/data will be maintained
A message in the UI prompting a rebuild that is destined to fail felt really inelegant.
Was there no way to at least flag this topic for sites running a minimum docker manager version?
This meta topic isn’t really what you would want to see though.
The difficulty lies with knowing which plugins you should remove from your app.yml and which plugins you should not remove.
