自动链接词
:exclamation:Discourse has a built-in feature called Watched Words which can replicate most of the features of this theme component. Consider using that before installing this theme component.
:discourse2: Summary Auto-Linkify Words allows you to automatically hyperlink certain words or patterns in your post with the desired destination URL.
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-linkify-words
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
How to configure?
Configure the theme settings with the format
WORD, https://destination.url.com
or using regular expressions (in JavaScript implementation) with the format
/regex/, https://destination.url.com
One item per line
Using regular expressions
With regular expressions, you can match a certain pattern to a single URL. This is useful for synonyms or for words which can take different forms in the sentence etc.
However, you can also generate the URL automatically based on what was matched. For example, let’s say you have a line of products, each with its own numeric id, and you want to autolink them to their own URLs. Using
/product-([0-9]+)/, https://myshop.com/product/$1
product-42 will be autolinked to https://myshop.com/product/42
Notice the capturing parentheses in the regular expression and the $1 in the URL which is substituted by the match inside the parenthesis. You can also capture multiple parts of the string and use $2, $3 and so on.
Regular expressions are by default case sensitive (unlike WORD’s which are case insensitive). However, you can change that by using a standard “i” modfier like this:
/foo/i, https://example.com
In this case, FOO, Foo or foo will all be matched.
How this looks in action?
Limitations
  • Replacement will only appear in the web UI and will not appear in emails.
Settings
Name Description
linked words
excluded tags
excluded classes
Credits
Big thanks to @Osama for building theme settings and https://stackoverflow.com/questions/8949445/javascript-bookmarklet-to-replace-text-with-a-link for guiding on the implementation.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
104 个赞
Add <abbr> tags to words in posts
How to automatically convert Keywords to Affiliate Links?
Special inline commands
Discourse Linkify Google Sheets
Is there a plugin to make my forum a shop?
When a thread is too important to lose
Customizing your site with existing theme components
User preference persists through Safe Mode
Add settings to your Discourse theme
Discourse Dictionary Plugin :ab:
How to replace text and update dynamically
Redirecting internal links via routes
Watched Words to serve as shortcut command to insert links
Limit # of links for a watched word?
How can I enable: Auto-hyperlinking text to reference to other posts?
Notification email without external link
Rewrite external URLs
Linked/forcing search keywords to specific topics/posts
Replace text with more than just links?
Community glossary?
The most easy way to let my users insert a FinViz chart image based on values?
Options for integrating a wiki knowledge base
Abbreviations and acronyms plugin
Support for magnet links
Need proofread of this advise about using theme preview
Meta annotation sidepost for bots?
Object Settings?
Any Autolinker solution for Discourse?
Javascript in theme component only runs once?
Images in posts versus topic-list-previews
Replacing special text to linkify them on posts
Comment on a question instead of answering it
Auto-replace text with link to topic
What are the different ways to customize content inside a post (custom attributes and such)
Minor mod to Automatic Actions based on Words Found in Posts
Prevent hyperlink
Turn off automatic (c) to © substitution
Watched words links corrupt @mentions and #categories
Get only top level posts in topic via discourse API
fantastic, system-wide feature… was thinking about this just the other day!
Hi
First off, I’d just like to thank everyone for all the help provided to me over the past few weeks. I know I’ve been asking lots of questions - I am also a beginner to Discourse and coding in general, and the community here has been incredible.
I am wondering if it would be possible to add on a feature to this, which is very similar in nature. I think most of the functionality is built, my use case for this is slightly different however.
Would it be possible to have a box like this on a ‘Tags’ page, where the user can type in specific tag words manually, and it would create a customized url based on these words? For example, the image below would produce a url something like this: www.websitename.com/tags/■■■■■/■■■■■/■■■■■. This would be a great feature for Tags Intersection, and would allow the user to specify the words in their intersection.
Thanks.
1 个赞
seems to be not showing when you add it to a theme:
21%20AM
tried adding to default… but doesn’t seem to be working as intended:
It is not a problem related to this specific theme, see:
https://meta.discourse.org/t/js-error-on-click-adding-a-theme-component/82313
4 个赞
Sometimes one like is not enough. :heart: Office high-fives took place today as we thought through all the ways we could put this to use!
One question, though: Is the following a bug?
Most of my links are working, however urls that include appended parameters are failing.
For example, I want to use this link:
https://republicwireless.com/shop/phones/moto-x4/?icid=phones-cta-forums-moto-x4-post
but when it is created from linkified words, clicking it results in:
https://forums.republicwireless.com/clicks/track?url=%20https%3A%2F%2Frepublicwireless.com%2Fshop%2Fphones%2Fmoto-x4%2F%3Ficid%3Dphones-cta-forums-moto-x4-post&post_id=134361&topic_id=16863
The same link added to a post traditionally (pasted, or using the “link” icon from the toolbar) works.
5 个赞
Looks like @zogstrip fixed this FIX: don't track clicks · discourse/discourse-linkify-words@ef072b3 · GitHub … I just updated your component, can your refresh the problem page and try again?
6 个赞
That appears to have fixed it! Thank you!!
1 个赞
Keep in mind, we are going to elevate this to a proper feature in Discourse in the “special actions on words” section, but it will take a bit.
I love that this is a component though cause we get to “test out components” in anger. @Osama / @j.jaffeux one huge omission we have here is that it is ultra mega super painful working with long lists in settings, try this out with 50 or so links to experience the pain. We need a different “list” control for managing long lists of things.
14 个赞
do you have any idea in mind about this?
1 个赞
Honestly, I am not sure, but have a look at republic for an example of how painful this gets.
2 个赞
Agreed it’s a massive pain…
A first step would be to give it more width, but that wouldn’t make it perfect.
What do you think if I hide the part after the comma, and you can only see it when mouse overing ?
I think that would be good, you mostly care about the words you are linkifying when you look at the list.
2 个赞
I kind of think it needs another mode of item per row, that way at least you can tell what is going on in long lists
2 个赞
I see. Shouldn’t be hard to do, I already apply this kind of per multi-select modification for category colors, I have an idea, will work on it in the next days.
4 个赞
Here is my proposal:
A new site-setting type: dictionary.
  • one item per row
  • explicitly shows the key/value relation
  • ellipsis the end of the value so it’s always readable
  • will limit the height for the component so it becomes scrollable after something like 10 rows
If it works for you I will work on it beginning next week.
8 个赞
Do we have other site settings that need this?
not to my knowledge, but AFAIK it doesn’t have to be an explicit new type server side, it could only be a new type client site like (url-list, host-list…)
So in the end it would be very little code, it’s mostly a subclass of list-setting where I split the label and present it differently.
We should split this topic
I feel there are a few settings that list urls like allowed iframes and some others that can easily benefit from item-per-row, maybe even the user list in admin groups as well
I think we should start with a simple item per row mode prior to adding dictionary
8 个赞
After a discussion with sam:
  • rename our current “list” to “compact-list”, which will display as many items per row it can (list current behavior)
  • “list” will now only display one item per row
  • this shouldn’t touch server side client setting, default UI for list will be modified, and the new client side site setting “compact-list” will rely on “list”
8 个赞
I think, there is a missing step in configuring Linkify component.
After this
Then, activate the linkify components in every theme.
I hope the last step should help others newbie like me.
I am certainly love this feature. :heart:
9 个赞
