Discourse Policy
:discourse2: Summary Discourse Policy gives the ability to confirm your users have seen or done something, with optional reminders.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Features
Discourse policy shares much of its DNA with polls, it has the goal of ensuring members of a group accept certain policies by clicking a button.
It has some specific features that set it apart from polls:
  1. It must apply to a group.
  2. It can optionally nag members of a group either weekly or daily to click accept on a policy.
  3. The UX makes it very easy to see who accepted and who did not accept a policy.
Configuration
Screenshots
Before clicking accept
After clicking “grey” person on top right
After clicking accept
Creating a policy
Discourse policy registers a custom [policy] BBCode element. Which means you need to write this block of code in your post where you want to show this policy.
[policy group=founders reminder=daily]
I accept this policy will annoy me daily until I click accept
[/policy]
In this case the policy applies to the founders group and a reminder is sent daily to all users that did not accept the policy.
Site settings
policy_enabled : Enable the discourse policy plugin on the site.
policy_restrict_to_staff_posts: Policies may only appear on staff posts.
policy easy revoke: Show the accept and revoke buttons at the same time.
BBCode attributes
The [policy] element can accept the following attributes.
  • group: the group name that policy will apply to required
  • version: the version number of the policy, bump number up to require all users re-accept the policy
  • reminder: remind users of the group to accept policy (weekly or daily), optional, default off
  • accept: text used for accept button, default is “Accept Policy”
  • revoke: text used for revoke button, default is “Revoke Policy”
  • renew: number of days or text describing period (monthly, quarterly or yearly) after which a user needs to re-accept policy
  • renew-start: the first date renewals will start at Eg: 17-10-2017, useful if you want to set the renewal cadence so it happens every half-year (Jan,June)
  • add-users-to-group: accepts a single group as input; users who accept the policy will be automatically added into this group (when policy is manually revoked or if the policy version is updated, user(s) gets removed from group)
  • private: hide users who accepted/did not accept the policy
:information_source: The backend job to check for policy reminders runs every 6 hours. If the reminder element is set to weekly or daily, users who have not accepted a policy will be sent notification reminders to accept the policy only if they have not already received a reminder notification for the policy within the past week or day.
Usage examples
Basic policy:
[policy group="team" reminder="daily" accept="Accept" revoke="Ignore" version="1"]
I have read, understand and acknowledge this policy.
[/policy]
Bumping the revision number, to require that everyone reads the update:
[policy group="team" reminder="daily" accept="Accept" revoke="Ignore" version="2"]
I have read, understand and acknowledge this policy. (Last updated [date=2020-04-23 timezone="America/Los_Angeles"])
[/policy]
Periodic auditing task:
[policy group="audit_committee" reminder="weekly" renew="90" renew-start="01-07-2019" version="1" accept="Assignment Complete"]
I have ensured that someone is assigned to this quarterly audit task.
[/policy]
CHANGELOG
TODO
  • Optional immediate reminder for new policies
  • Possibly allow certain groups to apply policies (expanding on staff)
2 posts were split to a new topic: Limit Policy creation to just staff?
4 posts were split to a new topic: Is it possible to disallow revoking agreement to certain policies?
It looks like the 200 limit and the policy_max_group_size got removed with this commit. Am I missing something?
6 posts were split to a new topic: People receiving reminders even though they’ve accepted the policy
When a policy with long button text is applied to a large group, the UI gets mangled: in the screenshot below, we can see that the avatars form an near infinite column that makes it a bit akward. I will look into the CSS to see if that can be easily fixed, but probably there should be some kind of redesign:
Removing display: flex on .cooked .policy .user-lists makes it look fine on Desktop:
I ended up using the following CSS:
/* Make policy user list not overflow */
.cooked .policy .user-lists {
    display: block;
Error after installing the plugin. Don’t know why. Something related “while trying to load /admin/dashboard/general.json”.
Server Error
while trying to load [/admin/plugins]
Error code: 500 error
Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
Hello,
Will the Accept/Revoke Buttons show if the Policy is in a Category Topic that is Closed so it doesn’t allow Replies?
Thanks
I haven’t used this plugin in a while however I think that it will allow users to accept/revoke when a topic is closed since pressing a button is not a reply which is what closing prevents.
hi i have a question :
We want to use the Discourse Policy plugin to : force first-time users to accept Terms of Service (ToS). Requirements:
  • If they don’t accept → they cannot use the forum (only see ToS page)
  • When they accept → they can use the forum + get a “ToS” badge
my solution was to create a new subject and within i added this :
[policy group=trust_level_0 reminder=daily add-users-to-group=tos_accepted accept=“I Accept Terms” version=“1”]
By clicking “I Accept Terms”, I confirm that I have read and agree to the Terms of Service.
[/policy]
but if a new user logs in the policy doesn’t show up at all and he can do whatever he wants we want only if he click on “Accept” to be able to access our page . how to do that and thanks
You could use a custom field and link the ToS and FaQ page. Once a user reads them they will receive the ‘Read Guidelines’ bagde.
Thank you for your response — it worked just as you said. However, what I really want is to display this banner after the user logs in, and only allow access to the page if the user clicks ‘Accept’. If not, the banner should remain visible, and the user shouldn’t be able to interact with the page
what i have right now is this :
after that the user can access our page normally
is there any way to do that and thanks
:partying_face: This plugin is now bundled with Discourse core as part of Bundling more popular plugins with Discourse core. If you are self-hosting and use the plugin, you need to remove it from your app.yml before your next upgrade.
It would be nice if you could add the ability to remove users from a group upon acceptance or rejection.
As of now this feature only nags users (optionally) and adds - unless I am missing something.
Thanks!
