Using Plugin Outlet Connectors from a Theme or Plugin
Discourse includes hundreds of Plugin Outlets which can be used to inject new content or replace existing contend in the Discourse UI. ‘Outlet arguments’ are made available so that content can be customized based on the context.
Choosing an outlet
To find the name of a plugin outlet, search Discourse core for “<PluginOutlet”, or use the plugin outlet locations theme component. (e.g. topic-above-posts).
Wrapper outlets
Some outlets in core look like <PluginOutlet @name="foo" />. These allow you to inject new content. Other outlets will ‘wrap’ an existing core implementation like this
<PluginOutlet @name="foo">
  core implementation
</PluginOutlet>
Defining a connector for this kind of ‘wrapper’ outlet will replace the core implementation. Only one active theme/plugin can contribute a connector for a wrapper plugin outlet.
For wrapper plugin outlets, you can render the original core implementation using the {{yield}} keyword. This can be helpful if you only want to replace the core implementation under certain conditions, or if you would like to wrap it in something.
Defining the connector
Once you’ve chosen an outlet, decide on a name for your connector. This needs to be unique across all themes / plugins installed on a given community. e.g. brand-official-topics
In your theme / plugin, define a new .gjs connector with a path formatted like this:
:art: {theme}/javascripts/discourse/connectors/{outlet-name}/{connector-name}.gjs
:electric_plug: {plugin}/assets/javascripts/discourse/connectors/{outlet-name}/{connector-name}.gjs
The content of these files will be rendered as an Ember Component. For general information on Ember and the .gjs format, check out the Ember guides.
For our hypothetical “brand official topics” connector, the file might look like
<template>
  <div class="alert alert-info">
    This topic was created by a member of the
    <a href="https://discourse.org/team">Discourse Team</a>
  </div>
</template>
Using outlet arguments
Plugin Outlets provide information about the surrounding context via @outletArgs. The arguments passed to each outlet vary. An easy way to view the arguments is to add this to your template:
{{log @outletArgs}}
This will log the arguments to your browser’s developer console. They will appear as a Proxy object - to explore the list of arguments, expand the [[Target]] of the proxy.
In our topic-above-posts example, the rendered topic is available under @outletArgs.model. So we can add the username of the team member like this:
<template>
    {{@outletArgs.model.details.created_by.username}}
    (a member of the
    <a href="https://discourse.org/team">Discourse Team</a>)
  </div>
</template>
Adding more complex logic
Sometimes, a simple template is not enough. To add Javascript logic to your connector, upgrade your .gjs file to export a class-based component. This functions just the same as any other component definition, and can include service injections.
In our topic-above-posts example, we may want to render the user differently based on the ‘prioritize username in ux’ site setting. The .gjs file might look something like this:
.../connectors/topic-above-posts/brand-official-topic.gjs:
import Component from "@glimmer/component";
import { service } from "@ember/service";
export default class BrandOfficialTopics extends Component {
  @service siteSettings;
  get displayName() {
    const user = this.args.outletArgs.model.details.created_by;
    if (this.siteSettings.prioritize_username_in_ux) {
      return user.username;
    } else {
      return user.name;
  <template>
      {{this.displayName}}
      (a member of the
    </div>
  </template>
Conditional rendering
If you only want your content to be rendered under certain conditions, it’s often enough to wrap your template with a handlebars {{#if}} block. If that’s not enough, you may want to use the shouldRender hook to control whether your connector template is rendered at all.
Firstly, ensure you have a class-based .gjs connector as described above. Then, add a static shouldRender() function. Extending our example:
  static shouldRender(outletArgs, helper) {
    const firstPost = outletArgs.model.postStream.posts[0];
    return firstPost.primary_group_name === "team";
  // ... (any other logic)
  <template>
  </template>
Now the connector will only be rendered when the first post of the topic was created by a team member.
shouldRender is evaluated in a Glimmer autotracking context. Future changes to any referenced properties (e.g. outletArgs) will cause the function to be re-evaluated.
Introducing new outlets
If you need an outlet that doesn’t yet exist, please feel free to make a pull request, or open a topic in Development.
This document is version controlled - suggest changes on github.
Using discourse's plugin outlets
Add HTML (Link) Next To Logo
What is the best way to integrate member applications?
Group Semantics
Can I put the search form at the top of our 404 page?
Native theme support
How to show user total post count beside name
Developing Discourse Plugins - Part 2 - Connect to a plugin outlet
Split up theme Javascript into multiple files
Feedback on "on-discourse" javascript for setting up custom JS for each page?
Topic-timeline api.decorateWidget call has stopped working
Developing Discourse Themes & Theme Components
How to add btn before "sign in"
Minimizing Maintenance on Theme Customizations
How to add custom fields to models
Tags at the top of the topic list in a Category
I want to insert images (banner) between the topic answers. How do I start?
How to add a link shortcut to the area under the title
Baidu Search
Add Banner/HTML (Widget) before reply button
Upcoming Header Changes - Preparing Themes and Plugins
Upgrading Discourse to Ember 4
Converting modals from legacy controllers to new DModal component API
Need help integrating code wrote on Edittext to the Discourse
Add link to external SSO profile to profile page
How to add a custom button in user profile card?
(not recommended) Overriding Discourse templates from a Theme or Plugin
How to override the site-header.hbs file from custom theme?
Upcoming topic-list changes - how to prepare themes and plugins
Working with .erb templates in a plugin
How to Integrate a Custom Plugin in discourse UI
Templating of my "component" broke. How do I fix it?
Modernizing inline script tags for templates & JS API
Custom Components -- add button or text at any plugin outlet
Adding "latest topics" header in the main interface
Display Tags inline with thread title, instead of being on the bottom line
Settings not appearing
Discourse view file update does not reflect in browser
Add likes and views to search display
Using template hbs to add HTML content to a plugin outlet
Adding a billing section in the member section
How to modify the header HTML, but still remaining the default founctions
Removing support for "template overrides" and mobile-specific templates
How can i add image in login and register box
Most “traditional” or classic forum Category listing
Customizing the topic list
Newbie help accessing code
How to add custom html next to logo using discourse plugin methods
Using the DModal API to render Modal windows (aka popups/dialogs) in Discourse
Air Theme
How to create a plugin with backend API calls to populate composer while drafting?
How to add a custom url text link on the login page
Add Text In Header Beside Logo
This is now depreciated, right?
Deprecation notice: Defining connector classes via registerConnectorClass is deprecated. See https://meta.discourse.org/t/32727 for more modern patterns. [deprecation id: discourse.register-connector-class-legacy]
That’s right; you can use api.renderInOutlet instead. :slight_smile:
https://github.com/discourse/discourse/blob/main/app/assets/javascripts/discourse/app/lib/plugin-api.js#L982-L1008
Except a bit more complicated than that I think :sweat_smile:
https://github.com/Firepup6500/discourse-custom-profile-link/blob/master/common/head_tag.html
Don’t worry; I will see what I can do to help you later (I need to sleep right now). :smile:
Thanks! (Sorry about the code being an mess, I just wanted it to work when I last touched it :sweat_smile:)
I’m in a bit over my head here, I got a notice for my component used in my theme’s HEAD file. I’m not sure how to rewrite with api.renderInOutlet.
  const ajax = require('discourse/lib/ajax').ajax;
  const Topic = require('discourse/models/topic').default;
  // We're using ajax and the Topic model from Discourse
  api.registerConnectorClass('above-main-container', 'featured-topics', {
    // above-main-container is the plugin outlet,
    // featured-topics is your custom component name
    setupComponent(args, component) {
   // rest of code follows
I guess tried replacing api.registerConnectorClass with api.renderInOutlet but it borked. I’m not really expert in theme coding here. Thanks for any help.
You can see an example here:
StatBanner is a native class defined in components directory:
In your case, that would be api.renderInOutlet("above-main-container", YourClass)
I don’t think you can do it in the HEAD file. You should split your code into multiple files.
I encourage you to use Discourse Theme CLI as it will be much easier to develop a Theme component!
Is your Theme Component public?
Is there a way to get the current outlet in my .js file?
I don’t think that’s possible.
It used to be possible to inspect parentView in Classic Components.
But that property has been deprecated.
Get glimmer component access to stuff from the parent - #5 by david
What do you mean by “get the current outlet”? You want the name of the outlet? Or something else?
I found a solution for my problem (here), but it was something like this:
  • Create .hbs and .js files for 3 different outlets.
  • In each JS file, check if the outlet it is using is the setting banner_location value.
  • If it is, show the banner. If not, hide the banner.
Cool! It looks like you settled on using the api.renderInOutlet, with a dynamic value for the outlet name :chefs_kiss:
