Use Discourse as an identity provider (SSO, DiscourseConnect)
So you want to use Discourse as an identity provider for your own web app? Great! Let’s get started.
Enable DiscourseConnect provider setting
Under Discourse admin site settings (/admin/site_settings) enable setting enable discourse connect provider and add a secret string to discourse connect provider secrets (used to hash SSO payloads).
Implement DiscourseConnect in your web app:
  • Generate a random nonce. Let’s call this value NONCE. Save it temporarily so that you can verify it with the nonce value that will be returned in the response.
  • Create a new payload with the NONCE and a RETURN_URL (where Discourse will redirect the user after verification). Payload should look like: nonce=NONCE&return_sso_url=RETURN_URL. The host of RETURN_URL must match against the domain pattern you used when configuring discourse connect provider secrets.
  • Base64 encode the above raw payload. Let’s call this payload as BASE64_PAYLOAD
  • URL encode the above BASE64_PAYLOAD. Let’s call this payload as URL_ENCODED_PAYLOAD
  • Generate a HMAC-SHA256 signature from BASE64_PAYLOAD using your sso provider secret as the key, then create a lower case hex string from this. Let’s call this signature as HEX_SIGNATURE
Send auth request to Discourse
Redirect the user to DISCOURSE_ROOT_URL/session/sso_provider?sso=URL_ENCODED_PAYLOAD&sig=HEX_SIGNATURE
Get response from Discourse:
If the above steps are done correctly Discourse will redirect the logged-in user to the provided RETURN_URL. You will get query string parameters with sig and sso along with some user info. Now follow below steps:
  • Compute the HMAC-SHA256 of sso using sso provider secret as your key.
  • Convert sig from it’s hex string representation back into bytes.
  • Make sure the above two values are equal.
  • Base64 decode sso; you’ll get the passed embedded query string. This will have a key called nonce whose value should match the nonce passed originally. Make sure that this is the case, and be sure to delete the nonce from your system.
  • You’ll find this query string will also contain a bunch of user information. Use as you see fit.
That’s it. By now you should have set up your web app to use Discourse as SSO provider!
More Parameters, More Options
In addition to nonce and return_sso_url, the request payload has several additional optional parameters.
  • prompt: If prompt=none, then the SSO request is treated as a “just checking” request. If the browser/device is already logged-in to Discourse, Discourse will return a successful SSO response bearing user authentication information, as usual. If the browser/device is not already logged-in, then Discourse will not ask the user to log in, and will immediately return an SSO response bearing the parameter failed=true instead of user information. This provides a mechanism to query if the user is logged-in, without ever directing the user to a login dialog if they are not.
  • logout: If logout=true, then the SSO request becomes a logout request. If a user is logged-in to Discourse on that browser/device, they will be logged out of that device. In either case, Discourse will immediately redirect back to the return_sso_url, without sso or sig added to the query string.
  • require_2fa: If require_2fa=true, then Discourse will require the user to verify two-factor authentication before being redirected back. The response payload will include confirmed_2fa=true if the user successfully completed 2FA verification, or no_2fa_methods=true if the user has no 2FA methods configured.
prompt=none and logout=true are mutually-exclusive; it makes no sense to provide both in the same request.
sso= Payload Reference
Request parameters:
  • nonce: (string, required) a securely-generated random string
  • return_sso_url: (string, required) the URL to redirect back to with the response
  • prompt: (string, optional) If none, probe authentication status without prompting user to log-in.
  • logout: (boolean, default false) If true, log the user out of Discourse.
  • require_2fa: (boolean, default false) If true, require the user to verify two-factor authentication before redirecting back.
Result parameters:
  • There is no sso= payload, or signature, in response to a logout request, just a redirect to the request’s plain return_sso_url.
  • The result payload for a login request will always contain the nonce, reflected from the request.
  • The result payload will also reflect any other request parameters. Do not rely on this behavior; it is not necessarily intentional and not a guaranteed aspect of the API. (E.g., why is the return_sso_url parameter copied into the payload that is sent to the return_sso_url?)
  • If the request failed to authenticate a user, the result payload will contain failed=true.
  • If the request succeeded in authenticating a user, the result payload will contain user credentials/information:
    • external_id: (string) Discourse user id
    • username: (string) username/handle
    • name: (string) user’s real name
    • email: (string) email address
    • avatar_url: (string) full CDN URL of the user’s uploaded avatar image
    • admin: (boolean) true if user is an Admin, otherwise false
    • moderator: (boolean) true if user is a Moderator, otherwise false
    • groups: (string) comma-separated list of groups (by name) to which the user belongs
    • profile_background_url: (string) full CDN URL of the user’s profile background image
    • card_background_url: (string) full CDN URL of the user’s card background image
    • confirmed_2fa: (boolean) true if the user completed 2FA verification (only present when require_2fa=true was requested)
    • no_2fa_methods: (boolean) true if the user has no 2FA methods configured (only present when require_2fa=true was requested)
    name, avatar_url, profile_background_url, and card_background_url may be absent if the user has not set these. (Any element with a nil value within Discourse will be omitted from the response.)
Discourse official “Using Discourse as identity provider” implementations:
Community contributed “Using Discourse as SSO provider” implementations:
Use discourse for SSO in a non-web app?
Can I require a Discourse login to view things on a different site?
SSO Redirect Problem
How-to setup a Discourse network?
Setting the session token '_t' on the entire domain, not just my subdomain
Reverse Single-Sign-On: Possible to use Discourse accounts on my other site?
Discourse a SSO provider for Wordpress
Inter-Discourse
Login via discourse
Login to Discourse with custom Oauth2 provider
Can I log into multiple instances of discourse simultaneously?
Validate User Session on another custom site
Use the same user database and login credentials in multiple discourse instances
Discourse as an identity provider not working in localhost
How to use SSO (Discourse on subdomain)
Login error while trying to use Discourse as an identity provider (SSO, DiscourseConnect)
Best way to use discourse as SSO - Wikimedia, Nextcloud, Immich
Discourse doesn’t redirect to return_sso_url after user logs in on private site
Is it possible?
Use Discourse SSO with Mediawiki
Use Discourse SSO with Mantis Bug Tracker
Use Discourse API to check whether username/password combination is valid
How to create a login on my front-end application to a specific Discourse site?
When Discourse is an identity provider, does it save the external user IDs?
How can I change the registration URL?
Should Discourse make an effort to become a viable comment platform?
Game Dev - User Registration & DB management (advice needed)
[Paid?] Migrate comments from several Blogger & Wordpress blogs to Discourse, under an SSO
System deleting users: 'inactive user', 'Automatically deleted as abandoned, deactivated account', and 'staged unused'
Checking whether a user is logged in on Discourse from another website
Communities using discourse SSO for their in-app community experience
OAUTH flow to Integrate the discourse community account with the third party CRM tool where it can create tickets of community
Setup DiscourseConnect - Official Single-Sign-On for Discourse (sso)
Is it Possible to Send Encrypted Email and Password in the Authentication Flow?
How Discourse ID works
Security/Privacy concern: Email exposed in DiscourseConnect Provider redirect URL
Discourse as an SAML, OAUTH IDP?
What to do with response from Discourse SSO as provider
Discourse as SSO provider for Prosody
[Paid] WP + Discourse user authentication for IRC or other chat
User API keys specification
Discourse session variables
Enabling Login to Discourse from a third party api
Return_sso_url is blank but provided
Set up your DiscourseConnect(DiscourseSSO) to SimpleSAMLphp, use your Discourse forum as a SAML IDP (Identify Provider)
Discourse doesn't redirect to return_sso_url after user logs in on private site
Can Discourse be used as an OAuth provider?
Log in to Rocketchat with Discourse?
Authorization from a desktop application (and base domain site)
Can two Discourse Instances share and use One Database?
Nil secret on SSO
Can I authenticate to Drupal via Discourse?
Using Discourse as an authentication provider
Triggering account creation/login on external service when a user logs in on discourse
Using Discourse as SSO for desktop app
Getting more discourse user data when using discourse as identity provider
Discourse as SSO Provider: Login Error
SSO between two Discourse instances
Could Discourse offer a StackExchange-like SSO/Federated login service?
Confirming a correct User+Pass combination via API?
How can I authenticate 3rd party website using discourse?
Share sign-up and login between Discourse and site?
How to configure Discourse as the sole user-facing login/sign-up provider for Wordpress site
Discourse SSO Provider doesn't redirect to return_sso_url as user logs in with custom SSO
OAuth 2 and other discourse sites?
Can I use the Discourse API to authenticate users in another app?
How can generate _forum_session and _t for an user through code/api call or without login to browser?
Login w/ Discourse w/o SSO?
DiscourseConnect provider does not redirect to return_url after entering correct id and password
Great how to, thanks.
FYI, the term ‘nonce’ has an unfortunate meaning in Britain.
I wrote a class to implement the process in Ruby. I use it to work with devise in my web application.
https://github.com/gogo52cn/sso_with_discourse
sso seems to have a trailing newline which needs to be included when sent to the HMAC function, so it’s important to make sure that SSO consumer applications don’t strip whitespace from these query arguments.
Our app users get their own subdomains. Is there a way to implement this with variable SSO urls?
interesting, this is tricky you would need to monkey patch this in, or better still make core extensible in this way and add a plugin.
Hello,
I have created an Erlang implementation for encoding/decoding the payloads described in this specification. You can find it here:
https://github.com/reverendpaco/discourse-as-sso-erlang
Feedback is welcome.
Thanks to @mpalmer on another thread for setting me straight.
As I put together this implementation, I realized that the specification does not say too much about a few things:
  1. the user information that is returned in the query parameters,
  2. what happens when a user is not found
When I got around to testing I found the answers, and then confirmed by looking at the code, here: discourse/app/controllers/session_controller.rb at main · discourse/discourse · GitHub
I shall assume that in regards to 1. that while new user information may be added, that none of these values (“name”,“username”,“email”,“external_id”, etc) will be removed. This is just as important, contractually as what is described in the main post.
One piece of feedback I’d like to give the Discourse team is that it would be nice to add a means to optionally return back to the calling application in the case of a missing user.
Currently, at line 51 a non-logged-in or non-registered user will be forwarded to the Discourse login page. While this can be useful, I would rather programmatically have the option to learn that this person has not yet logged in (or registered) and give them the opportunity on my site to continue anonymously.
I can imagine something like this:
sso=URL_ENCODED_PAYLOAD&sig=HEX_SIGNATURE&
returnBackIfUserMissing=true
and then the Discourse site sending back to the return_sso_url with either a special header, or an attribute, rather than redirecting to /login.
This change should be backwards compatible.
I’m new here, so if this is something that could be contributed via a pull-request, please tell me and I could take a shot at it next week.
thanks,
daniel
Sure, totally open to add another option to the payload you send us for create_new=false PR welcome.
added a PR for this
Commit-Message:
Implemented an optional 'no_user_found_return_sso_url' parameter to be called
 by the client when client is using Discourse as an SSO and wants Discourse to
redirect back to a place of the client's choosng when a user is not found.
Currently, the Discourse as an SSO implementation checks the cookies _t and
 _session_forum to see if the user is registered and present in the database
(_t is the token that is located in the users table). If a user is not found,
the current implemenation forwards to the forum's /login URL. This behavior
may be what the client wants, but it would be good to give an option to the
client to send somewhere else.
This commit allows the client to embed an optional 'no_user_found_return_sso_url'
parameter in the payload, prior to base64 and URL-encoding. If the Discoure SSO
endpoint detects that this parameter is present in the payload (and has a non-empty
value) the Discourse server will redirect to this new location if it does not detect the
user. If this parameter is not present, then the redirection to /login will take place
as it currently does.
Additionally, as the client may choose to use the same URL for
'no_user_found_return_sso_url' as for 'return_url', this commit introduces a new
query-string name-value pair to be sent back to the client 'no_user_found_return_sso_url'
location. This parameter 'user_found' will ALWAYS be sent back to the client, either when
the user is found and 'return_url' is used or when the user is not found
'no_user_found_return_sso_url' is used (values will be 'true' and 'false' respectively).
thanks,
daniel
Nice work :slight_smile:
redirect_to can be routed to a url with parameters. But isn’t a create_new=false enough? Or whatever name it is. You’ll get nonce and the flag back.
I wanted to give the client the flexibility of sending a failure to a different URL than the success url (return_url). With complicated SSO architectures, this might be a requirement. (Selfishly, I wanted to make my return endpoint code less convoluted – i.e. on my side I have two codebases at /sso for success and /sso_failure for failure).
Implicitly there are already two URLs (return_url for success and ‘/login’ for failure) – I didn’t want to lose that.
So just to be clear, the payload you send to the Discourse endpoint should have both return_url and no_user_found_return_sso_url if you want Discourse to send it back when no user is found. It should have return_url only if you are ok with Discourse forwarding to /login.
Should look like this:
1.If you want Discourse to forward to login if no user found, then:
PAYLOAD = return_url=mydomain.com/clientendpoint&nonce=xE787euK
2. If you want Discourse to send back to you to the same endpoint for failure as success:
PAYLOAD = no_user_found_return_sso_url=mydomain.com/clientendpoint&return_url=mydomain.com/clientendpoint&nonce=xE787euK
3. If you want Discourse to send back to you to a different endpoint as success:
PAYLOAD = no_user_found_return_sso_url=sub.mydomain.com/handleNewUser&return_url=mydomain.com/clientendpoint&nonce=xE787euK
Potentially a bit over-engineered, but that was my thought process.
To be clear, it’s not user_not_found, it’s not logged in.
It’s about protocol not engineering in the first place. Given two endpoints, you have to deal with two possible endpoints. In both cases you must validate the nonce and destroy it. It’s a hurdle not benefit.
In extreme case, a client can ask Discourse several times with/without session (current_user), thus you would get n responses in each endpoints. It would be twice as hard to secure it due to changing cookies on your end.
Completely agree on protocol over engineering. Hence, my submission.
The semantics are equivalent to an if-else block, or more generally a case/switch block. result_url is our true condition, and user_not_found_url is our else block. If we didn’t provide it, we would force the client to have to deal with the ‘failure’ condition in the same codebase/endpoint – and for 90% of the people, this will be fine.
90% of people who want Discourse to return back to them will set return_url and user_not_found_url to be exact same thing. This bears repeating, and really renders the motivations for the 10% moot.
90% of the time you will make return_url and user_not_found_url the exact same thing. These 90%-ers will use their JSESSIONID/ PHPSESSID/ ASPSESSIONID /_session to look up the returned encoded nonce in their framework-supplied session-store and engineer accordingly.
7% of people will be happy to pass it to a different URL on their same app-server, which does some decoration (servlet-chains anyone?) or routing, but still looks up the nonce in their session.
3% will have some complicated polyglotish system that uses a distributed session store (like memcache) to store sessions for different app servers implemented in different legacy codebases. It’s up to them to store/invalidate the nonce across these different systems.
I realize I might not have been completely clear, but the user_not_found_url still receives the sso and sig parameters, just like the return_url.
So, if you are the 90% scenario, when you get the payload and verify/decode it, you will find the parameter user_found=false|true to know why it’s coming back to you.
@fantasticfears, as per your recommendation on the PR, I have renamed the attribute from user_not_found_url to return_sso_unlogged_in_url.
3 posts were split to a new topic: Can Discourse be used as an OAuth provider?
Great job !
Do you know how it possible to adapt it to GitLab in order to allow the Discourse users to directly login there?
Hey folks, I could not find anything, so I created a npm for Discourse auth using Passport for node.js.
It’s here, and in npm if anyone needs it:
(really appreciate the team’s work, we’ve been a user since the very early days @ talk.wigwag.com)
@sam,
I have submitted a reply back to your rejection of the PR:
Optional 'no_user_found_return_sso_url' parameter for using Discourse as SSO by reverendpaco · Pull Request #4211 · discourse/discourse · GitHub
As I have been relying on my patched version of discourse for these months, I would be interested in convincing you as to my need.
If this PR is going to be rejected, could you explain what I can do to get the functionality that I need?
Does anyone know of a wordpress plugin that works with discourse as the SSO provider?
