Discourse Assign
:discourse2: Summary Discourse Assign provides the ability to assign topics and individual posts (both private and public) to a user or group.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Features
Discourse Assign adds a “tag like” annotation on the topic list and topic header with the username of the assigned user.
It allows you to assign topics to users and list all of the assigned topics.
Also, user groups can be assigned to the topic. In that case, each group member will receive a notification. In group Interaction configuration, you can specify Who can assign this group. By default, is it set to nobody.
In addition to assign to specific topic, individual post can be assigned as well. This option is hidden under “…” (show more) post toolbar. When a post is assigned, information about that is included in the topic title. Also, first post contain link to assigned post.
Assignments can also (optionally) be associated with customizable statuses, and will track changes to their statuses in small_action posts.
Configuration
Site Settings
  • assigns by staff mention if you would like mentions by a staff member of another staff member to assign a topic select this
  • unassign creates tracking post: out of the box when you unassign a topic a post is created in the stream to keep track of the fact it was unassigned, disable to remove the tracking post
  • assigns public : out of the box all assignments are hidden from non-staff, if you want non-staff to be able to see who owns which topic, enable this setting.
  • assign self regex if you would like to use a magic phrase to assign stuff to yourself add a regex here
  • assign other regex if you would like to restrict it so only mentions with a particular phrase are assigned to others add something here
  • unassign on close if a topic is closed it will automatically be silently unassigned
  • unassign on group archive when a message is archived unassign it, once it moves back to inbox reassign it.
  • reassign on open When a topic is opened reassign previously assigned users/groups
  • assigns user url path template to path that is used as a hyperlink for any user assigned tags.
  • assign mailer When to send notification email for assignments
  • remind assigns frequency` Frequency for reminding users about assigned topics.
  • max assigned topics Maximum number of topics that can be assigned to a user.
  • assign allowed on groups controls the list of groups you can assign to. When a topic is assigned to a group it shows up in the individual assign list for all group members. They are notified when this assignment happens.
  • enable assign status Add a customizable status field to every assignment.
  • assign statuses is a list of statuses available to each assignment. The first status is the default status applied to every new assignment.
Listing assigned topics
There are 2 ways of viewing assigned topics,
  • In topic list format:
    • https://sitename.com/latest?assigned=username to view all assigned topics for a user
    • https://sitename.com/latest?assigned=* to view all assigned topics for all users
    • https://sitename.com/latest?assigned=me to view all assigned to current user
    • https://sitename.com/latest?assigned=nobody to view all unassigned
  • The user page activity there is an extra assigned tab visible to staff on activity and messages tabs
CHANGELOG
TODO
  • Keyboard shortcuts
Thank you to McNeel for sponsoring this work!
57 Me gusta
Tickets Plugin :tickets:
Generating Support Metrics (with Assign and Solved plugins)
Modifying Staff Roles to go beyond Administrator and Moderator?
Easiest way to pull other users in on a discussion non-publicly?
Recommended workflows for support and community?
Creating Custom Flag
Bookmark labels to save for later
Task manager within Discourse?
Creating a User - Tag relation plugin
Inbox Customisation and Organisation Features
Using discourse as a community ticket system
Possibly to automatically assign user/users to tags?
Advise on how to organize my forum categories and tags
Comment on a question instead of answering it
Discourse Assign - how to assign posts using regex
New customer setup
Volunteer Activities - a simple setup for non-hierarchical collaboration
Assigned topic summary for groups
A layout for community projects
Allow Group Mentions in Post Edits to Trigger Notifications (Opt-In Setting)
Implementing KCS
Reassigning to a group creates a /u/ link in the @group mention
Using Discourse as a social media platform
URL query string params
Hello Community Experts- are we able to configure discussions to be threads AND questions?
Setup Continuous Integration using GitHub Actions
Search filter - only topics / only posts
Issue Tracker for Discourse
Assign topics or messages when created via API
Using query strings to filter topic views
New user alerts
Discourse Automation
It would be great to be able to assign personas created in Discourse AI to respond to the topic
Why you should use Discourse internally for your company/team instead of Slack (4 years use case)
How to put own username in header links
Setting timer to be viewed by all and for moderators specifically to follow- up topics
User assignments and kanban
Cannot assign topic to group
Bundling more popular plugins with Discourse core
How Discourse Uses Discourse
Regarding possibility to use Discourse as an alternative to JIRA or Zendesk
Advice on a support forum
Performing bulk actions as a moderator
Reminder function for pre-defined trust levels
Different themes per category?
Color of tags in header not changed by Color Scheme
Cannot delete topic that is assigned
Link behavior inconsistent
View PMs assigned to nobody
Unassign topic when marked as solved
Time tracking using Discourse?
Customize hamburger menu to add switch what switches theme and applies predefiend filter
Install plugins on a self-hosted site
Send email notifications for small actions
Esto no parece funcionar por ahora. Si soy parte del grupo A y alguien asigna el grupo A a un tema, no me aparece cuando visito /latest?assigned=me.
1 me gusta
Hola Kuba. :wave:
Ese es un filtro en la página “latest”. La “lista de asignados individual” mencionada está en /my/activity/assigned. :+1:
¡Gracias! ¿Hay alguna razón específica por la que esos dos filtros se comportan de manera diferente? :thinking:
1 me gusta
¿Hay alguna forma de configurar la hora de las notificaciones recurrentes?
ACTUALIZACIÓN: Cuando un tema se asigna a un grupo, los usuarios del grupo no reciben notificaciones por correo electrónico. ¿Es correcto? Esperaba que los usuarios recibieran un correo electrónico + correos electrónicos recurrentes (cada día, cada semana) como un asignado individual.
2 Me gusta
2 publicaciones se dividieron en un nuevo tema: ¿Se pueden eliminar las asignaciones cuando un tema se resuelve?
Disculpa si esto ya se mencionó (no pude encontrarlo).
¿Pueden los no miembros del personal usar este plugin para asignar? No pude hacer que este plugin funcionara incluso si el usuario es moderador. El usuario tiene que ser administrador.
Mi caso de uso: Un líder de equipo (no personal/no administrador) escribe un tema y se lo asigna a un miembro del equipo (usuario TL0-3). El líder del equipo no es necesariamente el administrador del sitio o el personal del foro de Discourse porque tenemos muchos líderes de equipo.
Sería útil incluso si puedo convertir al líder del equipo en moderador y hacer que este plugin funcione.
¡Gracias y lo aprecio!
¿No haría eso establecer assign allowed on groups?
Hola @Jagster,
He configurado assign allowed on groups en everyone
Por ejemplo, los permisos de este usuario son:
Pero este usuario no puede ver el botón assign
A veces «todos» no funciona. ¿Has probado trust_level_0 en su lugar?
3 Me gusta
Solo una nota rápida: el botón Asignar aparecerá como su propia opción en temas/publicaciones y no estará en el menú :wrench: :slight_smile:
Acabo de probarlo en mi sistema con una cuenta TL3 configurada en las siguientes condiciones y obtuve estos resultados:
Usuario TL3 con permiso para todos
Mismo problema que @carlito, la opción no aparece.
Usuario TL3 con permiso de trust_level_0
Esto funciona como se esperaba.
Entonces… dicho esto, necesitarías configurar trust_level_0 como sugirió @Moin. Creo que se esperaría que funcionara de otra manera si seleccionaras a todos, ¿así que tal vez esto sea un error?
3 Me gusta
@Moin y @HamMan2118
¡Genial, funcionó!
¡Muchas gracias a ambos!
2 Me gusta
¿Cómo puedo encontrar y editar la plantilla de correo electrónico que se envía cuando se asigna a alguien? No existe junto con las otras plantillas de correo electrónico.
¿Este?\n
\n\nPuedes encontrarlo en Admin > Textos del sitio. Busqué assign_mailer, que devuelve el título (assign_mailer.subject_template) y el cuerpo del texto (assign_mailer.text_body_template).
2 Me gusta
Sí, eso es todo, ¡gracias!
3 Me gusta
¿Dónde en la interfaz de usuario se expone el estado?
Veo a quién se asigna un tema, pero no veo ninguna forma de saber cuál es su estado actual.
¡La imagen muestra una publicación en un foro con una mezcla de caracteres aleatorios en el cuerpo del texto, una flecha señalando al texto indicando la anomalía, y una mención asignada a un usuario. (Etiquetado por IA)|690x258
@tknospdr ¿Has visto esta parte?
Sí, pero eso solo aparece una vez que realizas un cambio. No hay ninguna indicación visual de que se haya asignado un estado, hasta que lo cambias de X a Y.
Puedes ver el estado actual si vas a la pestaña ‘Editar asignación’, debajo del botón ‘Asignar’.
Te refieres a “Editar asignaciones”, que está oculto detrás del botón que dice “Anular asignación…”
Si no quiero anular la asignación, dudaría en hacer clic en ese botón, ¿verdad?
  1. Es poco intuitivo.
  2. ¿Estás diciendo que no crees que una indicación visual para que sepas cuál es el estado asignado de un tema a simple vista sea una buena idea?
Simplemente no puedo imaginar que sea una gran exigencia en términos de código, y tiene sentido tenerlo a la vista.
3 Me gusta
