Discourse Templates
:discourse2: Summary Discourse Templates allows the creation of content templates for repeated use. The templates are stored as topics in a special category, where they can be edited and discussed as needed.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
:information_source: This plugin is pretty much a new version of Discourse Canned Replies but it is more flexible and stores the templates in a different way.
Features
This plugin uses one or more categories to store the templates for later use. The first post on each topic in these categories will be used as the template for the replies.
This approach provides a lot more functionality then it was available before with discourse-canned-replies as each template will have edit history, can have associated tags, and the subsequent posts can be used to discuss the content of the template if needed.
Only visible topics will be used as templates, so topics unlisted and archived won’t be listed.
The plugin also leverages the categories security settings to check which users can use the templates. If the user can read the topics in the category then the option to ā€œinsert templatesā€ in the composer will be available to use. The user will only be able to see the templates/topics in the categories that they have access
Multiple parent categories and/or sub-categories can be used to provide different sets of templates to be used to different groups of users and organize the templates.
Private templates
The plugin also supports private templates. Private templates are private messages tagged as templates. These messages will be available as templates only to the author of the message.
Archived messages won’t be listed as templates.
:bulb: You can find all your private templates at:
/u/{USER-NAME}/messages/tags/{PRIVATE-TEMPLATE-TAG}
Settings:
  • discourse templates enabled: Activates the plugin
  • discourse templates categories: Categories that used to store the templates. Each topic in theses categories and their sub-categories will be used as template and will be available to users that can see them in their original categories.
  • discourse templates enable private templates: Enables the use of private templates.
  • discourse templates groups allowed private templates: Groups of users allowed to use private templates.
:warning: Staff members are always allowed.
  • discourse templates private templates tags: Tags that will be used to mark private messages as templates.
How to use it
After installing the plugin, you will need to create at least a category to store the templates.
Notice that every user that has access to read the topics in this category will be able to use the plugin functionality in the composer.
:bulb: Pro-tip: The same settings to edit topics will be applied to ā€œtemplateā€ topics. If you want that anyone with write access in the category be able to edit the existing templates, you should activate Make new topics wikis by default on the category settings.
After that, specify the category in the plugin settings.
That’s it. Now you only have to create some topics in the specified category and they will be available to use as templates.
If you want you can create sub-categories to better organize the templates or to provide different sets of replies to multiple groups of users.
To insert templates you must first open the reply composer and click the extras button, then select the option ā€œInsert templateā€
Select the desired template, you can search by text or tags and click on the ā€œpasteā€ icon.
Keyboard shortcut
You can use Ctrl+Shift+I on PCs or ⌘+Shift+I on Macs to insert templates.
:bulb: The keyboard shortcut will work inside any textarea on Discourse
Private templates
:warning: Private templates will only work in instances with both private messages and tags enabled.
You need to configure the following settings Discourse settings in order for it to work:
  • tagging enabled: must be enabled.
  • enable personal messages: should be enabled if you want to make the feature available for non-staff users.
  • pm tags allowed for groups: you will need to allow the groups that will use private templates to tag private messages.
To use private templates you must first enable it in settings, assign the groups of users that can use it and assign at least a tag to mark the PMs as a template.
To create a personal template the users must:
  • send an unencrypted personal message to themselves tagged with one of the tags configured in the plugin settings. Only to the author of the message will view it as a private template.
:bulb: Private messages sent to other users also can be also be tagged but only the author of the message will be able to use it as a template.
Pre-filled variables
The plugin supports the following variables on the templates:
  • my_username
  • my_name
  • topic_title
  • topic_url
  • original_poster_username
  • original_poster_name
  • reply_to_username
  • reply_to_name
  • last_poster_username
  • reply_to_or_last_poster_username.
All the above variables supports fallback text and will strip out the variable if fallback is not specified and the variable can’t be replaced.
Both title and body supports variable replacement.
Example:
Hi %{reply_to_username,fallback:there},
Regards,
%{my_name}
If the reply_to_username is not available, the template will be:
Hi there,
Regards,
Arpit Jalan
Migration from discourse-canned-replies
There is a rake task to migrate the existing canned replies to templates:
rake "discourse-templates:migrate-from-canned-replies"
This took only a few seconds to to run on Meta to migrate 47 canned replies so it should be safe to use unless you have a staggering amount of canned replies.
TODO
  • extend functionality to other places beyond the composer :white_check_mark:
  • allow using more than one parent category as template sources :white_check_mark:
Changelog
  • 2022-07-14T03:00:00Z: Added ability to use multiple parent categories as source for templates
  • 2022-07-18T03:00:00Z: Private templates
  • 2022-08-10T03:00:00Z: Global keyboard shortcut
Canned Replies by Group
Discobot Type Message Automation
Canned respones location
Option to allow Category Moderators to use canned-replies?
It would be helpful to be able to use the To: username (in PMs) for Templates
Plugin causing errors during rebuild
Canned reply hotkeys?
Poll-restriction
Is it possible to block a category from Upcoming Events?
I'm working to build a "marketplace" on top of Discourse. Would love some suggestions/feedback
Balancing Costs and Functionality in AI-Powered Forums
Canned Replies without extra lines
Exploring Discourse as a Learning Management System
Template Button Relocation
Enforce discourse template by category and /or tag
Give me some control of how the form template post is styled
Can I customize the welcome message shown when creating a new topic based on the chosen tag or category?
More efficient (inline) template usage
Will uninstalling a plugin leave any residual debris files in the database?
Build Poll not showing under Post Settings
Feedback on Our Community
How are we all feeling about ChatGPT and other LLMs and how they'll impact forums?
Daily Summary (5am UTC)
General Question About Saved Replies
Using template with a [wrap] code while in Rich Text Editor not working
Bundling more popular plugins with Discourse core
Discourse Category Lockdown
Advice on a support forum
Add the option to insert the component's 'Reply Template' code to the composer's toolbar
Using topic templates for categories
Speak with the Discourse product team about moderation
Templates for Staff Notices
Check boxes and Mandatory fields in Topic templates?
Time tracking using Discourse?
Send a message to an inactive group
Discourse template plugin added itself to my discourse?
Community Guide: Activating Lurkers
Ability to Create Private Templates
Where is the appropriate place to request a feature? I see the issue tracker for the associated GH repo is disabled. I would like the ability to paste replies ā€œinlineā€ i.e. in the middle of a sentence. I had requested this for the previous other plugin, and there was some (seemingly positive) discussion about it, but I have not been able to locate that.
I very often need to craft replies that have e.g. GitHub Issue in the middle of a sentence:
  • If you’d like to request [thing] as a new feature, please open a GitHub Issue
  • [Feature] is under-documented, a GitHub Issue would be appropriate to increasing visibility.
  • [Some behavior] seems to be a bug, please open GitHub Issue with full details.
I have lots of these kinds of snippets, and use them constantly in our user support forum.
Generically, I’d like to be able to insert templates right exactly at the current cursor position. It’s really annoying to have the template get inserted on a newline with another newline above it, and have to manually delete all that whitespace just to get it back up to the previous cursor position, several times every day. I just want to type my reply as fast as possible.
Even better would be a text-only way to insert these without having to use any mouse/menu interactions at all.
You can make a topic in #feature with the tag templates
A post was split to a new topic: Create an advertising page
3 posts were split to a new topic: Template list takes 5-10 seconds to load
:partying_face: This plugin is now bundled with Discourse core as part of Bundling more popular plugins with Discourse core. If you are self-hosting and use the plugin, you need to remove it from your app.yml before your next upgrade.
Can templates assist in creating a list of canned email replies to applicants trying to sign up to my forum? I often need to reject applicants based on the information provided during sign up, and need to communicate why, with suggestions as to what would need to change if they want to apply again.
A drop down selection of canned replies to insert into the ā€˜reason for rejection’ field is what I am after (much nicer than the cut and paste method from external text file that I must currently resort to)
I have not so far spotted an obvious way to use templates for this purpose, though as an administrator, this for me would be the single most needed context for them.
Are you sending and receiving the responses via Discourse?
You can use templates in many input fields where the toolbar is not shown by using the keyboard shortcut ctrl + shift + i
@Hawk Yes, sending via the ā€˜why are you rejecting this user’ field when deleting the user who was not approved.
That is good!
Even better than needing to remember a keyboard shortcut (which in my case would get used maybe once a month and thus forgotten) would be a small button associated with each blank field, to trigger the templates sub dialog
Yes, that button would also be helpful for creating official post notices, user notes, etc.
I usually use the keyboard shortcut help in the sidebar or press ? to find out that it’s ā€œiā€. (I tried to remember ā€œinsert templateā€, but that didn’t work that well for me, because I couldn’t find a German wording that starts with ā€œiā€)
Is it/would it be possible to access these templates in a new composer by link? Such as compatibility with Creating a link to start a new topic with pre-filled information?
