Daily Summary (9pm UTC)
Today on meta.discourse.org…
Key Stats
Top contributors (posts / likes in the last 24h)
User Posts Likes Recent reference
Lilly 5 13 Helped explain profile titles in “regular” title thread and asked about disabling Upcoming Changes alerts without CSS in Upcoming Changes
Moin 2 9 Clarified that “regular” is a selectable title in this reply and pointed to UX discussion for anon reactions access in this reply
Noble_Fish 3 1 Raised moderation defaults gap in approval settings request and flagged potential duplicate badge issue in Badges thread
Arkshine 1 2 Investigated edge cases + shortcut ideas for Quote Callouts in this update
merefield 1 2 Posted a deployment + sponsor-feature split update in Locations plugin
Falco (team) 1 0 Advised on structured outputs model requirements in AI translations errors
Interesting Topics
Support
  • kairo162 noticed the label “regular” showing under usernames and across profiles; Lilly connected it to trust-level naming (post), and Moin clarified it’s a selectable Title (often from trust-level badges) that users can enable in preferences (solution). read more
  • In Chinese-language support, jack222 reported that anonymous visitors can’t view /activity/reactions and suggested either enabling read-only access or improving the error message (report); Moin pointed to an existing UX request discussing exactly that permission/UX gap (reply) and referenced the related feature request (Allow /activity/reactions to be visible by anon). read more
  • cshll hit a “Badges” page failure and suspected configuration issues (report); NateDhaliwal suggested checking the enable_badges site setting (reply), while Noble_Fish asked whether it duplicates an earlier thread (dup-check) and probed whether the install looked non-standard (follow-up). read more
  • cshll also posted an SEO/validation screenshot about “inspecting Live URL,” but without details yet—likely a “needs repro steps” thread unless more context lands (topic). read more
  • Noble_Fish requested global defaults for “New topic approval” and “New reply approval,” noting that current global settings only cover Everyone except selected groups and don’t match the workflow where a subset of users later gets moved into “must be reviewed” mode across all categories (feature request). read more
  • In a self-hosting migration discussion, Lilly shared a recent real-world migration (Ubuntu 24.04 → Ubuntu 24.04) and highlighted practical tips like shortening DNS TTL and planning for backup upload time (migration notes). read more
bug
  • janbolmeson reported that @discourse/mcp fails when connecting to Discourse installed in a subfolder (e.g. /forum) because tool calls drop the subpath—breaking validation and subsequent API calls (bug report). read more
  • In an ongoing structured-data issue, Richie noted Google tests still failing for three URLs due to missing mainEntity.suggestedAnswer.text, despite partial improvements (status update). read more
  • AI translation troubleshooting continued: RBoy encountered a 400 error tied to unsupported json_schema response formatting with a model change (error details), and Falco explained translations need a model that supports structured outputs (common in recent SOTA models) (guidance). read more
#customization:theme component
  • Quote Callouts got a UX + edge-case sweep: nathank observed rendering issues in excerpts/Oneboxes (note), scavin flagged the default shortcut as risky on macOS because users may hit ⌘+Q and quit the browser (macOS concern), and Arkshine weighed alternative key combos while tracking excerpt/Onebox behavior (response). read more
#Announcements
  • The “Upcoming Changes” notification system drew feedback on notification noise: Lilly asked if alerts can be disabled without CSS (preferring a setting-level solution) and shared a temporary CSS workaround (request + snippet); NateDhaliwal pointed out a likely remaining unread-count indicator even if notifications are hidden (reply). read more
#customization:plugin
  • The Locations plugin thread got a substantial update: merefield announced a fix now deployed (plus compatibility work) and described how Early Access differs from the public version—including a 3D globe users map and IP-based location lookup (release notes); gilles thanked them for the quick turnaround (thanks). read more
development
  • Theme authoring guidance discussions continued: BrianC asked how to approach forking a theme while ensuring the parent stays updated over time—raising the common long-term maintenance question for serious customizations (question). read more
General
  • A complex “facts from logs” question landed: Sukenik asked how a forensic expert might establish whether historical suspensions carried over during a 2023 migration from Discourse to a custom forum (scenario); Andrew_Rowe highlighted how hosting model and log retention matter, and that three years is a long time for server logs to survive (initial response). read more
Activity by the @team Group
  • Falco helped unblock AI translation troubleshooting by explaining that translation workflows require a model that supports structured outputs, and that most modern SOTA models now include this capability (AI translations guidance, context in error report).
If you made it through today’s feed without accidentally hitting ⌘+Q while trying to insert a callout, you’ve earned your Regular title the hard way.
Key Stats
  • New posts (last 24h): 97 (spread across threads like the iOS PWA push investigation in read more and the new bulk tag workflow announcement in read more)
  • New topics (last 24h): 13 (including new reports like the Edge mobile modal sizing issue in read more, plus new how-tos like standardizing sidebar categories in read more)
Top users (posts / likes in the last 24h)
User Posts Likes Recent activity sample
Lilly 15 21 Automation troubleshooting in read more and theme/login guidance in read more
Moin 10 12 Sidebar defaults discussion in read more and passkeys setting tip in read more
chapoi 9 7 Confirming old modal UI and next steps in read more
klappradla 2 7 Deep-dive + PR proposal for iOS PWA push in read more
RGJ 2 5 Klipy + infinite search limit bug analysis in read more
denvergeeks 7 3 Repro attempts for repeated image uploads in the RTE in read more
nat 1 3 Translation/quote attribute investigation in read more
lindsey 1 3 Announcing the new bulk tag management modal in read more
sniper756 1 3 Reporting the Edge mobile “permanent delete” modal width issue in read more
fzngagan 1 4 Publishing a sidebar-standardization how-to in read more
Interesting Topics
#Announcements
  • Staff introduced a cleaner bulk-tag workflow: a single Manage Tags modal replaces separate add/replace/remove actions, prompting follow-up feedback about revision history clarity and missing UI affordances in Better bulk tag management. Related: the missing tag info button discussion in read more and the older feature request this essentially fulfills in read more.
#Site Management
bug
ux
Support
#Self-hosting
  • A migration/restore failure involving Cloudflare R2 and checksum incompatibilities surfaced during a server move; troubleshooting and environment details are collected in 迁移Discourse恢复数据失败, including an R2-specific env-var suggestion in read more.
  • A “badges error launching” support thread turned into a broader self-hosting health-check: plugin overload, incorrect SMTP settings, and risky storage choices were called out in Badges Error launching, with concrete “remove unofficial plugins first” guidance in read more.
  • chapoi confirmed the Edge mobile delete-modal is legacy UI and praised the report in read more, continued triage on the repeated-upload-in-RTE report in read more, and helped narrow self-hosting/plugin troubleshooting steps (including safe mode) in read more. chapoi also pulled nat into localization/quote metadata concerns in read more, and confirmed a fix got merged for reaction long-press behavior in read more.
  • fzngagan posted a clear step-by-step guide for enforcing consistent sidebar categories for all users in read more, sparking follow-up testing/edge-case questions from others in read more.
  • lindsey announced the consolidated bulk tag management modal and invited feedback in read more, which immediately surfaced UX expectations around tag tooling and revisions in read more.
  • nat analyzed why translated quotes lose useful source info (with German being hit hardest) and noted more evaluation work is needed in read more.
  • sam linked a fix PR for a reported MCP subfolder-install issue in read more.
  • manuel clarified how the “skills” track and the Blocks API should remain maintainable over time (and what to expect if you fork examples) in read more.
  • awesomerobot acknowledged the “Permanent” filter confusion on Upcoming Changes and explained it as an optional workflow step that was skipped for some items in read more.
  • gerhard proposed a concrete Cloudflare R2 workaround using AWS checksum-related env vars (plus rebuild steps) for restore failures in read more.
  • HAWK responded to an SEO console “Live URL inspection” concern, suggesting the issue is likely due to new/empty sitemaps and minimal public content in read more.
  • supermathie requested environment details (object store specifics) to unblock troubleshooting for the restore/migration failure in read more.
Yesterday’s theme was “tiny modals, missing automations, and service workers refusing to take charge”—may today’s builds be smooth, your tags tidy, and your push subscriptions actually land where they should.
Key Stats
  • New posts (last 24h): 53
  • New topics (last 24h): 12
Top contributors (posts / likes received on their recent activity):
User Posts Likes
Falco 2 23
Lilly 5 8
chapoi 3 3
zogstrip 3 2
bayardo.rivas 2 2
putty 2 2
martin 1 2
awesomerobot 1 2
ferdnyc 2 1
RGJ 1 1
Interesting Topics
#Announcements
Support
bug
ux
General
Yesterday’s theme was making things smaller, smoother, and less surprising—may your GIFs shrink into WebPs, your automations land on the right day of the month, and your 404s politely find their way home.
Key Stats
In the last 24 hours (2026-05-12 → 2026-05-13):
  • New posts: 95
  • New topics: 15
A lot of the conversation clustered around major product updates like nested replies (read more) and improvements to solved workflows via the new “Me too” button (read more), plus a steady stream of bug reports and fixes (e.g., the grid lightbox order issue: read more).
Top users (posts / likes in the last 24h):
User Posts Likes
markvanlan 5 40
Lilly 8 25
lindsey 2 13
NateDhaliwal 3 6
martin 3 6
awesomerobot 4 6
gilles 6 6
zogstrip 2 5
Richie 3 4
merefield 2 3
Interesting Topics
#Announcements
  • Introducing nested replies — markvanlan unveiled an early look at Discourse’s new fully-threaded topic view and the admin controls behind it (read more). Follow-up discussion covered practical rollout concerns like bulk-toggling existing topics (read more), reversibility and how nested mode is represented in the DB (read more), and why threading is intentionally not a per-user preference (read more).
  • Solved improvements: “Me too” for unsolved support topics — lindsey announced a new “Me too” button for solved topics in support categories to help members signal impact and opt into solution notifications (read more). Feedback quickly turned toward admin-side reporting/threshold alerts (read more) and whether “Me too” should bump older threads (read more); awesomerobot also clarified how it differs from experimental “boost” behavior (read more).
  • Granular group-based permissions for anonymous and logged in users — martin explained the deprecation of the confusing @everyone pseudogroup in favor of two explicit automatic groups: anonymous (ID 4) and logged_in_users (ID 5) (behind an upcoming change) (read more). A key clarification: this won’t unexpectedly lock down public categories, because category/tag permissions treat “everyone” differently (read more).
bug
  • Grid lightbox images show in the wrong order (lightbox) — Shauny reported that arrow-key navigation in a grid-based lightbox didn’t follow upload order (read more). zogstrip traced it, fixed it, and linked the core PR for review (read more).
  • Users cannot see who is a group owner — A regression left “group owner” info present in page data but no longer rendered for regular users (read more). awesomerobot confirmed it was likely an unintentional change from a 2023 refactor and opened a PR to restore visibility (read more).
  • Norwegian locale mismatch in AI locale detection vs content-localization locales (ai) — A report showed Norwegian being detected as no while translation targets used nb_NO/nb-NO, causing near-identical translations and wasted credits (read more). nat suggested a quick mitigation by duplicating the locale detection agent and adjusting its prompt (read more); the reporter found nb-NO wording worked best in practice (read more).
  • Assign/Re-assign on mobile: can’t type in the search field (mobile, assign) — Continued reports suggest the assign modal can error out on mobile, preventing typing and producing JS exceptions (including attempts at safe-guarding targetElement) (read more).
  • Incorrect ActivityPub handler addresses shown in /ap/about (activitypub) — A small but impactful formatting bug: displayed handles were missing a leading @, making them harder to copy into ActivityPub clients (read more).
development
  • Discourse-patch-triage bot: how to work with forks — Lilly asked how to collaborate effectively with the new discourse-patch-triage bot, especially when the PR is from a fork and the bot suggests changes (read more). isaac clarified how to invoke it (@patch-triage + plain English), what it can do, and that it cannot commit onto forks (and promised clearer messaging + internal discussion about permissions) (read more, read more).
  • Potential upcoming plugin name clash: “Workflow” — merefield flagged a possible collision: a core PR appears to introduce “Workflow” while a long-standing plugin with the same name already exists, risking admin UI confusion (read more). Related background: the existing plugin’s Meta topic and ongoing compatibility updates (read more).
  • MiniScheduler + Sidekiq 8 integration PR merged and released — A quick turnaround: dmke requested another look, and david confirmed the PR was merged and released (read more, read more).
Support
  • Hide user cards for anonymous users (solved) — In a French-language support thread, gilles asked how to prevent user cards from displaying to anonymous visitors (read more). chapoi pointed to the relevant site setting and the topic was marked solved (read more).
  • Translation only translates the title, not the post (content-localization) — A report described post body translation failing while topic titles translated normally (read more). nat noted a post-length limit can block translation and indicated it could likely be increased; shortly after, the content did translate (read more).
  • Fresh install: activation email not sent (but test email works) (email) — A self-host admin found that registration/activation emails didn’t arrive even though discourse-doctor test email delivered immediately (read more). Troubleshooting focused on verifying whether the mails were logged/sent via EmailLog and checking /logs + /sidekiq for enqueue/sending behavior (read more), with follow-up evidence showing only the test message present in EmailLog (read more).
  • markvanlan drove the launch discussion for nested replies, covering enabling options, bulk actions, and reversibility (read more, read more, read more). He also clarified why threading is an admin-level decision rather than user preference (read more).
  • lindsey shipped and discussed the new solved “Me too” workflow, inviting ideas for admin-facing reporting and surfacing mechanisms (read more, read more).
  • martin explained the new anonymous/logged-in pseudogroups and reassured admins that category visibility won’t unexpectedly change when the upcoming change is enabled (read more, read more). He also landed a clarity improvement related to reporting permissions options in an ongoing announcements thread (read more).
  • awesomerobot handled multiple fixes and clarifications: distinguishing “Me too” from “boost” in solved contexts (read more), confirming the group owner visibility regression and opening a PR (read more), and pushing an update to the Air Theme to address reported issues (read more). He also opened a PR for a minor LLM default selection UI improvement (read more).
  • zogstrip fixed the grid lightbox ordering bug and linked the core PR (read more). Separately, he noted a mention-check fix revealed a new edge case affecting AI agent mentions and linked the PR tracking that nuance (read more).
  • nat helped diagnose translation behavior (including post-length limits) in Support (read more) and acknowledged the Norwegian locale detection mismatch, proposing prompt-level mitigations while a core prompt update is considered (read more).
  • chapoi provided the solved answer for disabling user cards for anonymous visitors via a site setting (read more).
  • dax jumped into the “Me too” launch thread to explain it wasn’t enabled on Meta, then enabled it for testing on try.discourse.org (with a brief “power went out” interruption mid-setup) (read more, read more).
  • Falco supported self-hosted Discourse AI sentiment users by noting an upstream model PR wasn’t merged yet and recommending pointing to his branch directly, with updated docker guidance (read more).
  • isaac closed the loop on the discourse-patch-triage bot workflow, detailing how to interact with it, what actions it supports, and why forks can’t receive bot commits—then followed up to raise fork write-access internally (read more, read more).
If yesterday was any indication, today’s going to be deeply threaded—just try to keep your debugging sessions shorter than the neighborhood power outages.
Key Stats
User Posts Likes
Lilly 7 24
EricGT 8 8
ice.d 4 4
ted 2 5
NateDhaliwal 3 2
RGJ 3 2
putty 2 2
jpishgar 1 3
HAWK 1 2
ToddZ 1 2
A few of the most-referenced/active conversations to catch up on quickly: Discourse Reply Button Labels, Hide Votes Left, What are some common breaking points as communities grow?, Custom dropdown user field contains unselectable value, and Norwegian locale detection.
Interesting Topics
#Enterprise (enterprise-ready)
#Announcements
  • The newly announced “Me too” capability for solved topics continued to evolve via feedback: NateDhaliwal helped folks find it under Admin → Upcoming Changes (where to enable it), EricGT proposed a complementary “Works for me now” signal to reflect real-time recoveries (suggestion), and RGJ questioned whether the counter should start at 0 vs 1 and asked for visibility into who clicked it (counter + attribution — read more)
  • Third-party client implications of nested replies kept rolling in: nicolsdennis asked whether the Top/New/Old sort could be exposed via the existing flat topic JSON endpoint so clients can benefit without adopting nested rendering (API/sort question — read more)
  • Admin UX snag: EricGT reported that when opening Upcoming Changes from inbox notification URLs, the Preview link disappears, making it easy to miss the intended workflow (report — read more)
  • A UI regression report landed on the long-running Foundation modernization thread: NateDhaliwal noted severe overlap in the pinned state menu options (screenshot + report — read more)
bug
  • A subtle signup edge case around custom user fields got a concrete fix direction: ted confirmed inconsistent sanitization between signup vs profile update, and posted a PR to align behavior (analysis — read more)
  • AI localization configuration: Norwegian was being detected as no while the localization setting expects nb_NO; nat confirmed the correct approach and planned prompt improvements so it respects supported languages settings (team confirmation — read more)
#contribute:feature
  • Moderation ergonomics: ice.d suggested a multi-select “flag as spam/off-topic” workflow to reduce repetitive clicking and potentially enable batch handling in the review queue (moderation review-queue) (proposal — read more)
  • Branding/UX for first impressions: Ethsim2 proposed a separate mobile_logo_dark (or login-specific) setting for the login/signup splash screen so admins don’t have to compromise between the unauthenticated splash and the compact logged-in header (login ux) (feature request — read more)
#Self-hosting
  • Security heads-up: AquaL1te shared a write-up on chaining an nginx rewrite-engine RCE with a kernel LPE, and RGJ clarified it doesn’t apply to a standard Discourse install (still useful reading for self-hosters with bespoke nginx setups) (advisory link, scope clarification — read more)
Support
  • Discourse Workflow plugin got a usability upgrade: merefield added a new visual editor to make step editing less opaque, and bundled fixes for some deprecations (visual editor PR announcement — read more)
  • Discourse Subscriptions (official) saw a serious real-world edge case report: a Stripe PaymentIntent is allegedly created without a valid payment method in certain “expired card then update” flows, causing silent failures for end users (bug report — read more)
(More threads that also saw activity, if you’re doing a broader scan: Graceful theme discussion + pattern replacement work (Graceful); OpenID Connect username edge case (OIDC); “anonymous email” category issue persisting in 2026.5.0 (bug thread); signup URL parameter behavior (support); Custom Wizard maintenance concerns (plugin thread); plus install/how-to docs referenced by new theme components (theme install guide, themes beginner guide).)
  • HAWK weighed in on scalable moderation governance—emphasizing trusted people, regular comms, documented processes, and clear appeals—continuing the “breaking points as communities grow” thread in #Enterprise (reply — read more)
  • awesomerobot shared an important update for topic-voting admins: a new site setting Topic voting enable vote limits can remove limits entirely, reducing the need for huge “workaround” limits (while still noting the theme component’s value for mixed trust-level configurations) (vote-limit setting note — read more)
  • awesomerobot also addressed a design concern in the official Graceful theme: after noting the pattern’s association risk, they proposed swapping it for a different traditional Japanese pattern and linked the PR (context + PR — read more)
  • nat confirmed how to fix Norwegian locale mis-detection for AI localization and noted an upcoming improvement to the generic system prompt so it better respects configured supported languages (confirmation + plan — read more)
That’s a wrap: yesterday’s meta was all about making tiny UI labels do big clarity work—while “Me too” counters, vote limits, and nested reply sorting all tried to politely line up and behave.
Key Stats
  • New posts (last 24h): 60
Top users (posts / likes received in the last 24h):
Threads that drew quick attention (likes + replies):
  • A near-miss UX moment: the Delete button positioning while editing categories raised alarms in this report.
  • Bookmark UI polish: a confusing toggle/button in the edit-bookmark modal sparked a fix in this thread.
  • Horizon theme news: high context topic cards are now default (with lots of love for the theme) in the announcement.
  • Docs UX friction: how to get TOC back (and where “toggle translations” went) came up in this discussion.
  • Composer edge case: an HR line stealing focus from the emoji picker was captured (with repro steps) in this bug report.
Also active across the site (support, plugins, and product feedback):
Interesting Topics
#Announcements
  • martin announced that high context topic cards are now enabled by default in the Horizon theme (with a recap of signals like Solved / Voting / Assign / tags / excerpts) — read more.
    (Related: the original Horizon cards intro is here: read more, plus plugin refs for Discourse Solved, Topic Voting, and Assign.)
  • In the nested replies rollout, markvanlan explained why the team didn’t extend Post Voting to achieve the same effect, emphasizing maintainability and UX in this reply.
ux
  • RGJ flagged that the Delete category action appears far more prominent than Save in the simplified category screen, creating a risky “oops” moment in this UX report.
  • ted questioned whether a “superfluous” toggle/button belongs in the edit bookmark dialog; chapoi ultimately removed the toggle (and linked a PR) in the follow-up (bookmarks fixed).
  • Moin asked how to re-enable the TOC on docs (after clicking timeline) and noted that “Toggle translations” becomes hard to reach in simple mode in this thread (disco-toc doc-categories content-localization).
  • ted proposed showing uneditable user fields as disabled inputs (instead of hiding them) to reduce confusion; chapoi raised questions about hidden-field use cases in the discussion (user-custom-fields).
bug
  • Lilly shipped improvements to Discourse Reply Button Labels, including a new setting to show the topic reply button label on mobile viewports (with notes on why post-reply labels would break the mobile footer) in this update.
#contribute:feature
  • Moin suggested suppressing the “New features available!” notice on brand-new forums, arguing that everything is “new” for first-time admins in this feature request.
  • Ethsim2 opened a draft PR to support a separate dark-mode login/signup splash image (new splash_screen_image_dark setting) in this implementation update (login ux).
  • In feedback about Discourse Embedding, Falco confirmed the login friction loop (new tab → logged in → iframe still logged out until refresh) is now fixed and pointed to an update path in this reply (embedding).
#Enterprise
  • A cautionary scaling story: a community’s information architecture collapsed under thousands of categories, and HAWK reinforced why scalable IA (and tags) matter in this exchange (enterprise-ready).
#Site feedback
General
  • A community member suggested nominating Discourse for the Digital Public Goods Alliance registry as both a values and marketing win, with links to the registry process in this topic.
That’s a wrap—may your emoji picker keep focus, your category editor keep “Delete” far away from “Save,” and your bookmarks stay blissfully toggle-free.
Key Stats
  • New posts (last 24h): 81
  • New topics (last 24h): 14
User Posts Likes
Lilly 18 17
martin 1 12
Arkshine 1 5
darkpixlz 4 5
sam 1 5
Falco 2 4
Moin 3 3
EricGT 7 3
NateDhaliwal 2 3
Jagster 1 2
Most active @team (Discourse Team) members:
Interesting Topics
#Announcements
Support
  • Nginx CVE-2026-42945—are Discourse containers vulnerable? A security question kicked off with k0tsk, darkpixlz pushed back on scope, and sam confirmed Discourse will update the base image and noted default rewrite rules aren’t vulnerable. read more, read more, read more
  • Discourse AI translation “not working” turned out to be a preference toggle: EricGT reported translation confusion, and Lilly/Moin helped trace it to the “show original language” preference (and the topic-level toggle tied to it). read more, read more, read more (Background referenced: Viewing localized content read more)
  • Trouble deleting topics, plus nested replies edge cases: In a “why can’t I delete topics?” thread, Falco clarified the user-facing rule (only if no replies and <24h old), while follow-ups suggested Nested Replies Testing can interfere with moderation/admin actions in nested view. read more, read more, read more (Related: wrench actions failing in nested mode read more, deleted nested topic causing issues read more, permissions reference mentioned read more)
  • /about page group visibility: hidden groups vs overlapping visible groups: Ethsim2 documented a scenario where hiding a group section on /about didn’t prevent a user from showing up via another visible group, and asked whether that’s intended behavior. read more
  • Tags on the hosted Free plan: A quick clarification thread noted that tags aren’t available on the hosted free tier right now (upgrade/self-host needed). read more, read more (Related: Free plan beta announcement read more)
bug
  • Theme Creator export shows a white screen (mobile-only repro so far): kairo162 reported a broken export flow, and Lilly confirmed it reproduces on mobile (desktop OK), leaving the page stuck blank. read more, read more
  • How do you close full-screen reactions on mobile? Lilly described getting trapped in a full-screen reactions UI on iPhone/Chrome with no obvious dismissal except reloading the site—hard to reproduce, but disruptive. read more
  • Flags requiring a message can crash and fail to submit (TypeError): cuo_wu reported an uncaught error when submitting require_message flags (e.g. “Something else”), with a console stack trace and root-cause notes. read more
  • Nested mode breaks post admin “wrench” actions (and related deletion/recovery pain): Lilly reported that wrench actions appear but fail silently in nested view, requiring switching back to flat mode for moderation actions. read more (Related nested/deletion symptoms: read more, read more)
wordpress
  • Older WordPress-embedded topics missing noindex + canonical: Thiago_Mobilon reported older embed-created topics losing the X-Robots-Tag: noindex header and canonical back to WordPress; angus asked targeted questions to narrow down what changed. read more, read more (Possibly related embed/nested behavior observed elsewhere: read more)
development
  • Upcoming plugin name clash: “Workflow”: In a naming dispute, j.jaffeux advised third-party developers to avoid “Discourse X” style names to reduce collisions (suggesting explicit vendor namespaces), with the plugin author disagreeing. read more, read more
  • Dev bootstrap: creating the first admin without email + what the dev toolbar does: Ethsim2 summarized a clearer mental model for admin creation in dev (d/boot_dev --init, MailHog, rails admin:create), and Moin pointed out the vertical developer toolbar and its toggles (safe mode, verbose localization, outlets, etc.). read more, read more (Toolbar intro: read more)
  • Quote Callouts: updates to history rendering, excerpts, and shortcut: Arkshine shipped improvements so callouts render in revision history, onebox excerpts strip the marker, and the keyboard shortcut changed to ctrl/⌘ + alt + c. read more
#contribute:feature
  • Change the “More…” reactions icon when any-emoji reactions are enabled: A feature request proposes replacing the gray smiley used as the “More…” affordance in reactions, continuing the earlier thread about reactions UX. read more (Context: read more)
  • martin shipped an #Announcements guide to streamline creating Events categories—automatically enabling key calendar/event settings and wiring the category into the events calendar configuration. read more
  • sam responded to the Nginx CVE thread, saying Discourse will update the base image and noting default rewrite rules aren’t vulnerable. read more
  • Falco clarified topic-deletion limits for regular users (no replies, under 24h), and separately flagged what looks like a bug path involving deleted nested topics (planning to investigate). read more, read more
  • j.jaffeux weighed in on a plugin naming conflict, recommending developers avoid “Discourse X” naming to reduce clashes and adopt explicit namespaces. read more
Yesterday’s vibe check: we made event planning easier while simultaneously discovering that nested replies can hide the moderation wrench—so if your tools go missing, try “flat mode” before you start blaming Nginx. (See: events category setup, nested wrench issue, Nginx CVE thread)
Key Stats
  • New posts (last 24h): 36
  • New topics (last 24h): 4
  • Top users (posts / likes):
Interesting Topics
Support
bug
  • TroLLoBlogger documented a crash after attempting to update via the admin UI, then recovered by rebuilding from the terminal (./launcher rebuild app). The error log points to a plugin asset compilation timeout, and the thread pivots into practical guidance on update workflow and resource constraints. read more
    Notable replies: Lilly on avoiding admin-UI updates for self-hosting read more, and Falco requesting server specs to understand the 120s build timeout read more
  • In an older-but-still-active bug report, Moin pointed to a fix PR for the “Thanks for Contributing” popup still appearing after the intended limit had been passed. read more
ux
  • sniper756 reported that, on mobile browsers, the admin tag-group management page renders incorrectly (noted alongside “Modernize Foundation theme”), with a screenshot showing layout issues. read more
#community-building Building
  • A discussion on using Discourse for small town government sites focused less on software capability and more on institutional realities: moderation ownership, what counts as “official,” authentication, security, and user expectations. Ethsim2 emphasized that the human/process side is the hard part read more, while NateDhaliwal highlighted privacy implications—whoever hosts has “absolute access.” read more
Support (site setting behavior & governance)
  • mcwumbly jumped into a heated hosted-pricing/support thread to clarify that Starter has been deprioritized on the pricing page but should still be available from Free upgrades, then began troubleshooting where the upgrade flow was being triggered. See: initial clarification and question read more, confirmation it “should” appear and plan to investigate read more, an attempted quick fix read more, and the final “hang tight” update pending deeper review read more.
  • Falco investigated a self-host update crash tied to plugin asset compilation timeouts, narrowing suspicion to the plugin build exceeding the two-minute limit and requesting server specs to confirm whether resources were the bottleneck. read more
May all your upgrade buttons reveal the plan you actually want—and may every ./launcher rebuild app finish before the timeout gremlins notice.
Key Stats
  • New posts (last 24h): 80
  • New topics (last 24h): 11
Top users by activity (posts) + appreciation (likes)
  • Lilly — 10 posts, 16 likes (e.g. helping debug signup flows in read more, and advising on nested replies limitations in read more)
  • Falco — 8 posts, 15 likes (e.g. investigating update/build constraints in read more, and shipping nested-replies fixes via PRs referenced in read more)
  • awesomerobot — 3 posts, 11 likes (e.g. tightening up reactions UX consistency in read more)
  • Thomas_Rother — 1 post, 7 likes (sharing a community-building case study in read more)
  • TroLLoBlogger — 2 posts, 6 likes (sharing swap + resource context for update crashes in read more)
  • lindsey — 2 posts, 6 likes (announcing recurring-event RSVP improvements in read more)
  • greymont — 3 posts, 4 likes (closing the loop on a hosted signup/verification confusion in read more)
  • david — 1 post, 4 likes (clarifying how prebuilt assets are distributed and where plugin builds can bite in read more)
  • nat — 2 posts, 4 likes (sharing quick updates on bulk-tagging + AI locale detection in read more and read more)
  • Richie — 2 posts, 3 likes (confirming a theme-component update after a PR merge in read more)
A lot of today’s “hands-on admin reality” clustered around updates + nested replies behavior (see read more, read more, and read more).
Interesting Topics
#Announcements
  • Discourse Events got a usability boost: recurring-event RSVPs now let members choose “this occurrence only” vs “this and all future occurrences”, helping organizers interpret attendance and reminders more accurately (calendar-and-event) — read more
  • The Horizon theme now enables “high context” topic cards by default, and feedback immediately surfaced around making that configurability more granular (ideally per-category) (horizon-theme) — read more
  • A request for group notifications for upcoming events resurfaced in the context of the new RSVP workflow (and the historic workaround of group PMs) — read more
  • “Upcoming Changes” admin UI got a small-but-useful confirmation: the Preview button now appears with the expected filtered URL, helping admins validate which flags they’re previewing (upcoming-changes) — read more
bug
  • Self-hosters reported update crashes and rebuild pain, with discussion centering on resource constraints (notably single vCPU setups) and how non-core plugins can force asset builds that tip low-resource servers over — read more
  • Nested replies continues to shake out: the post-admin wrench actions can fail in nested mode, and the emerging guidance is to switch to flat mode as a workaround while fixes land (nested-replies) — read more
  • Related nested-replies fallout: recovery actions for deleted posts were discussed alongside references to fixes in progress (nested-replies) — read more
  • A report flagged a TypeError when submitting certain custom flag flows (“require_message” flags), and the team invited reproduction details (and even PRs) — read more
  • AI plugin link-click behavior was reported as “no response” in a Chinese-language bug report (ai) — read more
Support
  • A brand-new hosted admin hit a confusing “Oops! page doesn’t exist or is private” during email verification; the root cause appeared to be testing while still authenticated as admin in another window/session — read more
  • “Change Ownership” appeared to do nothing for an admin using nested replies; switching to flat mode resolved it, reinforcing that nested mode is still blocking some post-admin tooling (nested-replies) — read more
  • A moderation best-practices thread asked whether Discourse ships with a default profanity/abuse list; the answer highlighted Watched Words as the built-in mechanism, but without a default list (you bring/import your own) — read more
  • A UX-writing/editor question: users want an easy “post-number mention” shortcut (e.g. #123) to link to a reply without quoting; today’s best workaround remains copying the post link, or implementing custom behavior via theme component — read more
#contribute:feature
  • A feature request proposed adding Group selection when bulk converting Topics → Messages, enabling a smoother “convert a category into a group inbox” workflow rather than ending up with messages limited to current participants — read more
  • A smaller admin-cleanup request asked for auto-purging silenced spam accounts with no posts after X days; discussion pointed back to existing cleanup tools and the “delete and block” spam flow — read more
  • “Normalized Profile Links” got maintenance love: Lilly’s PR fixed array deprecations and was merged, with confirmations that updates worked cleanly on live sites — read more
  • “Quote Callouts” received a CSS fix for <code> styling in callout titles (alignment/visual consistency, especially noticeable with certain fonts and CJK text sizing) — read more
#Self-hosting
  • A self-host admin lockout scenario: disabling Discourse ID before establishing local admin access can leave “no login methods configured”; recovery guidance centered around creating an admin via Rails (rake admin:create) — read more
  • lindsey shipped an Events quality-of-life improvement: recurring RSVPs now distinguish between “next occurrence only” and “all future occurrences,” reducing reminder noise and clarifying attendance for organizers (calendar-and-event) — read more. She also pointed older support threads to the new behavior to close the loop (see follow-up linking in read more).
  • Falco spent time in the trenches on nested replies + admin tooling: clarifying expected behavior boundaries and pointing bug reports into the right funnel in read more, then linking an in-flight fix for wrench-action failures in read more. He also referenced a fix for deleted-post recovery issues in read more, and helped diagnose low-resource update failures in read more.
  • david weighed in on update crash analysis, clarifying how prebuilt assets should be pulled even during web-based updates, and narrowing the likely culprit to non-core plugin asset build time rather than core itself — read more.
  • awesomerobot pushed forward on UX consistency: agreeing that the “More…” emoji trigger should be consistent when allowing any emoji for reactions (reactions) and working on a fix — read more. He also recommended the “delete and block” spam flow as best practice while discussing account noise cleanup — read more — and incorporated feedback into solved-status counting behavior — read more.
  • nat provided two quick “this is landing” style updates: noting a returning capability around bulk-tagging management — read more — and confirming that the default AI locale detection agent now includes better language-code handling for Norwegian/Greek (ai) — read more.
  • HAWK expanded on moderation tooling: confirming there is no default blocked-word list, but detailing the breadth of Watched Words actions (block/require approval/flag/censor/etc.) and import/export capabilities — read more. He also reassured Enterprise users that calendar/events work is active and video conferencing is on the roadmap — read more.
  • featheredtoast responded to concerns about the discourse/discourse Docker image update cadence, explaining a slowdown was an unintended ESR-branch side effect and would be corrected — read more.
  • sam acknowledged a bug report around a flag-submission TypeError and invited more info (and potential community PRs) — read more.
Yesterday’s vibes: if your recurring RSVPs are finally behaving and your 1vCPU server survived an update cycle, you’ve basically cleared Discourse hard mode.
Key Stats
In the last 24 hours (2026-05-18 → 2026-05-19), Meta saw 87 new posts spread across 16 new topics, including multiple product announcements like starring AI conversations (read more) and a docked composer for AI bot chats (read more), plus an intermediate security release (read more).
Top users (posts + likes in the last 24h)
User Posts Likes Recent activity (linked)
sam 1 15 Shipped starred AI conversations (ai) (read more)
Lilly 7 11 Dug into Horizon Theme mobile layout quirks (read more) and advised on redundant-container backups (read more)
keegan 1 9 Announced AI bot docked composer (ai-bot) (read more)
Falco 3 8 Pointed to nested reply read-state linkage in a mobile 404 report (read more) and shared new splash SVG results (read more)
david 1 7 Posted May 19 intermediate releases (release-notes) (read more)
Danielle 1 5 Published Office Hours replay for MCP + Data Explorer (read more)
awesomerobot 3 5 Confirmed you can customize the “Me too” string (read more) and improved new-site feature popups (read more)
chapoi 1 5 Introduced FormKit checkbox redesign upcoming change (read more)
Ethsim2 8 4 Helped troubleshoot phpBB import slowness / Redis timeouts (read more) and PG18 backup failures (read more)
Architect 1 3 Shared progress on adopting Discourse for small-town government (read more)
Interesting Topics
#Announcements
  • sam announced a quality-of-life improvement for Discourse AI: you can now star common AI bot conversations so they remain pinned at the top of your chat list (toggle coming under upcoming changes) — a small tweak aimed at making AI chats feel more “messaging-like.” (read more)
  • keegan unveiled a new docked composer for ai ai-bot conversations, keeping the input persistently available at the bottom of the topic so you don’t have to click Reply for every turn in a back-and-forth chat. (read more)
  • david posted May 19th 2026 intermediate releases, pointing admins to critical/security update streams and changelogs for multiple supported lines. (read more)
  • Follow-up on Solved improvements (“Me too” for reported issues): admins asked whether the “Me too (%{count})” text is customizable, and awesomerobot confirmed it’s safe to change via site text. (read more, read more)
  • The Events team published an Office Hours replay featuring a deep dive on MCP + Data Explorer, demonstrating how AI assistants can generate queries and translate community analytics into natural language workflows. (read more)
ux
  • chapoi introduced an upcoming-change flag for a Form checkbox redesign (FormKit), visually hiding the native checkbox while preserving functionality and enabling smoother styling/animation. (read more)
  • “Where did the tag info button go?” got an official answer: it was removed after adding a dedicated tag settings page, and awesomerobot opened a PR to bring it back with a refreshed banner aligned to category banner styles. (read more)
#customization:theme / #Theme_component
  • The official Horizon Theme thread saw renewed attention on small-screen ergonomics: users reported odd “suggested threads” rendering on mobile emulation and raised concerns that the pinned category/tag navigation consumes too much vertical space; Lilly traced the behavior to navigation-container and suggested CSS workarounds for button/text layout. (read more, read more, read more)
  • Discourse Mermaid users asked about the cadence for updating the underlying mermaid.js library (specifically to reach newer chart types like Wardley Mapping), and Falco encouraged contributors to submit a PR. (read more, read more)
#support:migration
  • A large phpBB → Discourse migration prompted performance troubleshooting: the importer was running ~440–450 items/min while CPU stayed low, with Redis timeouts and skipped posts appearing in logs; discussion focused on I/O/DB bottlenecks, Redis diagnostics, and the tradeoffs of bulk importers. (read more, read more, read more)
Support
  • A self-hosting admin reported that backups fail with PostgreSQL 18 due to a pg_dump client/server version mismatch (container has pg_dump 15.x vs server 18.3), raising the practical question of whether to align Postgres versions, upgrade the client, or segregate DB clusters. (read more, read more, read more)
  • A report of Internal Server Error when approving new users (with OAuth2 auth) focused on where to look first: /logs, browser console, and approval workflow diagnostics. (read more, read more)
bug
  • A tricky bug hunt continued for a TypeError when submitting “require message” flags, where postActionFor can return undefined in certain “nested replies” situations; repro steps narrowed in on flagging in nested mode and then selecting another notify-type reason. (read more, read more, read more)
  • A mobile-only issue reported a 404 at the bottom of a nested replies testing topic, suspected to relate to recent nested read-state behavior; additional context connected to broader “topic list state / old topics showing” weirdness. (read more, read more, read more)
  • Voting UI regression watch: users can’t view who voted on a closed topic when topic voting is enabled, with both the UI and API returning empty voter lists—raising concern that an older bug may have resurfaced. (read more)
  • sam shipped Star common AI conversations to keep frequently used bot chats surfaced (#Announcements, ai) (read more).
  • keegan announced the docked composer for AI bot conversations, now available behind an upcoming-changes flag (#Announcements, ai-bot) (read more).
  • david published May 19th 2026 intermediate releases with pointers to the official changelog streams (#Announcements, release-notes) (read more).
  • Danielle posted the Office Hours replay: a guided walkthrough of MCP + Data Explorer and how AI can assist with community analytics workflows (events) (read more).
  • chapoi introduced an upcoming-change flag for the Form checkbox redesign (ux) (read more).
  • awesomerobot confirmed site text customization for “Me too” in Solved’s reported-issue UX (#Announcements, solved) (read more), noted that brand new sites won’t be spammed by historical “New features available!” notices (#contribute:feature) (read more), and opened work to restore the tag info button UX (ux) (read more).
  • Falco connected a mobile nested-replies 404 report to recent nested read-state changes (bug, nested-replies) (read more), encouraged contributions to Discourse Mermaid update cadence (#Theme_component) (read more), and shared improved custom SVG splash examples (#Announcements, splash) (read more).
  • mae shared that Discourse was submitted to the Digital Public Goods Alliance registry (a step toward broader public-interest adoption) (General) (read more).
  • nat merged a fix after adding specs for a language-code-related bug, thanking the contributor for the PR (bug, translation) (read more).
  • isaac marked updates to @patch-triage, enabling review/rebase/commit requests and improving fork behavior (development) (read more).
Yesterday’s theme was unmistakable: Meta got a bit more “chatty,” with AI conversations now star-able and the bot composer docking itself like it owns the place.
Key Stats
In the last 24 hours, meta saw 63 new posts across 16 new topics—with conversations spanning everything from open web values to chat quirks and migration performance. Activity clustered around threads like the blog post on staying browser-first (read more), the #support:migration importer tuning discussion (read more), and a handful of fresh bug / ux reports (e.g. read more, read more).
Interesting Topics
blog
  • ducks argued that Discourse won’t force mobile users into an app, positioning Discourse as explicitly pro–open web in contrast to app-first lock-in trends (read more). NateDhaliwal also flagged a housekeeping detail about the topic author attribution (read more).
#support:migration (phpbb)
  • A deep-dive on speeding up phpBB → Discourse imports focused on database I/O bottlenecks, with cocococosti recommending pragmatic tactics like adding indexes/views and tuning DB settings—and teasing “new tooling” aimed at dramatically faster migrations (read more). The thread also includes real-world importer failure logs from an ongoing run, useful for diagnosing repeatable edge cases (read more).
ux
  • Richie requested small consistency tweaks for the expanded search UI—specifically the casing of dropdown options and removing an unnecessary ellipsis—while NateDhaliwal noted that lower-case options read better in-sentence (“Where topics are closed…”) and agreed the other dropdown likely needs standardizing (read more, read more, read more).
  • RGJ spotted an auditability gap: restoring (undeleting) a post does not create a staff action log entry, unlike deleting/restoring topics—making it harder to see who restored content without digging into system logs (read more).
#Announcements
  • Building on the Events + Calendar work, martin explored whether Discourse could auto-enable an upcoming-events sidebar block when the “right sidebar blocks” component is present, and nathank proposed a more unified Events category view combining calendar-style “upcoming” visibility with a topic list (read more, read more).
  • In the “Me Too” + Solved improvements thread, EricGT suggested making “Me Too in closed topics” a customization option, and floated an approach where “Me Too” on a closed issue could prompt creation of a new topic after AI checks for duplicates (read more). The discussion also branched into whether the button should appear in deleted/closed contexts, referencing a related layout thread (read more).
  • davidb announced an opt-in layout tweak for sites using Discourse Reactions: moving reply count to the right to keep reactions alignment consistent, enabled via upcoming changes as Enable new post reply count position (read more).
wordpress
  • For WooCommerce + WP Discourse setups, angus clarified that usernames don’t need to remain in sync: DiscourseConnect maps accounts via external_id (WP user id), not the WordPress username—so letting users change their Discourse username shouldn’t break SSO matching (read more).
  • A WordPress embed SEO issue: older embedded topics were missing x-robots noindex and canonical tags, and angus narrowed it to missing topic_embed records required for canonical-url-for-embeds—while Thiago_Mobilon argued for a more robust category-level “noindex all topics” checkbox to avoid reliance on embed records (read more, read more).
Support
  • A site admin asked how to export all site data (not just a personal archive). NateDhaliwal pointed them toward Admin → Backups for a full instance backup suitable for upgrades and server moves (read more, read more).
  • A theme-component update attempt hit about.json does not exist during import; responders suspected ZIP structure issues (parent directory nesting differences across OS zip tools). Moin demonstrated that re-zipping with the right folder structure fixed installation (read more, read more).
  • Postgres tooling friction surfaced again: a self-host reported backups failing with Postgres 18, prompting advice to install matching postgres client packages inside the container and then persist that setup via app.yml rebuild hooks—plus a pointer to prior related discussions about upgrading the postgres client (read more, read more, read more).
  • A small but impactful paper-cut: the “update available” email included a broken release-notes link due to a missing v prefix in the changelog URL (read more).
  • Pricing anxiety continued: a user tracked visible shifts on the Discourse pricing page and reported previously-available features now appearing “Upgrade to unlock” on a recently created community, connecting their concerns to earlier free-plan beta discussion and a “no starter option” thread (read more, read more, read more).
bug
  • Moin reported a Unicode edge case in emoji autocomplete (notably with ü) where selection via “more” fails to replace typed text; in chat it escalates into a console error (emojiTermStart null) and broken selection behavior (read more). The report also cross-referenced an older “revision despite grace period” observation triggered while reproducing (read more).
  • Starred chat UX bug: Shauny described how the Chat “Back” button forgets you were in Starred, always returning to Channels/DMs, undermining the time-saving intent of starring channels—and pointed to the original “star your favorite chat channels” feature announcement for context (read more, read more).
  • A tag-icons regression hunt: AquaL1te noticed tag icons rendering inconsistently (sidebar OK, topics not), and Lilly hypothesized an underscore-vs-dash slug mismatch introduced by a component change—suggesting updating slugs in config rather than renaming tags (read more, read more).
  • ducks published the day’s headline blog thread asserting Discourse’s browser-first stance: “Discourse Will Never Block You From the Web” (read more).
  • cocococosti advised on accelerating phpBB imports by targeting the typical bottleneck—database I/O—and recommended indexing/views/tuning to make repeated imports less painful, while hinting at upcoming faster migration tooling (read more).
  • martin chimed in on Events category creation UX, noting a potentially valuable integration point with right-sidebar blocks and proposing investigation into enabling an events block when the relevant component is installed (read more).
  • davidb announced an upcoming change for sites using Reactions: an opt-in reply-count position adjustment to improve alignment consistency, enabled via the upcoming-changes UI (read more).
  • markvanlan followed up on a reported 404 at the bottom of a nested replies testing page, noting they couldn’t reproduce at the time but would keep an eye out for recurrence (read more).
Yesterday’s energy was all about staying on the open web—even as folks simultaneously shipped new UI polish and dreamed up native app experiences—so however you’re browsing today, at least you’ve got options.
Key Stats
In the last 24 hours (2026-05-20 → 2026-05-21):
  • New posts: 67
  • New topics: 9
Top contributors (posts / likes received in the last 24h):
User Posts Likes
saquetim 1 12
zogstrip 6 7
Lilly 5 6
NateDhaliwal 3 5
Tris20 1 5
kairo162 3 4
pfaffman 1 3
david 1 3
HAWK 3 3
Crown1 3 3
Biggest “headline” drop: a new reading-first “simple mode” for Doc Categories landed as an announcement — read more
Interesting Topics
#Announcements
  • A new “simple mode” for Doc Categories (reading-first docs, replies behind a toggle). saquetim introduced a documentation-shaped topic experience in #Announcements with doc-categories, including auto-expanding when linking directly to replies and a simplified “Updated” list column — read more (background: Discourse Doc Categories plugin, and a real-world “oops, I missed earlier replies” example: Backup from command line)
bug
  • iOS PWA nested replies layout gap (username/profile spacing). kairo162 reported an odd spacing issue in nested replies on iOS PWA, and markvanlan said they’ll dig in — read more (team acknowledgment: read more; related testing thread: Nested Replies testing)
  • Horizon theme header breaks on mid-size/folding-phone viewports (640–767px). nathank shared screenshots where the search/avatar vanish at a specific width range, with Lilly offering a CSS workaround and tying it to viewport-based mode switching — read more (CSS investigation: read more; related discussion on mobile/desktop switching: read more)
  • Core reactions “+1 hover popover” stuck loading due to URL encoding. PortChange traced the issue to reaction_value=+1 being interpreted as a space, and zogstrip pointed to a fix; the reporter confirmed it was working quickly after — read more (fix noted: read more)
  • Mobile UX: browser back button while reaction list modal is open. Canapin reported the reaction list staying open and the page jumping to the footer on Chrome Android; Moin connected it to earlier reaction-modal work — read more (related earlier posts: read more, read more)
  • Emoji autocomplete + special characters (e.g., “ü”). renato linked a proposed fix PR for emoji autocomplete behavior involving special characters — read more
  • “Users for approval” notification claims approvals exist, but the queue is empty. Christian_Bailey confirmed they’re hitting the same “phantom approvals” bug (and that they’re the only admin, ruling out someone else approving) — read more
  • Flagged post restoration is confusing when a “reason given” blocks restore. zogstrip credited a community find and pointed to a fix-incoming PR — read more
Support
  • Hosted upgrade UX: “Starter” plan not selectable (only Pro shown), partially fixed. Crown1 reported that Starter details appeared but couldn’t be selected from some upgrade surfaces; later confirmed “Manage Account” now works, and rishabh explained the underlying recommendation logic issue (Free/Starter staff-limit parity) and promised a fix — read more (confirmation it worked via Manage Account: read more; team follow-up: read more)
  • Free plan / pricing structure confusion: category types and missing feature-matrix rows. HAWK clarified the Free plan is still new/being tuned, noted transactional-email limits (and an “email in” oversight that got reverted), and agreed feedback about the feature matrix and category-type changes is fair — read more (category type concerns: read more; follow-up: read more)
  • Backups failing with Postgres 18: solved with package changes. A backup failure thread ended with a working solution flow (installing/upgrading Postgres packages), plus pfaffman recommending pinning client packages and moving commands into app.yml — read more (follow-up advice: read more)
  • View count doesn’t increment on one topic (others are fine). Prempavee asked why a single topic isn’t counting views; NateDhaliwal asked for specifics and suggested testing safe mode to rule out theme/component interference — read more (triage questions: read more)
General
  • A native iOS+Android Discourse client app (preview) and what it needs to work broadly. In show-and-tell, nicolsdennis explained the app isn’t store-published yet, and that some features depend on an accompanying plugin + configuration like Allowed user API auth redirects — read more (implementation details: read more)
  • Chat UX: floating chat + browser history causing confusion. sam confirmed a reported “back button” issue is specific to floating chat mode and argued floating chat shouldn’t participate in page history; zogstrip noted it should improve once a fix is merged — read more (status update: read more)
  • Discourse Automation: can an auto-reply mention the user? A question in the official automation thread asks whether automated replies can @mention the newly-posting user (useful for “first post” onboarding patterns) — read more
  • Featured Topics component: possible collision with a Pavilion dropdown header. TestingRico reported that previewing the Featured Topics component seems to make the Pavilion dropdown header disappear, asking if it’s known and how to keep both working — read more (related component referenced: pavilion dropdown header)
wordpress
  • WordPress embeds: old embedded topics missing x-robots: noindex and canonical tags. angus explained canonical URLs should work, but missing embed records imply some external deletion/operation; Thiago_Mobilon argued category-level indexing control should be native and that republishing isn’t viable at large scale — read more (SEO feature request argument: read more)
  • saquetim shipped an announcement introducing Doc Categories “simple mode” (a reading-first docs view with replies one click away) — read more
  • zogstrip had a busy bug-fix/status-update day:
    • Pointed to an upcoming fix for chat floating-mode back button quirks — read more
    • Posted a hopeful fix direction for Googlebot 404s from page number URLs — read more
    • Confirmed a UX tweak (“Auto silence first post regex” description should link to watched words) is pending merge — read more
    • Investigated the hard-to-repro full screen reactions close behavior on mobile — read more
    • Confirmed the encoding-related “+1” reaction hover popover bug would be fixed — read more
    • Flagged-post restore workflow: acknowledged a find and linked the fix path — read more
  • david responded on the folding-device/mobile-mode discussion, noting Discourse design work assumes viewport-based mobile mode remains enabled and that Horizon should be fixed without toggling that setting — read more
  • HAWK engaged on hosted-plan expectations and market-fit iteration (Free plan, email constraints, category type changes), and took feedback to raise internally — read more (follow-up: read more); also continued the growth/process conversation in #Enterprise — read more
  • markvanlan acknowledged and agreed to investigate the iOS PWA nested replies spacing bug report — read more
  • featheredtoast updated self-hosters using the official Docker image that the next build should restore expected upgrade behavior (and later confirmed it was back) — read more
  • sam clarified the floating chat context for a back-button report and suggested floating-mode chat should avoid participating in browser history — read more
  • rishabh apologized for the hosted-plan upgrade confusion and explained why Starter was incorrectly skipped by the recommender, promising an update once fixed — read more
  • renato linked a fix PR for emoji autocomplete issues involving special characters — read more
  • supermathie asked for more details on a Chinese-language support post about the review queue (“what reason was given for the flag?”) — read more
Yesterday’s vibe: between simple-mode docs, folding-phone headers, and reaction popovers that don’t like plus signs, Meta was basically a usability escape room—now with better lighting and fewer hidden toggles.
Today on meta.discourse.org…
Key Stats
  • New posts (last 24h): 90
  • New topics (last 24h): 10
User Posts Likes Recent reference
Lilly 15 15 Tracked down a Foundation/“Modernize” font-size regression and shared a CSS workaround in this thread
Moin 13 9 Reported and investigated “Approve” failures for users in Approval button on user’s profile doesn’t work
sniper756 7 3 Reported tiny homepage typography after rebuild in this UX report
darkpixlz 4 6 Requested feature parity for action-log notes in nested/threaded view in this UX topic
Ed_S 4 3 Confirmed and escalated the approval/phantom queue issue, linking it to the new report in this post
awesomerobot (team) 3 10 Weighed pros/cons of AI crawler access in the Agent Ready discussion
supermathie (team) 3 4 Diagnosed clipboard-formatting behavior for syntax highlighting in this debugging reply
Orioni 3 4 Added SEO/AI nuance about #llms-txt in this reply
Tris20 1 3 Shared enterprise migration “breaking points” context in this ongoing enterprise thread
Discourse 1 6 Published the “Agent Ready” blog companion topic here
Top contributors from the @team group (posts / likes)
Other active threads that picked up replies (quick link roundup):
Phantom approval notifications, Doc categories “simple mode” follow-up, Tags UI spacing feedback, Voting button got smaller, Calendar event UX question, Docker dev install gotcha (UID 1000), Shortlink Router README/guide, and an ongoing discussion on Daily Summary formatting.
Interesting Topics
blog
  • Discourse published “Discourse is Agent Ready”, sparking a practical debate about whether communities should welcome or block AI crawlers; awesomerobot framed it as “depends on whether your forum is support vs social,” while others raised GDPR/LGPD and scraping concerns in the companion thread read more.
bug
  • A potentially serious moderation workflow issue emerged: admins report the “Approve” button on a user profile can fail, leaving users unapproved yet missing from the review queue; Moin’s repro and Ed_S’s “me too” add weight to the report in Approval button on user’s profile doesn’t work (closely related to the “phantom approvals” thread here).
  • A copy/paste edge case: syntax highlighting colours don’t reliably carry over when copying code blocks into external clients; supermathie showed that the codeblock “Copy” button yields plain text, while selecting rendered HTML can preserve formatting—then the thread narrowed to browser/client behavior differences in this bug report.
  • Good news on email polish: the “update available” email had a broken release-notes URL (missing a v), and a fix was prepared and then confirmed merged in Email with update available has invalid link to release notes.
  • iOS PWA composer UX: when text size is set smaller, the Reply button can disappear in the iOS PWA (while Safari works), with a fresh report and screen recordings in Reply button not visible when composing on iOS PWA (noting a possibly related earlier thread here).
ux
Support
#Site feedback
  • Attribution vs simplification: Lilly asked for “simple mode” to be disabled (or contributors restored) in the Wiki category, arguing the current presentation can unintentionally erase visible credit for non-staff authors in this feedback topic.
  • Meta’s own digest mechanics were discussed again in the long-running “daily summary” thread, including how top-user callouts and references get presented in Daily Summary Feedback.
#Announcements
  • The nested replies rollout continues to spur customization discussion: one thread revisited how to handle reply-label language/translation tradeoffs, pointing from the nested replies announcement toward a dedicated labels solution in Introducing nested replies (see also the linked labels topic here).
#customization:plugin
  • In topic-voting, admins reported the familiar big “Vote” button has become a small arrow that users overlook, prompting requests for UI reversal or customization guidance in Discourse Topic Voting.
Activity by the @team Group
  • awesomerobot engaged in the “agent-ready” discussion, outlining when AI visibility might be a net positive (support/answers) versus harmful (social community goals) in this reply, and also cautioned that blocking scrapers isn’t foolproof if content is public in this follow-up.
    They also clarified free-tier inactivity expectations and timelines in the free-plan support thread.
  • supermathie broke down why syntax highlighting colours don’t always paste into other apps—distinguishing the Discourse “copy button” vs selecting rendered HTML—in this diagnostic post, adding additional troubleshooting steps in this follow-up, and explaining Firefox vs Chromium style-inlining differences in this technical note.
  • techAPJ confirmed how the “help answer similar questions” PM chooses suggested topics (and how “limit suggested to category” affects it) in the solved reminders thread.
If yesterday’s Meta felt like a mashup of AI crawler ethics, mysteriously tiny fonts, and haunted approval queues, that’s because it absolutely was.
Key Stats
In the last 24 hours, Meta saw 36 new posts across 9 new topics, with most of the churn concentrated around bug triage, permission/UX refinement, and a couple of theme-component releases (e.g. read more, read more, read more).
User Posts Likes Recent highlight
Ethsim2 9 2 Reported a bundled reactions serializer regression (read more) and tied it back to broader “update all” fallout (read more)
Lilly 4 1 Pointed out likely incompatibility between nested-replies and post-voting (read more) and helped debug missing Like UI (read more)
bird 3 1 Confirmed Likes were suppressed by Topic Voting and applied a CSS fix (read more)
wenqin 1 4 Raised cross-cultural/generational UX concerns about reply order discoverability (read more)
mcmcclur 1 3 Released a KaTeX-based theme component to typeset topic titles (read more)
Ryan_Hyer 1 2 Reported infinite scroll breakage in the user directory tied to a theme component (read more)
pfaffman 1 1 Recommended a rebuild after an “update all” incident with missing assets (read more)
dax 1 1 Clarified Meta usage boundaries and redirected functional testing to try.discourse.org (read more)
Moin 1 1 Investigated a confusing “approval button” flow involving prior reviewables (read more)
rokejulianlockhart 1 1 Added Chromium-oriented investigation angles to copy/paste syntax highlighting limitations (read more)
Interesting Topics
#contribute:feature
  • wenqin shared cross-cultural and generational feedback on topic reply order and discoverability for older users, suggesting admins should be able to choose a default “newest-first” view while still allowing per-user overrides (read more); jack222 echoed the friction of landing at the bottom and needing to scroll to understand context (read more).
  • Ethsim2 proposed splitting the broad permission delete_all_posts_and_topics_allowed_groups into own-content vs global-content capabilities to better support least-privilege role design (especially around deletion footprint vs moderation power) (read more), then dug into how PostGuardian checks differ for “seeing deleted posts” vs “seeing deleted post bodies” (read more).
ux
  • Continuing the permissions thread, Ethsim2 asked for clearer wording on “delete removed posts after” to distinguish the author-facing removal action from later automatic cleanup, and to clarify what staff/regular users can see during the window (read more).
bug
  • After “update all”, ice.d hit an intermittent “forum issues” situation that looked like a stale-tab vs rebuilt-asset mismatch; Falco asked to check /logs (read more), Ethsim2 identified missing Propshaft chunks and connected a separate backend exception to the bundled reactions regression (read more), and pfaffman advised a command-line rebuild (read more).
  • Ryan_Hyer reported broken infinite scroll in the user directory when a specific theme component is enabled, with loadMore failing because this.model is undefined (tagged user-card-directory) (read more).
  • cuo_wu found a 500 error when enabling both nested-replies and post-voting, triggering undefined method 'post_number' for nil in NestedReplies::PostTreeSerializer (read more); Lilly suggested the two features likely aren’t compatible yet, linking to prior nested replies discussion (read more).
  • Ethsim2 reported a NameError: ReactionsSerializerHelpers during topic load on 2026.5.0-latest.1, pointing at a bundled reactions serialization path (read more) and noting they opened a PR to move/load the helper earlier in the chain (read more).
  • A longer-running issue about copy/paste of syntax highlighting (where destinations that support coloured text still lose the colours) picked up further investigation ideas from rokejulianlockhart, including looking for relevant Chromium source references (read more).
  • The “Approval button on user’s profile doesn’t work” thread deepened: Moin hypothesized the issue may relate to users being reviewed before (and not being reviewable again in the expected way), sharing analysis around suspect_user and reviewable states (read more); Ed_S later found similar evidence and tied it to possible historical ID reuse / deleted-user artifacts (read more), also referencing an older related report (read more).
Support
  • In a Chinese-language support thread, bird asked why the Like button wasn’t visible; supermathie found Likes are suppressed in categories using Topic Voting and linked the canonical explanation from the voting plugin docs (read more). The thread also referenced how to re-enable both Like + Vote (read more) and noted enabling reactions can make a Like-like control appear in voting contexts (read more). bird ultimately confirmed success via a CSS component workaround (read more).
  • A solved report about a Chrome back-button bug appears to be language/translation dependent: NateDhaliwal suspected a translation mismatch (“theme” vs “topic”) (read more), and jack222 observed the issue disappears when switching UI language to English (read more).
  • A moderation-permissions question asked whether category moderators can be prevented from reviewing flags on their own posts; Ethsim2 reasoned through role trade-offs (TL4 vs category moderator) and emphasized that theme components shouldn’t be treated as security boundaries (read more).
#customization:theme component
  • mcmcclur published “KaTeX titles”, a theme component that typesets math in topic titles using KaTeX (with notes about MathJax conflicts) (read more). The motivation references prior requests for math in titles and the constraints around title formatting (read more, read more).
  • The long-running “Discourse Indented Subcategories” theme component thread saw a post removed by its author, a small but notable moderation/maintenance blip in an actively used sidebar-related component discussion (sidebar) (read more).
  • In the official Discourse Calendar (and Event) topic, nathank noted an idea would make an excellent Contribute > UX topic, and mentioned it’s timely given a recently implemented edit button on the preview (read more).
  • A “New community” thread received a firm but constructive reminder from dax: Meta isn’t for running functional tests or promoting trial sites; use the demo instead, and avoid unsolicited PM outreach for testing workflows (read more).
  • supermathie diagnosed why Likes were missing in a Voting-enabled context (Likes are automatically disabled), pointed to the relevant canonical docs, and suggested possible paths forward (CSS workaround / Reactions) in the support thread “请问一下点赞按钮如何显示” (read more).
  • Falco responded to “Bug? forum issues” by directing the reporter to inspect /logs as the first step in narrowing down the incident after an update (read more).
  • dax clarified appropriate usage of Meta in “New community,” steering testing to try.discourse.org and discouraging direct PMs for test-related outreach (read more).
That’s all for today—yesterday’s Meta energy was basically “votes ate my likes, nested replies fought post voting, and KaTeX tried to sneak math into titles anyway.”
Key Stats
  • New posts (last 24h): 37
    Activity clustered around nested replies UX, moderation workflow edge-cases, and admin-quality-of-life requests like logging setting changes (e.g. read more, read more, read more).
  • New topics (last 24h): 3
    Fresh reports/questions included a docs UX overlap issue (read more), a self-hosting reverse-proxy setup question (read more), and how to disable “invite accepted” notifications (read more).
  • Top posters & most-liked (last 24h):
Interesting Topics
#contribute:feature
  • wenqin gathered cross-cultural feedback on default reply order (oldest-first vs newest-first) and the discoverability of jumping around long topics; discussion touched nested replies behavior and the presence/absence of the right-hand timeline (read more, read more, read more).
#Announcements
  • The rollout discussion for nested-replies continued, with skepticism about whether nesting reduces the “thousands of replies” problem—or simply adds cognitive load—while still welcoming choice (read more, plus related testing feedback in read more).
  • In doc-categories, “simple mode” sparked UI overlap reports: Moin noted tags colliding with edit counts and dates, and the comparison to safe mode suggested a theme/component interaction or layout regression (read more, with a similar overlap symptom noted in read more).
blog
  • The “Agent Ready” post drew pointed commentary about regulation, licensing, and copyright enforcement, with ted arguing that existing frameworks have already been ignored at scale (read more).
ux
  • A brand-new report showed the “pending suggested edit” banner overlapping the wiki edit-history pencil/date in docs, and also highlighted missing tagging/organization around suggested-edits documentation (read more, referencing suggested edits context in read more).
bug
  • A long-running annoyance resurfaced: notifications claiming “X users for approval” when none can be found. RGJ argued the cause has been clear for years and asked for a fresh team look (read more, pointing back to earlier diagnosis in read more).
  • Account approvals hit another snag: the “Approve” button on a user profile appears non-functional in some cases, with suspicion of malformed ReviewableUser records, silent failures, and review queue omissions (read more, read more).
Support
  • A Chinese-language thread investigated an iOS Chrome back-button issue that may actually be tied to Chrome’s page translation interfering with Discourse navigation/history state, rather than a theme-specific bug (read more, with clarifying questions in read more).
  • Admins asked for a way to turn off “accepted your invitation” notifications (invites). The current answer appears to be “not configurable,” with a pointer to an older forgotten request and a workaround via a “dummy inviter” account (read more, historic feature request: read more).
  • A moderation integrity question: can category moderators be prevented from reviewing flags on their own posts (moderation category-moderators review-queue)? Heliosurge advocated for removing temptation via finer-grained controls or Customization workarounds, and linked to tooling ideas (read more, read more, plugin mention: read more).
#Self-hosting
  • A self-hoster asked for reverse-proxy config guidance when Nginx and Discourse run on separate machines, including how proxy_pass should map compared with the single-box unix-socket examples in the docs (read more).
#Integrations
  • The long-running embedding thread got a fresh question: can you import Discourse-style comments into a mobile app “these days”? Falco noted the embedded comments list is essentially read-only unless you build more around it, and asked for details to guide the approach (read more, read more).
  • In a automation thread about messaging users at scale, haydenjames and Moin discussed the pain of silent setting changes after updates and the desire for better auditability. A concrete suggestion emerged: log update-driven setting changes in staff logs, and optionally automate admin notifications when settings change (read more, proposal: read more, notification automation idea: read more).
#support:migration
  • A phpbb migration story: after completing an import, Mattash realized passwords weren’t imported and planned a restart—this time pruning low-value posts (“half million jello and count down posts”) to speed things up (read more).
  • Falco weighed in on a feature request about reply order and navigation discoverability, pointing out the timeline jump behavior and noting nested replies already address some “reply order” goals—but also acknowledging design gaps: the nested-replies timeline was added briefly, deemed lacking, and reverted while the team explores a better approach (read more, read more, related nested replies testing: read more).
  • Falco answered an integrations question about embedding Discourse comments into a mobile app, clarifying current constraints (read-only embed list) and inviting more specifics to tailor guidance (read more).
Yesterday’s theme was clear: if you can’t find what you need, it’s either one click on the timeline—or nested replies temporarily ate the timeline while everyone argues about discoverability.
Key Stats
  • New posts (last 24h): 41
  • New topics (last 24h): 9
Top users by recent activity (posts) & appreciation (likes):
User Posts Likes
Moin 8 13
Lilly 6 11
Jagster 3 3
haydenjames 2 2
dax 1 5
ToddZ 1 4
Eviepayne 1 4
fitzy 1 3
RGJ 1 2
manuel 1 2
A few threads attracted quick, high-signal replies—like the UX discussion on installing duplicate theme components (read more), and the new theme component to reduce admin notification clutter (read more).
Interesting Topics
ux
  • Jagster flagged that “Featured components” can look like they’re re-installable even when already present, which feels like it should at least signal “installed”; dax clarified it’s intentional to allow the same component across multiple themes with different configs, while Moin dug into inconsistent detection behavior (read more) (context from @dax) (follow-up from @Moin)
#customization:theme component (#TAG: notifications)
  • Lilly published “Dismiss Admin Noise!”, a lightweight theme component to auto-dismiss specific admin-only user-menu notifications; the thread includes install info and even Rails-console snippets to generate test notifications (read more) (testing tips) (install guide reference)
Marketplace (#TAG: meta-theme-feedback, meta-redesign-2026)
  • A discussion about whether you can “copy the meta branded theme” turned into a reality-check on brand/design licensing and what commissioning a similar theme might cost; manuel also pointed folks toward building blocks/components as a practical alternative (read more) (cost/licensing perspective) (theme skills link)
bug (#TAG: nested-replies)
Support
Support (#TAG: invites)
  • “Turn off invite accepted notifications?” got a practical answer: Lilly pointed directly to the new Dismiss Admin Noise theme component as a way to cut down that admin dropdown clutter (read more) (theme component)
Support
Support (#TAG: activitypub)
  • A feature request asked for a public, dynamic list of ActivityPub handles for federated categories (the current list lives behind an admin-only URL), to enable easier linking from external public pages (read more)
Support (#TAG: composer)
  • Moin questioned how educate_until_posts interacts with recent behavior changes in check_education_message, after seeing the “education banner” appear fewer times than expected even with a higher threshold—backed with code references and a reproducible test scenario (read more) (related prior discussion)
#Announcements
  • Image optimization discussion continued: a request for broader WebP usage (including PNG conversions/compression) got a candid reply from Falco about tradeoffs—especially the settings explosion that would be required to keep admin control flexible while shipping sane defaults (read more) (team response)
#support:migration (#TAG: phpbb)
  • In the phpBB migration performance thread, cocococosti reiterated a crucial point: passwords aren’t imported (and generally shouldn’t be), and users should reset passwords post-migration—best communicated proactively to reduce confusion (read more)
#Self-hosting
  • A Chinese-language self-hosting thread asked whether others noticed smaller Docker image sizes after rebuild (e.g., ~7GB down to ~5GB), likely reflecting recent image/build changes (read more)
#customization:plugin (#TAG: official, calendar-and-event, included-in-core)
#Enterprise (#TAG: enterprise-ready)
  • The “community breaking points” conversation added a strategy angle: HAWK emphasized intentionally supporting fragmentation into semi-autonomous subgroups as communities scale, citing “mitosis” style lifecycle thinking (read more)
blog
  • In the “Agent Ready” blog discussion, Eviepayne suggested that making Anubis a supported captcha would be a strong complement to the broader agent-readiness direction (read more)
  • dax weighed in on the UX concern about duplicate theme component installs, explaining the behavior is an intentional design choice to support multiple themes/configurations and testing workflows (read more).
  • manuel replied in the marketplace thread about copying Meta’s branded theme, reiterating brand language constraints and pointing people to official learning resources for building similar homepage components (read more) (skills resource).
  • fitzy closed the loop on the Nginx CVE work, confirming completion and pointing to the updated base/default images (via linked PRs) (read more).
  • Falco left two notable technical touchpoints: a quick triage note on the nested-replies link breakage pointing to nested.js (read more), and a detailed reply on why broader WebP/compression controls likely need many settings (and why there’s limited appetite internally right now) (read more).
  • HAWK contributed scaling guidance in the enterprise discussion, recommending processes that help large communities split into semi-autonomous groups while retaining shared identity (read more).
  • cocococosti clarified migration best practice: do not import passwords during phpBB migrations; plan instead for password resets and set expectations with users (read more).
That’s a wrap—may your approvals be real, your nested links not 404, and your admin notifications politely dismiss themselves overnight.
Key Stats
In the last 24 hours (2026-05-25 → 2026-05-26):
Top users (posts / likes in the last 24h):
User Posts Likes
martin 2 11
markvanlan 4 8
Lilly 6 8
zogstrip 3 5
rishabh 1 5
Falco 3 4
darkpixlz 4 4
david 1 4
Moin 6 4
Bas 1 3
Interesting Topics
#Announcements
  • martin announced an upcoming rollout to enable Discourse Reactions by default across new and existing sites, with discussion about how this overlaps (or doesn’t) with “Boosts” and longer-term engagement strategy (read more).
  • GitHub Oneboxes got nicer: PR oneboxes now show live pull request statuses inline, powered by a core change linked from the announcement thread (read more).
  • Feedback continued on the “me too” button/label in Solved topics—highlighting that the phrase can feel loaded in some communities and pointing out that the label is customizable via Site Text (shared_issue) (read more).
bug
  • A compatibility problem between nested-replies and post-voting moved toward a practical fix: make post voting explicitly incompatible with nested reply topics (plus related PR links for implementation) (read more).
  • The “suggested topics” widget had a broken link to nested topics, and a fix PR was shared for the issue (read more).
  • A self-host upgrade to 2026.4.1 triggered repeated “can’t alloc thread” errors; after diagnostics around ulimit/cgroups/PID ceilings, a CLI rebuild appeared to stabilize things, with follow-up questions about browser upgrade safety checks (read more).
  • An ongoing crawler-related exception—“Document tree depth limit exceeded”—was reported as resurfacing even after being “fixed twice,” now seen again after upgrading to 2026.4.1 (read more).
  • A plugin-side regression/bug: user-card-directory infinite scroll broke with a loadMore error, and a fix was applied via a plugin PR (read more).
Support
  • A self-host email deliverability/config thread dug into DigitalOcean’s blocked SMTP ports and Resend configuration; the “gotcha” turned out to be curly quotes in YAML (plus follow-on port guidance and a suggestion to run a diagnostic rake task) (read more).
#Site feedback
  • A UI/UX gripe surfaced: on Meta, user info appears hidden on wiki posts due to “simple mode” behavior; discussion pointed back to the “simple mode for docs” rollout and included a userstyle workaround (read more).
development
  • Mobile/desktop mode behavior moved forward with an important cleanup: legacy mobile mode has been removed, referenced directly by commit link in the dev-news thread (read more).
#contribute:feature
  • A request proposed webhook/event support for Discourse AI artifacts (key-value updates), with Falco hinting this may align better once “Workflows” lands as a new automation approach (read more).
ux
  • A docs usability workaround was shared: when TOC/timeline seems missing in docs, scrolling down to “show N comments” can re-surface related UI—flagged as a likely side-effect worth checking (read more).
Marketplace
  • A moderation workflow need hit the Marketplace: a request for a moderator-friendly “recent replies” view (last X hours) beyond the review queue—seeking plugin/theme/Data Explorer approaches (read more).
#community-building:praise
  • A long-form success story celebrated a multi-site install and described replacing Trello workflows (and scaling moderation operations) using Discourse, while testing hardware limits and operational patterns (read more).
  • The MD Topic List Mobile component was checked against the viewport-switching changes; it still works on latest but now throws a deprecation warning about accessing site.mobileView / site.desktopView during initialization (read more).
#Integrations
  • A renewed discussion about embedding Discourse comments via JavaScript clarified “read-only” vs full commenting expectations; a newer guide thread for embedding as a full comment system was recommended as the next stop (read more).
  • martin introduced the plan to enable reactions by default and answered questions about prioritization and how reactions/likes/boosts might converge in the future (announcement, follow-up). Related background: the core Reactions feature thread (read more).
  • rishabh shipped a polish win for developers: PR status support inside GitHub oneboxes, linking the implementation PR directly from the announcement thread (read more).
  • david noted a platform simplification: legacy mobile mode removal as part of improving automatic switching between mobile/desktop modes (read more).
  • markvanlan drove two separate nested-replies bugfix efforts: proposing an incompatibility guard for post-voting when nesting is enabled and sharing the PR, plus posting the fix PR for broken nested-topic links from “suggested topics” (post voting + nested replies, PR link, suggested topics fix).
  • zogstrip continued a strong run of bugfix PRs: addressing approval button edge cases (read more), fixing a “users for approval but none found” notification issue (read more), and confirming an upcoming fix for topic voting voter visibility on closed topics (read more).
  • awesomerobot applied a fix for the infinite scroll loadMore error in the user card directory plugin and asked reporters to confirm after updating (read more).
  • Bas clarified confusion around billing/pageview-based reporting and migration status, offering a path for customers who want to switch over (read more).
  • lindsey pointed out that the “me too” label is configurable via Site Text (shared_issue), helping admins adjust terminology to match their communities (read more).
  • Falco responded across multiple threads: aligning AI artifact webhooks with future Workflows/Automation direction (read more), linking an alternative PR in the nested replies + post voting investigation (read more), and steering an embedding discussion toward the “full comment system” approach and API alternatives (read more, plus the recommended guide: read more).
  • supermathie added a practical troubleshooting step for outbound email failures: run rake emails:test, pointing to the canonical “troubleshoot email” how-to (read more, background guide: read more).
Yesterday’s energy in one line: between curly quotes breaking YAML, PIDs hitting limits, and reactions getting switched on for everyone, Meta managed to be both a debugging clinic and a celebration of tiny-but-mighty UX wins.
Key Stats
  • New posts (last 24h): 69
  • New topics (last 24h): 5
Top users (posts / likes received in the last 24h):
User Posts Likes
Lilly 7 3
jdc20181 6 6
NateDhaliwal 6 2
sam 3 3
pmusaraj 3 2
david 2 9
chapoi 2 1
renato 1 5
RGJ 1 4
martin 1 3
Danielle 1 2
A quick “where the action was” sampling (for source/reference): discussions ranged from admin/security UX in email edit controls, to localization quirks in the composer typographer, to self-hosting setup blockers like Discourse ID registration, plus ongoing threads on nested replies vs post voting, Reactions default enablement, and a doc update on pinning versions via d-compat branches.
If you only have five minutes today, scan the “Interesting Topics” section and then peek at the team roundup for official guidance and next steps.
Interesting Topics
#contribute:feature
  • jdc20181 proposed adding finer-grained controls so admins can edit user emails even when “Edit email after signup” is disabled—while Lilly argued the current friction is a security feature, eventually converging on the idea of a sudo/2FA/password-confirm style guardrail for high-risk actions (read more, plus the evolving security angle in this reply).
  • In Discourse AI, sam supported the idea of server-side webhooks for AI artifact key-value updates, ideally scoped to an artifact id—positioning it as both automation-enabling and a showcase for artifacts as a storage primitive (read more).
  • A follow-up on category-scoped translation landed: after a technical change, Discourse now defaults to translating broadly, and admins should use ai_translation_excluded_categories to exclude categories; pmusaraj asked folks to report any migration issues (read more).
  • The long-running request to use translated posts when emailing users remains on the roadmap; pmusaraj asked for clarification/screenshots around “custom remarks,” and confirmed there’s no timeline yet (read more, and the roadmap note in this post).
bug
  • A French-language report showed the composer “replacing special characters” (e.g., j'ai becoming j>ai): renato identified this as markdown typographer behavior and pointed to adjusting markdown_typographer_quotation_marks or disabling enable_markdown_typographer as immediate mitigation (read more, with confirmation in this follow-up).
  • In the intersection of post-voting and nested-replies, markvanlan decided to disable post voting for nested replies for now, with a future-looking suggestion to build a more native “vote” feature directly into nested replies (read more).
Support
  • For “Middleware document tree depth exceeded,” sam noted Falco had already written a guard and that the fix requires three commits, meaning upgrading to the latest release (or waiting for the next monthly) (read more).
  • A self-hosting setup went sideways when local logins were disabled and SMTP settings broke the rebuild; Lilly diagnosed an incorrect app.yml and walked through droplet sizing, swap, and quoting pitfalls, while NateDhaliwal highlighted “smart quotes” breaking config and suggested alternative SMTP ports/hosts (read more and the quoting callout in this reply).
  • Discourse on UXP-browser forks (e.g., Pale Moon): Lilly pointed to Discourse’s supported browser baseline, NateDhaliwal suggested the “dumbcourse” UI plugin as a workaround, and david recommended checking the dev console for the failing JS/CSS feature detections (read more, workaround pointer here, and debugging tip here).
  • A new question asked how to keep registrations disabled while still allowing private-group invite links for existing users—especially in an SSO-paid-access context (read more).
#Self-Hosting
  • A fresh install hit “Failed to automatically register with Discourse ID” due to a redirect URI HTTPS requirement; the thread quickly moved to checking /logs, enabling force_https, and using rake admin:create from inside the container as a recovery path (read more and the admin-create steps in this post).
  • On DiscourseAI sentiment/emotion, a request resurfaced for connecting sentiment analysis to other LLMs (with Gemini cited); Falco replied that support was added “yesterday” and should appear soon (read more and the update in this reply).
#Developer Guides / #Announcements / events
  • The “d-compat/*” versioning strategy doc was updated: david revised guidance for pinning plugin/theme versions for older Discourse installs, referencing the newer strategy work (read more, background: RFC topic).
  • On enabling Discourse Reactions by default, martin explained the historical reluctance to change defaults, and noted upcoming rollout improvements that make opt-out, low-risk default changes more practical (read more).
  • The “Community Retention” webinar thread got its promised relay + recap, posted by Danielle (read more).
  • david updated guidance on the new d-compat/* strategy in the version pinning doc (read more), and suggested using the browser dev console to identify failed feature-detections for UXP browsers (read more).
  • renato diagnosed the “apostrophe becomes >” composer issue as typographer replacement behavior, pointing admins to enable_markdown_typographer and quotation mark settings as immediate workarounds (read more).
  • sam provided fix guidance for “Middleware document tree depth exceeded,” noting required commits and release timing (read more), and endorsed adding server-side webhooks for AI artifact updates (read more).
  • martin expanded on operational philosophy and tooling behind flipping defaults, in the announcement about Reactions being enabled by default (read more).
  • Danielle posted the webinar recap for the Community Retention event (read more).
  • pmusaraj clarified the updated mechanics for category-scoped translation exclusions via ai_translation_excluded_categories (read more), and followed up on translated-email discussions by requesting more detail while confirming it remains on the roadmap (read more).
  • Falco replied that DiscourseAI sentiment support for additional LLM connections was added and should roll out soon (read more).
  • markvanlan decided to disable post voting in nested replies for now, suggesting a future built-in vote feature more native to nested UX (read more).
  • chapoi provided admin guidance for anonymizing/disconnecting users in the WordPress SSO context (read more), and suggested systematic extension/browsers checks for weird translated-text formatting reports on Debian/Linux (read more).
Sign-off: Yesterday’s energy was peak Meta: half the forum chased down why an apostrophe could turn into a > (read more), while the other half debated how to make “sudo-mode” admin actions safer and less painful (read more).
Key Stats
  • New posts (last 24h): 111
  • New topics (last 24h): 16
User Posts Likes
Lilly 17 26
abeen 13 12
merefield 7 12
chapoi 5 9
rishabh 1 8
system 1 8
haydenjames 2 7
Moin 5 7
darkpixlz 3 6
loic 1 6
Notable drops & updates
  • The May 2026 monthly release (v2026.05) shipped with a full changelog in the announcement thread — read more
  • The Current Projects newsletter landed, recapping recent plugin improvements and what’s next — read more
  • Discourse’s Discover May Roundup companion topic went live — read more
Interesting Topics
#Self-hosting
  • abeen asked for real-world guidance choosing Vultr vs DigitalOcean (with SMTP blocks and install gotchas becoming the real pain point), and got a mix of “host doesn’t matter—email does” and “avoid DO Marketplace installs” advice — read more (plus related install/email context in If local logins are disabled and the evergreen Troubleshoot email on a new Discourse install)
  • A self-hoster hit an upgrade snag where db:seed_fu fails on 002_groups.rb due to “Name has already been taken”, and shared a workaround by manually inserting the new system groups — read more
  • Discourse ID setup trouble was resolved after the admin enabled Discourse ID login in site settings, after initially working around onboarding via rake — read more
bug
  • “Phantom Unreads” struck again: /unread showed empty while the header counter claimed 14 unreads; the team confirmed the bug, and Lilly provided a Rails/SQL “mark all as read” workaround that cleared counts site-wide — read more (team acknowledgement: read more, workaround script: read more)
Support
  • Admins discovered a hidden setting controlling the impersonation time limit (experimental_impersonation_time_limit_minutes) and discussed how to change it via Rails console (and why it’s not visible in the UI) — read more (background: Using hidden site settings)
  • A high-scale integrator needed to create Chat channels via API; it turns out the endpoint exists (POST /chat/api/channels), and the thread now includes example parameters (notably chatable_id) — read more
  • A “Community Groups” landing-page request (show only specific groups like CoPs) was solved by pointing to the Landing Pages plugin approach — read more (plugin thread: read more)
  • Form Templates + tag groups: a tag-chooser dropdown populated but wouldn’t allow selection; initial debugging focused on tag group restrictions matching the configured tag groups — read more
  • The Survey plugin docs claim min/max attributes, but a report says they aren’t enforced (and client-side values can be manipulated), raising questions about validation and implementation — read more
  • UX feedback: mobile users struggle to find “Sign Up” when only “Log In” is visible; the thread explores UI alternatives and points to a combined auth button component as a workaround — read more (related component: read more)
  • A site owner asked whether there’s a setting to default linked-post previews (expanded vs collapsed) when linking to other posts/topics — read more (related older discussion: read more)
#contribute:feature
  • The request to let admins always edit user emails even when “Edit email after signup” is disabled continued, with discussion of security/social engineering tradeoffs and the need for more granular admin permissions — read more
  • Long-running topic-timers request: category-level auto-delete (analogous to auto-close) got a forward-looking nod that it should be cleanly solvable via Discourse Workflows — read more
#Announcements
  • A self-hoster reversed course and praised bundled (pre-installed) plugins, noting how enabling them without rebuilds is a real production win — read more
#community-building Building
  • Managing product announcements across many products and versions: the community brainstorm kicked off around tags vs categories, subscription strategy, and how to avoid notification fatigue as release cadence increases — read more
  • chapoi confirmed the team is actively working on the phantom unread counter bug — > “We are aware of this bug and trying to resolve it.” read more
  • chapoi unblocked an integrator by pointing to the Chat channel creation API endpoint, and followed up to encourage marking the solution — read more and read more
  • chapoi helped triage a Form Templates tag-chooser issue by validating whether the category’s tag-group restrictions included the referenced tag groups — read more
  • chapoi consolidated Horizon feedback by folding a “category badges are distracting” thread into the main Horizon Theme discussion to keep feedback centralized — read more
  • rishabh published Current Projects – May 2026, summarizing recently finished work and inviting questions — read more
  • loic posted the official May 2026 monthly release announcement and changelog pointer for v2026.5 — read more
  • sam noted that category-level auto-delete topics should be “solvable quite cleanly” with Discourse Workflows — read more
  • markvanlan reported that a version of an idea discussed in Testing Nested Replies on Meta was implemented — read more
  • manuel shipped improvements to the Announcement Bar theme component (localized strings, localStorage dismiss, responsive layout, BEM classes) — read more — and later clarified support expectations for Featured Topics feedback requests — read more
  • pmusaraj thanked a reporter for clarifying translation behavior in the “translated posts in emails” feature discussion — read more
  • Falco pointed a Gamification user to the official guide for integrating points with an external system — read more
Yesterday’s moral: keep your YAML tidy, your plugin toggles handy, and your Unread counter firmly grounded in reality.
Key Stats
In the last 24 hours (2026-05-28 → 2026-05-29), Meta saw 82 new posts and 12 new topics (with plenty of follow-up activity across ongoing threads like nested replies and admin UX tweaks read more).
Top users (posts • likes in the last 24h)
User Posts Likes
Lilly 11 8
merefield 6 10
chapoi 3 6
sam 2 25
awesomerobot 2 18
ted 2 7
Eviepayne 2 4
darkpixlz 2 4
zogstrip 2 3
david 1 26
Interesting Topics
#Announcements
  • david announced a major core dev milestone: a new JavaScript build system moving from ember-cli/webpack to rolldown (Rust bundler), with ~80% faster dev builds while staying backwards compatible for production installs: read more. This builds on the earlier direction toward precompiled assets for self-hosters (referenced here).
  • sam shared a change many admins have wanted: “small action” posts (close/open/assign/admin actions) are being excluded from Watched/Tracked lists to reduce notification noise, and it’s not optional: read more.
  • awesomerobot introduced an improved event creation flow in the calendar-and-events plugin: an interactive editor embedded in the composer (plus clearer RSVP/attendance settings): read more (plugin background: Discourse Calendar and Events).
  • Ongoing feedback continued on the docked composer for AI bot conversations, with requests to make “Enter to submit” optional and reports of image upload issues when using the new flow: read more.
bug
  • A tricky edge case was reported: incoming email handling can crash with Gmail dot-variant addresses (e.g. user.name@gmail.com vs username@gmail.com), hitting Validation failed: Primary email has already been taken when processing inbound mail or adding a secondary email: read more.
  • A regression/upgrade snag: db:seed_fu can fail if a site already has a user or group named anonymous, leading to a “Name has already been taken” validation error during upgrade: read more.
  • A UX/permissions mismatch in #reactions: if a post is hidden, the reaction counter can still render, but clicking it can cause an infinite loading loop due to a 403 from the reactions endpoint: read more.
  • A report noted email notifications don’t mirror the web UI’s “display name” preference: even with full names shown in-app, emails still show usernames when mentioning people: read more.
  • A support-facing warning appeared as a bug report from the field: Firefox users on Ubuntu saw “Unfortunately, your browser is unsupported” despite running a current version; debugging started with console checks and a related browser-support reference: read more.
ux
  • Creating a request-only group without an owner yields an unhelpful generic FAILED message; the thread also surfaced additional state/validation inconsistencies (private group + public request policy) and a fix direction toward better backend errors: read more (plus historical related behavior: “You cannot allow membership requests without any owners”).
  • The keyboard shortcuts modal had misaligned key hints after a redesign, and the fix was quickly identified as legacy margin/CSS fallout: read more.
Support
  • Form Templates customization came up again: a marketplace-style category needs structured “product card” post layouts, but Form Templates output is linear; discussion covered “closest out-of-the-box” options vs building a theme component (and noted that some existing options are topic-list oriented): read more (referenced: Topic List Thumbnails, Topic Cards).
  • Accessibility troubleshooting: a JAWS screen reader user’s shortcuts conflicted with Discourse shortcuts; guidance covered toggling JAWS virtual cursor mode and investigating where category/subcategory reading becomes unusable: read more.
  • Category visibility management resurfaced: “Exclude category from latest” discussions continued, including guidance on the difference between muted vs suppressed categories and plugin-based approaches: read more (related: “Suppress category from latest topics” discussion, and the recommended plugin: discourse-categories-suppressed).
  • A UI behavior question asked if local “linked post” oneboxes can default to expanded; the conclusion was basically “no setting,” and any workaround risks rebakes/formatting tradeoffs: read more.
#contribute:feature
  • Discussion continued on making “Sign Up” easier to find on mobile; follow-ups focused on whether the new link will be manageable/removable from the community section customization UI: read more.
  • A request to use translated posts in emails for users with a specific user-language setting saw progress, with a fix merged and linked from the feature thread: read more.
bug (nested replies ecosystem)
  • Nested replies kept drawing real-world rollout feedback (including breakage reports, theme incompatibilities, and testing workflows). Separately, a bug around suggested-topic links to nested topics was discussed, including redirect/404 behavior and clarifying unread-count semantics in nested view: read more and broader nested discussion: read more.
  • david laid out the roadmap and technical rationale for Discourse core’s new JS build system (rolldown, ES Modules, big dev speedups) and set expectations around backwards compatibility: read more.
  • sam announced the in-progress rollout to stop tracking/watching “small action” posts, aiming to reduce admin-notification noise: read more. sam also tied the “phantom unread” experience back to that rollout in a related bug thread: read more.
  • awesomerobot shipped a smoother create-event flow in the composer for the calendar-and-events plugin: read more. awesomerobot also advised on JAWS shortcut conflicts and asked clarifying questions to pinpoint the categories/subcategories UX issue: read more.
  • chapoi helped clarify post-layout customization limits and the likely need for a theme component (vs Form Templates alone): read more. chapoi also identified the keyboard-shortcut modal misalignment as legacy styling after a redesign: read more.
  • zogstrip reproduced and solved a Form Templates issue where mixed-case tag names prevented selecting a group tag, and linked the resulting fix: read more.
  • Danielle posted a status update that a webinar recap was available (closing the loop on the event thread): read more.
  • tannerabread confirmed that copy/paste and drag/drop into a composer inside a form template is now available on latest, and invited verification: read more.
  • markvanlan responded on nested reply link behavior, noting the link update and plans to improve redirects (avoiding flat-view 404s), and clarified how unread counts do/don’t map to nested structures: read more and read more.
  • southpaw clarified what Discourse-hosting “cluster backups” are (catastrophic recovery only), and what support can do instead for full backups including uploads: read more.
  • pmusaraj noted a fix was merged for sending emails using translated content for users with a configured user language: read more.
If yesterday taught us anything, it’s this: may your builds be 80% faster, your “small actions” stay blissfully silent, and your nested links always land somewhere that isn’t a 404.
