Estratti dall'elenco degli argomenti
:discourse2: Summary Topic List Excerpts allows you to enable excerpts for unpinned topics (by default, Discourse only displays topic excerpts for pinned topics).
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-topic-excerpts
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Works great alongside Topic List Thumbnails in “list” mode!
:information_source: The excerpts themselves are generated by Discourse Core, using the same logic as the excerpts of ‘pinned’ topics. If you have a query / suggestion about how the excerpts are built, please make a new Support topic.
:bulb: Tip: you can keep line breaks in excerpts by adding this CSS to your theme:
.topic-list .topic-excerpt {
    white-space: pre-line;
Be aware that results may look off depending on the posts’ contents.
Settings
Name Description
show excerpts mobile
show excerpts desktop
enabled categories Enable excerpts in specific categories. Leave both categories and tags blank to show excerpts on all routes
enabled tags Enable excerpts in specific tags. Leave both categories and tags blank to show excerpts on all routes.
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
47 Mi Piace
MD Topic List component
Best way to implement Excerpts in topic list?
Topic List Previews (legacy)
Topic preview text
MD Topic List Mobile component
Topic List Previews (TLP)
How to keep line breaks on excerpts?
Customizing your site with existing theme components
Expand new posts in topics in "Unread" and "New" to full summary
Topic Author
All links to categories broken?
Topic List Latest-Post Excerpt
Information about topic is not updated when using new & unread topics banner
Compact and AI Expanded
Displaying Views in Topic view (with no replies)
Google complaining about slow Interaction to Next Paint (INP) on Discourse sites
Discourse AI Topic Summary :robot:
Formatting breaks when Topic (List) Excerpts theme component used with RSS Polling plugin
Display first 5 lines of every post
Display post content in homepage
Is there a way to display topic contents in category view?
Using Discourse as a social media platform
How to disable topic excerpts in category page
Potential way to hide ignored users from topic list?
Discourse Topic List Author & Posters
Discourse Topic Excerpts & AI Gists Button
Display in the topics list in homepage also the body topic
Display replies and likes count in mobile view
Is there a plugin to make my forum a shop?
Why do excerpts include some HTML tags, but not others?
Latest activity list as for replies
How to add topic excerpt to all my topics
How to show part of the text under the topic head?
Static content on Category main page
Discourse Category Lockdown
How can I keep post views on lists
How to change the topic excerpt from the first post to the last post?
Discourse Docs
Great, a blog-like topic listing (together with Topic List Thumbnails Component)! :clap:
Can it be restricted by category like the other component?
7 Mi Piace
Sure, I just added a category setting:
13 Mi Piace
Thanks, much appreciated.
I also take the chance to report that there is some kind of incompatibility with the Topic Thumbnails component, since the images appear twice for each topic in the topic list (topic list option on thumbnails component + topic excerpts component).
2 Mi Piace
You’re right, sorry about that. Should be fixed now
9 Mi Piace
Love this component; thank you! Is there any way to adjust the word/character length of the excerpts displayed in topic lists? (Never mind, I found the topic excerpt maxlength site setting, adjusted it, and rebuilt HTML for the topic posts in question.)
4 Mi Piace
L’impostazione della categoria funziona, ma l’impostazione del tag non funziona sull’ultima versione di Discourse.
2 Mi Piace
@th21 la gestione dei tag dovrebbe essere ora risolta. Mi scuso per il ritardo!
3 Mi Piace
Un post è stato diviso in un nuovo argomento: Essere in grado di visualizzare estratti solo per alcune categorie su /latest
Un post è stato diviso in un nuovo argomento: Differenziare i contenuti dalle righe dell’elenco degli argomenti utilizzando colori diversi
Ciao, perché il “leggi di più” sul mio sito è grigio mentre sul tuo è blu? Come posso cambiare il colore?
1 Mi Piace
Ciao, puoi usare il CSS per personalizzare.
Ad esempio, usando il colore predefinito per i link. Tuttavia, puoi fornire il colore che desideri.
.topic-excerpt-more {
    color: var(--tertiary);
1 Mi Piace
Ciao, questo componente viene renderizzato sulla pagina del plugin di documentazione di Discourse e rende l’estratto cliccabile all’URL della discussione di Discourse, non all’URL del documento. C’è un modo per evitare che ciò accada?
Ciao, è possibile mostrare l’ultimo post invece del primo?
2 Mi Piace
Ho un plugin + componente tematico per questo: Topic List Latest-Post Excerpt
2 Mi Piace
C’è un problema con il componente del tema sul desktop?
quando lo attivo, mostra gli avatar così:
ho aggiornato il mio discourse oggi
MODIFICA: C’è un modo per limitare il numero di righe/caratteri per l’estratto?
2 Mi Piace
Sì, lo stesso qui
L’ultima volta è andato tutto bene quando ero disconnesso, ma altre rotte quando blocchi della barra laterale destra di discourse sono abilitati succede questo
Il pulsante di attivazione/disattivazione dell’estratto non è visibile sui dispositivi mobili. Per design, un incidente o sto chiedendo troppo presto?
Lo adoro! C’è un modo per bloccare gli estratti dai messaggi privati?
Ho provato questo componente e non mostra estratti nei messaggi personali. :thinking:
