Is there any way to set this to only show tags from one tag-group sitewide?
I have it on tags mode and only want it to create a list for some tags across the site and not others. Users will be able to use tags like normal and the only ones which will create a column in the tags board are the tag-group ‘manufacturers’.
For example,
- On my site the Kanban component is set to only create Kanban columns on all boards for the tag-group ‘manufacturers’.
- If a user creates a thread and enters these tags: Honda, Convertible, Frank, Paris. The only tag which would create its own list in the board is ‘Honda’.
I get the impression this is already possible using the params in ‘default mode’ setting, but i tried for hours and cant work it out.
