יצירה והגדרה של שדות משתמש מותאמים אישית
:bookmark: This guide explains how to create and configure custom user fields in Discourse, including how to add them to the signup form, user profiles, and user directory.
:person_raising_hand: Required user level: Administrator
Custom user fields allow you to collect additional information from your users beyond the standard profile fields. These fields can be displayed on user cards, user summary pages, and even retrieved using the Data Explorer plugin. This guide will walk you through the process of creating and configuring custom user fields.
Adding a user field
  1. Go to Admin > Community > User Fields (discourse.example.com/admin/config/user-fields).
  2. If you haven’t created any user fields yet, you’ll see this screen:
  3. Click the “Add user field” button to add a new field.
Choosing a field type
The field type determines the input field users will see on the signup form. Choose based on the kind of information you’re collecting:
Text field
  • Use for short questions with many possible answers (e.g., “What company do you work for?”)
  • Displays as a single-line HTML text input
Textarea
  • Use for questions that may require longer, multi-line answers (e.g., “Tell us about yourself”)
  • Displays as a multi-line HTML textarea input
Date
  • Use for collecting date values (e.g., “What is your date of birth?”)
  • Displays as a date picker input
Confirmation
Dropdown
To add options for a dropdown field:
  1. Click on the option input
  2. Type an answer and click “Create”
  3. Repeat for additional options
The completed options should look similar to this:
Multiselect
  • Use for questions where users can choose multiple answers from a set of options (e.g., “Which topics interest you?”)
  • Displays as a multi-select input
  • Options are configured the same way as dropdown fields
Setting the field name and description
  • Field Name: Appears before the input on the signup form and user profile
  • Field Description: Appears after the input to help users complete the field
:information_source: Both the field name and description are required to save a field.
Here’s how custom fields appear on the signup form:
Configuring user field options
Field Requirements
  • Optional - Optional fields may be left empty by users
  • For all users - When a field is required by all users, every account, including logged on users will be forced to fill it. This is very useful for cases such as a terms-of-service (ToS) requirement.
  • On signup - All new account will be required to fill the field.
Additionally, at the bottom of the creation form, you’ll find these preference checkboxes:
  • Editable after signup: Allows users to update the field from their profile page
  • Show on public profile: Displays the field value on the user’s summary page
  • Show on user card: Shows the field value on the user card
  • Searchable: Enables searching for users based on this field’s value in the user directory
  • Show on signup form: Controls whether the field appears on the signup form. This is automatically enabled (and cannot be disabled) when the field requirement is “For all users” or “On signup”, or when the field is not editable after signup.
When enabled, the field value will be shown on the user’s profile page:
Show on user card
When enabled, the field value will be displayed on the user card:
Searchable
When enabled, you can search for users based on their custom field values:
Saving and editing fields
  1. Click “Save” to add the field to your site’s list of user fields
  2. To edit a field, click the “Edit” button next to it in the list
  3. To delete a field, click the ellipsis menu (⋮) next to it and select “Delete”
Adding custom fields to the user directory
  1. Go to the user directory
  2. Click the wrench icon:
  1. Check the custom user fields you want to display
  2. Click “Save”
The selected custom fields will now appear in the user directory table:
Last checked by @hugh 2024-08-27T04:45:20Z
39 לייקים
Any Plugins/Easy Mods for an Extended User Profile
Add introductory text for sign-up
Setting Security Parameters: Log-In, Read-Only, Protected Groups
Theme-Component v Plugin: What's the difference
User preference on theme components
Private custom user fields...?
Users self-select Category on Registration... is it possible?
Can we implement a system for user remarks during registration for admin review?
User Field Prompt
New user reviews: admin assignment and logging of progress
User customizable theme components (how-to)
Add users to groups on signup
Announcing - Gender Pronouns Userfield on Meta
Add a custom per-user setting in a plugin
Welcome questions on the first screen for bio
How to add min or max values in custom fields?
Custom user fields not available in api
Grant Custom Badge Upon Reading ToS
Required vs. optional sign-up fields
Add users to groups through custom field automation
Terms of Service Checkbox
Hidden User Fields
Social Features
Where in Discourse can users publicly share PII?
Linking "static" information about member to topic posted
Using Discourse as a social media platform
Custom user post display
Disable account confirm emails when creating users via API
Links in additional fields
Clickable Social Icon Links on Profile
Extend Existing Controller?
Requiring acceptance of terms and conditions
"Fake" OAuth Provider?
This freaking software works so well I can’t even
Allow users to block keywords
Customize Your Site Branding
Restrict the users to post in the groups who haven't uploaded their profile picture
Adding non-visible user custom fields to the API
Seeking Advice: making a discourse forum hyper local
Add custom fields to signup and login
Can add short message to verify? Just input phone number can sign up
Add terms when make new topic
Export custom field for users in discourse hosted forum
Customizing Sign-up and Log in
Grouping poll results by user custom field
Disclaimer for tutorials
How to add custom logic input on the signup page?
Terms of service changes in Discourse platform
I think two images are missing under these headings:
Not sure if it’s related to Missing images at Meta.discourse.org – will post there too.
I can see those images? (also in an anon window)
לייק 1
I cannot see theose
But the second one works in my quote.
Edit
לייק 1
Interestingly I can see the second picture in the quote, but not in the original post^^
לייק 1
Hmm. That’s interesting. I think there is a fix coming for the Missing images at Meta.discourse.org issue, so hopefully it will be resolved by that. :crossed_fingers:
2 לייקים
Is there a setting I have to modify to specify the maximum length of a custom user field? Right now, in this “Test” field that I created as a test user field, I cannot enter even a single character on my user profile (or even “Test”, as shown).
I would love a field type: link / URL is that possible?
As URLs are text, the text field technically works, @Vaping_Community. However, you may be asking for additional details such as value validation or similar.
You might search or create a feature topic with what you have in mind. :slight_smile:
3 לייקים
Are there any plans to allow multiline/composer for custom user fields? :folded_hands:
Note that if you want to embed a link into one of the custom user fields, you need to use HTML syntax!
<a href="url">link text</a>
For example, to acknowledge community guidelines / policies:
לייק 1
האם אני יכול לקשר טענה מותאמת אישית מ-Auth0 SSO שלי לשדה מותאם אישית? כרגע המשתמש מזין מידע בשדה ב-Auth0, ואז צריך להזין אותו שוב בעת ההרשמה. הייתי רוצה שהערך ימופה אם אפשר.
It’s possible, yes:
Within your SSO endpoint, you have the capability to map the claim to the payload, e.g.:
const ssoPayload = {
  nonce: nonce,
  email: user.email,
  external_id: user.sub,
  username: user.nickname,
  add_groups: a_custom_group,
  'custom.user_field_1': user['https://yourdomain.com/company_id'],
  'custom.user_field_2':  [etc...]
3 לייקים
תודה @dax
האם יש דרך לאמת את שם השדה במסד הנתונים? לדוגמה, יש לנו שדה שם פרטי, ניסיתי custom.firstname, custom.first_name ו-custom.firstName, אף אחד מהם לא גרם למילוי השדות במסך ההרשמה.
בדקתי את יומני השגיאות כדי לוודא ששדות האסימון נכנסים כפי שמוצג לעיל.
digging more into the code here, is this only for a Discourse Connect SSO? We’re using the Auth0 plugin
The syntax needs to be custom.user_field_x, where x is the numeric field ID shown in /admin/config/user-fields/{x}/edit.
That mapping feature is not available in the Auth0 plugin directly.
That said, there are still options to achieve what you’re describing:
  • creating a theme component. You can add a small front-end script that automatically syncs a Discourse custom user field with a value already stored in Auth0. For example, when a user logs in and the field is empty, the script can call a secure endpoint (a small cloud function) that fetches the field value from Auth0 and updates the Discourse profile via API.
  • using automation tools. You could also use external automation services like Zapier or Make to perform that sync outside of Discourse. The advantage is that you don’t have to write/maintain code but only pay for the third-party service
  • custom development. We can extend the Auth0 plugin itself to natively support mapping custom claims into user fields on login, or build a custom plugin that works in pair with the Auth0 plugin.
A clear drawback of the theme component approach is that you’d need to write and maintain custom code yourself, while also being careful from a security standpoint to avoid introducing potential bugs or vulnerabilities. Honestly, it’s not a solution I’d recommend for a production site like yours.
If I were in your position, I’d lean more toward the second option, using third-party tools, or consider submitting a feature request or custom work request (depending on our project managers’ evaluation) to enhance the Auth0 plugin itself.
If you’re interested in exploring the last option, we can continue the discussion privately.
לייק 1
I’m wondering if there is a less fiddly way to reorganise a long list of user fields than single-clicking on the little arrows to move them up or down one step at a time…? :face_with_peeking_eye:
In the user field listing overview, I can’t see how to distinguish fields that are on the signup from and are compulsory (Je suis… Pays for example) and those that are on the signup form but optional (Mes attentes). Am I missing something or is this an oversight? It’s quite cumbersome to have to edit the field to see if it’s optional or not. (Not sure if this is the right place for this, wasn’t sure where to put it.)
Maybe the json which provides the data can be a little help. It’s not beautiful but you can look at /admin/config/user-fields.json and get something like
      "id": 18,
      "name": "Age",
      "description": "How old are you?",
      "field_type": "text",
      "editable": true,
      "required": false,
      "requirement": "optional",
      "show_on_profile": false,
      "show_on_user_card": false,
      "show_on_signup": false,
      "searchable": false,
      "position": 9
      "id": 17,
      "name": "pets",
      "description": "choose your favourite",
      "field_type": "dropdown",
      "editable": true,
      "required": false,
      "position": 10,
      "options": [
        "cat",
        "mouse",
        "dog"
But of course that’s not as beautiful as information in the interface
לייק 1
oh that is honestly much more easy for me to work with!
Does that mean I can just edit that file and be done with it? Does it exist somewhere as such on my server, and where do I find it? :heart_eyes::heart_eyes::heart_eyes:
