Plugin de Eventos 📅
:electric_plug: Summary Discourse Events allows you to add and manage events with Discourse.
:hammer_and_wrench: Repository Link https://github.com/angusmcleod/discourse-events
:open_book: Install Guide How to install plugins in Discourse
:people_hugging: Community Community based support and discussions about this plugin are hosted on the Angus’ support site.
Watch this video to get an overview of the plugin and what it can do.
When you’re ready to get started, the next steps are:
  1. Get a subscription and authorize your forum.
  2. Set up a Google, Outlook, iCalendar, or other integration.
  3. Do your first event import and sync.
106 curtidas
Please better document the Discourse Calendar plugin
Video chat / conferencing add-ons?
Are custom_fields on posts/topics available via the API?
2018: The Year in Review
Object instead of users due to locations plugin
Discourse Calendar - How to?
Timezone showing in title due to Events Plugin
Different themes per category?
Build secret text plugin
Default value of user profile timezone picker is misleading
Custom Discourse instance for a writers club
User Posts in a Topic
2020: The Year in Review
Summarize This Topic button
Volunteer Activities - a simple setup for non-hierarchical collaboration
MS Power automate and discourse
Theme component to use "Category icons" in "Events plugin" calendar
Calendar plugin features to make it really useful for us
Fig - Native Discourse client for iOS
2019: The Year in Review
Plugin to show upcoming events on hosted discourse
What are options for handling due dates / deadlines?
2023: The Year in Review
Add color to events based on event category or tag?
Topic List Previews (TLP)
Adding Groups as Invitee to a Calendar Event
Air Theme
Change Default Category Based On Conditions
Display old Events on the 'Upcoming Events' page
Discourse Calendar (and Event)
Error updating with broken events plugin
Will uninstalling a plugin leave any residual debris files in the database?
Post Preview not working because of events plugin
Generating an ical to use with a custom map
Go from a Wordpress + Discourse structure to a Discourse site only?
Category Calendar with defaultView="listNextYear" not showing events
Infinite scrolling is a total pain
502 Bad Gateway for only two Topics
Topic in a category make unreachable the category and user activity and the topic itself
Topic List Previews (legacy)
Calendar plugin should offer ical export and caldav
Can't edit post title, javascript errors
New Theme: Tag-Pages Navigation
What happens next?
Discourse-events 'this.router' error
A "Votes" option for the top menu in main page
Uploading images to user profile failing due to js error
Link to first unread post?
Events Integration Plugin (Beta)
Infinite loading since upgrade to 3.2
Customize hamburger menu to add switch what switches theme and applies predefiend filter
Discourse Mingle
Opening a reply window via URL
2022: The Year in Review
Hi, I’m wondering the time zone settings. Can I specify a time zone and let different users know the time for their own.
6 curtidas
The time is always displayed in whatever timezone is set in the user’s browser.
Times are stored as unix timestamps (i.e. UTC) and then converted into the user’s timezone in the client via moment.js.
You can see this in action by viewing any events topic, e.g. this topic, in two different timezones.
You can open a chrome window in a different timezone by creating the dir ~/chrome-profile then running
TZ='US/Pacific' open -na "Google Chrome" --args "--user-data-dir=$HOME/chrome-profile"
(See further)
8 curtidas
A post was merged into an existing topic: Locations Plugin
Looking pretty good. Is there a way to change the display from 24h to am/pm?
Also, I think users will expect to find some sort of popup calendar when they click on the calendar icon. Could you make the link in the date-time-container trigger a popup calendar (similar to a date picker) instead of a link to the topic page?
6 curtidas
Not currently, but I will add this as a setting this weekend.
I’m not sure which calendar icon you’re referring to here. Do you mean this label in the topic list?
3 curtidas
Yes, that’s the div I was talking about (thanks for the pic). I’m used to having a calendar pop up whenever I click on a link with that icon… Maybe its just me.
3 curtidas
In the logs such errors
/var/www/discourse/plugins/discourse-events/plugin.rb:67:in `block (3 levels) in activate!'
/var/www/discourse/lib/post_revisor.rb:335:in `block (2 levels) in update_topic'
/var/www/discourse/lib/post_revisor.rb:333:in `each'
/var/www/discourse/lib/post_revisor.rb:333:in `block in update_topic'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/database_statements.rb:211:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/transactions.rb:220:in `transaction'
/var/www/discourse/lib/post_revisor.rb:332:in `update_topic'
/var/www/discourse/lib/post_revisor.rb:242:in `revise'
/var/www/discourse/lib/post_revisor.rb:235:in `revise_and_create_new_version'
/var/www/discourse/lib/post_revisor.rb:204:in `revise_post'
/var/www/discourse/lib/post_revisor.rb:152:in `block in revise!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction'
/var/www/discourse/lib/post_revisor.rb:151:in `revise!'
/var/www/discourse/app/controllers/topics_controller.rb:239:in `update'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionview-4.2.9/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiling_methods.rb:76:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:74:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:43:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/route_set.rb:817:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:189:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/strategy.rb:167:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/omniauth-1.6.1/lib/omniauth/builder.rb:63:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/conditionalget.rb:38:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:149:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activerecord-4.2.9/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/logster-1.2.7/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/rack/logger.rb:38:in `call_app'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/rack/logger.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:17:in `call_with_quiet_assets'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-mini-profiler-0.10.5/lib/mini_profiler/profiler.rb:171:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/message_bus-2.0.5/lib/message_bus/rack/middleware.rb:63:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/railties-4.2.9/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:606:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:702:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/lib/unicorn/http_server.rb:142:in `start'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/unicorn-5.3.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `load'
/var/www/discourse/vendor/bundle/ruby/2.3.0/bin/unicorn:22:in `<main>'
3 curtidas
@11145 What was the last thing you did before this error occurred? Did you remove an event from a topic?
Also, the stack trace is missing the first line, e.g.
NoMethodError - undefined method `to_datetime' for nil:NilClass
Could you take another look at the log and see if there is anything else relevant?
3 curtidas
hm, I’m not sure it makes sense to stick a calendar in in that fashion. Perhaps a calendar as an entirely separate list, like the Locations Plugin replaces the topic list with a map. I have no plans to do that any time soon though.
But having different parts of the same row take the user to different UIs would not be good UX. It would also be unexpected given the way topic list rows work in all other topic lists.
The association of that icon with linking to a calendar is a separate issue though. I think there should be an icon there, as without one it may not be immediately obvious what the numbers refer to. Can you think of a better icon to use there?
6 curtidas
Perhaps the icon could be omitted if you had something like:
Sep 12th (2-4:30pm)
Else maybe:
fa-calendar-check-o
5 curtidas
a new error has appeared
Geocoder::LookupTimeout (Geocoder::LookupTimeout)
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:288:in `rescue in make_api_request’
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:288:in `rescue in make_api_request'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:274:in `make_api_request'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:226:in `fetch_raw_data'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:177:in `fetch_data'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/nominatim.rb:24:in `results'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/lookups/base.rb:47:in `search'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder/query.rb:11:in `execute'
/var/www/discourse/plugins/discourse-locations/gems/2.3.4/gems/geocoder-1.4.4/lib/geocoder.rb:22:in `search'
/var/www/discourse/plugins/discourse-locations/lib/geocode.rb:24:in `perform'
/var/www/discourse/plugins/discourse-locations/controllers/geocode.rb:11:in `search'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/actionpack-4.2.9/lib/action_dispatch/routing/mapper.rb:51:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.3.0/gems/rack-1.6.8/lib/rack/conditionalget.rb:25:in `call'
4 curtidas
Thanks, but that looks like an error for the locations plugin, not this plugin. Could you re-post in that topic? I’ll take a look at that in a bit.
Could you take a look at my follow up for your previous post? Cheers
I think I’ve fixed it, but I want to be sure.
5 curtidas
I will add formatting for event labels to allow for this kind of format, however as the current format will still be an option (and other formats), I think it makes sense to have an icon.
28 PM
hm, I think the tick is a little confusing as it doesn’t connote anything in this context.
fa-calendar-o is possible
51 PM
This is what it looks like in context.
19 PM
vs fa-calendar:
43 PM
5 curtidas
You know what, I’ll just make the icon an optional setting when I add different datetime formats. :slight_smile:
I’ll be doing this over the weekend.
5 curtidas
I just pushed three new settings:
  • events_event_label_icon: Allows you to set the class of the event label icon
  • events_event_label_format: Allows you to set the moment.js format of the datetime in the event label.
  • events_event_label_short_format: Allows you to set the moment.js format of the datetime in the short event label in the topic list
Example:
29 PM
7 curtidas
Hi @angus
We just had this installed (running 1.8.7 - is this release supported as we always run on stable?)
Once I add a new topic and assign date/time to it - the topic does not render:
https://talk.manvfat.com/t/test-event/26291/1
Error: Compile Error: d-icon is not a helper
    at t.compile (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:17:11815)
    at t.compile (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:17:498)
    at t.e.compileStatement (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:15:31968)
    at t.compile (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:16:230)
    at i.compile (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:14:11831)
    at e.invokeBlock (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:17:25987)
    at t.evaluate (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:15:28195)
    at e.execute (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:17:25771)
    at e.resume (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:17:25387)
    at t.handleException (https://talk.manvfat.com/assets/ember_jquery-b018f0ade967f79b21dc04fb709bf3ce41b791c8047282d68784382bbd80ba38.js:18:1364)
4 curtidas
you will need to be on tests-passed, {{d-icon}} helper has been introduced recently.
7 curtidas
Ah ok - am not going to be able to do that sadly as running on Communiteq (formerly DiscourseHosting).
Thanks anyway!
4 curtidas
On the Professional plan and up, we can put customers on tests-passed upon request.
The plugin is working now.
8 curtidas
