Discourse REST API Documentation
Discourse API
Please view the Discourse API Documentation site for detailed info:
https://docs.discourse.org
:information_source: Authentication
API requests must use HTTP header based authentication. Pass your Api-Key and Api-Username as HTTP headers. Authentication via query parameters or request body is not supported (this was removed in April 2020). Please see the example cURL request below.
The only API endpoints that continue to support credentials in query parameters are requests to RSS feeds, the Mail Receiver endpoint, and ICS routes.
The Content-Type can be set to “application/x-www-form-urlencoded”, “multipart/form-data” or “application/json”.
Here is an example POST request via cURL:
curl -X POST "http://127.0.0.1:3000/categories" \
-H "Content-Type: multipart/form-data;" \
-H "Api-Key: 714552c6148e1617aeab526d0606184b94a80ec048fc09894ff1a72b740c5f19" \
-H "Api-Username: discourse1" \
-F "name=89853c20-4409-e91a-a8ea-f6cdff96aaaa" \
-F "color=49d9e9" \
-F "text_color=f0fcfd"
Here is an example of what the API Documentation site looks like:
redoc
Consuming the API
You can consume the API using cURL commands, but we recommend using the discourse_api gem so that you can use Ruby.
Reverse engineering API endpoints
Not every endpoint is documented, but you can see an example API request and response for any endpoint by follow this guide:
Global rate limits and throttling in Discourse
Discourse ships with 3 different global rate limits that can be configured by site admins. For more details about these limits see:
Creating notifications via the API
User API keys specification
Last Reviewed by @sam on 2026-03-17T17:00:00Z
97 лайков
API: Can I authenticate without putting the key in the URL?
Online User API?
Deeply integrating Discourse into website
How can I update trust level via SSO site
Discourse Add Group API
Do we have any API or way to get latest post details for a particular Topic in discourse?
JSON API, get topics sorted by created_at
Update current user fields through JavaScript?
API call to watch categories and tags
Quick Messages Plugin
'BAD CSRF' while creating a new post
How to get uploaded image url using the Discourse API?
Discourse Trust Levels for Discord
Discourse API - Unable to query certain endpoints
How to update profile information via API
Get notifications via the API
Use discourse_post_id to get single topic data from API
Synchronizing Changes for SSO users
What determines the order of frequent poster icons in the topic list?
Working with different needs in raw/cooked content
What is Discourse Blog built with?
How to Create a Script to "Bulk Remove" from a Group?
Display username when login in banner
Possible for admins to create bookmarks for users?
RSS Feed Stopped Working?
Logout POST Request
Which CMS for Discourse
SSO_SYNC not found
WP Discourse plug in being odd
Drupal SSO generates incorrect user sessions
403 Error during multiple API calls
/admin/users/1/log_out route error
Delete user avatar by API
Acess-Control-Allow-Headers CORS Error with API after updating discourse
How do I send a topic id just created?
What is Discourse API?
Can Discourse API link with Obsidian?
Bot writer's tip: Processing every post
Access reports JSON data via Pipedream
Provide topic count via Discourse AI tool API `discourse.getUser` function
Help me troubleshoot my Discourse SSO
Bulk undelete topics
Best Practise for Using a Raspberry PI as Bot for Posting Updates in Discourse
Getting ["BAD CSRF"] when updating topic via API [python]
"BAD CSRF" when executing PUT using API, curl, and PHP
Getting a user's discourse subscriptions through api
Understanding pageviews and the site traffic report
Where should I put the API keys of discourse so that I can fetch the posts?
Getting an error while trying to fetch individual posts
Update mail-receiver to the release version
Migrate a Jive Clearspace forum to Discourse
Reverse engineer the Discourse API
Use the Discourse API ruby gem
Return only specific fields from the API GET response
Having issue accessing the Discourse APIs from react app
Best way to create external-facing API for creating topics?
User Status
Share your use cases of using Discourse REST API 🧑‍💻
How to do single sign-on with forum program?
How to make "toggle whisper" reply using API and POST request
How to get posts viewed by a user via APIs?
Creating alternate user directory
Can't create new group via api (/admin/groups.json - post method)
Is there an api to set the primary group for a user
All API calls now getting "You are not permitted to view the requested resource"
Finding a user by their identity provider 'external ID'
Issues with the /get-users ending point
"Api-Key" and "Api-Username" for try.discourse.org?
Missing anchor links in certain TOC topics?
Creating a new topic on behalf of a user
Shopify Integration
[Announce] Search & replace / batch process Discourse posts
API Error: You are not permitted to view the requested resource
Can an admin change a user's email address?
Can't send PM via API (HTTPUnprocessableEntity 422)
Swagger, WADL or similar for the REST API?
Vague error from clicking on a tag link on this site
Work Around to posting
Discourse dislike Api?
A list of server-side functions for weekend/novice Discourse developers?
Seeding a new forum by creating users and content
How to implement Discourse with an already built Rails project
Using the API, can't PUT to topic unless slug is on the URL
Incoming webhooks (Incoming into Discourse)
Managing site customization via API
Discourse API Documentation Using RAML
Is it possible to mount a playable video game into a discourse forum?
Interact with discourse from Python?
Is there is any open API for getting similar topic in discourse?
