Select Enable API and search for Google Cloud Translator API. Look for the enable button and click it to enable the API. Note that there is no free tier for the Google Translator API so it may prompt you to enable billing.
Once you’re done, click on credentials in the left menu
저는 과거에 잘 작동했던 자체 호스팅된 LibreTranslate를 사용 중인데, 최근 “Job exception: The translator service is currently not available”(작업 예외: 번역 서비스가 현재 사용 불가능합니다) 오류가 반복적으로 발생하고 있습니다. URL을 확인해 보았는데, 과거에는 정상적으로 작동했습니다. 해당 URL에 접근하면 LibreTranslate 웹 페이지가 정상적으로 표시됩니다. LibreTranslate 인스턴스가 인터넷 접근이 없는 비공개 환경이므로 API 토큰이 필요 없습니다.
백트레이스는 다음과 같습니다:
Message (548 copies reported)
Job exception: The translator service is currently not available.
Backtrace
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/libretranslate.rb:168:in `result'
/var/www/discourse/plugins/discourse-translator/services/discourse_translator/libretranslate.rb:85:in `detect'
/var/www/discourse/plugins/discourse-translator/plugin.rb:120:in `block in execute'
/var/www/discourse/lib/distributed_mutex.rb:53:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:49:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:34:in `synchronize'
/var/www/discourse/plugins/discourse-translator/plugin.rb:119:in `execute'
/var/www/discourse/app/jobs/base.rb:305:in `block (2 levels) in perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.0.0/lib/rails_multisite/connection_management.rb:21:in `with_connection'
/var/www/discourse/app/jobs/base.rb:292:in `block in perform'
/var/www/discourse/app/jobs/base.rb:288:in `each'
/var/www/discourse/app/jobs/base.rb:288:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:202:in `execute_job'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:170:in `block (2 levels) in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:177:in `block in invoke'
/var/www/discourse/lib/sidekiq/pausable.rb:132:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:179:in `block in invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/middleware/chain.rb:182:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:169:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:136:in `block (6 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:113:in `local'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:135:in `block (5 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq.rb:44:in `block in <module:Sidekiq>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:131:in `block (4 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:263:in `stats'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:126:in `block (3 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:13:in `call'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:125:in `block (2 levels) in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_retry.rb:80:in `global'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:124:in `block in dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/job_logger.rb:39:in `prepare'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:123:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:168:in `process'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:78:in `process_one'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/processor.rb:68:in `run'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:8:in `watchdog'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-6.5.12/lib/sidekiq/component.rb:17:in `block in safe_thread'
discourse-translator 플러그인을 설치할 때 이 오류가 발생했습니다. 제 discourse 버전은 3.5.0.beta1입니다.
I, [2025-04-24T01:33:20.510994 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
82: from /usr/local/bin/bundle:25:in `<main>'
81: from /usr/local/bin/bundle:25:in `load'
80: from /usr/local/lib/ruby/gems/3.3.0/gems/bundler-2.5.18/exe/bundle:20:in `<top (required)>'
10: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:87:in `with_execution_control'
9: from /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.2.2.1/lib/active_support/lazy_load_hooks.rb:94:in `block in execute_hook'
8: from /var/www/discourse/config/application.rb:249:in `block in <class:Application>'
7: from /var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
6: from /var/www/discourse/config/application.rb:249:in `block (2 levels) in <class:Application>'
5: from /var/www/discourse/config/application.rb:249:in `each'
4: from /var/www/discourse/lib/plugin/instance.rb:629:in `notify_after_initialize'
3: from /var/www/discourse/lib/plugin/instance.rb:629:in `each'
2: from /var/www/discourse/lib/plugin/instance.rb:631:in `block in notify_after_initialize'
1: from /var/www/discourse/plugins/discourse-translator/plugin.rb:40:in `block in activate!'
/var/www/discourse/plugins/discourse-translator/lib/discourse_translator/inline_translation.rb:86:in `inject': protected method `register_topic_preloader_associations' called for an instance of Plugin::Instance (NoMethodError)
