Admin guide to tags in Discourse
:bookmark: This guide explains how Discourse tags work, how to configure tag settings, and how to manage tags across your site.
:person_raising_hand: Required user level: Administrator
Managing tags in Discourse
Tags in Discourse provide a powerful way to organize and filter content beyond categories. This guide covers everything administrators need to know about configuring and managing tags.
Summary
  • Configure tag settings in your admin panel
  • Create, manage, and bulk modify tags
  • Set up automatic tagging
  • Use tag groups to organize related tags
Configuring tag settings
Tag settings can be found in your admin panel under the “Tags” area of your site settings.
Tagging is enabled by default. To disable tags, uncheck the tagging_enabled setting.
Key tag settings include:
  • Maximum tags per topic (max_tags_per_topic)
  • Maximum tag length (max_tag_length)
  • Groups allowed to create tags (create_tag_allowed_groups)
  • Groups allowed to tag topics (tag_topic_allowed_groups)
  • Groups allowed to edit tags (edit_tags_allowed_groups)
  • Maximum tag search results (max_tag_search_results)
  • Tag sorting options (tags_sort_alphabetically)
Creating and applying tags
Tags are created upon first usage. When composing or editing a topic, a user with tag creation privileges will see a tag chooser next to the category chooser.
create_tag
Tags can also be adjusted when quick editing a topic title:
tag-edit
:information_source: Categories, depending on their settings, can optionally limit which tags may be applied to topics in that category.
Filtering topics by tags
You can find the full list of tags on the /tags page on your site, along with a count of how often each tag has been used. Selecting a tag will present a list of topics that have had the tag applied.
:information_source: To filter topics by more than one tag at the same time, use the following URL syntax:
https://discourse.example.com/tags/intersection/TAG1/TAG2
Managing individual tags
To manage a specific tag:
  1. Go to the /tags page on your site
  2. Select the tag you would like to manage
  3. Click the wrench icon and choose “Edit tag”.
  4. From the “Edit tag” page, you can update the tag’s name, slug, description, and synonyms, then click “Save tag”.
Bulk managing tags
To modify tags across multiple topics at once:
  1. Visit any topic list filtered by tag
  2. Press the list icon bulk-select button at the top left of the topic list
  3. Manually select topics or use the “Select All” option
  4. Use the wrench icon admin button that appears at the top-right of the topic list to open the Bulk Actions modal
  5. Choose from three tag options:
    • Replace Tags - replace all existing tags with new ones
    • Append Tags - add new tags while keeping existing tags
    • Remove Tags - remove all existing tags
Advanced tag administration
Go to the /tags page and look for the tag admin button in the upper-right corner, or navigate directly to /tag_groups:
From here you can:
  • Manage tag groups
  • Upload tags in bulk
  • Delete unused tags
Auto-tagging topics with watched words
The watched words feature can automatically tag topics based on specified words appearing in the content.
To set this up:
  1. Navigate to /admin/customize/watched_words/action/tag
  2. Add words or phrases that should trigger specific tags
:warning: This feature will not apply tags retroactively to existing topics.
Important considerations
  • Tags apply to topics, not to individual posts within topics
  • When users type something like #tagname in a post, they are creating a link to that tag, not applying the tag to their post
  • Tag groups can be used to restrict which groups of users can use specific tags
Related Topics
36개의 좋아요
Nesting categories in three levels
How to enable tags?
Is it possible to make tags mandatory?
Set up structured tagging with tag groups and category tag restrictions
Sub categories and tags
URL syntax for multiple tags within a category
Please create a subcategory for badges
User-defined keyword for each thread
Help with Tags that can only be created by the Moderators but used by everyone
How to display categories by alphabet on sidebar and how to display tags on sidebar?
Better navigation for (structured) tags
Renaming Tag to Existing Tag Should Merge
Discourse Tag Cloud
Moving from sub-categories to tags?
Share topic between multiple categories
I Need a category link to take me to a tags page
How to create leftsidebar tags section ? based on attachment
Ability to delete tags with < N topics
How to delete a single tag?
Can't add tags to category anymore
Tag upload with special characters via CSV is failing
Mandatory tagging for topics (either existing tags or user creates a new tag)
Allow non-admins to see tag usages for categories they have access to
Add a sub-category to a sub-category
Deleting multiple users in bulk
Discourse Tag Cloud
Tags are not working due to multilingual plugin
Search / Watching for Tags only populates Topics with the tag, not replies
The best way to answer customers?
Tag synonyms are fabulous
Create a category in Discourse
Use discourse information and basic calculations in custom css?
Special category label doesn't show up
My Wiki of useful Meta (and other) links
Not Able To Post New Topic Using Tags - Error
Questions about editor, style guide and tags
Could I create link to filter multi tags in private message?
3 posts were split to a new topic: How do I allow someone to create tags?
제가 원하는 것은 카테고리 간에 사용될 수 있고, 해당 태그가 선택 항목으로 설정되어 있지 않은 토픽 하위의 답변(리플)에도 추가할 수 있는 태그입니다.
토픽 헤더에 해당 태그가 선택 태그로 설정되어 있지 않은 토픽 하위의 답변에서 태그를 활용할 수 있는 방법이 있을까요?
즉, 저는 Phoenix를 선택 태그로 설정한 토픽을 하나 만들었고, 이 태그를 만든 것이 바로 그 토픽입니다.
Phoenix 태그가 다른 카테고리의 다른 토픽에서도 #Phoenix 형태로 사용할 수 있기를 원합니다. 또한 답변 내부의 태그를 클릭하면 해당 태그(#phoenix)가 포함된 모든 다른 답변과 게시물이 결과로 표시되기를 원합니다. 모든 토픽 헤더에 태그를 넣지 않아도 되는 방식이어야 합니다. (#issue, #Problem-Solved 등)에 대해서도 동일한 방식으로 작동하기를 바랍니다.
아래는 헤더에 태그를 만든 토픽입니다.
아래는 Phoenix로 태그를 붙인 몇몇 게시물/답변입니다. 이 태그의 결과물에 이 게시물들이 포함될 것으로 기대했지만, 실제로는 Phoenix를 선택 태그로 추가한 토픽만 표시됩니다.
Phoenix 태그가 포함된 다른 토픽의 답변 중 하나에서 태그를 클릭했을 때의 결과입니다. Phoenix 태그가 포함된 모든 게시물(토픽이든 답변이든)이 이 목록에 표시되어야 한다고 기대하지만, Phoenix를 선택 태그로 설정한 토픽 헤더에 Phoenix가 포함된 게시물만 표시됩니다.
사이트에서 Phoenix라는 단어로 검색했을 때의 결과입니다.
Support Contribute > Bug
1개의 좋아요
Have you read this post
2개의 좋아요
태그는 주제에 사용하는 것이지, 게시물에 사용하는 것이 아닙니다. 게시물에도 태그를 달 수 있으면 좋겠지만, 그렇게 하면 정말 빠르게 엉망이 될 수 있습니다. 또한 관리 부담도 크게 증가합니다.
tags 같은 형식으로 사용하시는 경우, 태그를 달기보다는 해당 태그에 링크를 거는 것입니다. Contribute > Feature 같은 카테고리의 경우에도 동일하게, 재분류가 되는 것이 아니라 링크를 거는 것입니다.
3개의 좋아요
thanks for the link. I will check it out and see if this will solve our issue.
Cheers!
1개의 좋아요
To me the labels on the Tag Group restrictions are not really clear.
What means can only ve used by a certain group? Does using means adding removing or also clicking on them to get the list of tagged topics. If that is possible than maybe replacing “used” with “edited” or explicitly “added/removed” would be helpful
1개의 좋아요
For the Automatically tag topics if the first post contains a specific word; is it somehow possible to set some words to only check the Title?
If not, could this functionality be added?
1개의 좋아요
업데이트: /tag_groups로 이동하여 해당 페이지를 찾았지만, 오른쪽 상단이 보이지 않는 이유는 알지 못합니다.
안녕하세요
저는 Discourse 버전 (3.6.0.beta2-latest)을 사용 중이며 관리자 계정도 가지고 있지만, 아래에서 언급된 태그 그룹 관리 페이지를 여전히 찾을 수 없습니다:
태그 그룹 관리 페이지로 바로 이동할 수 있는 링크는 무엇일까요?
감사합니다!
/tag_groups입니다.
포럼을 업데이트하는 것이 좋습니다. 메뉴가 표시되지 않는 버그가 수정되었습니다:
2개의 좋아요
고맙습니다 @Moin! 항상 많이 도움 주시네요… :slight_smile:
어떤 이유인지 모르겠지만, 관리자 사이트 설정의 탭 섹션에 tagging_enabled 옵션이 보이지 않습니다. 이것이 발생할 수 있는 이유가 있을까요?
미리 감사합니다!
메타에 오신 것을 환영합니다 :wave:
추가 정보가 없기 때문에 추측만 할 수 있습니다. 포럼을 직접 호스팅하시나요, 아니면 관리형 호스팅을 사용하시나요? 그 이유 중 하나는 Discourse 호스팅의 #무료-플랜에 태그가 포함되지 않을 수 있다는 점입니다.
