Custom Header Links
:discourse2: Summary Custom Header Links allows you to easily add custom text-based links to the header.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link GitHub - discourse/discourse-custom-header-links · GitHub
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Desktop
Mobile
(due to very limited space, adding more than one link on mobile is not recommended)
Settings
Setting Description
custom_header_links The structured list of links to display in the header. Each link is configured through a form with individual fields (see below).
links_position Controls whether links appear on the right (default) or left side of the header near the logo. When set to left, all links are automatically hidden on topic pages to make room for the topic title — regardless of individual link hide_on_scroll settings.
Adding Links
Links are configured through a structured form in the theme component settings. Click Add to add a new link. Each link has the following fields:
Field Required Description
Text :white_check_mark: Yes The visible label for the link. Max 100 characters. Also determines the CSS class applied to the link (see CSS Customisation below).
Title :x: No The tooltip text shown when hovering over the link. Max 1000 characters.
URL :white_check_mark: Yes The URL the link points to. Can be a relative path (e.g. /faq) or a full URL. Max 2048 characters.
View :x: No Controls which device the link appears on. If left unset, the link shows on all devices (same as vdm). See values below.
Target :x: No Controls how the link opens. If left unset, defaults to opening in a new tab (same as blank). See values below.
Hide on scroll :x: No Controls whether the link hides when the topic title becomes visible in the header on topic pages. Defaults to keep. Only applies when links_position is set to right — see note below. See values below.
Locale :x: No If set, the link is only shown when the site’s page language matches this value. Leave blank to show the link on all locales. See details below.
View values:
Value Behaviour
vdm Visible on both desktop and mobile
vdo Visible on desktop only
vmo Visible on mobile only
(unset) Same as vdm — visible on all devices
Target values:
Value Behaviour
blank Opens in a new tab
self Opens in the same tab
(unset) Defaults to opening in a new tab (same as blank)
Hide on scroll values:
Value Behaviour
keep Link stays visible even when the topic title is shown in the header (default)
remove Link hides when the topic title becomes visible on topic pages
:information_source: hide_on_scroll only applies when links_position is right. When links_position is left, all links are hidden together on topic pages regardless of their individual hide_on_scroll setting.
Here’s an example of hide_on_scroll in action (with links_position set to right):
Most Liked and Privacy are set to keep, so they remain visible when the title expands. The other links are set to remove, so they hide when the title becomes visible. This behaviour only affects topic pages.
Locale Filtering
The Locale field allows you to show a link only when the site is set to a specific language. This is useful for multilingual communities that want different header links per language.
  • Set the field to a locale code such as en, de, fr, zh_CN, etc.
  • The match is case-insensitive, and both - and _ separators are treated identically — so en-US, en_US, and en_us all match equally.
  • If the locale field is left blank, the link shows on all locales. This is the recommended setting for most single-language sites.
  • A CSS class headerLink--{locale} is also added to the link element, which can be used for additional CSS targeting.
:warning: Common issue: If your links are not appearing, check whether you have accidentally set a locale value that does not match your site’s configured language. Leaving the locale field blank is safe and will always show the link.
CSS Customisation
Each link automatically receives a CSS class derived from its Text value: spaces are replaced with hyphens, the text is lowercased, and -custom-header-links is appended.
For example:
  • A link with text Privacy gets the class privacy-custom-header-links
  • A link with text Visit Shop gets the class visit-shop-custom-header-links
Style all header links:
.custom-header-links .headerLink a {
  font-size: var(--font-up-1);
  color: var(--header_primary);
Style a specific link (e.g. a link with text “Privacy”):
.custom-header-links .headerLink.privacy-custom-header-links a {
  color: var(--tertiary);
.custom-header-links .headerLink.privacy-custom-header-links a:hover {
  color: var(--tertiary-high);
Show or hide a link based on login state:
Discourse adds an anon class to the <html> tag for logged-out users. You can use this to conditionally show or hide links:
/* Hide "Dashboard" from logged-out users */
html.anon .dashboard-custom-header-links {
  display: none;
/* Hide "Sign Up" from logged-in users */
html:not(.anon) .sign-up-custom-header-links {
  display: none;
:warning: CSS display: none is a visual-only hiding mechanism. The link’s HTML is still present in the page source. Do not use this to protect sensitive or access-controlled URLs.
Reorder links with CSS (using flexbox order):
.custom-header-links li {
  &:nth-child(1) { order: 3; }
  &:nth-child(2) { order: 1; }
  &:nth-child(3) { order: 2; }
Use the /my path for user-specific links, to avoid hardcoding a username:
/my/messages     → the current user's inbox
/my/activity     → the current user's activity
:discourse2: Hosted by us? Theme components are available to use on our Pro, Business, and Enterprise plans.
Changelog highlights:
  • The custom_header_links setting was migrated from a comma-delimited list format to a structured type: objects form UI. If you previously configured links using the old comma-separated text input, the migration should have preserved your data automatically
Last checked by @MarkDoerr 2026-03-23T22:39:09Z
84 лайка
How can I add custom hamburger menu
Header Submenus
Display StatusPage status on as a header link
Control CSS based on user's logged in state
Add secondary url / embed into Wordpress
"An empty string is not a valid JSON string" when updating theme component #2
Showing categories statically above most recent posts
How to add a button to the header area?
Looking for a freelancer to implement a custom Discourse theme (based on an existing mockup)
Add a global header between Discourse & Website
How to make custom setting type
Is it possible to have users' job titles next to their names on posts?
Link to find all deleted posts by all users in a particular period
Dropdown links in existing Header
Insert Link to External Website
Is anyone here using their Discourse instance as their entire website?
How to fire on every footer load (or page load?)
Custom links above header bar
Custom Header Links (icons)
Pre seeded posts all missing - Missing Terms of Service, FAQ and Privacy pages
Dropdown header links in the existing Header
Add a "curated personal learning" page for users
Redirect search icon to search page
Possible to change main logo URL?
2021: The Year in Review
How to add breadcrumb?
How to add contact us page?
Navigation bar above all post
Adding link to blog on main page
Customizing your site with existing theme components
Show "new topic" when not logged in
How can I add a new button to the topbar?
⬇️ Dropdown Header
How to fix logo size?
Links into the header block
Customize the header with links, icons, or menus
Privacy Policy does't meet Google's requirements
Custom Header Links and New Topic Header Button don't play nice
Customize Your Site Branding
Nextcloud support
How to override the site-header.hbs file from custom theme?
Sidebar link / top button to PM admin
Toolbar under site header per category
Link buttons on the top disappear when scrolling around the site
Disclaimer section on the "about" page
What Themes are being used for these Discourse forums?
Alternative component (plugin?) to categories navbar
Add button in header for logged in users
Use decorateWidget to add text link to header
[PAID] Expert Wanted for Forum Redesign
Add social media handles on home page
Create hyperlink from home logo
Configure a custom sidebar link to open in a new tab
2023: The Year in Review
Modifying Header
Visiting /admin/upgrade may lead to a server error
Header Submenus
How do I go about making a very customized theme?
How to Integrate a Custom Plugin in discourse UI
Embedding a whole Discourse forum on another site in an <iframe>
Custom website header with forum
Brave default Theme
Why does the logo navigate to Discourse home not main site home
Structuring a multilingual community
How to make sidebar sticky?
Forum navbar is repeating
Adding my Nav into the header bar
Adding a header link for Guests Only
Allow non-members to pm the administrator
Best place(s) to link back to a non-forum homepage?
Memberstack + Webflow + Discourse OpenID Connect
External header links are not opening in a new tab
How can I add a button to the header?
Fully Theme
Link on Top header to Go to Home page of main site
How to finely scroll out custom header?
Can I add a icon and link back to my homesite at the top bar
Custom Header links was automatically hide when scrolling topic page contents
Link behavior inconsistent
Upcoming Header Changes - Preparing Themes and Plugins
How to add a "button" which composes a pre-filled topic
Where to place project external URL?
Change destination of logo link
How to split the forum into two main parts (general/groups) and how to display only subcategories I can create a new post in?
Не знаю, предлагалось ли это ранее; я попытался поискать, но не нашёл.
Думал, что, возможно, стоит добавить возможность создания «подссылок», чтобы реализовать идею списка, который можно редактировать (цвет текста, фон при наведении и т.д.), и получать результаты, похожие на то, что есть в Zoom.
8 лайков
Ссылки, у которых справа есть стрелка, например ‘developer’, означают, что у них есть «вложенные ссылки».
1 лайк
Можно ли добавить простое выпадающее меню к любому элементу?
Мне не удалось создать выпадающее меню с помощью «Custom header links». Похоже, это сделал Zoom. Я изучил их выпадающее меню через консоль, но не смог понять, как они вмешиваются в HTML этого компонента для добавления выпадающего меню к любому элементу.
Есть ли способ добавить такое выпадающее меню к элементу? @Johani
<div id="dropdown">
  <a title="Zoom Developer Documentation" href="https://marketplace.zoom.us/docs" target="_blank">Developer</a>
  <span class="caret"></span>
  <div class="dropdown-content">
    <a title="Zoom API Docs" href="https://marketplace.zoom.us/docs/api-reference/introduction" target="_blank">API</a>
    <a title="Zoom SDK Docs" href="https://marketplace.zoom.us/docs/sdk/native-sdks/introduction" target="_blank">SDK</a>
    <a title="Zoom Developer Blog" href="https://medium.com/zoom-developer-blog" target="_blank">Blog</a>
    <a title="Zoom Developer Changelog" href="https://marketplace.zoom.us/docs/changelog" target="_blank">Changelog</a>
    <a title="Zoom Developer Survey" href="https://docs.google.com/forms/d/e/1FAIpQLSeJPLhNuxjtkxyyV276R8S_nYz99fpMbbS8VWkC8Hwi7-2Byg/viewform" target="_blank">Survey</a>
  </div>
</div>
5 лайков
У кого-нибудь возникали проблемы с тем, что ссылки не открываются при установке links position в значение “left”?
Ссылки работают в Preview, но не работают после применения к теме.
Ссылки, выровненные по правому краю, работают нормально.
1 лайк
Привет! Спасибо, что создали это.
Можно ли добавить SVG перед текстовой ссылкой? Если да, то как это сделать?
1 лайк
Вы нашли решение этой задачи? Я тоже ищу аналогичное решение.
6 лайков
Как заголовок может преобразовать **код форматирования** в реальное форматирование? А как насчёт иконок Font Awesome перед текстом?
2 лайка
Возможно ли добавить флаг для отображения или скрытия ссылок для определённых групп пользователей?
3 лайка
Можно ли настроить этот компонент темы для поддержки выпадающего меню? То есть, при наведении на ссылку в заголовке под ней должны появляться подпункты. Я знаю, что это можно реализовать с помощью HTML/CSS, как показано здесь:
2 лайка
Спасибо за создание этого компонента!
Один вопрос и, возможно, предложение по новой функции: можно ли отображать конкретную ссылку для конкретной группы?
Например, если пользователь входит в группу customers, я хочу показать ссылку на панель управления клиента; если пользователь в группе workers — добавить ссылку на другую панель.
Думаю, это была бы очень полезная функция.
Имя группы могло бы быть последним (опциональным) параметром.
2 лайка
Спасибо за это! Я только что нашёл его после того, как перепробовал различные другие баннеры и компоненты. Это именно то, что мне нужно!
Одна просьба/предложение: возможность изменять порядок ссылок. Я только что создал несколько ссылок и понял, что хотел бы добавить одну в начало. Теперь мне придётся вручную копировать и вставлять их все, что на самом деле довольно утомительно, так как при копировании вниз они постоянно синхронизируются/обновляют другие записи.
Функция перетаскивания или кнопки «вверх/вниз» были бы очень полезны для будущих пользователей (или для будущих правок).
4 лайка
Вы уже можете легко изменять порядок с помощью нескольких строк CSS, поскольку мы используем свойство flex.
Например:
  • Порядок по умолчанию
  • Пользовательский порядок
Пример CSS:
  &:nth-child(1) {
    order: 3;
    background: red;
  &:nth-child(2) {
    order: 1;
    background: green;
  &:nth-child(3) {
    order: 2;
    background: yellow;
5 лайков
@Nick_Chomey Я часто сталкивался с необходимостью делать это не только для этого компонента темы, но и для многих других компонентов темы, использующих настройку type: list. Я планировал ранее отправить запрос на добавление функции, но полностью забыл об этом. Однако, поскольку вы напомнили мне, я добавил его здесь:
3 лайка
@dax Спасибо! Я и не знал, что это возможно!
@keegan Выглядит отлично, надеюсь, это когда-нибудь добавят!
2 лайка
Я тоже ищу такое решение, вы уже выяснили, как они это сделали?
Спасибо!
1 лайк
Привет, @Johani!
Спасибо за создание такого крутого компонента!
Можно ли сделать ссылку видимой только для авторизованных пользователей?
Это будет внешняя ссылка.
1 лайк
Привет @andreas_can, добро пожаловать в Meta :wave:
Этот компонент добавляет CSS-класс к каждой ссылке на основе её текста. Добавляемый класс совпадает с текстом ссылки, за исключением того, что пробелы заменяются на дефис (-), а текст приводится к нижнему регистру. В конце строки добавляется суффикс -custom-header-links.
Например, если вы добавите ссылку с текстом
privacy
то элемент ссылки получит класс
Если текст вашей ссылки
Visit Shop
то CSS-класс будет
Итак, теперь вы знаете, какой класс добавляется к каждой ссылке. Вернёмся к вашему вопросу.
Discourse добавляет CSS-класс к тегу <HTML>, когда пользователь не авторизован. Этот класс —
anon
Таким образом, вы можете использовать его, чтобы скрыть определённые ссылки для пользователей, не вошедших в систему. Допустим, у меня есть ссылка с текстом
Customer Support
и я не хочу, чтобы она отображалась пользователям, не авторизованным в системе.
В этом случае я добавлю следующий CSS
.anon {
  .customer-support-custom-header-links {
    display: none;
во вкладку common > CSS моей основной темы.
Это скроет указанную ссылку для пользователей, не авторизованных в системе.
11 лайков
Спасибо за такой быстрый и подробный ответ!
Это именно то, что я искал.
Попробую :slightly_smiling_face:
3 лайка
Обратите внимание, что CSS display: none; лишь скрывает ссылку от отображения в браузере, но она всегда полностью видна любому, кто просматривает исходный код страницы, веб-роботам и поисковым системам.
3 лайка
