DiscoTOC - índice automático
:discourse2: Summary DiscoTOC will allow you to generate an interactive table of contents for your topics with one click!
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/DiscoTOC
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Samples
Desktop
Mobile
Features
toc = table of contents
  • Automatically generates the entire toc via a button in the composer gear menu
  • The toc will always be on the screen - scrolls with content like the topic progress widget
  • As you scroll past sections in the topic, the active element in the table of contents will be set to active (blue highlight)
  • adds id attributes to headings (you can link to a specific section from another topic / post)
  • clicking on any link in the toc will instruct the browser to navigate to relevant section (smooth-scrolling)
  • adds a copy-able link next to each heading (if you want to link to it)
  • RTL support
  • The colors are based on your current active color palette
How does it work?
In a nutshell, it looks for headings in topics which are marked to have a toc (via the composer button) and if it turns out the current topic is marked, then it takes all the headings and puts them in the toc (nested in order of heading levels) - this means that your markdown must be syntactically correct.
# heading 1
## heading 2
### heading 3
#### heading 4
##### heading 5
###### heading 6
You’re free to go back and fourth in heading levels, but the order must be correct
# heading 2
## heading 3
## heading 3
### heading 4
## heading 3
# heading 2
etc...
In order for the links in the toc to work, headings must have id attributes. The component will check if the headings already have ids and if they do, then they are respected. This is handy if you ever manually created a toc.
If the headings don’t have ids, then it will generate an id for each heading based on its text (unwanted characters are stripped out)
once all of that is done, it will also add a link next to each button that links directly to that section:
Settings
Name Description
minimum trust level to create TOC The minimum trust level a user must have in order to see the TOC button in the composer
composer toc text Text that appears at the top of the preview pane of the composer to indicate the topic will have a table of contents
auto TOC categories Automatically enable TOC on topics in these categories
auto TOC tags Automatically enable TOC on topics with these tags
TOC min heading Minimum number of headings in a topic for the table of contents to be shown
Translations
Translation Default
table_of_contents table of contents
insert_table_of_contents Insert table of contents
jump_bottom Jump to end
toggle_toc.show_timeline Timeline
toggle_toc.show_toc Contents
The theme comes with three strings that you can translate or change.
table_of_contents: "table of contents"
this used for the button that opens the toc on mobile
insert_table_of_contents: "Insert table of contents"
this is used as the text for the toc button in the composer gear menu
topic_will_contain_a_table_of_contents: "This topic will contain a table of contents"
This is the text that shows up in the composer preview to indicate that the a toc will be generated for the topic
How do I create a toc?
  1. Write a topic with syntactically correct headings
  2. Click the toc button in the gear menu (only shows up when creating a regular topic - replies and PMs are ignored
  3. Profit.
What happens to the topic progress widget when a topic has a toc?
As you can probably guess, there’s no space to show both at the same time, so the way this component works is as follows
in a topic with a toc, the topic progress widget is hidden while the first post is on screen, and you see the toc instead.
Once you scroll past the first post, the toc will not scroll with you and the topic progress will be shown instead while you read any replies.
So, first posts get the toc, and subsequent posts get the regular topic progress widget.
The happens on both desktop and mobile.
Are there any downsides to using this component?
Nothing I am aware of, all the changes are done on the client-side. So you can easily remove the component and your posts would go back to the way they were before you installed it.
Limitations
This component assumes the standard topic layout. As such, it won’t work with themes that modify that layout such as the Vincent theme. Support for popular themes that modify the layout will come at a later stage in the form of component settings.
Credit
I started with Greg Franko’s tocify.js library. However, it looks like it’s not been updated in a while, so this is essentially a hard-fork that removes a lot of unnecessary features, integrates and styles the rest for Discourse.
So, there are no external requests and the total size is ~ 4kb gzip.
Big thanks to @erlend_sh for lots of valuable feedback and to @david for his help with translations.
:discourse2: Hosted by us? Theme components are available to use on our Pro, Business and Enterprise plans.
181 curtidas
Automatic Table of Contents generation
Creative Uses of Discourse
Wiki improvement – Split content into multiple sections?
Blog Post Styling
Linking to a heading within a post or topic
Understanding Discourse for new users
:cn: DiscoTOC 自动内容表格
How do you create a table of content like this one?
What are the different ways to customize content inside a post (custom attributes and such)
How to get topic navigation menu
Theme Components - Can Discourse hosted sites install them?
Big Header - Little Header
How can i show a floating sticky 300x250 Adsense Ad on right side bar of topic page above the fold?
Tagged topic progress bar - feasible or not?
Timeline with labelled step by step sections - how is this achieved?
Reader Mode
Is anyone working on a Discourse Wiki?
How To Add Marker To Table Of Contents Feature?
Traditional multi level hierarchy vs flat discourse hierarchy
How do I add a table of contents sidebar to a topic?
Cannot deep link to anchor in text
How can I compare arbitrary revisions of a post?
Problem with DiscoTOC: TypeError: _offsetCalculator.headerOffset is not a function
How to create an In-app Knowledge Base with Discourse Docs?
OP Contents on Progress Bar
How to get topic sidebar
Customizing your site with existing theme components
Link to headers (anchor links)
Outline Enable
What is essential content for a new community?
Tools for creating image-heavy articles
Adding DiscoTOC to Published Pages
Customize Your Site Branding
Discourse Doc Categories
Gif icon not displaying and showing error
Must have plugins and components for Discourse?
I created a bookmarklet to create the table of content for forum posts
Could a List of Recommended Topics Be Added to the Top Menu?
?page=n URLs have high CLS hence bad SEO
Something recently changed, can't increase `--topic-body-width`
How to enable side navigation?
Improve iPad screen real estate
Missing strings (DiscoTOC)
Missing anchor links in certain TOC topics?
DiscoTOC not showing in composer after latest component update
How to create a documentation theme used by discourse
Where's Jump to end?
Handling anchors in posts created with markdown
Reader Mode
Hidden Timeline button
Horizon Theme
Bulk Export of Raw Post Sources with Markup
:cn: Discourse Post Formatting Guide 加点格式,让帖子多姿多彩
Wiki table of contents on pro plan
Auto-Linkify Words
Collections
Living with corrupted SVGs for almost a year. Need Help!
Require users to "Reply as Linked Topic"
Links not working
Blog Post Styling
Using Posts as a Wiki?
DiscoTOC & Brand Header - using together
Docs: Add link to top menu
Layouts Plugin
More than two levels of [details]
Discourse Docs
Category page with fixed organization of topics
Blog Post Styling
Inlink the topics within the same article
Navigating to local URL fragment doesn't modify browser history
Relating to Profile Picture Scroll Functionality
Copy pasting nested lists from Word into a post
Need to include PGN (chess game notation) in a post
How can I get a table of contents for my docs?
Topic list on the right side
Set up Slack notifications using the discourse-chat-integration plugin
Wrong title in the history popup (firefox)
Possible to insert post in a topic
How to add table of content sidebar beside a topic?
4 posts foram divididos em um novo tópico: Como mover o TOC para o lado esquerdo da postagem?
Eu não sei como este componente é implementado ou muito sobre a estrutura frontend do Discourse, então só posso arriscar um palpite.
Será que a barra de progresso só poderia ser mostrada a) se houver mais de 1 post no tópico e b) ajustar seu início para ser a partir do 2º post (em vez do 3º), mas também c) adicionar uma margem inferior/superior confortável a um dos dois elementos para garantir que o outro permaneça distante o suficiente (ex: 1vh) para não ficar com uma aparência estranha?
Em outras palavras, em vez de usar o post inteiro como lacuna, use CSS para permitir algum espaço entre eles (se houver mais de 1 post).
Novamente, isso pode não fazer sentido algum, pois não sei muito sobre a forma como isso está funcionando no momento.
3 curtidas
Olá! Recentemente instalamos o DiscoTOC em nossos fóruns e estávamos nos perguntando se é possível fazer com que o componente leia o texto alternativo (alt text) em imagens? Usamos imagens para alguns cabeçalhos de notas de atualização…
assim:
Performance and Stability
E, infelizmente, o sistema TOC não parece conseguir analisar uma imagem como um cabeçalho, criando uma entrada em branco na lista e gerando um link que leva a uma página em branco. Existe alguma solução alternativa para isso além de “não usar imagens”? Obrigado! Adoramos o sistema de resto.
1 curtida
Minha suposição é que a solução é não usar imagens como títulos, mas talvez haja uma maneira de fazê-lo funcionar adicionando algum código ao seu site que se conecte ao código do DiscoTOC. Se vale a pena investigar isso ou não, dependerá de quão importante é para você usar imagens nos títulos das postagens.
3 curtidas
Temos usado imagens como cabeçalhos em nossas notas de atualização de forma consistente por um bom tempo, e isso faz parte da nossa marca e apresentação; não apenas nos fóruns, mas também no Steam e similares. Gostaríamos de ter a capacidade de continuar usando imagens como cabeçalhos ao usar o DiscoTOC para manter a consistência.
O DiscoTOC tem sido ótimo para outras coisas, como um resumo de AMA (Ask Me Anything), uma megapublicação sobre nosso aplicativo de inicialização de servidor dedicado, guias para novos jogadores, etc. Gostamos muito do sistema, mas adoraríamos um pouco de funcionalidade extra para a maneira como apresentamos as notas de atualização.
1 curtida
A funcionalidade de âncora de título neste componente conflita ligeiramente com a funcionalidade Automatic header links adicionada na 2.7.0beta6, já que os títulos recebem dois ícones ao passar o mouse, um do Discourse e outro do DiscoTOC. Existe uma maneira de contornar isso?
1 curtida
Olá,
Você pode ocultar a âncora Automatic header links com
.anchor {
  display: none;
Olá dodesz,
Eu deixei a largura da postagem muito maior que a padrão, e depois de instalar este componente, ela ficou com uma aparência estranha. Você poderia me dizer como corrigir este problema?
:heart: obrigado!
Selection_839
1 curtida
Em um fórum rodando Discourse 2.8.0.beta4 (90232af778), incluir o componente DiscoTOC leva a uma mensagem de erro:
oops
O componente havia sido ativado antes e também gerou um problema com a versão do Discourse instalada anteriormente, embora eu não possa dizer qual era essa versão.
Você consegue encontrar alguma mensagem de erro relacionada ao problema nos logs de erro do seu site?
Essa mensagem de erro é um erro de backend, enquanto o DiscoTOC é um componente de tema de front-end, então é difícil que estejam relacionados. Você tem algum plugin instalado?
1 curtida
Infelizmente, não consegui encontrar nada útil em /logs.
Eu tenho, aqui está o trecho relevante do app.yml:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-openid-connect.git
          - git clone https://github.com/discourse/discourse-checklist.git
          - git clone https://github.com/discourse/discourse-push-notifications.git
          - git clone https://github.com/discourse/discourse-characters-required.git
          - git clone https://github.com/angusmcleod/discourse-news.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/DNOeV/discourse-watch-category.git
          - git clone https://github.com/discourse/discourse-footnote.git
          - git clone https://github.com/discourse/discourse-knowledge-explorer.git
1 curtida
Quando um cabeçalho está dentro de uma citação, o cabeçalho não aparece no TOC (Tabela de Conteúdo). Esse comportamento poderia ser alterado?
Este cabeçalho não aparecerá no TOC
Conteúdo citado
Este cabeçalho APARECE no TOC
Conteúdo citado
Eu não sei como está planejado para funcionar, mas normalmente não, porque faz parte da citação, não um cabeçalho desse texto.
1 curtida
Você poderia tentar usar o <blockquote> do HTML em vez disso? Isso permitiria que o cabeçalho # ficasse no início de uma linha.
Exemplo:
<blockquote>
### Cabeçalho de Âncora
</blockquote>
Cabeçalho de Âncora
Eu não tentei em um TOC (Table of Contents - Índice), mas parece funcionar com os cabeçalhos com âncora automática em uma postagem normal.
Por que você quer que os cabeçalhos dentro de aspas apareçam no sumário? Qual é o seu caso de uso?
Obrigado pela ideia. Não funcionou para mim, no entanto.
Aqui está um exemplo de quando uso citações para estruturar visualmente o conteúdo que começa em Área de Problema: Idade
3 curtidas
Por que você está usando aspas dessa forma? Dizer a fonte é suficiente. Além disso, gramaticalmente isso está errado, inclusive em inglês.
Isto é um bug ou apenas mais um usuário, mas… como devo fechar o TOC? Eu estava procurando por instruções básicas sobre como um usuário final deve usar mensagens privadas e, claro, fui para a documentação de novos usuários e abri o TOC para ver se havia alguma informação.
Eu estava usando um iPad e o DiscourseHub.
Eu obtive isto:
kuva
O TOC está ótimo. Mas está sobrepondo o texto e eu não consegui suprimi-lo novamente. Então, o que diabos eu fiz de errado, ou não fiz nada :pleading_face:
