Einrichtung von Let's Encrypt mit mehreren Domains / Weiterleitungen
NOTE: @pfaffman says: This page needs to be cleaned up. There is now a new ENV setting that will let you add more hostnames. In your app.yml under your DISCOURSE_HOSTNAME line (it can go many places but that one makes sense), add
 DISCOURSE_HOSTNAME_ALIASES: domain.com,other.domain.com
and early reports suggest that you’ll get valid certs for those domains and that accessing https://domain.com will properly redirect you to your DISCOURSE_HOSTNAME without a certificate error.
If you do that and it works for you, you might add another “me too!” post to the bottom. If you feel comfortable, you could also edit this first post with the instructions that you think would be most helpful.
This is to address the problem where you get certificate errors with any redirects or CNAME DNS entries which point to your actual installed Discourse (sub)domain.
If you do not have https configured already (you do if you have done a standard install recently) see Setting up Let’s Encrypt as your first step.
Legacy Method
The method below no longer reliably works as of August 2025
There are three patterns that need to be replaced. Enter your (sub)domain (and any additional subdomains preceded by -d ) and then add the following to your app.yml hooks section (towards the end of the file):
2025-04-23 @pfaffman changed the code because there’s a 3rd place it needs to be changed
  after_ssl:
    - replace:
        filename: /etc/runit/1.d/letsencrypt
        to: "-d =domain1= -d =domain2= "
        global: true
This will allow you to have HTTPS configured for a second domain that will redirect to the correct one without certificate issues.
If you need to add multiple extra domains, you can enter something like this in the domain2 field: www.bananas.com -d forum.bananas.com
For example, if you want people who visit https://forum.example.com to be redirected to your forum at https://community.example.com without a certificate error, this is all you need.
47 „Gefällt mir“
Discourse + Let's Encrypt w/ multiple hostnames
Problem in installing Let's Encrypt SSL for www and non-www
Making 'www' work with Discourse
LetsEncrypt working without www, not with www
Full site CDN acceleration for Discourse
Two domains, conditional redirect
How to setup 301 redirect -non-www to www
Setup Let’s Encrypt + non-www > www
How to create 301 redirect to a new domain
(Superseded) Redirect additional domain(s) to your Discourse instance
Best way to add a 301 redirect
Setup discourse for the main site (www.example.com) not on a subdomain
Www.example.com OK, but example.com NOT
About force www to non www
Why is the Apple Touch Icon loaded via HTTP instead of HTTPS?
DNS Settings for Digital Ocean Droplet - Root Domain?
SSL working on root, but not on www
Facebook login was flagged as non compliant by Facebook after change to Let's Encrypt certificate system
After activating HTTPS Discourse doesn´t work
Letsencrypt issued on every build?
DO Storage and uploaded backups not showing
Non www to www without certificate error
Infinite 301 redirect with reverse proxy setup
How to add ssl to non-www domain?
Adding www. to Domain
Discourse droplet unreachable on 80,443 ports after installation on Ubuntu 20.04
Installation without subdomain not working
Forum went down, then certificate renew error regarding firewall configuration?
Discourse Failing to Work
Change server to a two-container setup
LetsEncrypt certificate not renewing
How to redirect http to https on digital ocean droplet?
Redirect old forum URLs to new Discourse URLs using permalinks
Forwarding from https:// to https://www
Workaround for the 1 week Let's Encrypt limit
DNS settings for www
Migrate discourse from main domain --> subdomain
Migrate a XenForo forum to Discourse
How can I update the nginx config directly in discourse/docker ..?
Let's Encrypt with sub-subdomain?
Problems building a new server
Multiple hostnames for a single site for cut-over phase
Help with URLs not working on Chrome
Issue after Rebuilding Discourse on Digital Ocean Droplet
Error on attempting to remap links
Unable to reinstall Discourse
Can't load site in Safari
Lets Encrypt Certificate - Issuing Problem
Www to non www with https
Discourse setup completed successfully but not working due to SSL error
SSL on new host
Install fails on fresh Debian 12 installation
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
SSL is not valid for www.domain.com
Trying to set up Discourse on my website
Changed email service, now the forum won't resolve via IP address nor URL
Bootstrap error during Discourse install: ENOENT - /etc/runit/1.d/letsencrypt
Discourse not accessible - SSL Issue
Correct DNS records to set when Discourse is hosted on WWW subdomain?
Invalid certificate name when using www
Multisite configuration with Docker
PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
Rebuild appears to work, but site is not loading properly
Issue with app.yml file update
New install on ionos ubuntu 22.04 vps keeps failing
Connection Timeout/Security Issue
Let's Encrypt Limit (again)
Port issue - Please help
Sysadmins Index
Set Up Let's Encrypt with Second Domain for Existing Discourse Install
New domain new server and 301 redirect
Is anyone here using their Discourse instance as their entire website?
Able to receive e-mail in mail-receiver but NOT in Discourse?
I can't access after installing
Setting up Discourse
Migrating site from Personal vmware server to VPS
New install fails on Ubuntu 20.04.3 LTS
Discourse Setup Error
Danke, funktioniert dies, um „www.example.com“ auf „comunnity.example.com“ umzuleiten?
Oder wie kann ich das machen?
Ich habe Probleme mit meiner Domain www.example.com. Ich habe die DNS-Einstellungen so konfiguriert, dass sie auf comunnity.example.com umgeleitet werden, aber es funktioniert weder in Firefox noch in Chrome.
2 „Gefällt mir“
Es gibt ein Redirect-Checker-Tool, um Ihre Weiterleitungen zu überprüfen.
6 „Gefällt mir“
Ich habe damit ein wenig zu kämpfen. OK, viel.
Ich habe beschlossen, mit dem Hinzufügen eines CDN zu einer meiner Websites zu experimentieren.
Nachdem ich die Dokumentation gelesen hatte, erkannte ich, dass es für meine Website besser war, von ihrer aktuellen Apex-Domain auf eine Subdomain umzuziehen, um die von Fastly empfohlenen Kriterien (und die allgemeine Empfehlung dazu) zu erfüllen.
Also dachte ich: „Ach, das wird ein Kinderspiel, das habe ich schon mal gemacht …“. Oh ja?! :sweat_smile:
Die betreffende Website ist https://starzen.space.
Ich habe sie dieses Wochenende nach https://www.starzen.space verschoben, indem ich die Anleitung hier verwendet habe.
Alles lief gut, ABER natürlich muss ich immer noch die kleine Anzahl von Benutzern berücksichtigen, die ich bisher auf dieser Website gewonnen habe, also wollte ich eine Weiterleitung hinzufügen.
Nach meinem Verständnis muss ich dann auch den ursprünglichen Link mit einem Zertifikat ausstellen. Nach dieser Anleitung (die viel aufwendiger war?) habe ich dies zu app.yml hinzugefügt:
hooks:
  after_ssl:
    - replace:
        filename: "/etc/runit/1.d/letsencrypt"
        to: "-d starzen.space --keylength"
    - replace:
        filename: "/etc/nginx/conf.d/discourse.conf"
        to: |
          return 301 https://$host$request_uri;
  after_web_config:
    - replace:
        filename: /etc/nginx/nginx.conf
        to: |
          server_names_hash_bucket_size 64;
          sendfile on;
    - file:
        path: /etc/nginx/conf.d/discourse_redirect_1.conf
        contents: |
          server {
            listen 80;
            listen 443 ssl;
            server_name starzen.space;
            return 301 $scheme://www.starzen.space$request_uri;
Bei einem erneuten Build scheint alles gut zu laufen.
Wenn ich jedoch versuche, https://starzen.space über einen Browser aufzurufen, erhalte ich:
Und wenn ich curl verwende:
blah discourse % curl https://starzen.space
curl: (60) SSL: no alternative certificate subject name matches target host name 'starzen.space'
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Ich bin mir ziemlich sicher, dass das Zertifikat schuld ist, denn wenn ich dasselbe im unsicheren Modus ausführe, erhalte ich:
blah discourse % curl -k https://starzen.space
301 Moved Permanently
nginx/1.21.6
was meiner Meinung nach das ist, was ich will.
Ich denke, die geänderte Skriptdatei ist korrekt, hier ist, was ich habe:
root@starship-enterprise:/etc/runit/1.d# cat letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
issue_cert() {
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue $2 -d www.starzen.space -d starzen.space --keylength $1 -w /var/www/discourse/public
cert_exists() {
  [[ "$(cd /shared/letsencrypt/www.starzen.space$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")"]]
# RSA cert
issue_cert "4096"
if ! cert_exists ""; then
  # Try to issue the cert again if something goes wrong
  issue_cert "4096" "--force"
fi
<SNIP>
Ich habe dies sogar von der Befehlszeile aus innerhalb des Containers ausgeführt, nachdem ich ALLE Zertifikatsdateien aus dem Zielverzeichnis in ein Backup-Verzeichnis verschoben hatte, damit der richtige Befehl für die doppelte Domain ausgeführt wird:
root@starship-enterprise:/etc/runit/1.d# ./letsencrypt
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[Sun 25 Sep 2022 05:50:04 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sun 25 Sep 2022 05:50:04 PM UTC] Creating domain key
[Sun 25 Sep 2022 05:50:05 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:05 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Sun 25 Sep 2022 05:50:05 PM UTC] Getting domain auth token for each domain
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='www.starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] www.starzen.space is already verified, skip http-01.
[Sun 25 Sep 2022 05:50:08 PM UTC] Verifying: starzen.space
[Sun 25 Sep 2022 05:50:12 PM UTC] Pending
[Sun 25 Sep 2022 05:50:15 PM UTC] Success
[Sun 25 Sep 2022 05:50:15 PM UTC] Verify finished, start to sign.
[Sun 25 Sep 2022 05:50:15 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/128806215177'
[Sun 25 Sep 2022 05:50:16 PM UTC] Downloading cert.
[Sun 25 Sep 2022 05:50:16 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ff6b1b76f8516165032c6c2e02205a529b'
[Sun 25 Sep 2022 05:50:17 PM UTC] Cert success.
-----BEGIN CERTIFICATE-----
Lotsofcrazytext
-----END CERTIFICATE-----
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35281s
[Sun 25 Sep 2022 05:50:17 PM UTC] Reload success
[Sun 25 Sep 2022 05:50:18 PM UTC] Domains not changed.
[Sun 25 Sep 2022 05:50:18 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Sun 25 Sep 2022 05:50:18 PM UTC] Add '--force' to force to renew.
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Sun 25 Sep 2022 05:50:18 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35282s
[Sun 25 Sep 2022 05:50:18 PM UTC] Reload success
Größtenteils ein voller Erfolg!!!, curl ist jetzt viel freundlicher und gibt mir die Weiterleitung:
nginx/1.21.6
Und https://starzen.space in Firefox & Chrome funktioniert jetzt und leitet zur richtigen Unterseite weiter, aber ich bekomme immer noch die gefürchtete Grafik des Verderbens in Safari, was ist los? Ich habe es sogar neu gestartet und die Caches für diese Website gelöscht:
Wenn ich mir das Zertifikat vom Browser aus ansehe, sehe ich:
1 „Gefällt mir“
Ich wollte mir das schon genauer ansehen. Ich denke, es gibt jetzt zwei Stellen in der Let’s Encrypt-Vorlage, an denen die zusätzliche Domain eingetragen werden muss. Ich glaube nicht, dass Sie Änderungen am Nginx-Zeug vornehmen müssen, da es bereits eine 301-Weiterleitung für alles außer dem Hostnamen durchführt.
Sie müssen sich die Let’s Encrypt-Vorlage ansehen und prüfen, wo der Hostname eingetragen wird, und sicherstellen, dass Sie dies auch mit dem zusätzlichen Hostnamen tun.
3 „Gefällt mir“
Ja, danke, das habe ich der Vollständigkeit halber gemacht und es scheint noch keinen Schaden angerichtet zu haben, aber ich baue es gerne irgendwann ohne wieder auf.
Es scheint zwei Sätze kryptografischer Dateien zu geben?:
root@starship-enterprise:/shared/letsencrypt# cd starzen.space
root@starship-enterprise:/shared/letsencrypt/starzen.space# ls
backup	ca.cer	fullchain.cer  starzen.space.cer  starzen.space.conf  starzen.space.csr  starzen.space.csr.conf  starzen.space.key
root@starship-enterprise:/shared/letsencrypt/starzen.space# cd ..
root@starship-enterprise:/shared/letsencrypt# cd www.starzen.space
root@starship-enterprise:/shared/letsencrypt/www.starzen.space# ls
backup	    ca.cer	   www.starzen.space.cer   www.starzen.space.csr       www.starzen.space.key
backup_two  fullchain.cer  www.starzen.space.conf  www.starzen.space.csr.conf
Ah, könnte es hier sein (und unten)
Es enthält nur Informationen für den Hostnamen, nicht für die Apex?
1 „Gefällt mir“
Nein, ich denke, das ist richtig? Es sollte ein Zertifikat geben, und es sollte sowohl für www. als auch für Apex funktionieren.
Dieses Tool schlägt vor, dass auf meinem öffentlichen Zertifikat nur eine Domain vorhanden ist (was das Problem verursachen würde?):
1 „Gefällt mir“
Sie müssen den Teil von Let’s Encrypt ändern, der das Zertifikat abruft. Es muss das einzelne Zertifikat für beide Domains angefordert werden. Diese Anweisungen funktionierten früher, aber ich glaube, etwas hat sich daran geändert, wie das Zertifikat angefordert wird. Wenn es das richtige Zertifikat erhält, funktioniert alles andere einfach.
1 „Gefällt mir“
Wenn Sie certbot certificates ausführen, werden Ihr(e) Zertifikat(e) und die Domain(s), die es abdeckt, angezeigt. Wenn es sowohl den Apex als auch die www-Adresse nicht abdeckt, können Sie
  1. Certbot erneut ausführen und ein Zertifikat sowohl für den Apex als auch für die www-Adresse erstellen lassen;
Wenn Sie sich für diese Option entscheiden, führen Sie certbot certificates aus, um den Namen des zu löschenden Zertifikats zu erhalten. Führen Sie certbot delete (Name des zu löschenden Zertifikats) aus. Sie sollten nur noch Ihr neues Zertifikat (mit Apex und www) haben.
oder (am einfachsten)
  1. führen Sie certbot --expand -d existing.domain -d added.domain aus
Dadurch wird Ihr Zertifikat mit einem neuen Zertifikat aktualisiert, das die ursprüngliche Domain und die mit dem -d-Flag hinzugefügten Domains enthält.
2 „Gefällt mir“
Jim, certbot-Befehl nicht gefunden? Ist dies Teil der Standardinstallation und es gibt nur ein Pfadproblem?
1 „Gefällt mir“
Ohne nachzusehen… Ich glaube, certbot ist das, was man normalerweise benutzt, aber innerhalb des Containers hat Discourse acme verwendet.
Und auch damit zusammenhängend, versuchst du das innerhalb oder außerhalb des Containers?
(Außerdem wird mein Tag immer voller und ich kann das vielleicht nicht mehr so sorgfältig prüfen, wie ich es ursprünglich dachte, aber es stand auf meiner Liste)
3 „Gefällt mir“
Stimme zu … ein Weg, dies zu tun, ist meiner Meinung nach dieser?:
Wenn ich von einer beliebigen geeigneten Linux-Befehlszeile aus verwende
true | openssl s_client -connect www.starzen.space:443 2>/dev/null \
| openssl x509 -noout -text \
| perl -l -0777 -ne '@names=/\\bDNS:([^\\s,]+)/g; print join("\\n", sort @names);'
erhalte ich nur eine Domain und die Apex fehlt.
1 „Gefällt mir“
Im Container finden Sie den Code, der das Zertifikat anfordert (und erneuert?) und sehen, dass er es für beide Domains anfordert.
1 „Gefällt mir“
Ja, das ist der Fall, gemäß:
Und das können Sie in der obigen Protokollausgabe sehen.
Es gibt jedoch einige andere Schritte zur Zertifikatsinstallation, die nur -d www.starzen.space enthalten, was ein Problem darstellen könnte? Obwohl, wenn dieses Zertifikat für beides erstellt wird, ist das vielleicht nicht das Problem …
1 „Gefällt mir“
Das versuche ich die ganze Zeit zu sagen. Sie müssen diese anscheinend auch aktualisieren. Ich bin mir nicht sicher, warum es jetzt mehrere gibt, aber der OP muss mit Code aktualisiert werden, um all diese Schritte zu ändern. Oder das denke ich zumindest.
4 „Gefällt mir“
Ja, ich werde das versuchen, zunächst manuell
2 „Gefällt mir“
Gut. Das ist es, was ich tun wollte. Vielleicht habe ich Sie dazu verleitet. :winking_face_with_tongue:
1 „Gefällt mir“
Es ist sinnvoll, es zu versuchen, nur dass ich den Container möglicherweise neu erstellen muss, um nano zu installieren … :sweat_smile:
1 „Gefällt mir“
Nein!
 apt-get uodate;apt-get install nano
Das können Sie einfach innerhalb des Containers ausführen. Ich mache das ständig (außer dass ich vim benutze)
3 „Gefällt mir“
Das hat leider nicht funktioniert:
[Mon 26 Sep 2022 12:35:54 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Mon 26 Sep 2022 12:35:54 PM UTC] Creating domain key
[Mon 26 Sep 2022 12:35:56 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:35:56 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Mon 26 Sep 2022 12:35:56 PM UTC] Getting domain auth token for each domain
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='www.starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] www.starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:35:59 PM UTC] starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:36:00 PM UTC] Verify finished, start to sign.
[Mon 26 Sep 2022 12:36:00 PM UTC] Lets finalize the order.
[Mon 26 Sep 2022 12:36:00 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/129044627717'
[Mon 26 Sep 2022 12:36:01 PM UTC] Downloading cert.
[Mon 26 Sep 2022 12:36:01 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ffc90cecd2f11f2ba386da2d501127aee5'
[Mon 26 Sep 2022 12:36:02 PM UTC] Cert success.
phewbigcert
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 329s
[Mon 26 Sep 2022 12:36:02 PM UTC] Reload success
[Mon 26 Sep 2022 12:36:03 PM UTC] Domains not changed.
[Mon 26 Sep 2022 12:36:03 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Mon 26 Sep 2022 12:36:03 PM UTC] Add '--force' to force to renew.
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Mon 26 Sep 2022 12:36:04 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 331s
[Mon 26 Sep 2022 12:36:04 PM UTC] Reload success
Was immer noch ein Zertifikat mit einer einzelnen Domain zu exponieren scheint…
www.starzen.space
1 „Gefällt mir“
