Configurer Let's Encrypt avec plusieurs domaines / redirections
NOTE: @pfaffman says: This page needs to be cleaned up. There is now a new ENV setting that will let you add more hostnames. In your app.yml under your DISCOURSE_HOSTNAME line (it can go many places but that one makes sense), add
 DISCOURSE_HOSTNAME_ALIASES: domain.com,other.domain.com
and early reports suggest that you’ll get valid certs for those domains and that accessing https://domain.com will properly redirect you to your DISCOURSE_HOSTNAME without a certificate error.
If you do that and it works for you, you might add another “me too!” post to the bottom. If you feel comfortable, you could also edit this first post with the instructions that you think would be most helpful.
This is to address the problem where you get certificate errors with any redirects or CNAME DNS entries which point to your actual installed Discourse (sub)domain.
If you do not have https configured already (you do if you have done a standard install recently) see Setting up Let’s Encrypt as your first step.
Legacy Method
The method below no longer reliably works as of August 2025
There are three patterns that need to be replaced. Enter your (sub)domain (and any additional subdomains preceded by -d ) and then add the following to your app.yml hooks section (towards the end of the file):
2025-04-23 @pfaffman changed the code because there’s a 3rd place it needs to be changed
  after_ssl:
    - replace:
        filename: /etc/runit/1.d/letsencrypt
        to: "-d =domain1= -d =domain2= "
        global: true
This will allow you to have HTTPS configured for a second domain that will redirect to the correct one without certificate issues.
If you need to add multiple extra domains, you can enter something like this in the domain2 field: www.bananas.com -d forum.bananas.com
For example, if you want people who visit https://forum.example.com to be redirected to your forum at https://community.example.com without a certificate error, this is all you need.
49 « J'aime »
Discourse + Let's Encrypt w/ multiple hostnames
Problem in installing Let's Encrypt SSL for www and non-www
Making 'www' work with Discourse
LetsEncrypt working without www, not with www
Full site CDN acceleration for Discourse
Two domains, conditional redirect
How to setup 301 redirect -non-www to www
Best way to add a 301 redirect
Setup discourse for the main site (www.example.com) not on a subdomain
How to create 301 redirect to a new domain
I can't access after installing
Setting up Discourse
Migrating site from Personal vmware server to VPS
New install fails on Ubuntu 20.04.3 LTS
Discourse Setup Error
Www.example.com OK, but example.com NOT
About force www to non www
Why is the Apple Touch Icon loaded via HTTP instead of HTTPS?
DNS Settings for Digital Ocean Droplet - Root Domain?
SSL working on root, but not on www
Facebook login was flagged as non compliant by Facebook after change to Let's Encrypt certificate system
After activating HTTPS Discourse doesn´t work
Letsencrypt issued on every build?
DO Storage and uploaded backups not showing
Non www to www without certificate error
How to add ssl to non-www domain?
Adding www. to Domain
Discourse droplet unreachable on 80,443 ports after installation on Ubuntu 20.04
Installation without subdomain not working
Forum went down, then certificate renew error regarding firewall configuration?
Discourse Failing to Work
DNS settings for www
LetsEncrypt certificate not renewing
How to redirect http to https on digital ocean droplet?
Forwarding from https:// to https://www
Workaround for the 1 week Let's Encrypt limit
Migrate discourse from main domain --> subdomain
Let's Encrypt and multisite (on 2 containers)
Migrate a XenForo forum to Discourse
How can I update the nginx config directly in discourse/docker ..?
Let's Encrypt with sub-subdomain?
Problems building a new server
Multiple hostnames for a single site for cut-over phase
Help with URLs not working on Chrome
Issue after Rebuilding Discourse on Digital Ocean Droplet
Error on attempting to remap links
Unable to reinstall Discourse
Can't load site in Safari
Lets Encrypt Certificate - Issuing Problem
Www to non www with https
Discourse setup completed successfully but not working due to SSL error
SSL on new host
Install fails on fresh Debian 12 installation
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
SSL is not valid for www.domain.com
Trying to set up Discourse on my website
Setup Let’s Encrypt + non-www > www
Changed email service, now the forum won't resolve via IP address nor URL
Bootstrap error during Discourse install: ENOENT - /etc/runit/1.d/letsencrypt
Various multisite installation questions
Redirection from https://www.mydoimain.com/ doesn't work
SSL cert not working on main Discourse site
Change server to a two-container setup
Infinite 301 redirect with reverse proxy setup
[Paid] Discourse configuration changes
New installer works well, but one hostname gave me fits
Redirect old forum URLs to new Discourse URLs using permalinks
Discourse not accessible - SSL Issue
Correct DNS records to set when Discourse is hosted on WWW subdomain?
Invalid certificate name when using www
Need help with dual container. Issue with LetsEncrypt for a few days now
PEM_read_bio_X509_AUX() failed (SSL: error:0909006C:PEM routines:get_name:no start line:Expecting: TRUSTED CERTIFICATE)
Rebuild appears to work, but site is not loading properly
Issue with app.yml file update
New install on ionos ubuntu 22.04 vps keeps failing
Connection Timeout/Security Issue
Let's Encrypt Limit (again)
Port issue - Please help
Starting a second Discourse forum on the same VPS
Sysadmins Index
Set Up Let's Encrypt with Second Domain for Existing Discourse Install
New domain new server and 301 redirect
Able to receive e-mail in mail-receiver but NOT in Discourse?
Merci, cela fonctionne pour rediriger « www.example.com » vers « community.example.com » ?
Ou comment puis-je le faire ?
J’ai des problèmes avec mon domaine www.example.com, j’ai configuré le DNS pour rediriger vers community.example.com mais cela ne fonctionne pas sur Firefox ou Chrome.
2 « J'aime »
Il existe un outil de vérification des redirections pour vérifier vos redirections.
6 « J'aime »
J’ai un peu de mal avec ça. OK, beaucoup.
J’ai décidé d’expérimenter en ajoutant un CDN à l’un de mes sites.
Après avoir lu la documentation, j’ai réalisé qu’il était préférable pour mon site de passer d’un domaine apex actuel à un sous-domaine afin de répondre aux critères recommandés par Fastly (et aux conseils généraux de le faire).
Alors j’ai pensé : “meh, ça va être un jeu d’enfant, je l’ai déjà fait…” oh oui ?! :sweat_smile:
Le site en question est https://starzen.space.
Je l’ai déplacé ce week-end vers https://www.starzen.space en utilisant le guide ici
Tout s’est bien passé, MAIS bien sûr, je dois encore tenir compte du petit nombre d’utilisateurs que j’ai déjà acquis sur ce site, j’ai donc voulu ajouter une redirection.
D’après ma compréhension, j’ai alors aussi besoin du lien original délivré avec un certificat, donc en suivant ce guide (qui était beaucoup plus impliqué auparavant ?), j’ai ajouté ceci à app.yml :
hooks:
  after_ssl:
    - replace:
        filename: "/etc/runit/1.d/letsencrypt"
        to: "-d starzen.space --keylength"
    - replace:
        filename: "/etc/nginx/conf.d/discourse.conf"
        to: |
          return 301 https://$host$request_uri;
  after_web_config:
    - replace:
        filename: /etc/nginx/nginx.conf
        to: |
          server_names_hash_bucket_size 64;
          sendfile on;
    - file:
        path: /etc/nginx/conf.d/discourse_redirect_1.conf
        contents: |
          server {
            listen 80;
            listen 443 ssl;
            server_name starzen.space;
            return 301 $scheme://www.starzen.space$request_uri;
Lors d’une reconstruction, tout semble bien se passer.
Cependant, si j’essaie d’accéder à https://starzen.space via un navigateur, j’obtiens :
Et si je fais un curl :
blah discourse % curl https://starzen.space
curl: (60) SSL: no alternative certificate subject name matches target host name 'starzen.space'
More details here: https://curl.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Je suis à peu près sûr que c’est le certificat qui est en cause, car si j’exécute la même commande en mode non sécurisé, j’obtiens :
blah discourse % curl -k https://starzen.space
301 Moved Permanently
nginx/1.21.6
ce qui, je crois, est ce que je veux.
Je pense que le script modifié est correct, voici ce que j’ai :
root@starship-enterprise:/etc/runit/1.d# cat letsencrypt
#!/bin/bash
/usr/sbin/nginx -c /etc/nginx/letsencrypt.conf
issue_cert() {
  LE_WORKING_DIR="${LETSENCRYPT_DIR}" /shared/letsencrypt/acme.sh --issue $2 -d www.starzen.space -d starzen.space --keylength $1 -w /var/www/discourse/public
cert_exists() {
  [[ "$(cd /shared/letsencrypt/www.starzen.space$1 && openssl verify -CAfile <(openssl x509 -in ca.cer) fullchain.cer | grep "OK")"]]
# RSA cert
issue_cert "4096"
if ! cert_exists ""; then
  # Try to issue the cert again if something goes wrong
  issue_cert "4096" "--force"
fi
<SNIP>
J’ai même exécuté ceci depuis la ligne de commande dans le conteneur, après avoir déplacé TOUS les fichiers de certificat du répertoire cible vers un répertoire de sauvegarde afin que la bonne commande soit exécutée pour le double domaine :
root@starship-enterprise:/etc/runit/1.d# ./letsencrypt
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address already in use)
nginx: [emerg] still could not bind()
[Sun 25 Sep 2022 05:50:04 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Sun 25 Sep 2022 05:50:04 PM UTC] Creating domain key
[Sun 25 Sep 2022 05:50:05 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:05 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Sun 25 Sep 2022 05:50:05 PM UTC] Getting domain auth token for each domain
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='www.starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] Getting webroot for domain='starzen.space'
[Sun 25 Sep 2022 05:50:08 PM UTC] www.starzen.space is already verified, skip http-01.
[Sun 25 Sep 2022 05:50:08 PM UTC] Verifying: starzen.space
[Sun 25 Sep 2022 05:50:12 PM UTC] Pending
[Sun 25 Sep 2022 05:50:15 PM UTC] Success
[Sun 25 Sep 2022 05:50:15 PM UTC] Verify finished, start to sign.
[Sun 25 Sep 2022 05:50:15 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/128806215177'
[Sun 25 Sep 2022 05:50:16 PM UTC] Downloading cert.
[Sun 25 Sep 2022 05:50:16 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ff6b1b76f8516165032c6c2e02205a529b'
[Sun 25 Sep 2022 05:50:17 PM UTC] Cert success.
-----BEGIN CERTIFICATE-----
Lotsofcrazytext
-----END CERTIFICATE-----
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Sun 25 Sep 2022 05:50:17 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Sun 25 Sep 2022 05:50:17 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35281s
[Sun 25 Sep 2022 05:50:17 PM UTC] Reload success
[Sun 25 Sep 2022 05:50:18 PM UTC] Domains not changed.
[Sun 25 Sep 2022 05:50:18 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Sun 25 Sep 2022 05:50:18 PM UTC] Add '--force' to force to renew.
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Sun 25 Sep 2022 05:50:18 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Sun 25 Sep 2022 05:50:18 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 579) 35282s
[Sun 25 Sep 2022 05:50:18 PM UTC] Reload success
Major success !!!, curl est beaucoup plus gentil maintenant et me donne la redirection :
nginx/1.21.6
Et https://starzen.space dans Firefox et Chrome fonctionne maintenant, redirigeant vers le bon sous-domaine, mais j’obtiens toujours le redoutable graphique de la mort dans Safari, qu’est-ce qui se passe ? J’ai même redémarré, vidé les caches pour ce site :
En regardant le certificat depuis le navigateur, je vois :
1 « J'aime »
J’avais l’intention d’examiner cela de plus près. Je pense qu’il y a maintenant deux endroits dans le modèle Let’s Encrypt où le domaine supplémentaire doit être ajouté. Je ne pense pas que vous ayez besoin d’apporter des modifications à la configuration Nginx car elle effectue déjà une redirection 301 vers tout ce qui n’est pas le nom d’hôte.
Ce qu’il faut faire, c’est examiner le modèle Let’s Encrypt et voir où il place le nom d’hôte et s’assurer que vous faites de même avec le nom d’hôte supplémentaire.
4 « J'aime »
Oui, merci, je l’ai fait par souci de complétude et cela ne semble pas encore causer de tort, mais je suis prêt à reconstruire sans cela à un moment donné.
Il semble y avoir deux ensembles de fichiers cryptographiques ? :
root@starship-enterprise:/shared/letsencrypt# cd starzen.space
root@starship-enterprise:/shared/letsencrypt/starzen.space# ls
backup	ca.cer	fullchain.cer  starzen.space.cer  starzen.space.conf  starzen.space.csr  starzen.space.csr.conf  starzen.space.key
root@starship-enterprise:/shared/letsencrypt/starzen.space# cd ..
root@starship-enterprise:/shared/letsencrypt# cd www.starzen.space
root@starship-enterprise:/shared/letsencrypt/www.starzen.space# ls
backup	    ca.cer	   www.starzen.space.cer   www.starzen.space.csr       www.starzen.space.key
backup_two  fullchain.cer  www.starzen.space.conf  www.starzen.space.csr.conf
Ah, est-ce que cela pourrait être ici (et ci-dessous)
Il n’inclut que les informations pour le nom d’hôte, pas l’apex ?
1 « J'aime »
Non, je pense que c’est correct ? Il ne devrait y avoir qu’un seul certificat et il devrait fonctionner à la fois pour www. et pour l’apex.
Cet outil suggère qu’il n’y a qu’un seul domaine sur mon certificat public (ce qui serait la source du problème ?) :
1 « J'aime »
Vous devez modifier la partie de Let’s Encrypt qui obtient le certificat. Il faut demander le certificat unique pour les deux domaines. Ces instructions fonctionnaient auparavant, mais quelque chose a changé dans la façon dont le certificat est demandé, je pense. S’il obtient le bon certificat, tout le reste fonctionne.
2 « J'aime »
Si vous exécutez certbot certificates, il affichera votre ou vos certificats et le ou les domaines qu’ils couvrent. S’il ne couvre pas à la fois le domaine racine et le www, vous pouvez
  1. exécuter à nouveau certbot et lui faire créer un certificat pour le domaine racine et le www ;
Si vous choisissez cette option, exécutez certbot certificates pour obtenir le nom du certificat que vous souhaitez supprimer. Exécutez certbot delete (nom du certificat que vous souhaitez supprimer). Il ne devrait vous rester que votre nouveau certificat (avec le domaine racine et le www).
ou (le plus simple)
  1. exécutez `certbot --expand -d existing.domain -d added.domain
Cela mettra à jour votre certificat avec un nouveau certificat contenant le domaine d’origine et ceux que vous ajoutez avec le drapeau -d.
2 « J'aime »
Jim, la commande certbot est introuvable ? fait-elle partie de l’installation standard et il y a juste un problème de chemin ?
1 « J'aime »
Sans regarder réellement… Je pense que certbot est ce que vous utilisez normalement, mais à l’intérieur du conteneur, discourse utilisait acme.
Et aussi, en relation, essayez-vous cela à l’intérieur ou à l’extérieur du conteneur ?
(Aussi, ma journée se remplit et je ne pourrai peut-être pas examiner cela aussi attentivement que je l’avais pensé, mais cela a été sur ma liste)
3 « J'aime »
D’accord… une façon de faire, je crois, est celle-ci ? :
Si j’utilise depuis n’importe quelle ligne de commande Linux appropriée
true | openssl s_client -connect www.starzen.space:443 2>/dev/null \
| openssl x509 -noout -text \
| perl -l -0777 -ne '@names=/\\bDNS:([^\\s,]+)/g; print join("\\n", sort @names);'
Je n’obtiens qu’un seul domaine et il manque l’apex.
1 « J'aime »
À l’intérieur du conteneur, vous trouvez le code qui demande (et renouvelle ?) le certificat et constatez qu’il le demande pour les deux domaines.
1 « J'aime »
Oui, c’est le cas, comme indiqué dans :
Et vous pouvez le voir dans la sortie du journal ci-dessus.
Cependant, il existe d’autres étapes d’installation de certificat qui n’incluent que -d www.starzen.space, ce qui pourrait poser problème ? Bien que si ce certificat est construit pour les deux, ce n’est peut-être pas le problème…
1 « J'aime »
C’est ce que j’essayais de dire. Il semble que vous deviez également mettre à jour ceux-ci. Je ne suis pas sûr pourquoi il y en a maintenant plusieurs, mais le message initial doit être mis à jour avec le code pour modifier toutes ces étapes. Du moins, c’est ce que je pense.
4 « J'aime »
Ouais, je vais essayer ça, d’abord manuellement
2 « J'aime »
Tant mieux. C’est ce que j’allais faire. Peut-être que je vous ai incité à le faire. :winking_face_with_tongue:
1 « J'aime »
C’est judicieux d’essayer, seulement je devrai peut-être reconstruire le conteneur pour installer nano… :sweat_smile:
1 « J'aime »
Non !
 apt-get update ; apt-get install nano
Vous pouvez simplement exécuter cela à l’intérieur du conteneur. Je le fais tout le temps (sauf que j’utilise vim)
3 « J'aime »
Malheureusement, cela n’a pas fonctionné :
[Mon 26 Sep 2022 12:35:54 PM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Mon 26 Sep 2022 12:35:54 PM UTC] Creating domain key
[Mon 26 Sep 2022 12:35:56 PM UTC] The domain key is here: /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:35:56 PM UTC] Multi domain='DNS:www.starzen.space,DNS:starzen.space'
[Mon 26 Sep 2022 12:35:56 PM UTC] Getting domain auth token for each domain
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='www.starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] Getting webroot for domain='starzen.space'
[Mon 26 Sep 2022 12:35:59 PM UTC] www.starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:35:59 PM UTC] starzen.space is already verified, skip http-01.
[Mon 26 Sep 2022 12:36:00 PM UTC] Verify finished, start to sign.
[Mon 26 Sep 2022 12:36:00 PM UTC] Lets finalize the order.
[Mon 26 Sep 2022 12:36:00 PM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/590255196/129044627717'
[Mon 26 Sep 2022 12:36:01 PM UTC] Downloading cert.
[Mon 26 Sep 2022 12:36:01 PM UTC] Le_LinkCert='https://acme-v02.api.letsencrypt.org/acme/cert/03ffc90cecd2f11f2ba386da2d501127aee5'
[Mon 26 Sep 2022 12:36:02 PM UTC] Cert success.
phewbigcert
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Your cert key is in  /shared/letsencrypt/www.starzen.space/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] The intermediate CA cert is in  /shared/letsencrypt/www.starzen.space/ca.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] And the full chain certs is there:  /shared/letsencrypt/www.starzen.space/fullchain.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing key to:/shared/ssl/www.starzen.space.key
[Mon 26 Sep 2022 12:36:02 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space.cer
[Mon 26 Sep 2022 12:36:02 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 329s
[Mon 26 Sep 2022 12:36:02 PM UTC] Reload success
[Mon 26 Sep 2022 12:36:03 PM UTC] Domains not changed.
[Mon 26 Sep 2022 12:36:03 PM UTC] Skip, Next renewal time is: Wed 23 Nov 2022 10:01:01 AM UTC
[Mon 26 Sep 2022 12:36:03 PM UTC] Add '--force' to force to renew.
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing key to:/shared/ssl/www.starzen.space_ecc.key
[Mon 26 Sep 2022 12:36:04 PM UTC] Installing full chain to:/shared/ssl/www.starzen.space_ecc.cer
[Mon 26 Sep 2022 12:36:04 PM UTC] Run reload cmd: sv reload nginx
ok: run: nginx: (pid 2970) 331s
[Mon 26 Sep 2022 12:36:04 PM UTC] Reload success
Ce qui semble toujours avoir exposé un certificat avec un seul domaine…
| perl -l -0777 -ne '@names=/\\bDNS:([^\\s,]+)/g; print join("\n", sort @names);'
www.starzen.space
1 « J'aime »
