Riepilogo giornaliero (21:00 UTC)
Today on meta.discourse.org…
Key Stats
Interesting Topics
  • Dev calendar-and-event #rest-api: ShiverTimber4973 shared a Python script to sync iCal/ICS feeds into Discourse topics—idempotently updating events by UID—prompting Ethsim2 and Cathyy01 to request a step-by-step admin guide and plugin packaging for non-coders read more.
  • Bug #theme-creator: Lilly observed that Theme Creator is locked in Chrome on the Horizon theme, with hidden consoles in Safari, leading NateDhaliwal to confirm the issue and david to disable the old component version read more.
  • Bug iOS users on 16.7.11 reported transparent dropdowns and overlapping UI elements on mobile, with sam and chapoi troubleshooting before david merged a backport fix to stable read more.
  • Support Users encountered SSL fetch failures from rubygems.org during bundle install, with connection resets—pmusaraj and NateDhaliwal exploring mirrors and IPv6 workarounds read more.
  • Installation Update to 3.5.0.beta9 caused rebuild failures due to a duplicate plugin directory (discourse-feature-voting), and david guided removing the old line from app.yml to restore migrations read more.
  • Support #brand-header: simonk flagged an overly restrictive compatibility entry in the Brand Header component; david clarified that beta9 users can install the update despite the pre-fix in .discourse-compatibility read more.
  • Bug #ai: J-Ha_Hasegawa showed that the Claude Sonnet 4 spam persona returned “Not spam” despite logs marking clear promotions as SPAM; Roman updated the test prompt to align the detector’s output with the scan log read more.
  • #Sysadmins how-to #letsencrypt: featheredtoast announced multi-domain SSL support in discourse_docker, using DISCOURSE_HOSTNAME_ALIASES in app.yml to set alternate hostnames for Let’s Encrypt certificates read more.
  • Support Monikas asked if a direct tar of /var/discourse could simplify migration; Canapin pointed to an rsync guide and pfaffman recommended ./launcher cleanup to free space pre-backup read more.
  • Support Picho_Pelis hit SMTP send failures with the Maileroo service; NateDhaliwal suggested port 2525 for DigitalOcean and testing on Hetzner VPS read more.
  • Support #seo: sam advised centralizing forum discussions to build domain authority and improve PageRank, using inbound link analysis to diagnose keycloak.discourse.group indexing issues read more.
  • Support #rest-api: Nikki_Locke explored adding/removing group owners via the API, uncovering endpoint nuances and pfaffman directing to the reverse-engineering guide for accurate parameters read more.
  • Feature #chat: donaldsoncd discovered a “My Threads” menu entry when DM threading was enabled, sparking calls to add a global toggle to disable chat threads with “My Threads” read more.
  • Bug polls pr-welcome #rest-api: clechasseur submitted a PR to avoid duplicate entries in /polls/voters.json, after experimentation revealed non-deterministic ordering could yield repeats read more.
  • Support bartv noted that the “Download remote images to local” feature auto-disables despite sufficient disk space; Canapin linked to discussions on backup compression space requirements read more.
Activity by the @team Group
Stay caffeinated—your rebuilds won’t fix themselves!
Key Stats
New posts: 100
New topics: 11
Top users:
Interesting Topics
Feature
Support
UX
Bug
Dev
With impersonations, spoilers, and calendar tweaks all rolling in, yesterday proved meta.discourse.org is where the fun—and the fine-tuning—never sleeps!
Key Stats
  • New posts: 115
  • New topics: 20
Top users (by posts & likes)
Interesting Topics
Announcements
  • lindsey kicked off Current Projects – August 2025, our monthly look at what the Discourse team is building next, including a revamped lightbox experience and centralized authentication testing. See the full rundown here and join the feedback thread.
Support
  • Shauny found an error with Tooltipify-words after upgrading Discourse. Arkshine merged a fix in a quick PR and confirmed resolution here read more.
  • ToddZ asked how to prevent Google OAuth2 users from getting default names like “User1”, and pmusaraj explained it stems from the “use email for username” setting. Lindsey then suggested improving the signup experience by leaving the field blank rather than auto-naming. Discussion at 379798/1 and solution talk at 379798/3.
  • Shauny noticed the background colour on unread notifications disappeared after a header redesign. chapoi traced it to a conflicting secondary palette variable and guided a reset at 379818/5 read more.
  • janbolmeson ran into the [wrap]-token issue in the new composer, seeking a replacement for custom banners in rich text mode. chapoi confirmed internal discussion and promised updates at 379830/4 details.
Bug
  • J-Ha_Hasegawa tested the new AI spam bot and found posts still slipping through when sent by admin-level users. Roman clarified the bypass conditions (e.g., trust level >1 or staff) at 379375/8 and confirmed the feature is working as intended after testing from a TL0 account read more.
  • NateDhaliwal reported the composer preview on mobile wasn’t fullscreen in Markdown mode. chapoi repro’d the issue and shipped a fix in discourse/discourse#34485 after confirming the behavior at 373852/7.
  • An old Bug on site header overlapping the composer on mobile was revisited. chapoi confirmed it’s now intentional for full-screen writing, with the header hidden when the composer opens at 366008/2.
Feature
  • JBdama proposed a security enhancement to allow stronger SSH keys (e.g., Ed25519 or RSA-4096) for Git-based theme/component installs. The request is logged at 379821/1 under development.
  • NateDhaliwal suggested a “Back to parent category” button in sub-category view. chapoi shared a sidebar workaround at 379774/2 and discussed possible UX changes at 379774/3.
blog
  • In Unboxing Discourse 3.5, Albert_Dessaint debated whether the showcased theme was public or internal. chapoi clarified it’s an internal design in progress at 379249/9.
UX
  • schleifer disagreed with the placement of the bookmark reminder notification preference, expecting it under Notifications instead of Interface. Details at 379938/1.
Theme component
Community
  • ToddZ asked for examples of “Introduce yourself” topics in the wild. Bas shared tips on making a single-topic megathread engaging and linked to past case studies at 379776/2.
#Site Management
  • In the Content Localization topic, nat explained why diffing translated content isn’t supported and highlighted the outdated-translation indicator at 370969/20.
That’s a wrap—after all that bug-fixing, feature brainstorming, and theme tweaking, even our puppies are wagging their tails! :paw_prints:
Key Stats
  • 73 new posts, 14 new topics in the past 24 hours.
  • Top users by posts & likes:
Interesting Topics
  • Feature Add a CLI warning when running launcher bootstrap/rebuild without app.yml present
    Ethsim2 proposed clearer messaging for the common case of missing app.yml and standalone.yml confusion, sparing new admins a dead end. As noted in the official backup/restore guide, restoring or copying a prior app.yml is also a frequent use case.
    read more
  • Support No more live reload with CSS modifications?
    After upgrading to 3.5.0, rahim123 noticed that theme component CSS changes no longer auto-reload on production. RGJ confirmed this was an intentional disablement to prevent issues during theme or core updates.
    read more
  • Support Can we avoid updates that force me to debug on the command line please?
    Benjol called for a heads-up in the UI before web-UI updates that trigger CLI rebuilds—especially when core now bundles plugins like Data Explorer. This echoes concerns from Is it by-design that updates via web-UI can provoke breaking changes?.
    read more
  • Support How can I delete an image based on only a URL?
    Facing a DMCA notice, physixfan wanted to trace an upload from a CDN link. Canapin pointed to DMCA: Remove individual image best practices, and RGJ recommended the Legal Compliance plugin for quick removals.
    read more
  • UX Is the login page .d-header color supposed to be the secondary color?
    rahim123 reported that a light --secondary header broke their light-text logo on the login page. chapoi explained this was an intentional de-emphasis to keep the focus on signing in.
    read more
  • Support Urgent help needed! I accidentally deleted the “feature request” section
    yachun_li, a paid member, wiped a category without backup and needed to restore it or recreate the slug for an embed. Canapin advised emailing team@discourse.org and referenced the Recover deleted categories procedure.
    read more
  • UX “Message” and “Chat” buttons on a user’s own profile page
    donaldsoncd found the prominent Message/Chat CTAs confusing on mobile. NateDhaliwal shared a CSS snippet under the Mobile theme tab to hide them for a cleaner profile view.
    read more
  • Support I forked the Discourse repository on GitHub. How can I replace it with the existing Discourse installation on my site?
    kuaza modified app.yml to point to their fork but saw Discourse revert to main. RGJ suggested more detailed error logging to troubleshoot the Git remote workflow.
    read more
  • Support How to create a left-sidebar tags section?
    tester123_tester123 asked how to replicate the categories & tags panel. NateDhaliwal walked through Admin → Customize → Sidebar, linking to the sidebar configuration guide.
    read more
  • Installation Failing update
    rlauriston’s rebuild failed, then a droplet resize triggered a PostgreSQL 13→15 upgrade, which aborted due to an unclean shutdown. Similar troubleshooting appears in Upgrade to latest release failed 8-21-25 and PostgreSQL-15 update.
    read more
  • Support The upgrade saga continues
    On a dual-site Docker host, MikeNolan found inbound email working on one forum but not the other post-upgrade, with no clues in the Discourse mail logs.
    read more
  • Community How have you built a local community around Discourse?
    justinm invited stories of geographically focused forums (from meal-delivery volunteers to neighborhood hubs), pointing to past successes like the COVID-19 meal delivery community.
    read more
  • Feature Generate a review item when a flag is resolved by the “Take Action…” feature
    per1234 proposed always logging moderation actions (even “Hide Post”) to satisfy DSA transparency. ondrej noted that only some actions currently create review items.
    read more
  • Dev Plugin Modal Component Import Error
    joo ran into module import errors migrating legacy DModal code. NateDhaliwal advised using relative paths (e.g., ../components/modal/...) instead of the discourse/ prefix.
    read more
  • Announcements Bundling more popular plugins with Discourse core
    After several plugins moved into core, rlauriston’s update errors hinted at leftover git clone lines in web_only.yml. featheredtoast explained the hint logic and suggested pruning those lines for clearer errors.
    read more
  • sam weighed in on AI bot – Personas, championing the forum researcher use case for persona-driven LLMs.
    read more
  • chapoi clarified the switch to var(--secondary) on the login page header in Is the login page .d-header color supposed to be the secondary color?
    read more
  • chapoi provided an admin-screenshot walkthrough to move the “Filter” link out of the More submenu in Move sidebar “Filter” item out of “More” submenu?
    read more
  • Lilly modernized the JS API for Image Alignment and Grid, planning further enhancements soon.
    read more
  • featheredtoast debugged the bundled-plugins hint behavior in Bundling more popular plugins with Discourse core.
    read more
  • renato requested a reproduction on Meta for the lingering inline spoiler-blur issue in Spoiler blur support for composer’s new rich text mode.
    read more
Phew! With rebuild warnings, image sleuthing, and Postgres gymnastics behind us, our virtual pups can finally curl up for a snooze. :paw_prints:
Key Stats
Total new posts: 67
Total new topics: 7
Top users (past 24 h):
Interesting Topics
Plugin
Support
Feature
Community
Support
Theme component
#Site-Management
Theme component
UX
Installation
Support
Bug
Bug
Bug
Support
And rest assured, after yesterday’s upgrade adventures, our digital pups survived the night unscathed!
Key Stats
Interesting Topics
Feature
Bug
Support
  • A Namecheap SMTP setup on self-hosted Discourse stalled at port 587. LG1 shared config details in post #1 and uncovered DigitalOcean port blocks in post #4. read more
  • Chinese-language users sought free SMTP options; ace_1 began troubleshooting in post #1 and confirmed a port fix in post #3. read more
  • Calls for clearer update warnings led Benjol to suggest log highlighting in post #6, while RGJ weighed in on race conditions in post #7. read more
  • Enforcing a required tag via theme JS was solved by chapoi pointing to built-in tag groups in post #2, after outlining the use case in post #1. read more
  • Intermittent “whispers” display glitches were traced to the post-voting plugin. patrickemin reported in post #1 and detailed repro steps in post #3. read more
Theme component
  • sam weighed in on Bug Disabled Uncategorized UI leakage in post #10 and post #13, proposed CJK word-count tweaks in post #4, and patched the message bus base-URL logic in post #2.
  • chapoi connected tipping ideas to the pay-best-answer thread post #7 and streamlined Message/Chat buttons on one’s own profile in post #8.
  • martin enabled experimental any-emoji support for Discourse Reactions in post #31.
  • awesomerobot built a fix for the welcome banner search text in post #24, demystified “Other traffic” on site analytics in post #2, and responded to an accessibility heading-nav report in post #12.
  • j.jaffeux reviewed and confirmed the S3 chat image upload fix in post #16.
  • pmusaraj proposed new iOS app home-screen toggles for Hot Topics & site URLs in post #32 and clarified date ordering for right-sidebar blocks in post #162.
  • Roman dove into the AI embeddings disable bug, validating model checks in post #3.
  • tobiaseigen recommended using safe mode to isolate the moment.tz embed error in post #20.
  • kelv confirmed the iOS mention-autocomplete menu now appears where there’s more screen space in post #6.
Here’s to fewer footnote gaps and more emoji experiments tomorrow! :tada:
Key Stats
Interesting Topics
Announcements
Bug
Support
Dev
  • j.jaffeux announced the FullCalendar 6 migration in post #1 of 380311.
  • chapoi restored the mobile Create topic button in Horizon 369608/44, clarified quoting options in 380263/7, and guided a user through iOS browser support 380297/8.
  • nat confirmed default mobile create button behaviors in Horizon 380264/2 and investigated the Calendar plugin search placement 379748/4.
  • david outlined maintenance challenges and future plans for the Theme Creator in 379393/5.
  • awesomerobot delivered a fix for the Advanced Search Banner component in 122939/201.
  • sam investigated the iOS input-jump bug 380187/2, proposed a patch for Chat Upload issues 379253/6, and examined Calendar search landing in 379748/5.
  • tobiaseigen escalated the tag SEO meta-description issue to the staff-experience team in 367683/11.
  • supermathie suggested adding an x-ms-reactions: disallow header to suppress Outlook clients’ emoji noise in 380418/1.
  • martin reviewed the Calendar plugin’s UI alignment with other plugins’ settings in 379748/6.
  • lindsey assessed potential regressions in unread-topic navigation behavior in 380224/4.
And that’s a wrap—may your notifications be light and the puppies blissfully unperturbed! :paw_prints:
Key Stats
Interesting Topics
Theme component
Feature
Support
#Sysadmins
Dev
#Site feedback
Bug
Announcements
#Site Management
Installation
Phew! Puppies are safe for another day—see you tomorrow for more meta mayhem!
Key Stats
Interesting Topics
#Hosting
#Site Management
Support
Bug
Announcements
Community
Dev
UX
Theme component
Feature
Fun fact: we fixed so many quirks in 24 hours that our Docker containers are starting to ask us for upgrade tips!
“When new threads spark and fixes flow, our community thrives!”
Key Stats
Interesting Topics
Announcements
Feature
Support
#Site Management
Dev
UX
Bug
With AI demos, calendar time-travel, and CSS wizardry, Meta’s pawsome energy keeps the forum howling—no puppies were harmed, but our brains are delightfully scrambled! :dog_face::tada:
Key Stats
Interesting Topics
#Site feedback
  • Everything is translated, help!
    tvavrda sparked a deep debate on whether fully blending multilingual posts into one “My language” view kills cultural nuance, with Jagster and schneeland weighing in on pros and cons of per-user locale options. read more
Support
  • Language switcher and language content
    nat diagnosed a language-detection quirk in the composer that mislabels English posts with French mentions, explaining the fallback logic in the locale detector code. read more
  • Only some threads are unabled for viewing
    nat guided a new moderator through safe-mode and plugin troubleshooting after reports of empty topics and laggy thread toggles on ForoMusculo.com. read more
Announcements
  • Content Localization and Automatic Translations for Your Community
    Tordanik reminded everyone that polyglots may want to keep multiple original languages visible, not force everything into one chosen locale. read more
  • Discourse Calendar updated to use fullcalendar 6
    hellekin humorously noted that leading zeroes on dates now ensure correct chronological sorting in the calendar plugin. read more
Plugin
  • Discourse Math
    Ethsim2 and ShiverTimber4973 shared tips on prompting external AI services to remember $…$ for math versus \$ for currency, streamlining copy-paste workflows. read more
UX
  • Inconsistent plugin settings
    RGJ pointed out that some plugins expose settings in the sidebar while others hide them under “Installed plugins,” and Moin linked to an internal topic tracking a unified UI update. read more
  • Re-order the groups list
    Richie proposed alphabetizing groups by full name (or at least @name), sparking a conversation on whether interface-language differences should affect group order. read more
Feature
  • Add ‘stop impersonating’ link to user avatar dropdown when impersonating
    hellekin envisioned expanding impersonation into a full persona system (e.g., @narrator, @characterN) with proper logging—an idea building on sudo-mode and staff aliases. read more
  • What are the prospects for an official Salesforce Integration/Plugin?
    MarkDoerr highlighted the recent release of an official Discourse Salesforce plugin to bridge communities with CRM workflows. read more
Bug
  • Internal Server Error when previewing digest emails
    xkhalid reported a 500 error on /admin/email/preview-digest when the “Last seen user” date uses Arabic numerals; Moin confirmed reproduction in Arabic interface and outlined steps to reproduce. read more
  • New user responding to invite fails, word_watcher.rb:258 error
    kgrier traced a registration crash to censored-word regex changes, clearing watchwords to restore invite acceptance; j.jaffeux is set to repro. read more
  • Viewing email templates in wysiwyg composer causes an error
    xkhalid discovered that toggling the new WYSIWYG mode on system message templates yields a composer exception; Moin reproduced it with the editor toggle. read more
  • Rich Text editor in topics breaks white-space characters in multiple ways
    rimelek detailed how the Rich Text composer mangles code block line breaks and indentation, leading to single-line code dumps; per1234 pointed to an existing bug report. read more
blog
  • Unboxing Discourse 3.5
    mcwumbly reminded folks that stable-branch installs will continue to receive security patches over the next six months, offering admins a smoother upgrade path. read more
And that’s a wrap! From translation tangles to math mysteries, Meta’s never short on surprises—keep your keyboards ready and your locales set!
Key Stats
Interesting Topics
Announcements
Community
Support
Feature
UX
Bug
Theme component
  • dax and davidkingham discussed legacy token support in Reply Template, planning [wrap] handling post-meetup after the current focus on the annual gathering.
May your translations stay sharp, your moderators stay Zen, and your oneboxes render flawlessly—no puppies were harmed in the making of this recap!
Key Stats
  • New posts: 147
  • New topics: 21
  • Top users:
Interesting Topics
Announcements
Feature
Support
  • Damian_Boon reported that the bottom nav bar on Android PWAs ignores theme palettes, leading to poor visibility for dark themes in Support mobile; read more
  • Users encountered a “Malformed version number” error when loading the /review or /plugin pages, traced to a bad entry in the new features API feed in Support; read more
  • A markdown wrap issue prevented calendar events from rendering (div_calendar_wrap), requiring a switch to the markdown editor in Support calendar-and-event; read more
Bug
  • Quoting multilingual content sometimes preserves the user’s view language rather than the original, causing awkward mix-ups in Bug content-localization; read more
  • The AI translation settings graph was hidden despite features being enabled, due to strict backfill requirements, leading to clarifications and tweaks in Bug ai content-localization; read more
  • After deleting a topic, some users saw a delete button instead of the restore action, making self-service restoration tricky in Bug UX; read more
Community
With yesterday’s palette glow-up and PWA experiments, our forum proved it’s not just clever, it’s looking sharp too!
Key Stats
Total new posts: 117
Total new topics: 14
Top Users (24 h)
Interesting Topics
#Site feedback
Bug
Support
Announcements
Dev
Support
Plugin
Plugin
Feature
Installation
Installation
Support
Support
Bug
Community
With so many features, fixes, and funny edge-cases uncovered, may your notifications stay crisp and your code never stray—keep calm and discourse on! :paw_prints:
Key Stats
Interesting Topics
Feature
Installation
Bug
Support
UX
Dev
#Site Management
Stay curious—yesterday we went from emoji archaeology to raw markdown exports, so who knows what surprises await today!
Key Stats
Date range: 2025-09-03 to 2025-09-04
New posts: 152
New topics: 20
Top users:
Interesting Topics
Support
Dev
Feature
Installation
Plugin
Bug
After yesterday’s whirlwind of theme deep-dives, plugin unveils, and OAuth sleuthing, the forum might just need an espresso break!
Key Stats
  • New posts: 139
  • New topics: 22
Top users (posts / likes):
Interesting Topics
Support
Feature
Bug
#Site feedback
Announcements
#customization:extras
What a whirlwind of ideas—no puppies were harmed, and we can’t wait to see what’s next!
Key Stats
Interesting Topics
#Hosting
#Site feedback
Support
#Sysadmins
  • In an ongoing discussion on two-container setups, merefield corrected a backup path typo in the official script 29413/111 and pfaffman clarified why hyphens work better for hostnames than underscores in Docker 29413/113.
Dev
Theme component
Bug
Feature
#Data & reporting
Community
  • In How have you built a local community around Discourse?, opcourdis suggested the push-notifications plugin 380036/7 and justinm highlighted PWA + WebPush as a native path for iOS and Android 8.
blog
  • emyoulation asked whether Discobot has ever been improved or given progress feedback in Who is Discobot?, sparking thoughts on UX enhancements for the onboarding bot.
Installation
#Site Management
Stay tuned for more—may your containers remain rock-solid, your oneboxes event-ready, and your discobot never run out of fishy farewells!
Key Stats
Total new posts: 37
Total new topics: 5
Top users (last 24 h)
Interesting Topics
Theme component
Support
Bug
  • NateDhaliwal detailed how hidden tag groups remained watched, causing unwanted notifications read more, and confirmed the persistent watch state when tag visibility toggles read more.
  • Moin identified faulty time span handling in the digest activity summary and argued for a more universal date input solution read more.
  • RGJ discovered that markdown wrappers and quotes in LLM responses break the locale detector and suggested sanitizing outputs to only allow language codes read more.
  • arun asked whether the login screen with unmatched password length falls under site signup or admin invitation flows, seeking clarification on error highlighting read more.
Plugin
  • RGJ added a warning when private topics are set to be visible by ‘everyone’ to prevent configuration errors read more, and sjjh appreciated the distinction between everyone and trust_level_0 permissions read more.
  • haydenjames questioned whether the “Who’s online active timeago” impacts email notifications read more, Jagster reasoned that visual presence shouldn’t suppress notifications read more, and haydenjames confirmed the plugin’s intended separation from notification settings read more.
Feature
  • Moin highlighted the new force lowercase tags site setting added via PR #6454, which now allows uppercase tags when disabled read more.
  • hellekin requested a bulk-actions feature to merge multiple topics at once, simplifying cleanup for high-email-volume categories read more.
From uppercase tags to disappearing calendar borders, we’ve seen it all—here’s to a brighter, more colorful week ahead on meta.discourse.org! :artist_palette::rocket:
Key Stats
Interesting Topics
Support
  • RichardTE encountered a layout discrepancy when his first Discourse community lacked the usual top menu dropdowns. Community members suggested it was due to the redditish theme and pointed to try.discourse.org for comparison. read more
  • Users discussed the API change process, with Ethsim2 proposing a resilient workaround using [event] BBCode to avoid breaking changes in calendar API endpoints. read more
  • A thread on OIDC Error was marked solved after screwballs identified expired client keys as the culprit when ./launcher bootstrap app failed. read more
  • The AVIF image embedding challenge for online book reading prompted recommendations for streaming-optimized readers and cloud-drive integrations to handle on-demand previews. read more
  • A Firefox-specific bug prevented the (+) menu drop-down from appearing unless in full-screen mode. Safe mode revealed a theme/component conflict behind the issue. read more
  • MentalNomad reported that the deprecated Discourse Encrypt plugin broke replies after the latest update, prompting warnings about its incompatibility and calls for offline decryption resources. read more
Bug
  • In the Daily summary AI issue, Ethsim2 highlighted a rogue “I’m sorry…” system reply in the automated summary, confirmed as a glitch rather than an easter egg. read more
  • The Rich text editor was found to drop [event] tags on Apple platforms, with j.jaffeux assuring support for calendar events in the next update. read more
  • selase investigated how hidden tag groups still allowed watchers to follow tags when permissions were toggled, seeking repro steps for the tags issue. read more
  • Reports surfaced that Horizon theme category images were not displaying, spurring users to test theme galleries and file bug reports. read more
UX
  • On iOS, Firefox users found HTML entities in bookmarks rendered as isn%rsquo;t instead of isn’t. Lilly confirmed the issue across browsers. read more
  • The mobile navbar placement of “Keyboard shortcuts” and “Add custom section” was deemed inconsistent with desktop, leading to calls for uniform bottom placement. read more
Feature
Theme component
  • The Custom Topic Sort Order Button merged new options—likes on OP, number of posters, category ID, and votes—expanding topic-voting and sorting flexibility. read more
#Developer Guides
  • Guides for installing Discourse received updates: Docker setup now supports user impersonation via /session/any-username/become, and macOS instructions recommend PostgreSQL 14+ with pgvector and ImageMagick. Docker guide | macOS guide
Hope your themes stay smooth and your puppies are safe after this whirlwind of layout tweaks, API hacks, and encryption escapades!
