DiscoTOC - טבלת תכנים אוטומטית
:discourse2: Summary DiscoTOC will allow you to generate an interactive table of contents for your topics with one click!
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/DiscoTOC
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Samples
Desktop
Mobile
Features
toc = table of contents
  • Automatically generates the entire toc via a button in the composer gear menu
  • The toc will always be on the screen - scrolls with content like the topic progress widget
  • As you scroll past sections in the topic, the active element in the table of contents will be set to active (blue highlight)
  • adds id attributes to headings (you can link to a specific section from another topic / post)
  • clicking on any link in the toc will instruct the browser to navigate to relevant section (smooth-scrolling)
  • adds a copy-able link next to each heading (if you want to link to it)
  • RTL support
  • The colors are based on your current active color palette
How does it work?
In a nutshell, it looks for headings in topics which are marked to have a toc (via the composer button) and if it turns out the current topic is marked, then it takes all the headings and puts them in the toc (nested in order of heading levels) - this means that your markdown must be syntactically correct.
# heading 1
## heading 2
### heading 3
#### heading 4
##### heading 5
###### heading 6
You’re free to go back and fourth in heading levels, but the order must be correct
# heading 2
## heading 3
## heading 3
### heading 4
## heading 3
# heading 2
etc...
In order for the links in the toc to work, headings must have id attributes. The component will check if the headings already have ids and if they do, then they are respected. This is handy if you ever manually created a toc.
If the headings don’t have ids, then it will generate an id for each heading based on its text (unwanted characters are stripped out)
once all of that is done, it will also add a link next to each button that links directly to that section:
Settings
Name Description
minimum trust level to create TOC The minimum trust level a user must have in order to see the TOC button in the composer
composer toc text Text that appears at the top of the preview pane of the composer to indicate the topic will have a table of contents
auto TOC categories Automatically enable TOC on topics in these categories
auto TOC tags Automatically enable TOC on topics with these tags
TOC min heading Minimum number of headings in a topic for the table of contents to be shown
Translations
Translation Default
table_of_contents table of contents
insert_table_of_contents Insert table of contents
jump_bottom Jump to end
toggle_toc.show_timeline Timeline
toggle_toc.show_toc Contents
The theme comes with three strings that you can translate or change.
table_of_contents: "table of contents"
this used for the button that opens the toc on mobile
insert_table_of_contents: "Insert table of contents"
this is used as the text for the toc button in the composer gear menu
topic_will_contain_a_table_of_contents: "This topic will contain a table of contents"
This is the text that shows up in the composer preview to indicate that the a toc will be generated for the topic
How do I create a toc?
  1. Write a topic with syntactically correct headings
  2. Click the toc button in the gear menu (only shows up when creating a regular topic - replies and PMs are ignored
  3. Profit.
What happens to the topic progress widget when a topic has a toc?
As you can probably guess, there’s no space to show both at the same time, so the way this component works is as follows
in a topic with a toc, the topic progress widget is hidden while the first post is on screen, and you see the toc instead.
Once you scroll past the first post, the toc will not scroll with you and the topic progress will be shown instead while you read any replies.
So, first posts get the toc, and subsequent posts get the regular topic progress widget.
The happens on both desktop and mobile.
Are there any downsides to using this component?
Nothing I am aware of, all the changes are done on the client-side. So you can easily remove the component and your posts would go back to the way they were before you installed it.
Limitations
This component assumes the standard topic layout. As such, it won’t work with themes that modify that layout such as the Vincent theme. Support for popular themes that modify the layout will come at a later stage in the form of component settings.
Credit
I started with Greg Franko’s tocify.js library. However, it looks like it’s not been updated in a while, so this is essentially a hard-fork that removes a lot of unnecessary features, integrates and styles the rest for Discourse.
So, there are no external requests and the total size is ~ 4kb gzip.
Big thanks to @erlend_sh for lots of valuable feedback and to @david for his help with translations.
:discourse2: Hosted by us? Theme components are available to use on our Pro, Business and Enterprise plans.
181 לייקים
Automatic Table of Contents generation
Creative Uses of Discourse
Wiki improvement – Split content into multiple sections?
Blog Post Styling
Linking to a heading within a post or topic
Understanding Discourse for new users
:cn: DiscoTOC 自动内容表格
How do you create a table of content like this one?
What are the different ways to customize content inside a post (custom attributes and such)
How to get topic navigation menu
Theme Components - Can Discourse hosted sites install them?
Big Header - Little Header
How can i show a floating sticky 300x250 Adsense Ad on right side bar of topic page above the fold?
Tagged topic progress bar - feasible or not?
Timeline with labelled step by step sections - how is this achieved?
Reader Mode
Is anyone working on a Discourse Wiki?
How To Add Marker To Table Of Contents Feature?
Traditional multi level hierarchy vs flat discourse hierarchy
How do I add a table of contents sidebar to a topic?
Cannot deep link to anchor in text
How can I compare arbitrary revisions of a post?
Problem with DiscoTOC: TypeError: _offsetCalculator.headerOffset is not a function
How to create an In-app Knowledge Base with Discourse Docs?
OP Contents on Progress Bar
How to get topic sidebar
Customizing your site with existing theme components
Link to headers (anchor links)
Outline Enable
What is essential content for a new community?
Tools for creating image-heavy articles
Adding DiscoTOC to Published Pages
Customize Your Site Branding
Discourse Doc Categories
Gif icon not displaying and showing error
Must have plugins and components for Discourse?
I created a bookmarklet to create the table of content for forum posts
Could a List of Recommended Topics Be Added to the Top Menu?
?page=n URLs have high CLS hence bad SEO
Something recently changed, can't increase `--topic-body-width`
How to enable side navigation?
Improve iPad screen real estate
Missing strings (DiscoTOC)
Missing anchor links in certain TOC topics?
DiscoTOC not showing in composer after latest component update
How to create a documentation theme used by discourse
Where's Jump to end?
Handling anchors in posts created with markdown
Reader Mode
Hidden Timeline button
Horizon Theme
Bulk Export of Raw Post Sources with Markup
:cn: Discourse Post Formatting Guide 加点格式,让帖子多姿多彩
Wiki table of contents on pro plan
Auto-Linkify Words
Collections
Living with corrupted SVGs for almost a year. Need Help!
Require users to "Reply as Linked Topic"
Links not working
Blog Post Styling
Using Posts as a Wiki?
DiscoTOC & Brand Header - using together
Docs: Add link to top menu
Layouts Plugin
More than two levels of [details]
Discourse Docs
Category page with fixed organization of topics
Blog Post Styling
Inlink the topics within the same article
Navigating to local URL fragment doesn't modify browser history
Relating to Profile Picture Scroll Functionality
Copy pasting nested lists from Word into a post
Need to include PGN (chess game notation) in a post
How can I get a table of contents for my docs?
Topic list on the right side
Set up Slack notifications using the discourse-chat-integration plugin
Wrong title in the history popup (firefox)
Possible to insert post in a topic
How to add table of content sidebar beside a topic?
4 posts were split to a new topic: How to move the TOC to the left side of the post?
I don’t know how this component is implemented or much about the frontend structure of Discourse, so I can only throw in a guess.
Couldn’t the progress bar only be shown a) if more than 1 post in the topic and b) adjust its start to be from the 2nd post (instead of 3rd), but also c) add some comfortable bottom/top margin to one of the two elements to make sure the other remains distant enough (eg 1vh) as to not make it strange looking?
In other words, instead of using the whole 2nd post as a gap, use CSS to allow some room between them (iff there’s more than 1 post).
Again, this might not make any sense at all as I don’t know much about the way this is working atm.
3 לייקים
Hi there! We recently installed DiscoTOC for our forums and were wondering if it’s possible to get the component to read alt text in images? We’ve used images for some patch note headers…
like so:
Performance and Stability
And unfortunately the TOC system doesn’t seem to be able to parse an image as a header, creating a blank entry on the list and creating a link that takes you to a blank page. Is there any workaround for this beyond “don’t use images”? Thank you! Love the system otherwise.
לייק 1
My guess is that the solution is to not use images as headings, but possibly there will be a way to get it to work by adding some code to your site that hooks into the DiscoTOC code. Whether or not it’s worth looking into that will depend on how important it is for you to use images in the post’s headings.
3 לייקים
We’ve been using images as headers in our patch notes consistently for quite some time now, and it’s a part of our branding and presentation; not just on the forums, but on Steam and such as well. We would like to have the ability to continue using images as headers while using DiscoTOC in order to remain consistent.
DiscoTOC has been great for other things such as for an AMA recap, a megapost about our dedicated server launcher app, new player guides, etc. We like the system a lot, but would love for a little extra functionality for the way we present patch notes.
לייק 1
The heading anchor functionality on this component slightly conflicts with the Automatic header links functionality added in 2.7.0beta6, since headings get two icons on hover, one from Discourse and one from DiscoTOC. Is there a way round this?
לייק 1
Hello,
You can hide the Automatic header links anchor with
.anchor {
  display: none;
Hi dodesz,
I made the post width much larger than the default one, and after install this component it looks something wrong, could you tell me how to fix this problem?
:heart: thanks!
לייק 1
On a forum running Discourse 2.8.0.beta4 (90232af778), including the DiscoTOC component leads to an error message:
The component had been activated before and raised an issue with the previously installed Discourse version as well, although I cannot say which version that was.
Are you able to find any error messages related to the issue in your site’s error logs?
That error message is a backend error, while DiscoTOC is a front-end theme-component so it’s hard for those to be related. Do you have any plugins installed?
לייק 1
Unfortunately, I couldn’t find anything useful in the /logs.
I do, here’s the relevant excerpt from app.yml:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-openid-connect.git
          - git clone https://github.com/discourse/discourse-checklist.git
          - git clone https://github.com/discourse/discourse-push-notifications.git
          - git clone https://github.com/discourse/discourse-characters-required.git
          - git clone https://github.com/angusmcleod/discourse-news.git
          - git clone https://github.com/discourse/discourse-data-explorer.git
          - git clone https://github.com/DNOeV/discourse-watch-category.git
          - git clone https://github.com/discourse/discourse-footnote.git
          - git clone https://github.com/discourse/discourse-knowledge-explorer.git
לייק 1
When a header is within a quote, the header doesn’t show up in the TOC. Could this behavior be changed?
This header won’t show up in TOC
Quoted content
This header DOES show up in TOC
Quoted content
I don’t know how it is planned to work but normally no because it’s part of quote, not a heading of that text.
לייק 1
Could you try using the html <blockquote> instead? That would allow the header # to be at the start of a line.
Eg:
<blockquote>
### Anchor Header
</blockquote>
Anchor Header
I’ve not tried it in a TOC, but it seems to work with the auto-anchor-headers in a regular post.
Why do you want headers within quotes to show up in the TOC? What’s your use case?
Thank you for the idea. It didn’t work for me, though.
Here’s an example of when I use quotes to visually structure content starting under Issue Area: Age
3 לייקים
Why are you using quoting like that? Telling source is enough. Plus grammatically that is wrong, in english too.
Is this a bug or just another user, but… how should I close the TOC? I was looking for some basic instructions how an enduser should use private messages and of course I went to new users doc and opened the TOC to see if there is some info.
I was using iPad and DiscourseHub.
I got this:
The TOC is just fine. But it is overlapping text and I coudn’t get is suppress back. So what the heck I did wrong, or didn’t at all :pleading_face:
