Calendrier Discourse (et Événement)
:discourse2: Summary Discourse Calendar and Event adds dynamic and interactive calendar and event features to your Discourse site.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
Enabling Calendar (and Event)
The Calendar plugin can be enabled either by the toggle or from its settings, both accessible from your admin/plugins page:
/admin/plugins
Features
Somewhat unsurprisingly, Discourse Calendar (and Event) adds both the calendar and event features to your Discourse site. With these, you can create individual topic calendars to track important occasions or timelines, display calendars in categories, add a holiday calendar to mark vacations, absences, or sick days, create interactive event topics, as well as show an easy-access calendar summary of all of your upcoming events.
Calendars
Bespoke calendars can be created in multiple topics, and ones you wish to give higher visibility to can be displayed above a category’s topic list.
You can find more detailed information on how to create and use calendars in:
Events
The Event feature allows interactive elements to be inserted into topics which your members can use to sign up to attend or participate in your community’s activities. These are all summarised in a dedicated site-wide calendar, with the option to add an easy-access link to your navigation menu. You can find more information on how to create and use this feature in:
:exclamation: This should not be confused with Pavilion’s Events plugin (note the plural)
Calendar Settings
Name Description
calendar enabled Enable the discourse-calendar plugin. This will add support for a [calendar][/calendar] tag in the first post of a topic.
holiday calendar topic id Topic ID of staffs holiday / absence calendar.
holiday status emoji Defines the emoji used for the holiday status.
delete expired event posts after Posts with expired events will be automatically deleted after (n) hours. Set to -1 to disable deletion.
all day event start time Events that do not have a start time specified will start at this time. Format is HH:mm. For 6:00 am, enter 06:00
all day event end time Events that do not have a end time specified will end at this time. Format is HH:mm. For 6:00 pm, enter 18:00
calendar categories Display a calendar at the top of a category. Mandatory settings are categoryId and postId. eg: categoryId=6;postId=453[1] Other valid settings: tzPicker[2], weekends[3] and defaultView[4].
calendar categories outlet Allows to change which outlet should show the category calendar.
working days Set working days. You can display the availability of a group using the timezones tag in a post, eg: [timezones group=admins][timezones]
working day start hour Start time of the working day hours.
working day end hour End time of the working day hours.
close to working day hours extension Set extension time in working day hours to highlight the timezones.
calendar automatic holidays enabled Automatically set holiday status based on a users region (note: you can disable specific automatic holidays in plugin settings)
map events title Maps title of the sidebar calendar based on category. Defaults to “Upcoming events”
Event Settings
Name Description
discourse post event enabled Enables the Event features. Note: also needs calendar enabled to be enabled.
discourse post event allowed on groups Groups that are allowed to create events.
displayed invitees limit Limits the numbers of invitees displayed on an event.
display post event date on topic title Displays the date of the event after the topic title.
use local event date Use local date after topic title instead of relative time.
discourse post event edit notifications time extension Extends (in minutes) the period after the end of an event when going invitees are still being notified from edit in the original post.
discourse post event allowed custom fields Allows to let each event to set the value of custom fields.
events calendar categories Display an events calendar at the top of a category.
sort categories by event start date enabled Enable the sorting of category topics by event start date.
disable resorting on categories enabled Allow categories to disable the ability for users to sort on the event category.
sidebar show upcoming events Show upcoming events link in the sidebar under ‘More’. Requires post event enabled
map events to color Assigns an event color to a specified tag or category
:information_source: :curling_stone: The discourse-post-event/events.json endpoint now has an added parameter to switch between simple and detailed response. To get the detailed response you can add ?include_details=true:
/discourse-post-event/events.json?include_details=true
Integrations with Other Plugins
You can use a component from this plugin with Right Sidebar Blocks. You’ll want to ensure the desired route is enabled in the Right Sidebar Blocks component. The block name will be upcoming-events-list. Historically, there were additional settings required in the Calendar plugin itself, but this has been streamlined.
This is how the sidebar calendar will appear by default.
If you don’t want the time, you can add an empty timeFormat value in the component’s block setting.
:discourse2: Hosted by us? This plugin is available on our Business and Enterprise tiers Calendar | Discourse - Civilized Discussion
  1. categoryId is the category the calendar will be displayed on top of.
    postId is the post in which you put the calendar in with [calendar][/calendar] ↩︎
  2. it can display a time zone picker on the upper right of the calendar. False by default, you can enable it with tzPicker=true ↩︎
  3. it can hide Saturdays and Sundays from the calendar. True by default. You can set it to false with weekends=false. ↩︎
  4. defaultView will set the calendar’s view (day, week, etc;). It can be set as:
    defaultView=agendaDay
    defaultView=agendaWeek
    defaultView=month (default)
    defaultView=listNextYear ↩︎
97 « J'aime »
How to use the calendar plugin?
Events Plugin :calendar:
Discourse Calendar - How to?
Calendar plugin, nothing is displayed
Discourse 2.2.0.beta3 Release Notes
Discourse Calendar dislpay link text rather than link url
Ability to mark any post as unread
Is there a room booking plugin?
📅 Event List Widget (Layouts Plugin)
I am looking for a webhook or event api
Inserting date/time into new topic's title field (ie, right here > !)
Db:migrate fails on discourse-calendar
Creating sub-communities in a discourse server
Plugin to show upcoming events on hosted discourse
Please better document the Discourse Calendar plugin
Go from a Wordpress + Discourse structure to a Discourse site only?
Vacation autoresponder for users who are away?
Plugin to gather approvals / signatures on an initiative?
Moderator/Admin Off Duty Button
Add recurrent items within a date-range
Use Case Question - Room/Equipment Booking
Best practices for communicating to user base
Integrate with Discourse-calendar
My Wiki of useful Meta (and other) links
Quotes in event name clears attendees
Calendar in Discourse
Show Cakeday dates on the Calendar plugin
Agenda de colegio
Display a category as a calendar by scheduled Topic-timer dates
Why you should use Discourse internally for your company/team instead of Slack (4 years use case)
SEO applied to Discourse Official Plugins
Help us test Horizon, our newest theme
How to display different calendar views?
Discourse calendar and event iCal integration?
Can the auto-responder fire on @mentions?
Event/Calendar Plugin - Cannot select a user for bulk-invite
Bulk Invite via modal only allowing one user (and not displaying correctly)
Event Creation
500 Error when posting, moment.tz runtime error
Best practice for a topic for a recurring event
How to get "back" btn
Event Chat Channels Now Available
📅 New Calendar Feature: End Date for Recurring Events
🌍 New Calendar Feature: Show Local Time
What livestream/webinar platforms do you use?
Custom Wizard Plugin :mage:
ICS → Discourse Importer
How have you built a local community around Discourse?
What happens next?
Bundling more popular plugins with Discourse core
It is very difficult to make events all day in the events modal (and 00:00 is confusing)
When "closing" event it moves it to today's date & time
Category Calendar with defaultView="listNextYear" not showing events
Calendar Core - Needs any special theme?
Creating and managing calendars
Sorting Categories by Title
Creating and managing events
The "Save Changes" button is very low on my user preferences interface page
Group Timezones
Available hours / work hours flair
Could use help, setting up new community
Feature request: wrap calendar items when there's just one per day
Custom Discourse instance for a writers club
Unread messages blue numbers appearing in Latest lately (when they shouldn't)?
Database migration chokes on huge value of a "calendar-details" item in table "post_custom_fields"
"Out of office" user indicator
Calendar plugin features to make it really useful for us
Topic List Previews (TLP)
Can discourse display topic replies in reverse order?
Discourse Livestream
New to Discourse, have some questions :)
Expired events with end times are being removed from upcoming-events even with setting set to -1
Setup Continuous Integration using GitHub Actions
Add color to events based on event category or tag?
Is there any way to change the starting date of the Calendar?
Ce plugin est prometteur - mais il manque certaines fonctionnalités qui nous empêchent de passer du plugin de Pavilion
  • Afficher les événements non journaliers avec l’heure de début sur le calendrier, actuellement tous les événements ressemblent à des événements d’une journée.
  • Bouton « Ajouter un événement » dans le compositeur à côté du sélecteur de balises (pas caché dans le rouage)
  • Limiter quelles catégories peuvent avoir des événements et si les événements sont obligatoires dans une catégorie
Les « nice to haves » :
  • Les métadonnées d’événement dans le sujet n’apparaissent/ne sont saisies qu’en haut du sujet (au lieu de là où se trouve le curseur)
  • possibilité de limiter quels groupes peuvent créer des événements dans une catégorie (par exemple, seul le groupe « EventPlanners » peut créer des événements dans la catégorie « Discussion », mais tous les utilisateurs peuvent créer des sujets non événementiels (ou modifier des sujets si le sujet est défini sur Wiki))
  • changer l’URL de /upcoming-events en /calendar
13 « J'aime »
2 messages ont été déplacées vers un nouveau sujet : Le statut des jours fériés est appliqué de manière incorrecte
Bonjour,
Merci pour ce travail.
J’ai 2 questions UX :
  • Est-il possible d’afficher le bouton « Ajouter un événement » à côté du bouton « Ajouter un lieu » dans l’éditeur de sujet ? Comme c’était le cas avec le plugin pavillion ?
  • Est-il possible d’ajouter une entrée de menu supérieur Calendrier ? Je ne la trouve pas dans les paramètres
Cela semble excellent ! Quelques réflexions/questions :
Suis-je dans l’erreur en supposant que pour créer un calendrier, il suffit de créer un nouveau fil de discussion/sujet et d’y coller ceci :
Nom du Calendrier
[calendar]
[/calendar]
Ensuite, pour ajouter des entrées au calendrier, il suffit de faire un nouveau message dans le même fil de discussion avec quelque chose comme ceci (en cliquant sur l’icône insérer date/heure dans les options de publication) :
Nom de l'événement/de l'entrée
[date-range from=2024-04-18 to=2024-04-19 timezone="Europe/London"]
Cela ajoute l’entrée au calendrier, ce qui est génial, cependant :
  • Y a-t-il un moyen d’ajouter des entrées à un calendrier tout en permettant à ces entrées d’avoir également un fil de discussion/sujet dédié ? (Je vois que l’on peut ajouter des événements dans de nouveaux fils de discussion, mais il ne semble y avoir aucun moyen d’ajouter ces événements à un calendrier).
  • Y a-t-il un moyen de mettre en avant les « Événements à venir » d’un calendrier spécifique dans les e-mails récapitulatifs ? Ou peut-être dans la colonne de gauche, et que chaque entrée soit liée au fil de discussion dédié pour cette entrée ?
Si ce n’est pas possible actuellement, avez-vous des projets pour l’ajouter ?
1 « J'aime »
@vinothkannans Pourriez-vous m’aider à examiner cette PR ?
1 « J'aime »
Y a-t-il des projets pour ajouter un flux URL auquel les utilisateurs peuvent s’abonner ? Je suis sûr que ce serait délicat pour tous les événements par rapport à ceux auxquels ils ont répondu.\n\nDeuxièmement, une couche supplémentaire serait incroyable si elle pouvait reconnaître les événements privés (ou peut-être s’agit-il simplement d’un flux URL différent par groupe).
6 « J'aime »
Il n’y a cependant pas de flux RSS pour l’URL /upcoming-events — ce serait un ajout intéressant !
3 « J'aime »
Qu’en est-il de la synchronisation CalDAV ?
6 « J'aime »
Ce serait aussi pour moi une raison de changer, en effet.
Cela nécessite plus de mises à jour car cela mentionne une insertion d’événement dans le compositeur et l’ajout de détails d’événement non tels qu’illustrés. À moins que l’événement ne soit un module complémentaire ?
J’ai installé le plug-in et la balise calendrier fonctionne dans le premier message d’un sujet. Mais je ne vois aucune option d’événement ou de calendrier dans le menu d’engrenage :
Quelqu’un peut-il m’expliquer ce que je dois faire pour obtenir l’option d’événement dans le menu d’engrenage ?
Vous devez activer la partie Événement du plugin discourse post event enabled
2 « J'aime »
Merci. J’ai d’une manière ou d’une autre manqué ce paramètre.
3 « J'aime »
Comment créer un événement pour qu’il s’affiche dans un sujet de catégorie avec des réponses qui sont des événements ?
Je vois que la création d’événement fonctionne pour la création de nouveaux sujets. Mais je cherche à avoir un calendrier dans un sujet où les réponses ajoutent des événements. Cela fonctionne partiellement avec l’insertion de date, mais ce n’est pas aussi bien que la création d’événement qui offre plus d’options.
1 « J'aime »
Actuellement, les utilisateurs peuvent définir la région dans les préférences de leur profil.
J’aimerais leur permettre de définir leur région lors de l’inscription en affichant ce champ dans le formulaire d’inscription. Est-ce réalisable ?
2 « J'aime »
Une réponse supprimée apparaîtra-t-elle toujours dans le calendrier ?
Je ne trouve aucun paramètre pour changer le premier jour de la semaine en lundi, est-ce facile à implémenter s’il manque ? :thinking:
Un autre problème est que la saisie de l’heure et de la date est cassée, s’il s’agit d’un événement d’une journée entière, il devrait y avoir une option pour le sélectionner avant que les champs de saisie de l’heure ne gâchent les dates, et les dates semblent changer aléatoirement lors de la modification.
J’ai également remarqué qu’il est possible d’entrer 00:00 dans l’heure et la date, (ce qui fonctionne parfois, parfois pas) ce qui entraîne une erreur du calendrier qui provoque alors un conflit avec les brouillons, entraînant une erreur 422 répétée jusqu’à ce que la page soit restaurée à une révision antérieure, puis rééditée, etc.
3 « J'aime »
[quote=“slower, post:10, topic:277113, full:true, username:joo”]
Lorsque j’active cette automatisation, le contenu « Dernière modification par » est automatiquement ajouté au calendrier. Je cherche des conseils pour savoir s’il s’agit d’un bug ou d’un problème avec mes paramètres. Quelqu’un pourrait-il m’aider à clarifier ?
[/quote]Veuillez vous référer ici
1 « J'aime »
Il n’y a pas de tel réglage et c’est pourquoi je ne l’utilise pas. Et je parie que l’équipe corrigerait cette erreur si c’était une astuce triviale.
1 « J'aime »
