تكوين البريد الإلكتروني الوارد لإنشاء مواضيع جديدة أو تجميع الرسائل
:bookmark: This guide explains how to set up incoming emails to create new topics or group messages in Discourse, including configuration of site settings and category or group-specific settings.
:person_raising_hand: Required user level: Administrator
This guide covers:
  • Enabling and configuring incoming emails
  • Choosing between category and group for incoming emails
  • Setting up incoming emails for a group
  • Setting up incoming emails for a category
  • Deciding how forwarded emails are handled
:information_source: If you have already set up reply via email, or you are on a hosting plan that pre-configures your incoming email, you’re now ready to set up Starting a New Topic via Email.
Configuring site settings
To enable incoming emails, you need to configure three main site settings:
  1. email_in: This setting must be enabled for incoming emails to work.
  2. email in allowed groups: Users must belong to this group to send an email to Discourse.
  3. enable_staged_users: This setting allows the creation of staged users for unknown email addresses.
:warning: For Discourse hosted sites, the enable_staged_users setting is disabled and hidden during the trial to prevent abuse. Once a subscription is started, the setting is unhidden. To ask for it to be enabled during your trial, contact team@discourse.org.
To configure these settings:
  1. Go to your site’s Admin panel
  2. Navigate to Settings
  3. Search for each setting and configure as needed
:information_source: Staged users are special user accounts in Discourse created to support incoming emails from anyone. They have limited functionality:
  • Can’t be mentioned or searched for
  • Don’t receive digests
  • Can only be notified of and reply to topics they started or were invited to
  • Will be promoted to a normal user if they create an account using the same email address
Choosing between categories and groups
Decide whether you want incoming emails to create topics in a category or messages in a group.
Using a group
Benefits of using a group:
  • Useful for setting up a support-like workflow
  • Creates a message sent to all group members
  • Messages appear in /my/messages
  • Anyone can send an email to the group
  • Any group member can read, reply, delete, or archive the message
  • Each group member has their own read tracking state
Using a category
Benefits of using a category:
  • Simulates a mailing list
  • Creates a topic in the specified category
  • Anyone with access to the category can read and reply via web interface or email
  • Respects category security settings
  • Respects the email in allowed groups site setting
  • Allows disabling staged users on a per-category basis
To configure incoming emails for a group:
  1. Go to the Groups page from the main menu
  2. Click on the group name (or create a new group)
  3. For a new group, find the “Custom incoming email address” field at the bottom of the form
  4. For an existing group, go to the Manage tab, then click Interaction in the left side menu
  5. Enter the email address(es) you want to associate with the group (separate multiple addresses with |)
  6. Click Save to apply the changes
:warning: For Discourse hosted sites, check the “Accept incoming emails sent to:” box and forward your custom email(s) to this address for proper functionality.
To configure incoming emails for a category:
  1. Go to the category page (e.g., /c/<category_slug>)
  2. Click the Edit button
    Edit category button
  3. In the Edit category modal, click the Settings tab
  4. Look for “Accept emails from anonymous users with no accounts” and “Custom incoming email address” fields
  5. Enable “Accept emails from anonymous users with no accounts” if you want to create staged users for unknown email addresses
  6. Enter the email address(es) you want to associate with the category
  7. Click Save Category to apply the changes
Forwarded emails behavior
You can decide how forwarded emails appear in Discourse using the forwarded emails behaviour site setting, which has the following options:
  • hide - a new new topic or PM will be created with the forwarded text included as hidden text that can be expanded to view
  • quote - a new topic or PM will be created with the forwarded text included as quoted text.
  • create replies - a new topic or PM will be created authored by the original sender. Replies will be created authored by participants in the email. If the user accounts do not already exist matching the sender email addresses, they will be created as staged user accounts.
Additional resources
50 إعجابًا
تم تقسيم 3 مشاركات إلى موضوع جديد: لا يمكن تعيين البريد الإلكتروني لمجموعة موجودة؟
تم تقسيم منشور إلى موضوع جديد: هل يمكن للذكاء الاصطناعي الرد تلقائيًا على البريد الإلكتروني
بعض الأفكار حول الخيار الوارد للبريد الإلكتروني المعاد توجيهه (لأن عنوان المستلم الأصلي محفوظ بدلاً من تغيير العنوان إلى العنوان المعاد توجيهه).
الحالة: لدي حساب Atlassian Confluence مع بريد إلكتروني شخصي مرتبط lee@dot.com. أردت تلقي رسائل بريد إلكتروني حول أي تغييرات في المساحة وجمعها في مكان واحد في منتدى. لذلك قمت بإنشاء اشتراك للمساحة بأكملها. تحتوي هذه الرسائل الإلكترونية التي تم إنشاؤها تلقائيًا على عبارة “Stop watching” (إيقاف المشاهدة)، والتي خططت لاستخدامها كنمط تصفية.
في إعدادات صندوق البريد، قمت بتمكين قاعدة إعادة توجيه للرسائل الإلكترونية التي تتضمن هذا النمط، كما هو موضح في الصورة أدناه. يجب إعادة توجيه البريد الإلكتروني إلى bob@ex.com. يتوافق هذا البريد الإلكتروني مع فئة منتدى معينة. بعد المعالجة، يتم حذف هذا البريد الإلكتروني تلقائيًا من صندوق البريد الخاص بي lee@dot.com، لذلك لا يتعين علي التعامل مع فيض الرسائل الإلكترونية.
كما اتضح، تم تعيين رسائل البريد الإلكتروني الموجهة مباشرة إلى bob@ex.com بشكل صحيح إلى فئة المنتدى. ولكن الرسائل المعاد توجيهها لسبب غير معروف ذهبت إلى قسم غير مصنف.
ربما سيبحث شخص ما عن حل للمشكلة نفسها التي واجهتها. لذلك سأصف المشكلة.
عندما نظرت بعناية إلى قسم السجل في /admin/email/received، وجدت أن حقل TO في الرسائل المعاد توجيهها يحتوي على عنوان بريدي الشخصي، وليس العنوان الذي حددته في خاصية الفئة. وهذا هو ما يجب أن أضعه في الفئة كعنوان البريد الإلكتروني الوارد.
شرح:
  • رقم 1 (بريد إلكتروني مباشر) يذهب إلى الفئة الصحيحة
  • رقم 2 ورقم 3 (رسائل معاد توجيهها) تذهب إلى غير مصنف
وبالتالي، ساعدني تلميح النافذة المنبثقة في فهم العنوان المستخدم في حقل TO. ربما يكون هذا صحيحًا هنا، أو ربما سيتم إصلاحه في المستقبل، ولكن في الوقت الحالي يعمل بهذه الطريقة.
