Multisite configuration with Docker
:warning: While multisite is supported in the Discourse application, this is an advanced sysadmin setup. If you don’t know what you’re doing, do not set up multisite. The Discourse team is unable to provide multisite configuration support.
If you wish to host multiple domains on a singled Docker setup, you’ll need a multisite configuration. Here are the basic building blocks for one.
Understand hooks
Multisite is a fairly advanced topic. Before attempting a multisite build, spend some time to learn about them.
Discourse templates use pups; its rules are simple and powerful.
Each rule you run may define a hook:
run:
  exec:
    cd: some/path
    hook: my_hook
    cmd:
      - echo 1
Later on in your container you can insert rules before or after a hook:
hooks:
  before_my_hook:
    - exec: echo "I ran before"
  after_my_hook:
     - exec: echo "I ran after"
So in the example above you will see output like the following:
I ran before
1
I ran after
You can read through the templates in /var/discourse/templates to see what hooks you have available.
Amend your standalone container to provision the second site tenant
Replace the entire hooks section with:
hooks:
  after_postgres:
     - exec: sudo -u postgres createdb b_discourse || exit 0
     - exec:
          stdin: |
            grant all privileges on database b_discourse to discourse;
          cmd: sudo -u postgres psql b_discourse
          raise_on_fail: false
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "alter schema public owner to discourse;"'
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists hstore;"'
     - exec: /bin/bash -c 'sudo -u postgres psql b_discourse <<< "create extension if not exists pg_trgm;"'
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
  before_bundle_exec:
    - file:
        path: $home/config/multisite.yml
        contents: |
         secondsite:
           adapter: postgresql
           database: b_discourse
           pool: 25
           timeout: 5000
           db_id: 2
           host_names:
             - b.discourse.example.com
  after_bundle_exec:
    - exec: cd /var/www/discourse && sudo -H -E -u discourse bundle exec rake multisite:migrate
There are 3 hooks in play:
  1. after_postgres ensures that after postgres is installed an additional db called b_discourse is created with the appropriate permissions.
  2. before_bundle_exec, ensures docker_manager is in place and that the multisite.yml file is in place (which defines where to find the databases)
  3. after_bundle_exec, runs the custom db migration task rake multisite:migrate this ensures all the dbs are up to date.
Note on configuration
The above sample can be split into data container / app container if needed. Just run the after_postgres hook in the data container and the rest in web container.
The above sample can be extended to provision even more DBs. To do so, provision more DBs by duplicating the create db etc calls, and make sure you add additional sites in multisite.yml.
Make sure you amend the host_names node in multisite.yml to match the actual host name you wish to host.
Also, if you plan to run HTTPS, you will need a proxy in front of the site to handle it as the built in letsencrypt functionality will not work in a multisite scenario.
How does multisite.yml look?
Multiple Forums in a Single Installation
How to create 1000 subcategories in a scalable way?
Multiple Discourses, multiple containers, one server
Pros and cons of multiple standalone containers vs one for multiple Discourse installs?
Success - New Multisite Install on Dedicated server using ServerPilot, Nginx and Apache
Multisite Installation
Will I need to start over with multisite configuration from standalone version?
Multiple Discourse Installs - Single Server
Starting a second Discourse forum on the same VPS
Pros and cons of a multisite installation
Installation wizard not appearing in multisite installs
Disabling/restricting user search
Sandbox and test discourse on host?
Multisite installation with seperated smtp emails
How do you set up multiple discourse forums on the same server?
Help me setup many websites on one VPS
Second discourse instance on the same server
Discourse multisite installation help with digitalocean
Need proper documentation for multisite discourse with docker
Discourse for 3 different Countrys
Micro Forums: how many could I create?
Remove sites from multisite config with Docker
How could I install another discourse on same server (docker)?
Can I log into multiple instances of discourse simultaneously?
How to setup host mapping on a multi-site discourse instance
Not receiving activation email for admin on multisite installation
Multisite viability - 2 read-only and 1 active
Install Discourse on Plesk / Ubuntu 14 without Docker
Totally Walled-Off Groups
Three sites in one setup
I want to host hundreds of instances of Discourse
Recover to one site from multisite
Publishing multisite
Multisite Config
Multiple communities on discourse?
Adding an instance to multisite without rebuilding the container
Is it possible to totally hide members
Need help with multisite configuration
Multitenat Dockerize Discourse
Installing on Kubernetes
How might we better structure #howto?
How to set redis DB ID in Docker container?
Pull request for Wikis?
How can I host more than 1 Discourse forum on 1 VPS?
Multiple discourse installation on single droplet
Integration with .NET MVC application for a SaaS platform
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
Docker image update: Redis 6 and 25% smaller image size
One server for 2 Discourse communities?
Multiple discourse instances in a single server
Pups::ExecError
Web-only - do I need a separate image for each container?
Multisite installation ... in subdirectories?
Stable branch assets won't compile
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR: column categories.search_priority does not exist
[mutlisite installation] pnpm permission error during rebuild
WP SSO + Discourse Multisite
All users are visible in @mentions autocomplete list
Migrate from VPS to a Dedicated
Are there other workarounds to not having category moderation such as multiple instances of the board?
Discourse Multisite – Nginx (Inside Docker) Only Serving Default Site
Two Discourse communities on the same VPS
How can I use different setting value for subdomain?
Will This Configuration Successfully Create a Second Discourse Instance (with Proxy)?
Pups::ExecError
Use CloudPanel to manage multiple sites with Discourse
Best approach for test and production instance of discourse
Two standalone instances on one server?
How can Admin login while Read-only mode is enabled on multisite?
Does discourse hosting use docker for all customer instances?
Tips for setting up a multi-subdomain Discourse instance with shared SSO?
Feature proposal: Customizations based on primary group membership, a.k.a. tenancy 'lite'
Using a launcher built docker image in docker-compose
Move from standalone container to separate web and data containers
Guidance on multi-site setup
Running multiple things on the same sever as my Pi (where Discourse is hosted)?
Contabo experience with Plesk, Webmin or other server-admin setup?
App.yml shared volumes for a two website setup
How extensible can I make my installation in terms of sub domains and restricting membership to them?
Discourse instance stops running in every midnight
Multisite for small collection of sites for a family?
Hosting Plan Suggestion for 500 Concurrent Online Users
Add path to cookie
Avatar, Site Logos, and Cert Errors
Database access issues after upgrade v3.5.2 -> v3.6.0.beta2
PAID Require Discourse expert for extreme customization
Can I have two domains pointing towards the same IP address without redirect?
Multiple container setup problems
I was wondering what does the db_id: 2 value in the suggested config above do?
Also, what is the procedure to add a new site to the existing multisite set-up? Is it just:
  • Update yaml
  • ./launcher bootstrap multisite [1]
  • ./launcher start multisite
I was wondering if there was a way to avoid impacting all the other existing sites by doing a full bootstrap or rebuild and somehow just add the extra database needed?
  1. I tried ./launcher rebuild multisite first, but this seems to fail ↩︎
I think that the db id is no longer needed.
You can just edit the multisite file with the new site and do a
sv restart unicorn
And then migrate the database.
You are a life-saver!
I was missing this command to restart (I also tried sv reload unicorn but somehow that wasn’t enough).
In terms of creating the database, is there already a way to do this automatically? It would be nice to have rake db:create[mynewdbname]. Otherwise, I can write a short shell script.
At the moment, I create manually (create db and set permissions) and then do a RAILS_DB=newdb rake db:migrate to populate it.
And just to check if I’m doing something stupid:
  • At the moment, I’m editing the multisite file within docker (/var/www/discourse/config/multisite.yml)
  • Creating the db manually
  • Running rake db:migrate
  • sv restart unicorn
  • I then also have to edit the yaml file outside of docker so that the multisite config is in sync in case of any future rebuild or upgrades.
Am I being silly editing the mutisite config in 2 different places when there’s already a way to edit in one place and push the changes through?
Is it possible to clean up this documentation a bit and provide a bit more directions in it? I am extremely new to Docker first off and although I have linux server experience I am not a pro at it. I am an old schooler love my cron jobs and shell scripts and you know weird stuff like that with apache multi site etc. But this is a bit more complex and using a different programming language than I am use to… Maybe even possibly an Demonstration video of some kind? It would be nice if discourse was just made multi site ready and that way all you would have to do is just edit a few files etc.
Just paste in that stanza of text and edit it to suit.
You also then either need a reverse proxy or to follow Set up Let’s Encrypt with multiple domains / redirects to get certs for all of the domains.
See also Setup Multisite Configuration with Let’s Encrypt and no Reverse Proxy. But that needs to get updated to have another line required that you can get from the previous link. I’ve been meaning to update it but haven’t managed
If I’m doing multisite, where should I point my domain to? The same IP as the server (which hosts another forum)?
Yes, point all domains to the same server IP.
Set up a revers proxy with Nginx or Caddy server.
Caddy is the best as it gives free automatic SSL certs to all your domains.
I followed this tutorial to set up with success a multisite install with Docker. I recently ran into an error when trying to upgrade and I believe the line:
    - exec: cd /var/www/discourse && sudo -E -u discourse bundle exec rake multisite:migrate
Should be edited to:
Could anyone confirm/edit the tutorial?
Yes. I ran into this too. You want to make that change otherwise your bootstrap will fail.
I enthusiastically confirm as well, that this correction is mandatory!
sure edited, thanks!
