Change the domain name or rename your Discourse
:bookmark: This guide explains how-to change the domain name of your Discourse site, and includes information about setting up DNS changes, editing configuration files, updating site settings, and correcting social logins and post content to reflect your new domain name.
:warning: This guide is for self-hosted Discourse instances that were installed using our installation guide on GitHub. If you are hosted by Discourse, please see Configure your domain name for hosted Discourse for specific instructions.
You may eventually want to change the domain name of your Discourse instance, from say
=BEFORE==AFTER=
Let’s get started.
Setting the DNS TTL low in advance
First, change the Time-To-Live (TTL) setting for your DNS to a low value like 60 minutes. This should be done days ahead of the actual domain change to ensure the change can propagate quickly across the internet.
Remove old domain name from any site settings
Visit /admin/site_settings in your Discourse admin interface, and search for any settings containing the old domain name. Update these settings to the new domain name.
Changing DNS Records
Update your DNS settings to disable the old domain and point the new domain to the IP address of your Discourse server.
Editing the site name in app.yml
You can edit the app.yml file manually to input the new domain information.
Here’s how to edit it manually:
cd /var/discourse
nano containers/app.yml
Locate the following line and replace it:
DISCOURSE_HOSTNAME: 'your.newdomain.com'
If using a Content Delivery Network (CDN), temporarily disable it by commenting out the respective line in app.yml. Rebuild your Discourse site with:
./launcher rebuild app
:information_source: Alternatively, you can run ./discourse-setup again and input the new domain information instead of editing app.yml.
Check that your site is operational under the new domain.
Fixing social logins
:exclamation: Depending on how you logged in, you may need to do this first or you won’t be able to log in once the name is changed.
If you use social logins, update the credentials on the platforms (Twitter, Facebook, Google, Yahoo, GitHub) to reflect the new domain. Look for guides on the Discourse how-to category.
Remapping domain names in posts
All the existing posts will still refer to the old domain.
You’ll need to change old domain references in your posts to the new domain:
./launcher enter app
then
discourse remap =BEFORE= =AFTER=
Alternatively, use Rake if discourse binary is unavailable, you can use the rake version:
bundle exec rake posts:remap["=BEFORE=", "=AFTER="]
Finalize with:
rake posts:rebake
This ensures that the domain name remaps in existing posts, and content is regenerated as necessary.
:information_source: If you have a CDN, remember to reactivate it post-domain change.
wondering how we created that form?
Changing the subdomain
Move your Discourse Instance to a Different Server
Changed Domains- Not getting redirects
Having an issue after changing domain
Great How To Guides
Put forum under sub-domain and have website
Our domain name changed, where do I edit the hostname?
Hosted-by-discourse.com .. how to configure / rebake / ssh?
Authentication and changing domain
Unable to change email address after switching domains
Unable to change domain name
Links broken after move
Rename existing discourse site
Moving to subdomain
WP Discourse - Relinking Comments After Moving Blog
Moving from one S3 bucket to another
Image links point to Incorrect (Previous) subdomain After Migration
Got a strange error when I transferred our forum to the new server and new domain
How to change URL associated with Activate Account button
Avatars lost after restore. How to get them back?
How might we better structure #howto?
Problem accessing plugin admin after restore
Unable to view all the images after updating to 3.4.0.beta1-dev
Migrate from AWS to Digital Ocean with 2 containers, spaces and 2 CDNs
Problem linking Discourse forum to WP Discourse
Site responds 502 Bad gateway - is it Ruby?
All internal links broken after restoring backup to new server
Set Up Let's Encrypt with Second Domain for Existing Discourse Install
Image uploads used to work but no longer do after forum name change?
Administrative Bulk Operations
Lost DNS Name, need to change to a new one
Questions about rebake
Cloned my DO discourse droplet, how to get clone to go to right domain?
Too many user emails domains not working lead to mailgun domain disabled: what to do?
I got example.com links. Where do they come from?
Help changing domain
Onebox error code of 403
Move Discourse to a new server without setting up the web UI first?
Can not save Default Watched Category/Tags
Images prior 2022 lost
Using external Domain in the browser address line
After activating HTTPS Discourse doesn´t work
504 Gateway error after launching new AWS instance
Adding www. to Domain
Unable to rebuild discourse due to no space left on device
Remap error when a post contains a quote from another topic
Attempted to switch mail provider, messed up my discourse
Changed domain of WordPress and Onebox
Can't reach site
Can't Reach Site (Take 2)
Admin panel messed up after changing the domain name
What I should know when changing the domain name of a discourse forum
Any ideas why my discourse can't show emoji and images?
Ghost hostname after hostname change
Changing hostname
Changing hostname
Rebake fails when changing the subdomain name only
How to remove "Website Name" links shared in a topic/post?
./launcher rebuild app for old 1.6 discourse not working
Error when I send a message in chat [downgraded to Stable from 3.1.0beta4]
Moving to Another VPS Provider
Changing domain and getting certificate for www
Some pictures don't display after a domain change
Multiple hostnames for a single site for cut-over phase
Change domain and rebake post all image not show
Set up Let’s Encrypt with multiple domains / redirects
Error on attempting to remap links
Site super slow after migration
Resource/Advice on how to change domains?
Can I upload discourse backup file to different domain address?
Discourse version at f.example.LTD: NOT FOUND
Remap command issues
Force pdf download
Images not appearing after domain change
What are the steps to test Discourse before switching domains
Remap failure when changing discourse domain
:cn: How to change the domain name | 如何修改 Discourse 的域名
Jump to main address automatically?
Migrate discourse from main domain --> subdomain
Uploads Path Should Update When URL Changes in app.yml During Container Rebuild
Change from example.com to community.example.com
Clone to a new server; Change Domain; New Topic Asking for Login Everytime
Attachments serving locally on the server but not publicly
Create self-hosting clean Incomplete cleaning
Rake:rebake crashes with errors: PG::ConnectionBad: PQsocket
Migrating from SMF to Discourse
After SSL installation pictures are not displayed
Bootstrap failed after rebuild - changed domain name
Nil usage errors in un-self-deleting posts
Effect of changing the WordPress site URL
How to determine performance bottleneck?
Changing discourse from domain to subdomain?
Restore backup without reconfiguring Discourse
Switching forum from subdomain to sub directory
Creating a duplicate of production environment
Rename custom domain of hosted Discourse forum
Discourse none admin side not working returning error 500
Broken image URL paths after changing hostname
File URLs broken after moving to a different domain
How can I bulk remap/update user email addresses?
I have a few questions before migrate from Xenforo 2.x to Discourse
Preparing test Installation -some questions
Re-Run Setup Discourse
How do I change the URL of my Discourse community
How to change the domain for Discourse?
Can I change the domain name - without a clean install?
Moving from Vultr to DigtitalOcean
Migrate a phpBB3 forum to Discourse
Missing avatars and site images after import of a backup
Discourse Install on Lightsail
Ssl_error_bad_cert_domain
There is really no reason for a rebake?
The remap already took care of mapping the old URL to the new URL.
@SaraDev Thanks for keeping things tidy. Can you have a look at:
and
Maybe I am missing something but… If you use the ./discourse-setup method you will need to set the ip for the new domain prior to running ./discourse-setup to prevent the dreaded domain check failure, yikes.
Using the talk.foo.comtalk.bar.com convention
Hostname for your Discourse? [talk.foo.com]: talk.bar.com
Checking your domain name . . .
WARNING: Port 443 of computer does not appear to be accessible using hostname: talk.bar.com.
WARNING: Connection to http://talk.bar.com (port 80) also fails.
Hi @philh,
Thanks for mentioning this:
This is correct, and if you run ./discourse-setup to and input the new domain information instead of editing app.yml you will need to setup the DNS records for your new domain first.
This information has updated this in the guide to reflect the correct order for updating the domain in this situation. :slightly_smiling_face:
Thanks Sara!
BTW: I am pretty sure there is a domain check during rebuild running ./launcher rebuild app :wink: which would suggest dns should be updated 1st either way: direct edit of app.yml or ./discourse-setup
Thanks again for working to keep things tidy. Up to date instructions does help the newer folks that come along. :slight_smile:
I want to do this, but I’m using Digital Ocean, and I’m no expert. Is there anything I need to change there?
For example I see this:
But I believe this is just a name I gave it, it’s not a real setting?
So as long as I follow the instructions on this page, I don’t have to make any changes in Digital Ocean (maybe apart from updating this name to the new domain, to avoid confusion?)
To make your new site work properly, you need to update the DNS settings at your domain name provider.
Example:
If your previous site was:
forum.example.com → 1.1.1.1
Then you should change it to:
forum.newname.com → 1.1.1.1
Are you changing the subdomain or the full domain?
In the example above:
  • Domain: example.com
  • Subdomain: forum
Make sure to update your DNS records accordingly depending on whether you’re changing only the subdomain or the full domain name.
:label: Are you changing the subdomain or the full domain?
  • Subdomain: forum
:globe_with_meridians: DNS Configuration Examples
:blue_circle: Cloudflare
  1. Log in to your Cloudflare dashboard.
  2. Select your domain (e.g., example.com).
  3. Go to the DNS tab.
  4. Find the existing A or CNAME record for forum.
  5. Edit it:
    • Name: forum
    • Content: 1.1.1.1 (or your server’s IP)
  6. Click Save.
:yellow_circle: GoDaddy
  1. Log in to your GoDaddy account.
  2. Click on Domains, then select your domain.
  3. Under Additional Settings, click Manage DNS.
  4. Scroll to the Records section.
  5. Find the A record or CNAME for forum, and click the Edit icon.
  6. Update the following:
    • Host: forum
    • Points to: 1.1.1.1
  7. Click Save.
:orange_circle: Namecheap
  1. Log in to your Namecheap account.
  2. Go to Domain List > click Manage next to your domain.
  3. Open the Advanced DNS tab.
  4. Under Host Records, look for the entry with forum.
  5. Click Edit, and update:
    • Host: forum
    • Value: 1.1.1.1
  6. Click the green checkmark to save the change.
DNS changes may take from a few minutes up to 48 hours to fully propagate, depending on your provider and TTL settings.
:three_o_clock: Note: The steps for changing DNS were generated using AI, and they may vary or contain errors.
My issue was actually just related to Digital Ocean, not the DNS, which I was able to change easily in Cloudflare. I figured out it was not necessary to make any changes in Digital Ocean, though.
Thank you for your reply, anyway!
