Discourse Assign
:discourse2: Summary Discourse Assign provides the ability to assign topics and individual posts (both private and public) to a user or group.
:open_book: Install Guide This plugin is bundled with Discourse core. There is no need to install the plugin separately.
:person_raising_hand: Required user level: Administrator (for configuration), members of allowed groups (for using assignments)
:discourse2: Hosted by us? This plugin is available on our Business and Enterprise plans. Data Explorer | Discourse - Civilized Discussion
Overview
Discourse Assign adds the ability to assign topics and individual posts — both public and private — to a specific user or group. Assignments appear as tag-like annotations in the topic list and topic header, providing a clear indication of who is responsible for a given topic or post. This is particularly useful for support teams, moderation workflows, and any scenario where you need to track task ownership.
Assigned user annotation in a topic list
Discourse Assign is bundled with Discourse core and doesn’t require separate installation. It’s disabled by default and can be enabled through admin settings.
Enabling Discourse Assign
  1. Go to AdminPlugins and find Discourse Assign.
  2. Toggle the plugin to enabled, or navigate to AdminSettings and search for assign_enabled.
  3. Set assign_enabled to true.
  4. Configure assign_allowed_on_groups to specify which groups can use the assign feature (see Configuring permissions below).
Assigning topics and posts
Assigning a topic
When you open a topic and you’re a member of an allowed group, you’ll see an Assign button in the topic controls. Click it to open the assignment modal, where you can:
  • Select a user or group to assign the topic to
  • Optionally set a status (if enable_assign_status is turned on)
  • Optionally add a note with additional context
Assigning an individual post
In addition to assigning entire topics, you can assign individual posts. This option appears under the (show more) button in the post toolbar for posts other than the first post. When a post is assigned, assignment information appears in the topic header and the first post contains a link to the assigned post.
Assigning to groups
Topics and posts can be assigned to user groups. When a group is assigned, each group member receives a notification. To make a group available for assignment:
  1. Go to the group’s settings page.
  2. Under Interaction, find the “Who can assign this group” option.
  3. Set it to the desired permission level (by default it’s set to “nobody”).
Unassigning
To unassign a topic or post, click the button that currently shows the assignee’s name. This opens a dropdown where you can select Unassign. You can also Reassign to a different user or group, or Edit assignments to modify the status or note.
Using assignment statuses
Assignments can optionally include customizable statuses that track the progress of assigned work.
  1. Enable statuses by setting enable_assign_status to true.
  2. Configure available statuses with the assign_statuses setting. The default statuses are New, In Progress, and Done, separated by the pipe | character.
  3. The first status in the list is automatically applied as the default for every new assignment.
Status changes are tracked in small_action posts within the topic, providing an audit trail.
To change the status of an existing assignment, click the assignee button and select Edit assignments. From there, you can update the status using the dropdown.
Controlling who can assign
The assign_allowed_on_groups setting controls which groups have permission to use assignments. Members of these groups can:
  • Assign topics and posts to users or groups
  • View assignment data across the site
  • See the “Assigned” tab on user profiles
:warning: When setting assign_allowed_on_groups, use a specific group like trust_level_0 rather than everyone. The everyone option may not work as expected. Using trust_level_0 effectively grants all registered users access to the assign feature.
Assignment visibility
By default, assignment data is only visible to users who belong to one of the assign_allowed_on_groups groups, or to admins. This applies regardless of how the group itself is configured for general visibility:
  • Publicly visible groups won’t expose their assignment tabs or indicators to non-assigned users.
  • Users outside the allowed groups won’t see assignment data even if they navigate directly to an assignments URL.
To make assignments visible to all users, including logged-out visitors, enable the assigns_public setting.
Scenario assigns_public: false (default) assigns_public: true
Members of assign_allowed_on_groups See all assignment data See all assignment data
All other users See nothing See all assignment data
Viewing assigned topics
There are two primary ways to view assigned topics:
Topic list filters
Append query parameters to any topic list URL:
  • https://discourse.example.com/latest?assigned=username — view all topics assigned to a specific user
  • https://discourse.example.com/latest?assigned=* — view all assigned topics across all users
  • https://discourse.example.com/latest?assigned=me — view all topics assigned to you
  • https://discourse.example.com/latest?assigned=nobody — view all unassigned topics
User profile activity tab
Each user who can assign has an Assigned tab under their activity page at /u/{username}/activity/assigned. This tab lists all topics and posts assigned to that user.
Unassigned category filter
Categories can optionally display an “Unassigned” navigation button at the top of their topic list, making it easy to spot topics that haven’t been assigned yet. This is controlled through the category’s settings.
Site settings reference
Core settings
Setting Description Default
assign_enabled Enable the assign plugin false
assign_allowed_on_groups Groups whose members can use assignments and be assigned topics (empty)
assigns_public Allow all users (including logged-out visitors) to see assignments false
max_assigned_topics Maximum number of topics that can be assigned to a single user 10
Automation settings
assigns_by_staff_mention Automatically assign a topic when a staff member mentions another staff member false
assign_self_regex A regex pattern that, when matched in a post, auto-assigns the topic to the post author (empty)
assign_other_regex A regex pattern that restricts auto-assignment via mention to posts matching the pattern (empty)
unassign_on_close Automatically unassign topics when they’re closed false
reassign_on_open Reassign previously assigned users/groups when a closed topic is reopened false
unassign_on_group_archive Unassign messages when archived by a group, and reassign when moved back to inbox false
invite_on_assign When a personal message is assigned to a user or group, invite them to the PM if they aren’t already a participant false
Notification and reminder settings
assign_mailer When to send notification emails for assignments: never, different_users, or always never
remind_assigns_frequency How often to remind users about their pending assignments 0 (disabled)
pending_assign_reminder_threshold Minimum number of pending assignments before a reminder notification is sent 2
Status settings
enable_assign_status Add a customizable status field to every assignment false
assign_statuses Pipe-separated list of available statuses (first one is the default) `New
Tracking settings
unassign_creates_tracking_post Create a whisper or small action post when a topic is unassigned true
assigns_user_url_path URL path template for linked assigned user profiles (use {username} as a placeholder) /u/{username}/activity/assigned
Integration with Discourse Solved
ignore_solved_topics_in_assigned_reminder Exclude solved topics from assignment reminders false
assignment_status_on_solve Automatically change assignment status to this value when a topic is solved (empty)
assignment_status_on_unsolve Automatically change assignment status to this value when a solution is removed (empty)
Customizing the assignment email template
The email sent when a user is assigned can be customized through AdminCustomizeText. Search for the following keys:
  • assign_mailer.subject_template — the email subject line
  • assign_mailer.text_body_template — the email body text
Thank you to McNeel for sponsoring this work!
Last checked by @MarkDoerr 2026-04-07T22:09:15Z
57 лайков
Tickets Plugin :tickets:
Generating Support Metrics (with Assign and Solved plugins)
Modifying Staff Roles to go beyond Administrator and Moderator?
Easiest way to pull other users in on a discussion non-publicly?
Recommended workflows for support and community?
Creating Custom Flag
Task manager within Discourse?
Bookmark labels to save for later
Inbox Customisation and Organisation Features
Using discourse as a community ticket system
Possibly to automatically assign user/users to tags?
Creating a User - Tag relation plugin
Advise on how to organize my forum categories and tags
Comment on a question instead of answering it
Discourse Assign - how to assign posts using regex
New customer setup
Volunteer Activities - a simple setup for non-hierarchical collaboration
Assigned topic summary for groups
A layout for community projects
Allow Group Mentions in Post Edits to Trigger Notifications (Opt-In Setting)
Implementing KCS
Regarding possibility to use Discourse as an alternative to JIRA or Zendesk
Using Discourse as a social media platform
URL query string params
Hello Community Experts- are we able to configure discussions to be threads AND questions?
Setup Continuous Integration using GitHub Actions
Search filter - only topics / only posts
Issue Tracker for Discourse
New user alerts
Discourse Automation
It would be great to be able to assign personas created in Discourse AI to respond to the topic
Why you should use Discourse internally for your company/team instead of Slack (4 years use case)
How to put own username in header links
Setting timer to be viewed by all and for moderators specifically to follow- up topics
User assignments and kanban
Cannot assign topic to group
Bundling more popular plugins with Discourse core
Reassigning to a group creates a /u/ link in the @group mention
How do I assign a topic via the API
Horizon: High Context Topic Cards
Using query strings to filter topic views
Different themes per category?
How Discourse Uses Discourse
Advice on a support forum
Performing bulk actions as a moderator
Reminder function for pre-defined trust levels
Color of tags in header not changed by Color Scheme
Cannot delete topic that is assigned
Link behavior inconsistent
View PMs assigned to nobody
Unassign topic when marked as solved
Current Projects - January 2026
Time tracking using Discourse?
Using Workflows to send a Slack message when a topic or post is assigned
Customize hamburger menu to add switch what switches theme and applies predefiend filter
Send email notifications for small actions
На данный момент это, похоже, не работает. Если я являюсь участником группы A, и кто-то назначает группу A на тему, она не отображается для меня при посещении /latest?assigned=me.
1 лайк
Привет, Куба. :wave:
Это фильтр на странице «Последние». Упомянутый «личный список назначенных» находится по адресу /my/activity/assigned. :+1:
Спасибо! Есть ли какая-то конкретная причина, по которой эти два фильтра ведут себя по-разному? :thinking:
1 лайк
Можно ли настроить время повторяющихся уведомлений?
ОБНОВЛЕНИЕ: Когда тема назначается группе, пользователи группы не получают уведомления по электронной почте. Это правильно? Я ожидал, что пользователи будут получать email + повторяющиеся письма (каждый день, каждую неделю), как и при назначении одному пользователю.
2 лайка
2 сообщения были перенесены в новую тему: Можно ли удалить назначения, когда тема решена?
Извините, если это уже упоминалось (я не смог этого найти).
Могут ли пользователи без статуса staff использовать этот плагин для назначения? Мне не удалось заставить плагин работать даже для пользователя с ролью модератора. Пользователь должен быть администратором.
Мой сценарий использования: Руководитель команды (не staff/не администратор) создает тему и назначает её участнику команды (пользователь с правами TL0-3). Руководитель команды не обязательно должен быть администратором или staff форума Discourse, так как у нас много руководителей команд.
Было бы полезно, если бы я мог назначить руководителю команды роль модератора и заставить плагин работать.
Спасибо и большое за помощь!
Разве установка assign allowed on groups не решит эту задачу?
Привет, @Jagster,
Я установил параметр assign allowed on groups в значение everyone
Например, разрешения этого пользователя:
Но этот пользователь не видит кнопку assign
Иногда «все» не работает. Попробовали ли вы trust_level_0?
3 лайка
Короткое замечание — кнопка «Назначить» будет отображаться как отдельная опция в темах/постах и не будет находиться в меню :wrench: :slight_smile:
Я только что протестировал это на своей стороне на аккаунте TL3, настроенном при следующих условиях, и получил такие результаты:
Пользователь TL3 с разрешением для всех
Та же проблема, что и у @carlito — опция не появляется.
Пользователь TL3 с разрешением trust_level_0
Это работает как задумано.
Таким образом, вам нужно установить trust_level_0, как предложил @Moin. Я думаю, что иначе это должно было бы работать, если выбрать «все», так что, возможно, это ошибка?
3 лайка
@Moin и @HamMan2118
Круто, сработало!
Спасибо вам обоим!
2 лайка
Как найти и отредактировать шаблон электронного письма, который отправляется при назначении задачи? Почему его нет среди других шаблонов писем?
Этот?
Его можно найти в разделе Администрирование > Тексты сайта. Я поискал assign_mailer, который возвращает заголовок (assign_mailer.subject_template) и текст тела сообщения (assign_mailer.text_body_template).
2 лайка
Да, именно так, спасибо!!
3 лайка
Где в интерфейсе отображается статус?
Я вижу, кому назначена тема, но не вижу способа узнать её текущий статус.
@tknospdr Вы видели эту часть?
Да, но это отображается только после внесения изменений. Никакого визуального указания на то, что статус был назначен, нет, пока вы не измените его с X на Y.
Вы можете увидеть текущий статус, перейдя на вкладку «Редактировать задание» под кнопкой «Назначить».
Вы имеете в виду «Редактировать назначения», скрытую за кнопкой «Отменить назначение…»?
Если я не хочу отменять назначение, я бы колебался нажать на эту кнопку, верно?
  1. Это не интуитивно понятно.
  2. Вы хотите сказать, что считаете плохой идеей наличие визуального индикатора, который сразу показывает статус назначения темы?
Мне просто трудно представить, что это сложная задача с точки зрения кода, и логично вынести эту информацию на видное место.
3 лайка
