Page Publishing
:bookmark: This guide covers how to use the Page Publishing feature on Discourse. This feature allows Staff users to convert a topic into a standalone static page with custom styling. Examples include the Terms of Service and Privacy Policy pages.
:person_raising_hand: Required user level: Staff
Publishing static pages on Discourse
Page Publishing allows Staff users to create standalone static pages from topics. This is similar to the process for creating Terms of Service or Privacy Policy pages.
Summary
This documentation will cover:
  • Enabling Page Publishing
  • Publishing a topic as a page
  • Unpublishing a topic
  • Common issues and solutions
  • FAQs
  • Additional resources
  1. Navigate to Admin > Settings.
  2. Activate the enable page publishing setting.
    Enable Page Publishing
Enabling page publishing when login is required
To allow published pages to be visible even when a user is not logged in:
  1. Activate the show_published_pages_login_required setting at Admin > Settings.
    Show Published Pages
Publishing a Topic
  1. Go to the first post of a public topic and select the ellipsis icon (...).
    Ellipsis Menu
  2. Select the wrench icon.
    Wrench Icon
  3. Choose the ā€œPage Publishingā€ option.
  4. A modal dialog will appear, allowing you to confirm the slug (which can be pre-filled from the post title) and preview the published page’s URL.
:warning: To allow page publishing, it’s necessary to deactivate the secure upload site settings.
:information_source: For hosted sites, secure uploads are limited to the Enterprise plan.
Published Topic
Published Page
Unpublishing a Topic
  1. Select Publishing Settings under the notice.
  2. Click Unpublish
  3. Page is unpublished.
Unable to see published pages when logged out
Ensure the show_published_pages_login_required setting is activated in Admin > Settings.
Adding a Discourse header to published pages
Currently, static pages are intended to be minimal and do not include the typical Discourse header and footer.
FAQs
Can I make a FAQ or About page public?
You can create a new topic with the desired content and publish it as a page. Change the links in site settings to point to these new pages.
How can I customize the look of a published page?
Use the structure of the HTML document and corresponding CSS selectors to apply custom styles under Admin > Customize > Themes > CSS.
Last checked by @huynhthai824 2024-05-27T12:26:36Z
Best landing page solution
ProCourse Static Pages
How to add a new page into the community? (Login isolated page)
Blog Post Styling
Is anyone here using their Discourse instance as their entire website?
How do I redirect urls or create new ones?
Host HTML page on Discourse install
Integrating webpage to current forum
Open (anon) interaction with a forum
Shared Drafts: Allow staff to collaborate on posts before publishing
Discourse + CMS, which one?
Is there an upper limit to how many pages can be published?
How to share only few posts to public as links?
Create a "Docs" page like discource meta's
Invite people to reply to a topic without them needing to create an account
Allow anonymous users to view a topic?
What's the usage of "show published pages login required" setting?
How to add contact us page?
Embed my Discourse Forum as IFrame
Is there any way to restrict posting in a topic to members of a group, but allow all users to read the topic?
Order posts by Title
Edit Code
Published page not visible?
Inline Tooltips
Making the About and FAQ visible to anon
Allow published pages to be visible to anon
Customize login page
7 myths why a blog isn't needed in the discourse core
Landing Page
Customizing FAQs and Guidelines
Can I use secure media and page publishing simultaneously in Discourse?
Publishing - how deep/good is fine-grained permisson control?
Publish Direct Messages
500 character ā€˜Reject Reason’ is too small a limit
How do I create a blank page within Discourse
How-to use Discourse for managing a collaborative newsletter?
Customize Login pop-up box?
Building a custom html page in discourse
Page for not-logged in users with a single topic displayed
Duplicate Terms of Service/Privacy Policy
Paid Groups
Help custom page?
Should Discourse make an effort to become the next best "CMS"
Is It Possible to Create Custom Pages in Discourse?
How to Enable Terms of Service and Privacy Policy Pages in Discourse?
Blank Pages Related Help
How do root level links work?
How can I make a static page?
Creating custom pages like "About" and "FAQ"
Static pages for things like guidelines?
Multi-factor authentication enforcement lock in without help
Can you create a custom landing page?
Generate static file in discourse
Using Discourse as a News Blog and Forum - Any Known Good Examples?
Create a new text page option?
Change topic visibility in an admin category to public
Create a custom page with theme cli?
DiscoTOC - automatic table of contents
Adding a static web page
[Urgent] privacy policy page
How to make a website with Discourse
Discourse for Teams is here!
Category Previews
Public Static pages and Private Forums - possible?
Filter view for muted categories
Category Previews
How to hide a single topic from showing up in "latest"?
Control the visibility of /faq and /about
[Question/Request] Featured image url for post
Custom Homepage for Groups
Embedding private discussions on a wordpress site
Table of Contents not working on Published Pages
Is there any way to listen User login event using Theme component
I still need to try this out first hand so the following may not be grounded in reality, but:
It strikes me that this permission model sets up a scenario where you always see two copies of the pages’ content – one in the relevant Discourse category, and one in the published pages themselves. This of course seems duplicative if you’re wanting to publish pages for the general population that is similar to, or identical to, your Discourse user base.
OTOH, if pages had the ā€œworld readableā€ flag available, you could then restrict who can see/edit them to a small group, and the only place the content would be available to other Discourse users would be in the published links themselves.
(I’m thinking of a use case of a ā€œdocumentation siteā€ here.)
Otherwise, I’m pretty excited to test things out!
Awesome stuff, and thanks again for listening to your users. I love the ā€˜lets make this better for us all’ vibe that Discourse has! We’ll make heavy use of this.
When discussing one use (patching up an install that went a bit awry), another user pointed out a remaining bit of icing that could do with going on the cake:
Hey, is there any way to include the ability to make /faq and /about public as well, as they are currently hidden in Login Required sites. We can of course use the existing functionality that you’ve just released for /faq by making our own, changing the link in settings, and explicitly linking to it. However, this is not pretty and the existing navigation to it remains hidden. We can’t do that at all for /about of course.
Something that would go nice with this feature is to make publications onebox-compatible such that people could easily share the content.
Please excuse my ignorance, as I am very much a beginner in the HTML/CSS space.. however, how would we go about applying our theme colour choices to published pages. At its simplest, I’d like to use the dark background/white text to give the published pages the same darkmode experience as accessing our forums.
Is this already in the product, or do I need to play with HTML/CSS? If the latter, could anyone give me some pointers in the right direction? Thanks!
Can you make this a separate feature request please? This is not related to page publishing, as in I wouldn’t have to change anything related to page publishing to make it possible. I do agree it would be better if all these ā€œstaticā€ pages could have more or less the same behaviour, but there are multiple solutions here (do nothing? add site settings? migrate these to page publishing?), so we might want to have a dedicated topic for this.
GTM not loaded on published pages? Would be nice.
Hmm that is a really good point.
Just trying to think of a solution here… would it work if type="text/javascript" and type="text/discourse-plugin" were treated differently? The API needs the latter, right?
Yes I think we already support having a text/javascript in the theme fields, so there are certainly solutions in this area.
That would be great.
So it’s currently impossible to have responsive published pages, and this site particularly wants
  1. images made available when sharing to public media, and
  2. responsive/resizing images displayed, especially on mobile–oh, mobile could just resize the image with CSS–that should work, right?
+1 for having the Discourse header in published pages. I’m missing my website logo, custom header links and beloved hamburger menu :slight_smile:
Another oddity: in posts, my lightboxed images open in a nice popup, whereas in published pages, they open in a new tab…
I think what’s needed is a set of theme components that add such. The last client I had to use this wanted the topic creator removed. I think it’s hard to guess what will meet people’s needs for this!
Are there currently any ongoing efforts for adding ā€œsimpleā€ (non-API) Javascript support to published pages? Or should we forget about this near- to mid-term ?
Can i display external non-Discourse JSON on this page? Because we can’t use php code here and discourse strip most of html so i do not know how to do it..
I have a problem with a published page - the button to copy the content of the code block is not visible on a published page. Screenshot: Screenshot by Lightshot. I move the mouse over the block, but the button doesn’t appear. When logged in - everything works as usual - ok.
Can anybody repeat the problem? Any solution?
Thank you @riking !
It indeed seems that ā€œregularā€ text/javascript is executing on published pages when it’s in the header or footer of a theme component.
Ha! So it seems that there’s a hacky way to make some theme components work with page publishing.
I’m looking into adding some header/footer to the published pages, and theme components seem to be the way to go. But it seems bad to go on and implement something that would potentially break in the near future.
@riking, it looks like the text/javacript type in header or footer working on published pages was unintented. Is it going to be fixed or used to extend published pages?
@syl, author of DiscPage, mentioned the possibility to re-implement the DiscPage plugin using Page Publishing functionality. Do you still have this in mind, @syl? What do you think would be the path of least resistance to integrate both functionality @riking?
Unfortunately, the ā€œPage Publishingā€ feature doesn’t meet my needs. For me to use it, I would need published pages:
  1. to be displayed within the normal Discourse layout, i.e. with the standard Discourse header (just like the Terms of Service and the Privacy Policy), and
  2. to be rendered like normal (decorated) topics, i.e. supporting bbcode and plugins.
In the meantime I used the default Discourse customization facility:
  1. Identify the added element, e.g., with a published-page-footer-links CSS class.
  2. Customize CSS to hide this element by default and show it only for published pages
  3. Add the element in the Footer space
2. In CSS, add:
/* Only show footer links on published pages */
.published-page-footer-links { display: none; }
.published-page .published-page-footer-links { display: block;}
3. in Footer, add:
<nav class="published-page-footer-links">
Hi there! This is the footer for published pages!
</nav>
