This guide provides step-by-step instructions for manually updating Discourse, the Docker container, and the Ubuntu operating system on a self-hosted setup.
Required user level: System Administrator
SSH access to the server.
If you self-host Discourse, you occasionally need to run a manual update via the command line to get the latest security releases newest libraries.
These updates are not picked up in admin/update, which is why youāll occasionally need to do these additional steps:
Updating Discourse
Discourse itself should be updated about twice a month, by clicking the āUpdate to Latest Versionā button in your admin dashboard (
admin/update). -
Every two months we recommend SSHāing into your web server (using putty or your favorite SSH client) and running the following commands, especially if the upgrade page doesnāt show up or you have any issues when trying to upgrade.
cd /var/discourse
./launcher rebuild app
Updating the Docker image and Ubuntu OS
For Ubuntu updates, make sure you have automatic security updates enabled for your Ubuntu! The command is:
dpkg-reconfigure -plow unattended-upgrades
However, that just covers critical security updates. Every so often you should get all the OS updates like so:
apt-get update
apt-get dist-upgrade
Due to the way docker packaging has changed you may also have to update your docker from lxc-docker or docker-engine packages. One way to do that is via the Docker script here (it will warn about an existing install but should upgrade ok):
wget -qO- https://get.docker.com/ | sh
This will now use the docker-ce main versions.
To summarize:
- update Discourse twice a month via web updater
- update the container every two months
- update the OS every six months
You could double these numbers and still be fairly safe, e.g. update Discourse once a month, container every 4 months, OS once every 12 months, and so on.
But you really, really want automatic security updates enabled in Ubuntu, as listed above.
FAQ
What is the right time to update?
It just depends on the time you have available and how close to bleeding edge you want to be. If you have non-official plugins, it is highly advisable to utilize a test/staging site. If you do not have any non-official plugins, you can likely upgrade immediately, but even then, some plugins may break for a couple of days as the team fixes them (there are a lot of them).
What is common practice when updating with many plugins installed?
If you have a lot of plugins, testing locally or on a test server is highly advised. Especially if you have non-official plugins, as something could have broken. If you find something does break, then it is a matter of, do you have time to fix it? Does the original plugin author have time to fix it? Either of those could take weeks. So at least this way, you simply have a broken test site and not a broken production site.
Iām running low on disk space
If you are running low on disk space (check with df) try clearing up old images using:
./launcher cleanup
apt-get autoclean
apt-get autoremove
Does updating the actual server version of Ubuntu matter since Discourse always operates in Docker?
It matters a lot less. But you should be on at least a currently supported LTS release of Ubuntu server. A 64-bit Linux OS with a modern kernel version is required.
Check document
Perform check on document:
