Install Discourse on macOS for development
:warning: This guide covers installation instructions for a macOS development environment, for production guides see: Install Discourse in production with the official supported instructions
So you want to set up Discourse on macOS to hack on and develop with?
We’ll assume that you don’t have Ruby/Rails/Postgres/Redis installed on your Mac. Let’s begin :rocket: !
Install Discourse Dependencies
You will need the following packages on your system:
** optional
restart your terminal
Now that we have installed Discourse dependencies, let’s move on to install Discourse itself.
Restart your Terminal
Exit your shell and restarting it ensures that the paths to the installed packages are correctly picked up by the Terminal.
Clone Discourse
Clone the Discourse repository in ~/discourse folder:
git clone https://github.com/discourse/discourse.git ~/discourse
~ indicates home folder, so Discourse source code will be available in your home folder.
Bootstrap Discourse
Switch to your Discourse folder:
cd ~/discourse
Install the needed gems
bundle install
Install the JS dependencies
pnpm install
Next, run these commands to set up your local Discourse instance:
bundle exec rake db:create
bundle exec rake db:migrate
RAILS_ENV=test bundle exec rake db:create db:migrate
Start rails + Ember servers, you have two options here.
Option 1: using two separate Terminal tabs/windows, run Rails and the frontend bundler separately via
bundle exec rails server
and
bin/dev --only ember
Option 2: using only one Terminal tab/window:
bin/dev # runs Pitchfork and the frontend bundler together
:tada: You should now be able to navigate to http://localhost:3000 to see your local Discourse installation. (Note that the first load can take up to a minute as the server is warmed up.)
You can also try running the specs:
bundle exec rake autospec
All (or almost all) the tests should pass.
Create New Admin
To create a new admin, run the following command:
RAILS_ENV=development bundle exec rake admin:create
Follow the prompts to create an admin account.
Configure Mail
Run MailHog:
mailhog
Congratulations! You are now the admin of your own Discourse installation!
Happy hacking! And to get started with that, see Beginner’s Guide to Creating Discourse Plugins.
This document is version controlled - suggest changes on github.
Setup discourse on Mac OS
Running Discourse on Docker for Mac
Localhost:3000/users gives no-results
How to install Discourse on windows
How to install Discourse locally?
Best dev installation method for running on macOS?
Starting discourse fails with bootstrap error
Discourse standalone
UndefinedTable: ERROR: relation "web_hook_event_types" when trying to run rspec test
Please help, how do I install Discourse on macOS?
MacOS Installation Gem::FilePermissionError
Error after cleaning tmp folder
Migrate a NodeBB forum with Redis to Discourse
Local installation internal use only
Dev environment setup failed on bundle install
Set up a local Discourse Development Environment?
[Need help][MacOS M1 dev installation] ArgumentError unknown keywords
Migrate a PunBB forum to Discourse
Migrate a phpBB3 forum to Discourse
Migrate a FluxBB forum to Discourse
Migrate a vBulletin 3 forum to Discourse via XenForo
Migrate a MyBB forum to Discourse
Migrate a NodeBB forum with MongoDB to Discourse
Migrate a Ning forum to Discourse
Migrate a Phorum forum to Discourse
Migrate from another forum to Discourse
Migrate a Kunena 3 forum to Discourse
Migrate a bbPress WordPress plugin forum to Discourse
Install Discourse for development using Docker
Use the Discourse API ruby gem
Enable CORS on localhost for DiscourseConnect
Set Environmental Variables
Need help integrating code wrote on Edittext to the Discourse
Keyboard navigation messes up the search menu
WP-Discourse not connected and admin email not recognized
Contributing to Discourse development
How to install discussions on localhost in my mac?
How to install Discourse for Wordpress locally running on MAMP
Error when building: "Runtime Error: discourse does not support compiling scss/sass files via sprockets"
How to add a new language
How to edit the discourse files? A development box?
Can't set up dev environment due to cppjieba_rb failing to install
Install error : Protocol violation
Cannot Backup my Development Instance (Fails)
Update PhantomJS to latest for Ubuntu dev guide?
Rake aborted message is showing when installing vagrant development
Nginx Performance Report plugin incompatible with development environment setup script
Installing problem - bundle install
Rails server --daemon and plugins
Moderation Tools
Migrate from GetSatisfaction to Discourse
Case study of an amateur plugin author
Upgrading Mathjax to version 4
Windows server publish method
I want to build a debug version of discourse
Discourse as Your First Rails App
Topic List Previews (TLP)
Change unicorn port from 3000 in development
Vagrant based server failing on db:migrate
Can't deploy to heroku
Category option: max topics per user (2 use-case examples)
How to relax Content Security Policy
Installing Discourse for macOS Development Using asdf and docker-compose
Override profile background via SSO
Install on macOS – Failure: Scheduler::Defer can pause and resume
Stuck in infinite loop in Mac terminal after source ~/.bashrc
Regarding the installation - docker
Disabling SSO in development environment
Local development and deploying from same repo
Discourse Connect on Local instance is not working
Can't start localhost server -- file was built for x86_64 which is not the architecture being linked (i386)
How to connect to an external database running on localhost
How can I include discourse in my local dev stack?
Global messages on 94632 timed out, restarting process, 95535 successfully terminated by `TERM` signal
Cannot get embedding to work
/admin/config/emoji non responsive/locks up
App.yml file does not exist when installing Discourse locally
Ember-cli error on local MacOS development
Importing / migrating from Zendesk Community to Discourse
Redis version error when I run bundle exec db:create
If anyone is getting failing specs with most of them being .count errors, then try the following:
RAILS_ENV=test bundle exec rake db:reset
I had a problem where development data somehow got into my test database and was causing lots of failures.
Is it possible to reset a discourse completely?
Yes, do:
rake db:drop db:create db:migrate
Note that this will wipe everything and you will have to create your Admin user account again.
Can someone assist me in how I can update my discourse?
/launcher rebuild app
returns an error.
./launcher rebuild app is for discourse_docker based production setup. To update local/development Discourse instance you need:
cd ~/discourse
git pull origin master
I get this error @techAPJ,
error: Your local changes to the following files would be overwritten by merge:
	.gitignore
Please commit your changes or stash them before you merge.
Aborting
The error message is pretty clear:
If you want to ignore your local changes, do:
git fetch origin
git reset --hard origin/master
Using the guide from the Ruby on Rails forum, I’m currently stuck on step 7.
This is probably a very “newbie” question, but how do I “point” to the experimental branch that was linked in that topic? I tried a few things and was ultimately giving the Unknown command mini_racer, message every single time.
They’re fine asking here.
There are some specific m1 instructions we wrote that we reference on the rails forum in this guide.
I’d have to look on my m1 air later, and maybe my fellow coworks who recently setup new macs might know better if this is even still needed, but there is an example of how to point to a branch in step 7:
gem 'mini_racer', github: 'rubyjs/mini_racer', branch: 'refs/pull/186/head'
So you would edit this line in your local version of discourse/Gemfile:
and then run bundle install.
It’s linked right at the top of the original post.
The topic from the Ruby on Rails forum has been dead for many months now. The OP hasn’t been active since Feburary and hasn’t replied to any comments there asking for help.
There are more people to help me here. Just saying. :wink:
I tried copying that into Terminal and received the same Unknown command mini_racer, error from before.
Admittedly, the guide from the Ruby on Rails forum isn’t as clear as I’d hope in that regard.
Apologies in advance… :pray:
It’s not a command to run. You will need to EDIT the actual text file called “Gemfile” located inside the discourse directory.
Doh! :facepalm:
Thanks! Let me try that right now.
In my opinion, somebody should edit the guide from the Ruby on Rails forum and provide further clarification regarding step 7. Just my two cents though.
I will be right back. Hold on a second…
Sorry I have to run, but I think that mini_racer fix for m1 macs has been merged in. I just checked my Gemfile on my m1 mac and mine isn’t edited. So I think you can skip step 7.
I ran step 8 and received the Could not locate Gemfile error.
I (think) I was able to figure out step 7, but step 8 is still giving me trouble and is spitting out the error mentioned above.
You need to be inside of the discourse directory when you run bundle install.
Hi @merefield: Can you describe your remote setup a little more?
While developing a theme allows me to add changes on a live site, for developing a plugin I don’t see any way around doing it on my local machine, having the whole discourse codebase there (with my plugin on top of it).
The result is that for any (non-css) change when coding a plugin, when I reload it 1) kicks off my computer’s fan and 2) takes a solid 30 seconds to reload. And if I need to restart the server, it takes several minutes.
Those delays really add up–with the result that it might take me an hour to code something up that with my normal coding flow (where there’s hot reload or at most 2-3 seconds per change) would take 15 minutes.
So, I’d appreciate any suggestions for speeding things up.
This arguably would be better on the Ubuntu topic, as I’m just running that install on a cloud server, fronted by nginx and a full DNS (no docker), so I’m actually addressing the domain. Running everything from the terminal. I’ve even got Ember CLI working well in that set up now.
It’s not that quick either, but fast enough. It has the benefit of being able to run and test full https callback services.
The fastest plugin development environment by far that I’m aware of is local Docker Dev on WSL2 which screams. It’s also extremely simple to maintain. Unfortunately discourse_theme doesn’t work in that environment yet afaik so I’m back to my cloud server for that work.
It’s a little odd why Apple is lagging behind here? The Microsoft engineers have shown themselves to be very canny.
In case someone gets errors trying to install ruby 2.7.3, apparently something changed after Xcode 12 which breaks the install process with rbenv:
https://github.com/rbenv/ruby-build/issues/1489
I kept getting this, even though I have the latest versions of psych and libyaml installed:
It seems your ruby installation is missing psych (for YAML output).
To eliminate this warning, please install libyaml and reinstall your ruby.
I tried the workaround they suggest in the guide, but I kept getting the same error and ended up having to use rvm:
rvm install 2.7.3
Regarding how to program faster when doing a plugin, I’ve recently changed my approach. And it’s working great. Basically, move any front end stuff to a theme component, and only code the backend stuff in the plugin itself. I know others have figured that out before. But now that I’m doing it, programming is so much faster and nicer. Details here.
