Install Discourse on Ubuntu or Debian for Development
:warning: This guide covers installation instructions in a development environment. For a production guide see: Install Discourse in production with the official supported instructions
So you want to set up Discourse on Ubuntu or Debian to hack on and develop with?
We’ll assume that you work locally and don’t have Ruby/Rails/Postgres/Redis installed on your Ubuntu or Debian system. Let’s begin!
Requirements
We suggest having at least 4 GB RAM and 2 CPU cores.
Current compatibility:
OS Compatibility
Debian 11 :white_check_mark:
Crostini (Linux on ChromeOS) :white_check_mark:
Ubuntu 22.04 or later :white_check_mark:
Install Discourse Dependencies
You will need the following packages on your system:
** optional
Now that we have installed Discourse dependencies, let’s move on to install Discourse itself.
Clone Discourse
Clone the Discourse repository in ~/discourse folder:
git clone https://github.com/discourse/discourse.git ~/discourse
~ indicates home folder, so Discourse source code will be available in your home folder.
Setup Database
Create role with the same name as your Linux system username:
cd /tmp && sudo -u postgres createuser -s "$USER"
[/details]
Bootstrap Discourse
Switch to your Discourse folder:
 cd ~/discourse
Install the needed gems
source ~/.bashrc
bundle install
Install the JS dependencies
pnpm install
Now that you have successfully installed gems, run these commands:
bin/rails db:create
bin/rails db:migrate
RAILS_ENV=test bin/rails db:create db:migrate
Start rails and the frontend bundler:
bin/dev
If the images are not appearing, use this command instead:
(you can also specify an IP if you are working on a remote server)
DISCOURSE_HOSTNAME=localhost UNICORN_LISTENER=localhost:3000 bin/dev
You should now be able to navigate to http://localhost:3000 to see your local Discourse installation.
Create New Admin
To create a new admin, run the following command:
bin/rails admin:create
Follow the prompts, and a new admin account will be created.
Configure Mail
Run MailHog:
mailhog
Congratulations! You are now the admin of your own Discourse installation!
Happy hacking! And to get started with that, see Beginner’s Guide to Creating Discourse Plugins.
Last Reviewed by @blake on 2023-04-03T06:00:00Z
This document is version controlled - suggest changes on github.
Docker setup for development
Share your Discourse dev setup
How to open via internal IP?
Discourse as Your First Rails App
Why is my dev server not showing me uploaded images in Topics?
Unable to Install Discourse for development
Can I install discourse on my local machine
Can't install the bundle
How do I go about making a very customized theme?
Bitnami Discourse VM on Virtualbox + SMTP mail-server for testing
How to add a new language
Can't set up dev environment due to cppjieba_rb failing to install
Override profile background via SSO
Issue in setup discourse on ubuntu server
Mini_racer installation issues on ubuntu vagrant (OSX)
Rspec failing to load when using the official beginners guide
Not receiving Activation Email
Export only database data Postgres (for users, posts and topics)
Jhead and svgo errors while running specs
Moderation Tools
Any interest in Podman?
Bundler cannot continue due installation error of mini_racer 0.4.0
How to setup discourse in my local for development?
How might we better structure #howto?
Please help, how do I install Discourse on macOS?
Can't reach Discourse server in VM from Host
Images are not being populated in discourse
How to install Discourse locally?
Discourse Local setup
Is this correct? How long to install dev Version?
Overriding user_guardian.rb in a plugin (no fork necessary!)
How Sam's Windows development environment is configured
Site setting is different Every time on Ubuntu development installation
Problems with understanding the development of Discourse
How do I change the address in the database?
Discourse on local pc
Error while importing topics from Flarum (users, groups import OK)
Flarum To Discourse Migration
Problem in development Installation
Calling out for Testers
Developing on the mobile version of Discourse
Can't build Discourse on Ubuntu 20.10
Discourse standalone
Set up a local Discourse Development Environment?
Unable to setup discourse
Migrate a phpBB3 forum to Discourse
Migrate a vBulletin 4 forum to Discourse
Migrate a FluxBB forum to Discourse
Migrate a NodeBB forum with Redis to Discourse
Migrate a MyBB forum to Discourse
Migrate a NodeBB forum with MongoDB to Discourse
Migrate a Ning forum to Discourse
Migrate a Phorum forum to Discourse
Migrate a PunBB forum to Discourse
Migrate from another forum to Discourse
Migrate a Kunena 3 forum to Discourse
Migrate a bbPress WordPress plugin forum to Discourse
Use the Discourse API ruby gem
Use Screen To Bootstrap A Development Install (Ubuntu)
Set up Discourse for development on Fedora Linux
Need to restart Ember in order to test front-end changes
Error installing `bullseye-backports` when trying to install for Development
Local installation internal use only
ImageMagick Install Fails during Dev Installation on Ubuntu 22.04.1
Installing Plugins in Discourse Development Install
Discourse dev install script may need upgrade
I'm having trouble installing a local Discourse instance on Windows 11
Login popup not display
Not able to restore discourse docker backup on Ubuntu discourse installation
Installing Discourse on windows using Docker Desktop
End-to-end system testing for themes and theme components
CSRF problem in development with 'Discourse OpenID Connect' plug-in
Need help integrating code wrote on Edittext to the Discourse
Integration into custom auth system where emails are not unique?
Contributing to Discourse development
Development install fails when running bin/rails db:migrate
Developing Discourse on GitHub Codespaces
Install Discourse on Windows for development
Connecting WP Discourse to a local Discourse Instance running a specific version
Chat not working after dev install
Discourse Ember CLI Proxy Error
Bundling more popular plugins with Discourse core
Dev environment: recommended way to bootstrap the first admin account without email?
Migrate from GetSatisfaction to Discourse
Developing Discourse Plugins - Part 6 - Add acceptance tests
Install Discourse for development using Docker
Install Discourse on macOS for development
Discourse Server logs show DB queries when I run the server
Docker in VMWare - How to access to Discourse
How can I make my own Discourse plugins?
What is the latest recommended workflow for local development? (Ubuntu 16.04)
How to customize the Discourse app using docker container?
Uploads location on dev instance?
Update PhantomJS to latest for Ubuntu dev guide?
A check for updates has not been performed lately. Ensure sidekiq is running
How to fix bundler executable conflicts in the `techAPJ/install-rails` script?
Ubuntu development install: Permission denied @ apply2files
Install discourse on localhost
Trouble getting a top level page to Ember
Formal german available?
Rake aborted message is showing when installing vagrant development
Where is the db connection information discourse?
How to install the bootsnap gem?
State of disqus to discourse importer
Connecting to Droplet
Install and import Mysql on the development environment
Can't uninstall on Ubuntu 18.04
How to install Discourse on windows
Discourse running very slow on local machine
Can't find the Discourse folder inside virtual box via ssh
Importing MyBB database to Discourse
How to create new user with verified email in development mode?
Unable to create Vagrant local installation
Installing problem - bundle install
How to get a docker image of discourse using bash on windows 10?
Attachment filename not set on download
[PAID] Import from Legacy Postgres DB
Does Gemfile need to include svg?
Database wont migrate Discourse
I want to build a debug version of discourse
How to reset discourse on dev mode? (w/o docker)
Nodebb to Discourse
RSpec search_spec.rb RateLimiter LimitExceeded problems
Issue with vagrant version following the dev guide
Which is the better option to self-host?
NULL first_visited_at dates in the topic_users table
Multiple instances. Visiting the second instance signs out the logged in account on the running instance
Can't run my Discourse locally
I want to install a plugin for development, what should I do?
Vbulletin 4 import -
Hello from Gitpod! (installing on google cloud + automated dev setup)
How to Install Discourse on LocalHost in Windows?
Migrating a myBB forum to Discourse using Kubuntu in a VM
Migration from Yahoo! Groups
Does the forum for development start up 24 hours*?
How to allow customs hosts in development mode
Help with setting up discourse An error occurred while installing xorcist (1.1.2), and Bundler cannot continue
