Integrazioni chat per Discourse
:information_source: Chat Integration is for using an external chat system together with Discourse — you may be looking for Discourse Chat which adds Chat functionality directly to Discourse.
:discourse2: Summary
:open_book: Install Guide
The Discourse Chat Integration plugin lets you send messages in your preferred chat platform when something happens in Discourse.
Messages can be triggered by:
  • New topics
  • New replies
  • Messages to a group
  • Mentions of a group
Functionality by provider
Provider Notifications Slash Commands Post Transcripts Threaded Replies
Slack :white_check_mark: :white_check_mark: :white_check_mark: :white_check_mark:
Telegram :white_check_mark: :white_check_mark:
Discord :white_check_mark:
Mattermost :white_check_mark: :white_check_mark:
Google Chat :white_check_mark:
Matrix (element.io) :white_check_mark:
Zulip :white_check_mark:
Rocket.Chat :white_check_mark:
Gitter :white_check_mark:
Stride Docs
Microsoft Teams :white_check_mark:
Basecamp Docs
IRC Cloud Docs
Flock Docs
Webex :white_check_mark:
:warning: Before you enabling Slash Commands for your provider, make sure to read the Security/Permissions section below!
Configuration
There are three key concepts in this plugin:
  • Providers: The chat platform that you’re connecting to (e.g., Slack, Discord, etc.).
  • Channels: A single chat area in your platform (e.g., channel, group chat, room, etc.). Each provider can have multiple channels.
  • Rules: The instructions for when and how Discourse should send a message to a channel. Each channel can contain multiple rules.
Configuring providers
  1. Go to Admin > Installed Plugins and ensure that the Chat Integrations plugin is enabled.
  2. Click Settings.
  3. Choose the chat platform that you’d like to connect to Discourse.
  1. For some providers (e.g., Discord), you’ll be directed straight to the next step (channel configuration). Others will ask for special information, which you’ll need to get from your chat platform.
Dedicated setup instructions for chat platforms
Configuring channels
Once you have configured a provider, you can now configure channels for that provider. From the Chat Integration plugin page, click Add channel and provide the requested information — typically a webhook URL and/or channel name, depending on the provider.
Configuring rules
After your channel is connected, you can click Create rule to create a new rule for when your community should send a message to your provider channel.
The main components of a rule are:
  • Type: What type of community content should trigger a chat message?
    • Normal: Send chats for topics in the selected category.
    • Group message: Send chats when a PM is sent to the selected group.
    • Group mention: Send chats when the selected group is mentioned.
  • Filter: You can optionally filter the rule so that it only sends chats in certain situations.
    • All posts with threaded replies: Send chats for all posts matching this rule, with replies threaded in the chat platform. This option is not available for all integrations.
    • All posts and replies: Send chats for all posts and replies that match this rule.
    • First post only: Only send chats for the first post in a topic or message that matches this rule.
    • Tag added to topic: When the create post for category and tag changes site setting is enabled, send a chat when someone adds adds a tag to a topic.
    • Mute: Do not send chats that match this rule. This is useful for carving out an exception to another broader rule.
  • Group: If you selected Group message or Group mention as the Type, select the group whose received PMs / mentions should trigger the chat.
  • Category: If you selected Normal as the Type, optionally select the category that a topic must be posted in to trigger the chat.
  • Tags: Optionally select one or more tags that matching topics must have at least one of to trigger the chat message.
What happens when there are multiple rules?
Rules are sorted first by type then by the filter:
  1. Group mentions
    1. Mute
    2. All posts and replies
    3. First post only
  2. Group messages
    1. Mute
    3. First post only
  3. Normal (i.e. topics)
    1. Mute
    3. First post only
If a post matches multiple rules, the plugin will trigger the first matching rule in the list.
For example, with the following rules
Filter Category Tags
All posts and replies Mentions of: @team (all tags)
Mute Support (all tags)
First post only Support unsupported-install
All posts and replies (all categories) (all tags)
Notifications would be triggered for:
…but not for:
Security / Permissions
By default the system account is used, which means that there is no restriction on notifications sent.
To secure your notifications, you should create a non-staff user with appropriate access privileges, and enter its username in the chat integration discourse username setting.
Slash Commands
If your provider supports slash commands, you can manage rules from within your chat interface. Each provider varies slightly in syntax, but in general they follow a similar structure. (Note that at this time, only the Slack integration implements threads.)
The commands available are
Posting a transcript
If your provider supports transcript posting, you can post your instant messaging history to discourse. This is currently only supported for the Slack provider. Note: You will need to be using the “Access Token” method of connecting to Slack.
Send /discourse post to see the interface. The plugin will try and “guess” where your current conversation starts, by looking for a gap in the message history of more than 3 minutes.
Alternatively, you can specify a number of posts after the command, or a URL to the first message.
To load a transcript for a Slack thread, you can use /discourse post thread {url}, where {url} is the permalink of the first message in the thread. For example:
/discourse post thread https://<slackname>.slack.com/archives/C6029G78F/p1522952993000017
Alternatively, you can use /discourse post with a thread-specific permalink like this:
/discourse post https://foo.slack.com/archives/G49KKS6AX/p1523062012000911?thread_ts=1523091738.000088&cid=G49KKS6AC
In both cases the “first/last message” UI is skipped - the entire thread is included in the transcript.
Adding new providers
Option 1: Submit a PR implementing your provider:
Option 2: Use your own plugin:
It is possible for third party plugins to register new “providers”. As an example, I’ve created a provider which sends webhooks to IFTTT. This could be used to automatically publish all posts in a category to facebook… or turn on your light when someone posts in Contribute > Feature… or feed your fish whenever there’s a new Customization > Plugin.
CHANGELOG
TODO
115 Mi Piace
Set up Slack notifications using the discourse-chat-integration plugin
Set up Mattermost notifications using the discourse-chat-integration plugin
Set up Rocket Chat notifications using the discourse-chat-integration plugin
Set up Microsoft Teams notifications using the discourse-chat-integration plugin
Set up Google Chat notifications using the discourse-chat-integration plugin
Set up Matrix (element.io) notifications using the discourse-chat-integration plugin
Set up Gitter notifications using the discourse-chat-integration plugin
Set up Webex notifications using the discourse-chat-integration plugin
Set up Telegram integration using the discourse-chat-integration plugin
iOS Mobile App Notifications
Tool for Tossing out Notifications via Discord
Auto Post New Topics to Social Media
Will Rocket Chat and others get transcript posting?
Discord chat integration for open source projects
Dynamic of community with a chat and discourse page
Slack to Discourse
Moving from Slack to Discourse
Discourse-official-slack: no error message after failed post to slack
Comment on a question instead of answering it
Federation support for Discourse
Set up Zulip notifications using the chat integration plugin
[PAID] Turning Discourse Forum to Messenger App
Configure Discord Login for Discourse
Query on Discourse Integration with Google Chat
Steam Authentication & Integration
Add a new provider to discourse-chat-integration
Slack Plugin Still Active?
German People here
Yammer integration
Best chat integration for a Forum breakout
Contributor Interviews – David Taylor
IFTTT Chat Integration Plugin - curious on status
Configure Groupme provider with the discourse-chat-integration plugin
Libera Chat Integration
Help configuring Slack Discourse plugin
How can I beef up Discourse notifications?
HipChat Integration
Notifications integration for Facebook and Twitter
Plugin for auto posting to social media?
Two-way sync chat with discourse
Send summary of new posts to chat instead of every post update
Discourse to Discord bot possible?
Writing messages from Slack to Discourse
Internal Onebox links cause full page reload
Gitter support in chat-integration appears to be missing settings and rules
Advice for getting my little game dev community "out there?"
Can Discourse Integrate with Free Slack?
Discourse & Drift Chatbot
Checking if post or thread - Ruby
Nextcloud support
Discourse Data Explorer Query Response to Slack
Using Workflows to send a Slack message when a topic or post is assigned
Advice for starting a community site for housing cooperative
More Like WhatsApp for addiction support?
Optionally threading posts to parent topic in slack integration
Set up Power Automate to send Microsoft Teams notifications using the discourse-chat-integration plugin
Introducing Discourse Chat (BETA)
Twilio - for SMS notifications to users - Anyone Else Interested?
Discourse Chat vs Chat Integration plugins
Discourse vs Salesforce Community vs Slack
Discourse for Teams is here!
Adding a confirmation to particular tag groups and @mentions
Different layout for posts with/without tags in webex chat integration
Chat Integration and Discourse Chat
Slack Bot Construction Kit :robot:
Set up Discord notifications with the discourse-chat-integration plugin
Test message works, but normal messages are never triggered
Integration of https://signal.org/ chat
Discourse as a Conference App (in person, virtual, or hybrid)
Discourse Chat
Can you enable a plugin that integrates slack and discourse?
We would like to add the plugin "discourse chat integration", but INCOMPATIBLE PLUGIN is returned
Babble Chat
Dedicated chat client?
Feed Discourse posts into my Discord server?
Bundling more popular plugins with Discourse core
Current Projects - April 2026
Sarebbe interessante aggiungere il supporto per il plugin ActivityPub Plugin di Discourse in modo che la pubblicazione possa essere attivata in base a tag e altri filtri dall’integrazione della chat.
1 Mi Piace
Ciao, l’anno scorso Telegram ha annunciato forum/argomenti (mini chat all’interno di chat di gruppo). Ho provato a collegare ogni singola mini chat a una o all’altra categoria del mio sito. Ma a quanto ho capito, gli indirizzi degli argomenti non sono supportati dal plugin? Ad esempio, nel mio caso, ogni argomento ha un indirizzo come segue: @telegram_topic /1, @telegram_topic /2, @telegram_topic /3
Se inserisco un nome di chat standard nella riga, ad esempio @telegram_chat, funziona senza problemi.
Sarebbe molto comodo se il plugin avesse la possibilità di inserire indirizzi di chat simili (../1), così gli utenti non dovrebbero essere iscritti a molti canali indipendenti legati a determinate categorie del sito.
1 Mi Piace
Hai considerato di usare i tag per raggiungere questo obiettivo?
:thinking: Penso che l’uso dei tag non sia del tutto adatto al mio caso. Perché anche con l’aiuto dei tag, non vorrei che tutte le notifiche finissero in un unico canale, creando rumore informativo. Allo stesso tempo, invece di avere 20 canali per 20 categorie/tag, preferirei avere un’unica chat di gruppo in cui potrei organizzare diverse mini-chat a tema (per categoria/tag) dove ogni utente può visualizzare quella di cui ha bisogno e avere la possibilità di guardare in altre mini-chat. Sono così infastidito perché nella mia regione (Asia) la maggior parte delle persone usa le chat di WhatsApp e Telegram - i forum non sono popolari. Ma sto cercando un compromesso).\n\nP.S. Se mi ripeto spesso, non giudicarmi, sto solo cercando di esprimere i miei pensieri correttamente, dato che uso Google Translate.
1 Mi Piace
Dovresti essere in grado di filtrare quali tag si applicano a quali chat, almeno per quanto ti sto capendo.
Mi sembra che stiamo parlando di cose diverse :thinking: Non ho una domanda sul filtraggio delle chat per tag/categorie.
Per contesto. In precedenza, Telegram aveva canali e chat (ad eccezione dei bot). Questi canali/chat hanno un nome utente, approssimativamente @nome_chat o @nome_canale.
Dallo scorso anno, Telegram ha avuto l’opportunità di trasformare chat in forum contenenti mini chat tematiche come questa. Queste mini chat hanno i propri nomi utente, ad esempio @nome_chat /1, @nome_chat /2. La comodità di tali chat con mini chat è che l’utente non ha più bisogno di iscriversi a diverse chat separate tra loro, ma basta iscriversi a una chat (ad esempio, con il nome del mio sito) e avere accesso a molte mini chat (nel mio caso, ogni mini chat avrebbe come target una categoria specifica del sito) che interessano all’utente.
Ora voglio collegare queste mini chat a questo plugin, ma mi sembra che il plugin non supporti il nome utente della mini chat come nome_chat /1.
1 Mi Piace
Esiste un modo per creare una regola in cui posso taggare un nuovo messaggio e/o una risposta in modo che non venga pubblicato nel sistema di chat di destinazione (in questo caso Slack)?
Ehi Albert, se stiamo parlando di tag Discourse normali, puoi impostare un filtro ‘mute’ per impedire che argomenti con quel tag attivino notifiche in Slack.
Ma in termini di singoli post, non c’è modo di filtrarli.
1 Mi Piace
Penso di avere lo stesso desiderio tuo, Aizada:
Mi piacerebbe poter avere una chat di gruppo su Telegram, con i topic abilitati (che corrispondano in qualche modo alle categorie su Discourse), e poi, nelle impostazioni di integrazione Discourse/Chat, specificare a quale topic dovrebbe postare.
Ho provato a creare ora una chat di gruppo con topic (solo con il bot e me), ma quando digito /help all’interno di un topic, il bot risponde nella chat generale.
Hai dato un’occhiata a questo @david? Ho trovato questo thread su Stack Overflow, che mostra come ottenere il message_thread_id (che è l’ID del topic) e dice che l’API del bot ha ottenuto il supporto per questo nella versione 6.3.
Grazie comunque per il tuo lavoro! :heart_hands:t2:
1 Mi Piace
Ciao @ErlendMS :wave:. Al momento non abbiamo miglioramenti in programma per questo plugin, ma se qualcuno volesse aggiungere il supporto per il ‘threading’ (o topic) per l’integrazione Telegram, probabilmente sarebbe pr-welcome.
Abbiamo un certo supporto per il threading nell’integrazione Slack, quindi dovrebbe essere possibile riutilizzare parte di quella logica.
3 Mi Piace
È possibile usare questo plugin per ricevere notifiche su Slack ogni volta che un post viene contrassegnato per la revisione? Grazie.
Questo plugin espone funzioni API aggiuntive?
Dove richiedo una revisione di una PR? Ho inviato questa PR alla fine della scorsa settimana per aggiungere un nuovo provider e questa è ancora in attesa di un revisore. Ho cercato nelle varie guide per sviluppatori su Meta e non sono riuscito a trovarne una per le richieste di PR corrette.
Ecco la mia PR: FEATURE: Added Power Automate as a new provider by benoitdesnoyers · Pull Request #204 · discourse/discourse-chat-integration · GitHub
Grazie,
1 Mi Piace
Ciao ragazzi! Abbiamo appena unito questo pr per il plugin di integrazione della chat
Questa modifica mira a rimuovere l’opzione tags_changed dal filtraggio delle regole dall’integrazione della chat – stiamo apportando questa modifica perché stiamo rimuovendo l’impostazione Creazione di un piccolo post di azione quando la categoria o i tag di un argomento cambiano.
Ma la funzionalità rimarrà la stessa, se hai Discourse Automation installato. La prossima volta che eseguirai le migrazioni per questo plugin, aggiungerà uno script al plugin Discourse Automation che funzionerà in modo simile a quello che abbiamo attualmente.
Questo è un esempio di automazione che verrà creata:
Verrà inviato al mio canale in base alle categorie e ai tag che sto monitorando.
${ADDED_AND_REMOVED} è il testo predefinito; si comporterà allo stesso modo della regola.
Abbiamo anche aggiunto per questa opzione di script alcune opzioni che possono essere utilizzate nel messaggio:
  • ${TOPIC} per il nome dell’argomento
  • ${REMOVED_TAGS} per i tag rimossi
  • ${ADDED_TAGS} per i tag aggiunti
    sia rimossi che aggiunti si attiveranno solo se contengono un tag.
    Ad esempio: il messaggio added: ${ADDED_TAGS} si attiverà solo se ci sono tag aggiunti.
4 Mi Piace
Abbiamo riscontrato un problema con l’altro PR (gli utenti che utilizzavano altri provider non potevano utilizzare l’automazione quando le etichette degli argomenti cambiavano), quindi per risolvere il problema, abbiamo creato questo nuovo PR, in cui teniamo conto di ogni provider.
L’impostazione Creazione di un piccolo post d'azione quando la categoria o le etichette di un argomento cambiano non apparirà nell’integrazione della chat.
Se hai installato discourse automation, la prossima volta che eseguirai le migrazioni per questo plugin, verrà aggiunto uno script al plugin discourse automation che funzionerà in modo simile a quello che abbiamo attualmente.
Le tue automazioni appariranno più o meno così:
E i tuoi provider sono i provider abilitati.
Ad esempio, ho abilitato Discord, Slack, Telegram e Google Chat
Il tuo nome del canale è il nome che gli hai dato nelle impostazioni di integrazione della chat.
Ad esempio, il nome qui è Spidey
3 Mi Piace
Abbiamo un nuovo lotto di modifiche per Automation/chat-integration
In questo nuovo lotto, le modifiche degne di nota sono:
  • Abbiamo aggiunto Trigger with PMs (Attiva con messaggi privati), che consente di controllare se questa automazione debba essere attivata anche sui messaggi privati.
  • Risolto un problema per cui l’automazione del trigger Topic tags changed (Tag dell’argomento modificati) veniva attivata durante la creazione dell’argomento.
3 Mi Piace
Come accennato in precedenza – qui
L’impostazione del sito create post for category and tag changes può attualmente divulgare tag/categorie private; un modo che abbiamo trovato per mantenere quella funzionalità è stato spostarla nei sussurri:
Funziona in modo simile ai piccoli post, ma ora è necessario disporre di whisper allowed groups con un certo gruppo per farlo funzionare.
Ho unito una PR per il core con questa modifica e una per chat-integration, rimuovendo l’uso di tale impostazione; la funzionalità di automazione aggiunta dovrebbe essere 1:1 con la piccola azione se qualcuno ha problemi, faccelo sapere!
3 Mi Piace
Ho altri aggiornamenti per questo plugin :steam_locomotive:
Abbiamo aggiunto il campo trigger on per l’automazione Send Chat-Integration message.
Cosa fa?
Controlla quando i tag vengono:
  • Aggiunti e Rimossi (predefinito)
  • Aggiunti
  • Rimossi
Attualmente, questo controllo è inclusivo.
Un buon esempio è se lo imposto su Aggiunti; affinché questa automazione venga eseguita, sarà necessario che qualsiasi tag venga aggiunto a un argomento.
Quando viene impostato Tags added, la tabella di automazione appare così:
Aggiunto tag all’argomento Rimosso Tag dall’argomento L’automazione è stata eseguita?
:white_check_mark: :cross_mark: :white_check_mark:
:cross_mark: :white_check_mark: :cross_mark:
Quando viene impostato Tags removed, la tabella di automazione appare così:
Rimosso tag dall’argomento Aggiunto Tag all’argomento L’automazione è stata eseguita?
2 Mi Piace
Oggetto: Impossibile accedere alla sezione Plugin per la configurazione dell’integrazione chat
Ciao,
Sono un amministratore del forum LXDAO e sto cercando di configurare il plugin Discourse Chat Integration per connettermi con Telegram. Secondo la documentazione ufficiale, dovrei essere in grado di configurarlo nella sezione Plugin del pannello di amministrazione.
Tuttavia, nella mia dashboard di amministrazione, ho accesso solo a quattro sezioni: Generale, Moderazione, Sicurezza e Report. La sezione Plugin menzionata nella documentazione non sembra essere disponibile.
Potreste aiutarmi a capire:
  1. Il plugin Chat Integration è già installato sul nostro forum?
  2. Ho bisogno di permessi aggiuntivi per accedere alla sezione Plugin?
  3. Se stiamo utilizzando una soluzione Discourse ospitata, ci sono limitazioni riguardo all’installazione/configurazione dei plugin?
Come amministratore, quali passaggi devo intraprendere per configurare correttamente l’integrazione Telegram per la nostra community?
Grazie per il vostro aiuto!
