Run other websites on the same machine as Discourse
@pfaffman edited this heavily 2022.02.24. Blame me if it’s broken.
If you want to run other websites on the same machine as Discourse, you need to set up an extra NGINX or HAProxy proxy in front of the Docker container.
NOTE: This is for advanced admins
This guide assumes you already have Discourse working - if you don’t, it may be hard to tell whether or not the configuration is working.
You cannot use ./discourse-setup to set up Discourse if another server is using port 80 or 443. You will need to copy and edit samples/standalone.yml with your favorite text editor.
Install nginx outside the container
First, make sure the container is not running:
cd /var/discourse
./launcher stop app
Then install nginx and certbot:
sudo apt-get update && sudo apt-get install nginx certbot python3-certbot-nginx
Change the container definition
This is where we change how Discourse actually gets set up. We don’t want the container listening on ports - instead, we’ll tell it to listen on a special file.
You need to edit /var/discourse/containers/app.yml to disable ssl and add template to create nginx sock. It should look like this:
# base templates used; can cut down to include less functionality per container templates:
  # - "templates/web.ssl.template.yml" # remove - https will be handled by outer nginx
  # - "templates/web.letsencrypt.ssl.template.yml" # remove -- https will be handled by outer nginx
  - "templates/web.socketed.template.yml"  # <-- Added
Be sure to remove or comment out the exposed ports by putting a # in front.
# which ports to expose?
# expose: comment out entire section by putting a # in front of each line
# - "80:80"   # http
# - "443:443" # https
Now you can
/var/discourse/launcher rebuild app
to rebuild Discourse to make its data available to the socket.
If you are using some other reverse proxy that cannot use a web socket, you can instead expose a different port in the section above like - 8080:80.
Create an NGINX ‘site’ for the outer nginx
Create a site file for Discourse:
cd /etc/nginx/sites-available
cp default discourse.example.com
cd ../sites-enabled
ln -s ../sites-available/discourse.example.com
Next edit that file by commenting out these lines:
        #listen 80 default_server;
        #listen [::]:80 default_server;
and editing the server_name and location stanza like this:
    server_name discourse.example.com;  # <-- change this
location / {
                proxy_pass http://unix:/var/discourse/shared/standalone/nginx.http.sock:;
                proxy_set_header Host $http_host;
                proxy_http_version 1.1;
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
                proxy_set_header X-Forwarded-Proto $scheme;
                proxy_set_header X-Real-IP $remote_addr;
If you’re using a two-container installation the socket line will be:
                proxy_pass http://unix:/var/discourse/shared/web_only/nginx.http.sock:;
Then, in a shell:
certbot --nginx
And follow the instructions. If you don’t understand the prompts, you probably shouldn’t be doing this, but can check the certbot docs for help.
@pfaffman thinks that certbot will do this for you, but if you make changes to the nginx config you will need to
sudo service nginx reload
Create your other sites
You’re done with the Discourse section!
Make other NGINX “sites”, then link and enable them, as in the last step above.
Tips
  • sudo netstat -tulpn : This will tell you what ports are being used
  • /var/log/nginx/error.log : Is the location of the nginx log on ubuntu. This will tell you what the error is when you get a 502 Bad Gateway error.
Port already in use, what to do?
Best way to install Discourse on my server?
Multisite configuration with Docker
Installing Discourse Under Nginx
Nginx configuration for discourse
Discourse + Nginx reverse Proxy
Using Multiple Websites with Nginx + Discourse
[Solved] Help setting other websites on the same DigitalOcean droplet
Setting up nginx for use with Discourse
Using Discourse With Other Sites on Same Droplet
Nginx + discourse
Can't make Discourse accessible through Apache
Wordpress and Discourse in a single droplet
Discourse not working through separate nginx docker
Problem with discourse in a subfolder
Faster rebuilds?
Setting up Discourse on a VPS with other sites
Wordpress and discourse on the same server
Disable direct access with port (nginx)
A better "site not available" page
NGINX proxy in front of the Docker container.errors
Bad gateway when trying to use SSL
Landing Page
Multiple container setup problems
Launcher rebuild app failing: repository name must be lowercase [SOLVED]
Custom Intro page for discourse
Broken images inside posts
Starting a second Discourse forum on the same VPS
Which performance is better if discourse or phpbb hosts on a same vps?
Discourse doesn't deliver webpages, fresh install on Linode Ubuntu 14.04
403 forbidden after installation
Installing docker on an already running web server?
Multiple discourse installation on single droplet
Can Discourse ship frequent Docker images that do not need to be bootstrapped?
IP Spoofing Attack
Error while doing discourse setup
Run other php script
Domain names pointing with shared AWS instance
How to install discourse on hosting?
Can not visit forum.abc.com again after port change to container/app/yml
Error connecting to Redis
Advice on integrating into a Docker-Compose setup?
Installation on v-server as a subfolder with other services in subfolders using apache
Wanting to run Discourse alongside apache
Add subdomain exception to nginx to host another site on same host
Docker0 Missing (OpenVZ)
Domain & Subdomains
Nginx rate limiting outside of container - any tips?
Sandbox and test discourse on host?
Best approach for test and production instance of discourse
Mixed content for icon using http on https setup
How do I do what I did in htaccess in nginx?
How Can I set up discourse on my hosting?
CDN causes white screen
Using a certificate when Discourse is installed behind a reverse proxy
Can I run wordpress in the same VPS with a second IP?
ERR_SSL_PROTOCOL_ERROR with Letsencrypt
Generals Subfolder recommendations and tips
Installing discourse with nginx already running?
Wordpress + Discourse using Digital Ocean and Serverpilot
Unsure About How to Start a Website Project
Install on vps problem?
Install discourse alongside WordPress in a dedicated server
Installation Help required
Installed OK. Working fine for one day. Suddenly stopped working
SSL received a record that exceeded the maximum permissible length
Change the maximum attachment/upload size
Moved from PluXml and phpBB to Wordpress and Discourse, my all-new experience :tada:
Discourse site loads via IP but via domain only header
Configuring Website with Discourse and Wordpress?!
Looking for a tutorial on discourse/wordpress 1 machine install
Blank pages, 500 errors and no logs
Remote users IPV6 address shows as localhost
Not able to send email Net::ReadTimeout
Add an offline page to display when Discourse is rebuilding or starting up
URLs for avatars & emoticons adding :80 to the end of the domain
OpenID Connect extension not creating new Discourse users
Installed discourse on a server that already runs a webserver, domain just redirects to subdomain
Installation fails on my Debian server
Discourse new Base Image
FAILED to rebuild discourse -- OpenURI::HTTPError: 401 Error: Invalid license key
How to install Discourse on Plesk?
Configure direct-delivery incoming email for self-hosted sites with Mail-Receiver
Discourse with Traefik 2.0
How to add a subdomain on a different droplet/server?
More than one site as different container running on the same do server
Can I have two domains pointing towards the same IP address without redirect?
Postgres already running
Install Discourse on a droplet with WordPress served by Apache?
Discourse OpenID Connect (OIDC)
How to collect all static assets (js, css) used by discourse
Avatar, Site Logos, and Cert Errors
Error 521 after latest update due to CloudFlare settings
Runing Discourse Along a Wordpress Website
Discourse and WordPress installation on one ubuntu desktop
How do I rebuild app using the host network rather than the docker network?
Can I Host More Than 1 Thing On My VPS?
Is it possible the certbot inside the container can affect new certbot outside it?
Discourse + web server. Possible or better to avoid?
Help for installing Discourse alongside Apache2
502 Gateway Error: Discourse Installation with SSL form Cloudflare
Installation of Wordpress and Discourse same domain same server?
Multiple subdomain instances of Discourse at the same domain?
I can't set nginx: [emerg] cannot load certificate "/var/discourse/shared/standalone/ssl/ssl.crt": BIO_new_file() failed
Discourse with other websites, SMTP issue: End of file reached
Error: Slow down, too Many Requests from this IP Address
Links in emails are using http instead of https
Google auth error
Anything else on same Digital Ocean droplet as Discourse?
Checking domain name fails behind NGINX proxy
Changing force_https does not update the url of uploaded images causing a mixed content warning
Running Discourse alongside LAMP
429 error when opening multiple topics
What is the best way to install Discourse Forum on a Proxmox VM and expose it on the internet
Setup Multisite Configuration with Let's Encrypt and no Reverse Proxy
WARNING: Port 443 of computer does not appear to be accessible using hostname
Address already in use during setup
Setting up Discourse on a machine with existing Nginx
Installing discourse with http only (no https)
Multisite Dockerfile issues
Nginx error 502
Nginx error 502
IP Lookup is Pulling CDN's X-Forwarded-For
Not getting Discourse Home page
Installing Discourse to Debian 10.5
Discourse overloaded real traffic or DDOS? 100% CPU usage despite of decent traffic and high specs server
Redirect_uri query parameter is not adding https
Use X-Forwarded or not?
How could I install another discourse on same server (docker)?
How to make Discourse coexist with nginx on a Debian 9 server?
Discourse won't start because port 80 is in use
Nginx.http.sock not created
Site backup after migration
Migrate Existing Community to a Docker based Discourse
Standalone discourse install issues and how to use a separate ip address?
Discourse installed on subdomain but not working
How do I run Discourse on Pterodactyl Panel?
Discourse on nginx WITHOUT Passenger?
Different Device, Same IP with Nginx
Can't Send Emails
Discourse shows server IP/localhost as user's IP
Discourse HTTPS Web Socket
Restore a backup from the command line
Use Nginx Proxy Manager to manage multiple sites with Discourse
Discourse-app container starts then silently stops
New installation behind Litespeed reverse proxy stalls on loading screen
Trouble configuring discourse with reverse proxy
WARNING: Port 443 of computer does not appear to be accessible, but web page is ok
Discourse on a Raspberry Pi | Blog
Centminmod + discourse
NGINX fails to start
How to install Discourse on Apache server with existing site
Freshly-installed site is showing the error: "Ember CLI is Required in Development Mode"
How do I set up a frpc server with frp to install Discourse?
Getting Discourse to see the Prometheus server IP
How to setup NGINX in the Discourse Docker container
Use CloudPanel to manage multiple sites with Discourse
Running on different port than 443: Disable redirect to nonport URL
Reverse proxy for Discourse | Real IP masking
Page Publishing
Wordpress and Discourse instance + some other functionality on one droplet
Run discourse in front of load balancer like AWS/Oracle OCI
Does discourse launcher / docker use the local postgresql and redis servers?
How to use FIDO2 with Discourse behind a reverse proxy?
Discourse installed in UNRAID Ubuntu Server VM behind NPM reverse proxy not resolving hostname
Setting a custom IP doesn't work?
Where to start with coding?
Assistance Needed for Configuring Discourse on a Multi-Site NGINX Server
Reverse Proxy Into Discourse
How to Change Discourse Port 80 and 443 to another Port
Problems installing on existing EC2 server
Infinite 301 redirect with reverse proxy setup
Hosting dynamic content inside a Discourse subfolder
Running multiple things on the same sever as my Pi (where Discourse is hosted)?
Need to setup discourse in ubuntu 22.04 server for my organization use
How do I even install Discourse?
Creating subdirectories in a Discourse hosting environment
Difficulty installing on vm that includes CPanel and Apache
Multiple Standalone containers instead of multisite?
Discourse socketed: Nginx in front of discourse: no IP adresses
How should I enable letsencrypt while discourse is beside other websites
How to Docker+Discourse and Apache too?
Help understanding the structure of using discourse + static website
Discourse not showing up at specified hostname
Success - New Multisite Install on Dedicated server using ServerPilot, Nginx and Apache
Error in installing
Regenerating LetsEncrypt keys from behind nginx
[Solved] Dev instance with nginx: topic preview not working
Installation on Ubuntu 14.04 LTS + Apache 2 + Plesk 12
Can't get Discourse to work on different ports
Webhooks/Sidekiq issue on dev instance
Discouse passes localhost uri as oauth redirect_uri
What is the recommended practice for WordPress and Discourse on the same server?
I cannot access my main site after trying to install discourse
Nginx + discourse
Discourse with zpanel
Backup uploads terribly slow
How to install wordpress in the Secondary directory?
Moving to subdomain
Deploying discourse on server already running another rails app
How to upload files in root directory?
WordPress, Discourse and Local SMTP Server
Default app.yml file anywhere?
Does it make sense to use Discourse on any server or is it with the hosting service Discourse provides?
Oauth2 redirect_uri uses HTTP when my forum is using HTTPS
502 Bad gateway error after switching to SSL
Wrong sending domain used
Wordpress integration with mini forums
How can one install a panel with discourse?
Accessing to the database from outside the container
How to change the port from docker - help
Discourse stopped working after installing Plesk
Discourse blocking with password reset
Difference between socket- and port-based connection to outer NGINX?
Layouts Plugin
Set up HTTPS support with Let's Encrypt
Put forum under sub-domain and have website
The guide in the first post is great and, on the whole, still works just fine :sunny:
There are three things worth noting:
  1. I initially missed some of the app.yml changes. There are 3 things you need to change in your app.yml. If you miss any of these things it won’t work:
    1. Comment out all ssl templates in the templates. If you are using letsencrypt you will have two:
    2. Add a socket template:
    3. Comment out all exposed ports:
      # - "80:80"   # http
  2. As others mentioned, I had to change the ssl cert and key names in the discourse.conf:
    ssl_certificate      /var/discourse/shared/standalone/ssl/discourse.angusmcleod.com.au.cer;
    ssl_certificate_key  /var/discourse/shared/standalone/ssl/discourse.angusmcleod.com.au.key;
  3. Turns out my site didn’t have a dhparams.pem key (dh stands for Diffie Hellman, there’s some good explanations of what this is here). You can generate this yourself:
    openssl dhparam -out /var/discourse/shared/standalone/ssl/dhparams.pem 2048
Some other things you may find useful:
  • sudo netstat -tulpn: This will tell you what ports are being used
  • /var/log/nginx/error.log: Is the location of the nginx log on ubuntu. This will tell you what the error is when you get a 502 Bad Gateway error.
  • You may finish a ./launcher rebuild app, excitedly go to your domain to see if it worked and be greeted with a depressing 502 Bad Gateway error. Before giving up in frustration, try restarting nginx one more time:
    sudo service nginx restart
    This clinched it for me.
Now my sandbox is using nginx outside the container (although I haven’t added the extra website yet).
Hi,
I am just doing a fresh install of Discourse.
I am very surprised that :
  • The setup script does not simply allow to setup on a different port, disabling SSL support, and then it’s up to us to do reverse proxy as we want (Apache, Nging) : It seems such a common setup, it would save hundreds of hours of life to humanity
  • I am even more surprised that the setup redirects us to an outdated forum topic, in which we need to dig for the proper information, instead of a proper documentation page, kept up to date.
Thanks guys anyway for your work, but I think there is room for improvement here.
Cheers
Just wanted to share how I accomplished this, it was a little easier than I first thought.
From an already running machine, with Caddy acting as a reverse proxy for a number of existing Docker containers already.
  1. Clone discourse as per the official instructions
  2. Copy /var/discourse/samples/standalone.yml -> /var/discourse/containers/app.yml
  3. Fill in SMTP settings and website address
  4. Comment out 443:443 from the expose: section
  5. Replace 80:80 -> 3001:80, 3001 being the port I’m serving via Caddy
  6. Run ./launcher rebuild app
  7. Done
Whop!
@TheBestPessimist I swapped the order of the HTTP/HTTPS sections, it works better than adding a “don’t do this!” notice :slight_smile:
I would recommend just doing double NGINX, it is far more complex to set it up direct and has virtually no performance cost. Getting it right would be very hard cause we serve some files direct and have a layer of caching that is tricky to configure.
Note, customizing NGINX is easy with mixin templates have a look at the various example templates here: discourse_docker/templates at master · discourse/discourse_docker · GitHub
PSA: If you want to allow uploads larger than 1MB to your site, you’ll also have to set client_max_body_size 100M in any nginx config that sits in front of your site.
For reference, here’s the full nginx config I use:
nginx config for other sites on same host
server {
    if ($host = discourse.mysite.org) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    if ($host = backupname.mysite.org) {
    listen 80; listen [::]:80;
    server_name discourse.mysite.org;
    server_name backupname.mysite.org;
    location / {
        proxy_pass http://unix:/var/discourse/shared/mysite/nginx.http.sock:;
# nginx 1.14.1 | intermediate profile | OpenSSL 1.1.0f | link
server {
    listen 443 ssl http2;  listen [::]:443 ssl http2;
    # from discourse examples
    http2_idle_timeout 5m; # up from 3m default
    client_max_body_size 50M; # allow 50M uploads
    location / {
        proxy_set_header X-Forwarded-Proto https;
    ssl_certificate /etc/letsencrypt/live/backupname.mysite.org/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/backupname.mysite.org/privkey.pem; # managed by Certbot
    ###### https://mozilla.github.io/server-side-tls/ssl-config-generator/ ####
    ssl_session_timeout 1d;
    ssl_session_cache shared:SSL:50m;
    ssl_session_tickets off;
    # modern configuration. tweak to your needs.
    ssl_protocols TLSv1.2;
    ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
    ssl_prefer_server_ciphers on;
    # HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
    add_header Strict-Transport-Security max-age=15768000;
    # OCSP Stapling ---
    # fetch OCSP records from URL in ssl_certificate and cache them
    ssl_stapling on;
    ssl_stapling_verify on;
    ## verify chain of trust of OCSP response using Root CA and Intermediate certs
    ssl_trusted_certificate /etc/letsencrypt/live/backupname.mysite.org/chain.pem;
    resolver 1.1.1.1;
16 posts were split to a new topic: Using Nginx Proxy Manager to manage multiple sites with Discourse
angus’s instructions still work; I have a question, though: will LetsEncrypt still work automatically with this after 3 months when it’s time to renew the certificates? (I assume/hope the answer is yes since the host nginx reads them directly from /var/discourse/shared/standalone?)
@Godmar_Back I ran into this problem right now, and my certificate was NOT renewed.
@angus - since we use the letsencrypt certs created by discourse, but commented out the relevant parts in app.yml, I guess the update script is no longer being started. Did you find a solution for that?
I tried entering the app and
 "/shared/letsencrypt"/acme.sh --cron --home "/shared/letsencrypt" --force
which kind of showed me at least a problem.
my.site.com:Verify error:Fetching https://my.seite.com/.well-known/acme-challenge/XXXXXXXedited-out-XXXXXXXXXXXXXXXXXXXX: Error getting validation data
[Mi 25. Aug 10:41:37 UTC 2021] Please check log file for more details: /shared/letsencrypt/acme.sh.log
Acme.sh.log pretty much repeats the error message. But it also tells me that all config files are empty.
On the otherhand acme.sh updated itself, so I assume it has not been started in the background for a while, probably since I changed to the outer nginx.
You’ll need to handle those outside the container. Follow whatever guide is for let’s encrypt and nginx.
As it’s past the period you can edit it yourself, you could flag it. You can flag a post, including your own, by clicking the ellipsis followed by the flag icon at the bottom of the post.
In this case you would choose to flag it as “Something Else” and explain that your email reply included the content from the previous post.
https://meta.discourse.org/t/upload-problem-with-https-or-http2-and-s3/202799/3
I’ve just got my new install of discourse on my new server, and after restoring the backup, now I get an issue with SSL.
It says that “parts of this page are not secure, such as images” and after a quick google search I seen that it means the images and fonts etc are not being served over https. However everything appears that it is.
I just copied the NGINX config, and it wasn’t there before I restored the backup.
Any ideas?
You could check your force_https is enabled in your admin settings. There have been a few issues with that recently.
If I had Discourse docker on server, but it was using port in 980 and 9443 (reserve proxy)
Could I use ./discourse-setup to set up another Discourse? (Pull another folder of discourse)
It seems more simple by this way, isn’t it?
Why would you do that over running multi-site?
You can create appy.yml but you can’t use discourse-setup. Copy the other one and edit it.
It is sort of more complicated and requires all sites to use same mail and plugins. For most people it’s easier to just run another server, I think.
Yes, exactly
And the single one will be supported more by discourse team
Could you explain how to do it?
  1. I had app.yml
    Could I copy other discourse folder, and app02.yml?
  2. Could I run ./discourse-setup when I copied discourse02 folder and app02.yml?
    How could I config it here?
    I want to be sure that two of container not conflict each other.
  3. My current container named “app”.
    Could I changed its name by rename app.yml?
