Install plugins on a self-hosted site
:warning: This guide assumes that you have a self-hosted standard installation. We only support the standard method of install here, so these instructions assume you have a standard install.
:warning: This guide only applies to self-hosted Discourse instances. If you are using a managed hosting service, the available plugins are controlled by your hosting provider. For example, on our hosting these specific plugins are available by hosting tier.
:information_source: As of mid-2025, many popular official plugins have been bundled into Discourse core. These plugins (including Solved, Data Explorer, AI, Assign, Reactions, and many more) no longer need to be installed separately — they ship with Discourse and can be enabled via site settings. If you try to rebuild with a bundled plugin still in your app.yml, you’ll see a HINT message telling you to remove it. This guide is for plugins that are not bundled with core.
In this tutorial, we’ll install the Discourse Shared Edits plugin.
This tutorial requires an understanding of how to use GitHub repos, specifically, how to get or copy the git clone URL and how to edit YAML (*.yml) files via the terminal using nano, specifically how to save and exit on nano. YAML files strongly follow indentations, so be sure to respect these as you copy and paste and edit the necessary *.yml for your Discourse instance. Always use spaces to indent in .yml files, not tabs.
  • Copy the plugin’s GitHub git clone url.
  • Access your container’s app.yml file (present in /var/discourse/containers/)
    cd /var/discourse
    nano containers/app.yml
  • Add the plugin’s repository URL to your container’s app.yml file:
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - git clone https://github.com/discourse/discourse-shared-edits.git
    Add the plugin’s git clone url just below the line containing git clone https://github.com/discourse/docker_manager.git)
    Follow the existing format of the docker_manager.git line; if it contains sudo -E -u discourse then include that prefix in your new line too.
  • Rebuild the container:
    cd /var/discourse
    ./launcher rebuild app
    That’s it, you’ve successfully installed the Discourse Shared Edits plugin on your Discourse instance!
If your plugin is hosted in a private repository
You must use an OAuth token:
With the OAuth token, you can install your plugin in the same way as a public repo, and you don’t need to create a SSH key.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
              - git clone https://<token>@github.com/owner/repo.git
We strongly advise you to use OAuth tokens for plugins in private repositories. However, if you cannot, see below.
SSH Key Private Install Steps
run:
  - exec: cd /var/www/discourse && sudo -u discourse bundle install --deployment --without test --without development
  - exec: echo "Host github.com\n\tStrictHostKeyChecking no\n" >> /user/.ssh/config
  - file:
      path: /user/.ssh/id_rsa
      chmod: 600
      contents: |
        -----BEGIN RSA PRIVATE KEY-----
        MIIEogIBAAKCAQEArCQG213utzqE5YVjTVF5exGRCkE9OuM7LCp/FOuPdoHrFUXk
           .... etc ....
        -----END RSA PRIVATE KEY-----
  - file:
      path: /user/.ssh/id_rsa.pub
      chmod: 600
      contents: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAklOUpkDHrfHY17SbrmTIpNLTGK9Tj .... etc .... user@discourse
  - exec: cd $home/plugins && git clone git@github.com:SecretOrg/secret-plugin.git
  - exec: cd $home && sudo -E -u discourse bundle exec rake db:migrate
  - exec: cd $home && rm -fr tmp/cache
  - exec: cd $home &&  sudo -E -u discourse bundle exec rake assets:precompile
  - exec: rm /user/.ssh/id_rsa
  - exec: rm /user/.ssh/id_rsa.pub
cd /var/discourse
Your private plugin should be installed on your Discourse instance.
How to uninstall a plugin
To remove a plugin, simply remove the - git clone https://github.com/... line from your app.yml file and rebuild your site via
cd /var/discourse
Discourse Slackdoor Plugin
How to create a new plugins?
Site maintenance mode during rebuilds?
Discourse Version 1.2
Embed Etherpad Lite pads into Discourse
Solved Button Plugin
LDAP Setup for Discourse
Wild Apricot login plugin
Formatting toolbar
About the Plugin category
Can Plugins Be Added To Basic Docker Install
Discourse Mark Plugin
Quick Messages Plugin
"Onebox Assistant", crawl for those previews reliably!
Installing Plugins with Git
Does this software allow admin to put Adsense ads in?
Discourse Category Home :house:
Tickets Plugin :tickets:
Daemonite Material Theme
News Plugin :newspaper:
Generating lots of Invite Tokens
Installing new plugins
How do i install plugins after doing a fork?
Bump Reset plugin - Annotated to help new devs
Discord-rolesync plugin
Category Page Plugin
Update private plugin without rebuilding the application
Admin Statistics Report
Watching Categories based on on group in discourse
Topic Ratings Plugin
Application Files after Digital Ocean Setup
How do you add plugins?
User feedback plugin
Install plugins in your non-Docker development environment
Projects management plugin
How to ad banners?
Discourse BBCode
Introducing Discourse Chat (BETA)
Community Network Visualisation
LDAP Auth Missing from Plugins
Discourse Doc Categories
Fatal: Not a git repository (or any parent up to mount point /discourse)
How to add a Leaderboard link to the hamburger menu?
I need someone who can install a voting plugin
Custom Wizard Plugin :mage:
Introducing Font Awesome 5 and SVG icons
Click To Edit
Legal Compliance Plugin
Triggering account creation/login on external service when a user logs in on discourse
Are plugins free using the open-source, self-host option?
ListenBrainz
Subscription Plugin not working (Error)
Discourse-a2a-bbcode
Error using discourse-oauth2-basic plugin with NeonCRM
Question Answer Plugin
How might we better structure #howto?
Discourse Posthog Plugin
Cannot install new plugins: structure needs cleaning
Calendar Core - Needs any special theme?
Discourse Notifier
Discourse CommonMark text highlighting?
Mumble -- VOIP Plugin for Discourse
Advice on Installing Plugins
Smallcaps formatting
Cannot install plugin - nothing happens
What else do I need to take care of when self hosting?
Humanmark for Discourse - Hardware-Backed Humanity Verification
Verifiable Credentials Plugin
Installing discourse-math.git
Discourse Image Filter
Discourse Linkify Google Sheets
Discourse Voting missing table on postgresql
Discourse Signatures
Discourse BBCode Color
Discourse Post Sorting Customizer
Unikname Connect plugin
Discourse Video Upload Plugin with YouTube and Vimeo
Quoting not working
User profile by ID instead of username
Error after update failed today: [rake themes:update assets:precompile]
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return
Votes don't Merge when we combine posts
Discourse Video Inline
Discourse User Feedback
Availability of OpenID Connect in hosted plans
Codebytes Plugin
Multiple Users posting under same User or Group name?
What makes a successful volunteer Discourse sysadmin?
Not able to install any Discourse plugins
How to install the lazy-yt plugin
Issue With Sitemap
Discourse Private Replies
Google One Tap Login/Signup
Landing Pages Blog :small_airplane:
Search Thumbnails
Group Invitation Plugin
Discourse Mailgun Routes
Word Cloud plugin
Geo Blocking plugin
Post folding
Signed Google Cloud CDN URLs
Google Groups Link Plugin
Discourse LinkedIn Authentication
Discourse VK Authentication (vkontakte)
Discourse OneDrive Picker
Discourse BCC
Discourse Prometheus
Discourse Dictionary Plugin :ab:
Category Restrictor plugin
Dumbcourse – Old-browser friendly UI at /dumb (D-pad + small screens)
Slack Bot Construction Kit :robot:
Discourse Authorship Plugin
Discourse Livestream
Locked out from WinSCP and can't Install Plugins!
Create custom Automations
Affiliate link functions - rewrite
🤖 Discourse llms.txt Generator Plugin
Editing a table whose some rows don't start with a pipe duplicate these rows
How to: discourse-sitemap is deprecated and merged into Discourse's core. Please remove it from your app.yml file.?
How to update plugins manually from the command line?
Discourse Restricted Replies
Discourse Yearly Review
Discourse Saved Searches
Discourse Intercom (Advanced)
Discourse Salesforce
Sign-In with Ethereum plugin
Discourse GitHub Verification
Discourse Algolia Search
Discourse Characters Required
Discourse No Bump
Discourse Teambuild
Installing Plugins in Discourse 101 for super-super dummies
Discourse Tooltips
Discourse Steam Login
Should I update my app.yml file?
Discourse Reach and Rights
Not enough space to rebuild
Landing Pages Plugin :small_airplane:
Configure OneLogin's SAML for Discourse
Plugin to Post Anonymous Thread via PN or give anonymous Feedback
Migrate a phpBB3 forum to Discourse
Discourse Codeberg Login
Mentionables
Discourse hosting on Linode?
Can I use the Subscriptions plugin on my own server?
Embed comments from Discourse in your single page app
Discourse Confused About the Number of Posts in a Topic?
How to show Full Name in Embeds
Restrict users to post certain words per category
Microsoft Graph Mail Poller
Allow-pm-to-staff
Snapblocks
Discourse AI Topic Summary :robot:
Animated Avatar
Discourse Who's Online
Discourse Google Perspective API
Discourse Newsletter Integration
Discourse Docs
Gitcoin Passport Plugin
Discourse Math Editor
Rebuilding the container is constantly failing after following the standard instructions on plugin install
ActivityPub Plugin
Developing Discourse Plugins - Part 6 - Add acceptance tests
Modal Window
Silenced Avatar Flair
Discourse Staff Alias
Discourse GCS Helper
Discourse Another SMTP
Can more than one post be selected as the solution?
I need help on installing a plugin
Discourse Follow
Custom Topic Button (group)
Discourse FontAwesome Pro
Discourse Zoom
Rocket.Chat SSO + embed plugin
Discourse blog (article and comments)
Stop Forum Spam Plugin
Email Extension
NFT avatar
Discourse Mingle
How can I install my own plugin written in Ruby?
Discourse MusicBrainz Onebox
Custom Topic Button
No editor preview while editing after upgrading to 3.x
Better-Anonymous
Error during upgrading from Beta 3.1.x to latest
Signatures plugin not in the /admin/plugins page
Category Moderators Enhancer
Monero Subscriptions Plugin
:cn: Discourse Math 插件
Discourse Audio Message
Discourse Jira
Randomized Banner
🏆 Discourse Rich JSON-LD Microdata Plugin
Private Topics Plugin
Install discourse doc plugin from Git is failed
Discourse Restrict PMs to certain Groups
Discourse Chatbot :robot:
🖼️ Topic Gallery
Data Explorer Tutorial - Part 1 - Writing Your First Query
Option for scheduled replies
Discourse Disable Browser History Experiment
Publish Direct Messages
Discourse Authentication Validations
Discourse Provide Full Name in Mentions
Disable Email Verification for Discourse Plugin
Discourse send PDF inline
Discourse Anonymous Post
Indisposable Email - block disposable email domains
Discourse-embed-bilibili(在discourse中插入哔哩哔哩视频)
Set user registration IP address API endpoint
Installing discourse follow plugin in development (boot_dev) setup — no app.yml file
Locations Plugin :earth_africa:
User Response Times
Babble Chat
Discourse mail daily summary plugin
Discourse Preset Topic Composer
Discourse Custom Topic Lists
Highest-Post Excerpts in Topic List
What to Expect When Rebuilding Discourse
Discourse Points Mall (Check-in, Shop, Orders, Makeup Cards, Ledger)
Seen lots of threads asking if Discourse is free when self hosted but nothing about the plugins
Rebuilding Forum (Restoring back-up works, rebuilding does not)
Discourse Surveys
Login Helper Plugin
Can't install reaction plugin
Error when installing Advertising
Globally replace translations
Discourse Retort
Discourse Translator
Discourse Category Experts
Discourse Chat Bridge (Telegram)
Trading Buttons
Discourse Disorder
Hubot Adapter for Discourse
Discourse No Bump
CJK Formatter Plugin
Self-hosting Index
SCIM Plugin
Journal Plugin
Problem installing docs
How to install and configure AI features step by step
Discourse Encrypt (deprecated)
Discourse Open Graph
Turbowarp plugin
Question about Docker Manager?
Moderation API Plugin
Discourse OpenID Connect (OIDC)
Dark Visitors
Discourse Dynamic Groups
Custom Summary Gist
Created as Default Sort Order
Truncate Digest
Topic List Previews (TLP)
Allow Title-Only Onebox
How to install the plugin on bitnami's repository
Discourse BBCode Tabs Plugin
Tag Intersection Navigator
📞 diskuz Call – Voice and video calls inside Discourse (P2P, no external apps)
I broke my site while updating it
Collections
Can Discourse ship frequent Docker images that do not need to be bootstrapped?
Push notifications for iPhone and Android apps
Automation script: Move topic on close
Error installing theme from Github
Discourse Amazon SNS notifications
Best practices of keeping track of feature requests
Contact Form
No Bump First Post Plugin
How to Install Discourse Plugins Hosted in Private Repositories Using SSH Key?
Unable to rebuild app - failed with exit code 1
National Flags (fork)
What's yall's work-flow like?
Discourse Suggested Edits
VK ID OAuth 2.1 Authentication for Discourse
🔐 Yandex ID OAuth2 Authentication for Discourse
Discourse Daily Challenges
Discourse Bilibili Onebox
Buffer -- streamline sharing topics on social media
Discourse Member Application
Time Registration plugin
Plugin Cleaner
Communiteq Power Tools plugin
Category Event Policy
Calendar RSVP Posts
Contact Form
Workspace groups
ProxyTracer: VPN & Proxy Blocker
Discourse Ko-fi integration
ReplyGif
Telegram Auth Plugin (work with latest discourse version)
Discourse User Location
什么时候可以在管理后台直接安装插件?
Process Manager :left_right_arrow: - formerly "Discourse Workflow"
Gitee 码云登录插件
Upgrading Mathjax to version 4
Updates no longer in the Admin UI?
Group User Status
Discourse AI plugin with self hosted discourse site
Angus' Events Plugin :calendar:
Install Discourse for development using Docker
Slow Discourse Rebuild on a VM with slow disks
Trading Buttons
Why can't I install plugins locally?
MODELOC OneBox Plugin
How to install plugins without using a third-party host?
How to make a discourse forum look like forum.glamour.de
Discourse-Telegram chat bridge
[Solved] Admin-upgrade page not showing up
Synchronizer-base for any backup provider
"Your Docker installation is not using a supported storage driver."
Formatting issues adding plugins to app.yml
Solution icon does not show in posts
Fixing problems with rebuild app
Auto Bookmarks plugin
Force specific users through moderation
Homepage Filter plugin
Voice recording plugin
How to hook up JWT Single Sign On to Discourse
Should all plugins be cloned as the `discourse` user?
How I can add plugin to my discourse
OAuth2 integration with Drupal
Discord Sync: sync a Discourse forum with a Discord server
No option appears to choose better answer
Discourse Avatar name_first_letter
Auto-suspend inactive users
Algolia plugin indexation
Telegram Notifications Plugin (discourse-telegram-notifications)
Trying to install plugin (But not working)
How to break 99k char limit?
How to edit plugins code?
I want to install a plugin for development, what should I do?
Azure Blob Storage Plugin
./launcher rebuild app error './launcher: No such file or directory'
Discourse Wikilinks Plugin
SSO for College Account
Favorites - select your favorite categories
Why do I need a block storage?
Plugin for Preventing Malicious Linking
Discourse Fingerprint - Browser Fingerprinting Plugin
Solved Reminders Plugin
Sidebar with categories
Merge Users Plugin
Unable to find /plugins dir
Pwned Passwords Validator
Launcher rebuild app does nothing
Business plugins and install on-premise
Private repo on Github
Discourse Dice Roller (RogerBW)
Any options for over-riding the username restrictions?
Collude - a collaborative text editor for Discourse
Turn Based Board Game
Can I access Discourse forum Database to use for PowerBI reporting?
Discourse Code Review
Discourse Poison Fountain
Custom Trust Level
sorry for the dumb question but, how should I know if its required to include sudo -E -u discourse or not for the git clone statement?
How does your docker_manager line look like?
none of the other entries in my app.yml had the sudo part so I omitted that and its just worked so far
Seems like this method is not working anymore.
sh: 1: cannot create /user/.ssh/config: Directory nonexistent
With my self-hosted GIT repository, I’d really like to use SSH keys.
You shouldn’t need an ssh key in the container, just delete this:
Sorry, I don’t think I follow..
My repo is accessible via ssh. How can I get a plugin cloned without SSH key?
Oh. Maybe I’m wrong. Then maybe you need to create that directory with the right permissions m
What is confusing is that part of the commands in examples are to be run as root and part as user discourse. It doesn’t seem to be very consisent.
As opposed to
I will do some digging in the running container’s shell.
This plugin installation is a bit complicated. It would be great if it could be made the same as installing theme.
Dashboard.literatecomputing.com will install plugins with a few clicks. You can use it for free by joining the free trial group.
@Discourse, If you want to update the guide, here is the working code:
To use your own SSH keys for accessing a private repository, follow these steps:
  1. Place the private SSH key in /var/discourse/shared/standalone/identity/id_rsa (or another location accessible by the container; if you choose a different location, remember to update the path in the template below accordingly).
  2. Use the following template to add your plugins:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Set private repo access
          - chown $(whoami) /shared/identity/id_rsa && chmod 600 /shared/identity/id_rsa
          - git config --global core.sshCommand "ssh -o StrictHostKeyChecking=no -o IdentitiesOnly=yes -i /shared/identity/id_rsa"
          # My private plugins
          - git clone git@example.com:repo/private-discourse-plugin.git
          # Unset access
          - git config --global --unset core.sshCommand
Thanks for something I don’t need that one but I live with simple original.
Do you want to explain why we should use your example? Is it because of this:
Why not just use a token in the URL?
Well, we have tools to solve out this riddle :winking_face_with_tongue:
Understanding the Usefulness of Container Configuration Snippets AI
Jagster:
Why someone would like to use that snippet in container/app.ym
gpt-4o:
To effectively answer your question, I need to understand the context around the specific snippet in container/app.yml. Could you please provide more details or the actual snippet you’re referring to? This way, I can give you a precise and helpful explanation.
Jagster:
Sorry, but I needed this composer.
This is the snippet:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Unset access
gpt-4o:
Thank you for providing the snippet. This YAML snippet is intended to be included in the container/app.yml configuration file for a Discourse instance. Let’s break down what it does:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Unset access
Explanation
  1. Setting Directory:
    cd: $home/plugins
    This changes the working directory to where plugins are located ($home/plugins).
  2. Setting Private Repository Access:
    • Changes the ownership of the SSH private key (id_rsa) to the current user and sets its permissions to 600.
    • Configures Git to use a custom SSH command which uses the specified private key and disables strict host key checking.
  3. Cloning Private Repository:
    Clone a private Git repository containing a Discourse plugin.
  4. Unsetting SSH Command:
    Resets the Git SSH command configuration to its default state.
When and Why to Use This Snippet
  1. Private Repositories: If you have a private Discourse plugin repository that is not publicly accessible and requires SSH key-based authentication.
  2. Automation: This script helps automate the process of setting up access to the private repository, cloning it, and ensuring the environment is reset afterwards. This is useful for continuous deployment setups or automated server provisioning.
  3. Security Management: It handles the SSH keys securely (setting file permissions and then unsetting the custom SSH command), critical for maintaining security posture during automated deployments.
Important Considerations
  • Ensure your private SSH key (id_rsa) is securely managed and not exposed.
  • Verify the ownership and permissions are correctly set for your security policies.
For more detailed information and contexts about app.yml and hooks in Discourse, you can check relevant Discourse documentation.
If you have any further questions or need additional details on the configuration, feel free to ask!
Hi! It sounds great! But I don’t know how I must proceed after joining the free trial group! Please, @pfaffman, could you help me? I’m looking to install SAML plugin. It would be great to test Literate Computing to get it installed and running!
Thanks!
My template snippet is for when you don’t have any other means of accessing the Git repo besides an SSH key (for example, with a self-hosted Git repository behind SSH).
What would have helped me was if these instructions said something like, “Hey dummy! Don’t run the git clone command from the shell. Just add the command to the app.yml file per the example, make sure the indents are correct, save it, and then run the rebuild command.”
These instructions could also be clearer when -E -u are necessary and when they are not.
I did some other dumb things to before I succeeded. When I look at the instructions now, they make nearly perfect sense. But I fell into several pitfalls that I might have avoided if these instructions were written considering noobs like me would be trying to follow them.
I’m no expert, so bear with me…
Yesterday I installed Discourse and now I’m trying to install a plugin.
Do I need to run:
or can I just run:
./launcher destroy app
and then
./launcher start app
Running ./launcher rebuild app takes a long time and my website stops working or it becomes super slow.
Rebuilding is the only way to install plugins. Destroying and starting use only the old configuration.
But don’t destroy anything before rebuilding. Because if rebuild fails you can put old one online using start.
You have one container setup, right? Then that forum will be offline, because first rebuilding will stop your container. And yes, it takes long time to rebuild.
There is two container setup two, and then offline time is few minutes. But don’t change to it before you are comfortable with these basic operations.
