Instale plugins em um site auto-hospedado
:warning: This guide assumes that you have a self-hosted standard installation. We only support the standard method of install here, so these instructions assume you have a standard install.
:warning: This guide only applies to self-hosted Discourse instances. If you are using a managed hosting service, the available plugins are controlled by your hosting provider. For example, on our hosting these specific plugins are available by hosting tier.
In this tutorial, we’ll install the Discourse Solved plugin.
This tutorial requires an understanding of how to use GitHub repos, specifically, how to get or copy the git clone URL and how to edit YAML (*.yml) files via the terminal using nano, specifically how to save and exit on nano. YAML files strongly follow indentations, so be sure to respect these as you copy and paste and edit the necessary *.yml for your Discourse instance.
  • Copy the plugin’s GitHub git clone url.
  • Access your container’s app.yml file (present in /var/discourse/containers/)
    cd /var/discourse
    nano containers/app.yml
  • Add the plugin’s repository URL to your container’s app.yml file:
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git
              - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
    Add the plugin’s git clone url just below the line containing git clone https://github.com/discourse/docker_manager.git)
    Follow the existing format of the docker_manager.git line; if it does not contain sudo -E -u discourse then insert - git clone https://github.com/discourse/discourse-solved.git.
  • Rebuild the container:
    cd /var/discourse
    ./launcher rebuild app
    That’s it, you’ve successfully installed the Discourse Solved plugin on your Discourse instance!
If your plugin is hosted in a private repository
You must use an OAuth token:
With the OAuth token, you can install your plugin in the same way as a public repo, and you don’t need to create a SSH key.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
              - sudo -E -u discourse git clone https://<token>@github.com/owner/repo.git
We strongly advise you to use OAuth tokens for plugins in private repositories. However, if you cannot, see below.
SSH Key Private Install Steps
run:
  - exec: cd /var/www/discourse && sudo -u discourse bundle install --deployment --without test --without development
  - exec: echo "Host github.com\n\tStrictHostKeyChecking no\n" >> /user/.ssh/config
  - file:
      path: /user/.ssh/id_rsa
      chmod: 600
      contents: |
        -----BEGIN RSA PRIVATE KEY-----
        MIIEogIBAAKCAQEArCQG213utzqE5YVjTVF5exGRCkE9OuM7LCp/FOuPdoHrFUXk
           .... etc ....
        -----END RSA PRIVATE KEY-----
  - file:
      path: /user/.ssh/id_rsa.pub
      chmod: 600
      contents: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAklOUpkDHrfHY17SbrmTIpNLTGK9Tj .... etc .... user@discourse
  - exec: cd $home/plugins && git clone git@github.com:SecretOrg/secret-plugin.git
  - exec: cd $home && sudo -E -u discourse bundle exec rake db:migrate
  - exec: cd $home && rm -fr tmp/cache
  - exec: cd $home &&  sudo -E -u discourse bundle exec rake assets:precompile
  - exec: rm /user/.ssh/id_rsa
  - exec: rm /user/.ssh/id_rsa.pub
cd /var/discourse
Your private plugin should be installed on your Discourse instance.
How to uninstall a plugin
To remove a plugin, simply remove the - git clone https://github.com/... line from your app.yml file and rebuild your site via
cd /var/discourse
173 curtidas
Discourse Slackdoor Plugin
How to create a new plugins?
Site maintenance mode during rebuilds?
Discourse Version 1.2
Embed Etherpad Lite pads into Discourse
Solved Button Plugin
LDAP Setup for Discourse
About the Plugin category
Discourse Checklist
Wild Apricot login plugin
Formatting toolbar
Can Plugins Be Added To Basic Docker Install
Discourse Mark Plugin
Quick Messages Plugin
How do i install plugins after doing a fork?
Does this software allow admin to put Adsense ads in?
Tickets Plugin :tickets:
"Onebox Assistant", crawl for those previews reliably!
Daemonite Material Theme
News Plugin :newspaper:
Installing new plugins
Installing Plugins with Git
ReplyGif
Discourse BBCode
Topic Ratings Plugin
Install plugins in your non-Docker development environment
How to ad banners?
User feedback plugin
Update private plugin without rebuilding the application
Bump Reset plugin - Annotated to help new devs
Admin Statistics Report
Generating lots of Invite Tokens
Projects management plugin
How do you add plugins?
LDAP Auth Missing from Plugins
Application Files after Digital Ocean Setup
Category Page Plugin
Discord-rolesync plugin
Watching Categories based on on group in discourse
Discourse Category Home :house:
Any options for over-riding the username restrictions?
Collude - a collaborative text editor for Discourse
Can I access Discourse forum Database to use for PowerBI reporting?
Discourse Code Review
Custom Trust Level
Discourse Doc Categories
Fatal: Not a git repository (or any parent up to mount point /discourse)
How to add a Leaderboard link to the hamburger menu?
I need someone who can install a voting plugin
Custom Wizard Plugin :mage:
Introducing Font Awesome 5 and SVG icons
Click To Edit
Topic List Previews (legacy)
Legal Compliance Plugin
Discourse Spoiler-Alert
Triggering account creation/login on external service when a user logs in on discourse
Discourse Cookie Consent Banner
Community Network Visualisation
ListenBrainz
Subscription Plugin not working (Error)
Discourse-a2a-bbcode
Error using discourse-oauth2-basic plugin with NeonCRM
Question Answer Plugin
How might we better structure #howto?
Cannot install new plugins: structure needs cleaning
Slow Discourse Rebuild on a VM with slow disks
Calendar Core - Needs any special theme?
Discourse Notifier
Discourse CommonMark text highlighting?
Mumble -- VOIP Plugin for Discourse
Advice on Installing Plugins
Smallcaps formatting
Cannot install plugin - nothing happens
What else do I need to take care of when self hosting?
Humanmark for Discourse - Hardware-Backed Humanity Verification
Verifiable Credentials Plugin
Discourse Shared Edits
Install Discourse for development using Docker
Installing discourse-math.git
Discourse Image Filter
Discourse Linkify Google Sheets
Developing Discourse Plugins - Part 1 - Create a basic plugin
Discourse Voting missing table on postgresql
Discourse Signatures
Discourse BBCode Color
Discourse Post Sorting Customizer
Unikname Connect plugin
Discourse Video Upload Plugin with YouTube and Vimeo
Quoting not working
User profile by ID instead of username
Error after update failed today: [rake themes:update assets:precompile]
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return
Votes don't Merge when we combine posts
Discourse User Feedback
Availability of OpenID Connect in hosted plans
Codebytes Plugin
Multiple Users posting under same User or Group name?
What makes a successful volunteer Discourse sysadmin?
Not able to install any Discourse plugins
How to install the lazy-yt plugin
Issue With Sitemap
Discourse Private Replies
Google One Tap Login/Signup
Landing Pages Blog :small_airplane:
Group Invitation Plugin
Discourse Mailgun Routes
Word Cloud plugin
Geo Blocking plugin
Post folding
Signed Google Cloud CDN URLs
Google Groups Link Plugin
Discourse LinkedIn Authentication
Discourse VK Authentication (vkontakte)
Discourse OneDrive Picker
Discourse BCC
Discourse Prometheus
Discourse Dictionary Plugin :ab:
Category Restrictor plugin
Slack Bot Construction Kit :robot:
Discourse Authorship Plugin
Discourse Livestream
Locked out from WinSCP and can't Install Plugins!
Create custom Automations
Affiliate link functions - rewrite
🤖 Discourse llms.txt Generator Plugin
Editing a table whose some rows don't start with a pipe duplicate these rows
How to: discourse-sitemap is deprecated and merged into Discourse's core. Please remove it from your app.yml file.?
How to update plugins manually from the command line?
Introducing Discourse Chat (BETA)
Discourse Restricted Replies
Discourse Yearly Review
Discourse Saved Searches
Discourse Intercom (Advanced)
Discourse Salesforce
Sign-In with Ethereum plugin
Discourse GitHub Verification
Discourse Algolia Search
Discourse Characters Required
Discourse No Bump
Discourse Teambuild
Installing Plugins in Discourse 101 for super-super dummies
Discourse Tooltips
Discourse Steam Login
Should I update my app.yml file?
Not enough space to rebuild
Landing Pages Plugin :small_airplane:
Configure OneLogin's SAML for Discourse
Migrate a phpBB3 forum to Discourse
Discourse Codeberg Login
Mentionables
Discourse hosting on Linode?
Can I use the Subscriptions plugin on my own server?
Embed comments from Discourse in your single page app
Discourse Confused About the Number of Posts in a Topic?
How to show Full Name in Embeds
Restrict users to post certain words per category
Microsoft Graph Mail Poller
Allow-pm-to-staff
Snapblocks
Discourse AI Topic Summary :robot:
Animated Avatar
Discourse Who's Online
Discourse Google Perspective API
Discourse Newsletter Integration
Discourse Docs
Gitcoin Passport Plugin
Discourse Math Editor
Rebuilding the container is constantly failing after following the standard instructions on plugin install
ActivityPub Plugin
Modal Window
Silenced Avatar Flair
Discourse Staff Alias
Discourse GCS Helper
Topic List Previews (TLP)
Discourse Another SMTP
Can more than one post be selected as the solution?
I need help on installing a plugin
Discourse Follow
Custom Topic Button (group)
Discourse FontAwesome Pro
Discourse Zoom
Rocket.Chat SSO + embed plugin
Discourse blog (article and comments)
Stop Forum Spam Plugin
Email Extension
NFT avatar
Discourse Mingle
How can I install my own plugin written in Ruby?
Discourse MusicBrainz Onebox
Custom Topic Button
No editor preview while editing after upgrading to 3.x
Better-Anonymous
Error during upgrading from Beta 3.1.x to latest
Signatures plugin not in the /admin/plugins page
Category Moderators Enhancer
Are plugins free using the open-source, self-host option?
Monero Subscriptions Plugin
:cn: Discourse Math 插件
Discourse Audio Message
Discourse Jira
Randomized Banner
🏆 Discourse Rich JSON-LD Microdata Plugin
Private Topics Plugin
Install discourse doc plugin from Git is failed
Discourse Restrict PMs to certain Groups
Discourse Chatbot :robot:
Data Explorer Tutorial - Part 1 - Writing Your First Query
Option for scheduled replies
Discourse Disable Browser History Experiment
Publish Direct Messages
Discourse Authentication Validations
Discourse Provide Full Name in Mentions
Disable Email Verification for Discourse Plugin
Discourse send PDF inline
Discourse Anonymous Post
Discourse-embed-bilibili(在discourse中插入哔哩哔哩视频)
Set user registration IP address API endpoint
Trading Buttons
Locations Plugin :earth_africa:
User Response Times
Contact Form
Babble Chat
Discourse mail daily summary plugin
Discourse Preset Topic Composer
Discourse Custom Topic Lists
Highest-Post Excerpts in Topic List
What to Expect When Rebuilding Discourse
Seen lots of threads asking if Discourse is free when self hosted but nothing about the plugins
Rebuilding Forum (Restoring back-up works, rebuilding does not)
Discourse Surveys
Login Helper Plugin
Can't install reaction plugin
Error when installing Advertising
Globally replace translations
Discourse Retort
Discourse Translator
Discourse Category Experts
Discourse Chat Bridge (Telegram)
Trading Buttons
Discourse Disorder
Discourse AI plugin with self hosted discourse site
Hubot Adapter for Discourse
Discourse No Bump
CJK Formatter Plugin
Self-hosting Index
SCIM Plugin
Journal Plugin
Problem installing docs
How to install and configure AI features step by step
Discourse Encrypt (deprecated)
Discourse Open Graph
Turbowarp plugin
Discourse Workflow
Question about Docker Manager?
Moderation API Plugin
Unable to rebuild app - failed with exit code 1
Dark Visitors
Discourse Dynamic Groups
Custom Summary Gist
Created as Default Sort Order
Allow Title-Only Onebox
How to install the plugin on bitnami's repository
Discourse BBCode Tabs Plugin
Tag Intersection Navigator
I broke my site while updating it
Collections
Can Discourse ship frequent Docker images that do not need to be bootstrapped?
Push notifications for iPhone and Android apps
Automation script: Move topic on close
Error installing theme from Github
Discourse Amazon SNS notifications
Best practices of keeping track of feature requests
Contact Form
No Bump First Post Plugin
How to Install Discourse Plugins Hosted in Private Repositories Using SSH Key?
National Flags (fork)
VK ID OAuth 2.1 Authentication for Discourse
🔐 Yandex ID OAuth2 Authentication for Discourse
Discourse Bilibili Onebox
Discourse Math
Time Registration plugin
Category Event Policy
Calendar RSVP Posts
Discourse OpenID Connect (OIDC)
How to make a discourse forum look like forum.glamour.de
[Solved] Admin-upgrade page not showing up
Synchronizer-base for any backup provider
"Your Docker installation is not using a supported storage driver."
Formatting issues adding plugins to app.yml
Solution icon does not show in posts
Fixing problems with rebuild app
Auto Bookmarks plugin
Force specific users through moderation
Homepage Filter plugin
Voice recording plugin
How to hook up JWT Single Sign On to Discourse
Should all plugins be cloned as the `discourse` user?
How I can add plugin to my discourse
OAuth2 integration with Drupal
Discord Sync: sync a Discourse forum with a Discord server
Discourse Narrative Bot Beta Feedback
No option appears to choose better answer
How to block all crawlers but Google's
Discourse Avatar name_first_letter
Auto-suspend inactive users
Algolia plugin indexation
Telegram Notifications Plugin (discourse-telegram-notifications)
Trying to install plugin (But not working)
How to break 99k char limit?
How to edit plugins code?
I want to install a plugin for development, what should I do?
Azure Blob Storage Plugin
./launcher rebuild app error './launcher: No such file or directory'
Discourse Wikilinks Plugin
SSO for College Account
Developing Discourse Plugins - Part 6 - Add acceptance tests
Favorites - select your favorite categories
Why do I need a block storage?
Plugin for Preventing Malicious Linking
Discourse Fingerprint - Browser Fingerprinting Plugin
Solved Reminders Plugin
Sidebar with categories
Merge Users Plugin
Events Plugin :calendar:
Unable to find /plugins dir
Pwned Passwords Validator
Launcher rebuild app does nothing
Business plugins and install on-premise
Private repo on Github
Discourse Dice Roller (RogerBW)
Atualizei o guia para usar outro plugin de exemplo em vez do Discourse Spoiler Alert, que foi incluído no core.
Usei o Discourse Solved, mas me avise se um diferente seria melhor.
9 curtidas
Eu hospedei o discourse no Digital Ocean e quando usei esse formato, recebi este erro.
FAILED
Pups::ExecError: cd /var/www/discourse/plugins && sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git failed with return #<Process::Status: pid 252 exit 129>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home/plugins", "cmd"=>["sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git"]}
bootstrap failed with exit code 129
2a49220a4ff35feac3c1a9a4a9c1cad1094bde4c9ba321975ebc9ae7ead2bbee
Então eu usei este formato
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git && sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
em vez de
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
4 curtidas
8 posts foram divididos em um novo tópico: Problemas de formatação ao adicionar plugins ao app.yml
Desculpe pela pergunta idiota, mas como devo saber se é necessário incluir sudo -E -u discourse ou não para a instrução git clone?
3 curtidas
Como está a sua linha docker_manager?
4 curtidas
nenhuma das outras entradas no meu app.yml tinha a parte sudo, então omiti isso e funcionou até agora
5 curtidas
Parece que este método não está mais funcionando.
sh: 1: cannot create /user/.ssh/config: Directory nonexistent
Com meu repositório GIT auto-hospedado, eu realmente gostaria de usar chaves SSH.
3 curtidas
Você não deve precisar de uma chave ssh no contêiner, apenas delete isto:
1 curtida
Desculpe, não acho que entendi…
Meu repositório é acessível via ssh. Como posso clonar um plugin sem chave SSH?
1 curtida
Ah. Talvez eu esteja enganado. Então talvez você precise criar esse diretório com as permissões corretas.
1 curtida
O confuso é que parte dos comandos nos exemplos devem ser executados como root e parte como o usuário discourse. Não parece ser muito consistente.
Em oposição a
Vou investigar no shell do container em execução.
A instalação deste plugin é um pouco complicada. Seria ótimo se pudesse ser feita da mesma forma que a instalação de um tema.
2 curtidas
O Dashboard.literatecomputing.com instalará plugins com alguns cliques. Você pode usá-lo gratuitamente juntando-se ao grupo de teste gratuito.
4 curtidas
@Discourse, Se você quiser atualizar o guia, aqui está o código funcional:
Para usar suas próprias chaves SSH para acessar um repositório privado, siga estas etapas:
  1. Coloque a chave SSH privada em /var/discourse/shared/standalone/identity/id_rsa (ou em outro local acessível pelo contêiner; se você escolher um local diferente, lembre-se de atualizar o caminho no modelo abaixo de acordo).
  2. Use o seguinte modelo para adicionar seus plugins:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Define o acesso ao repositório privado
          - chown $(whoami) /shared/identity/id_rsa && chmod 600 /shared/identity/id_rsa
          - git config --global core.sshCommand "ssh -o StrictHostKeyChecking=no -o IdentitiesOnly=yes -i /shared/identity/id_rsa"
          # Meus plugins privados
          - git clone git@example.com:repo/private-discourse-plugin.git
          # Desativa o acesso
          - git config --global --unset core.sshCommand
5 curtidas
Obrigado por algo que não preciso, mas vivo com o original simples.
Você quer explicar por que devemos usar seu exemplo? É por causa disso:
use suas próprias chaves SSH para acessar um repositório privado
1 curtida
Por que não usar um token na URL?
1 curtida
Bem, temos ferramentas para resolver este enigma :winking_face_with_tongue:
Entendendo a Utilidade de Snippets de Configuração de Contêiner IA
Jagster:
Por que alguém gostaria de usar esse snippet em container/app.ym
gpt-4o:
Para responder à sua pergunta de forma eficaz, preciso entender o contexto em torno do snippet específico em container/app.yml. Você poderia fornecer mais detalhes ou o snippet real ao qual você está se referindo? Dessa forma, posso dar uma explicação precisa e útil.
Jagster:
Desculpe, mas eu precisava deste compositor.
Este é o snippet:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Definir acesso ao repositório privado
          # Desativar acesso
gpt-4o:
Obrigado por fornecer o snippet. Este snippet YAML destina-se a ser incluído no arquivo de configuração container/app.yml para uma instância do Discourse. Vamos detalhar o que ele faz:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Desativar acesso
Explicação
  1. Definindo o Diretório:
    cd: $home/plugins
    Isso muda o diretório de trabalho para onde os plugins estão localizados ($home/plugins).
  2. Configurando o Acesso ao Repositório Privado:
    • Altera a propriedade da chave privada SSH (id_rsa) para o usuário atual e define suas permissões para 600.
    • Configura o Git para usar um comando SSH personalizado que utiliza a chave privada especificada e desabilita a verificação estrita da chave do host.
  3. Clonando o Repositório Privado:
    Clona um repositório Git privado contendo um plugin do Discourse.
  4. Desativando o Comando SSH:
    Redefine a configuração do comando SSH do Git para seu estado padrão.
Quando e Por Que Usar Este Snippet
  1. Repositórios Privados: Se você tem um repositório de plugin privado do Discourse que não é acessível publicamente e requer autenticação baseada em chave SSH.
  2. Automação: Este script ajuda a automatizar o processo de configuração de acesso ao repositório privado, clonagem e garantia de que o ambiente seja redefinido depois. Isso é útil para configurações de implantação contínua ou provisionamento automatizado de servidores.
  3. Gerenciamento de Segurança: Ele lida com as chaves SSH de forma segura (definindo permissões de arquivo e depois desativando o comando SSH personalizado), o que é crucial para manter a postura de segurança durante implantações automatizadas.
Considerações Importantes
  • Certifique-se de que sua chave SSH privada (id_rsa) seja gerenciada de forma segura e não exposta.
  • Verifique se a propriedade e as permissões estão corretamente definidas para suas políticas de segurança.
Para obter informações mais detalhadas e contextos sobre app.yml e hooks no Discourse, você pode consultar a documentação relevante do Discourse.
Se você tiver mais alguma dúvida ou precisar de detalhes adicionais sobre a configuração, sinta-se à vontade para perguntar!
3 curtidas
Olá! Parece ótimo! Mas não sei como devo proceder depois de entrar no grupo de teste gratuito! Por favor, @pfaffman, você poderia me ajudar? Estou procurando instalar o plugin SAML. Seria ótimo testar o Literate Computing para instalá-lo e colocá-lo em funcionamento!
Obrigado!
2 curtidas
Meu trecho de modelo é para quando você não tem nenhum outro meio de acessar o repositório Git além de uma chave SSH (por exemplo, com um repositório Git auto-hospedado atrás do SSH).
5 curtidas
