Install plugins on a self-hosted site
:warning: This guide assumes that you have a self-hosted standard installation. We only support the standard method of install here, so these instructions assume you have a standard install.
:warning: This guide only applies to self-hosted Discourse instances. If you are using a managed hosting service, the available plugins are controlled by your hosting provider. For example, on our hosting these specific plugins are available by hosting tier.
:information_source: As of mid-2025, many popular official plugins have been bundled into Discourse core. These plugins (including Solved, Data Explorer, AI, Assign, Reactions, and many more) no longer need to be installed separately — they ship with Discourse and can be enabled via site settings. If you try to rebuild with a bundled plugin still in your app.yml, you’ll see a HINT message telling you to remove it. This guide is for plugins that are not bundled with core.
In this tutorial, we’ll install the Discourse Shared Edits plugin.
This tutorial requires an understanding of how to use GitHub repos, specifically, how to get or copy the git clone URL and how to edit YAML (*.yml) files via the terminal using nano, specifically how to save and exit on nano. YAML files strongly follow indentations, so be sure to respect these as you copy and paste and edit the necessary *.yml for your Discourse instance. Always use spaces to indent in .yml files, not tabs.
  • Copy the plugin’s GitHub git clone url.
  • Access your container’s app.yml file (present in /var/discourse/containers/)
    cd /var/discourse
    nano containers/app.yml
  • Add the plugin’s repository URL to your container’s app.yml file:
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - git clone https://github.com/discourse/discourse-shared-edits.git
    Add the plugin’s git clone url just below the line containing git clone https://github.com/discourse/docker_manager.git)
    Follow the existing format of the docker_manager.git line; if it contains sudo -E -u discourse then include that prefix in your new line too.
  • Rebuild the container:
    cd /var/discourse
    ./launcher rebuild app
    That’s it, you’ve successfully installed the Discourse Shared Edits plugin on your Discourse instance!
If your plugin is hosted in a private repository
You must use an OAuth token:
With the OAuth token, you can install your plugin in the same way as a public repo, and you don’t need to create a SSH key.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
              - git clone https://<token>@github.com/owner/repo.git
We strongly advise you to use OAuth tokens for plugins in private repositories. However, if you cannot, see below.
SSH Key Private Install Steps
run:
  - exec: cd /var/www/discourse && sudo -u discourse bundle install --deployment --without test --without development
  - exec: echo "Host github.com\n\tStrictHostKeyChecking no\n" >> /user/.ssh/config
  - file:
      path: /user/.ssh/id_rsa
      chmod: 600
      contents: |
        -----BEGIN RSA PRIVATE KEY-----
        MIIEogIBAAKCAQEArCQG213utzqE5YVjTVF5exGRCkE9OuM7LCp/FOuPdoHrFUXk
           .... etc ....
        -----END RSA PRIVATE KEY-----
  - file:
      path: /user/.ssh/id_rsa.pub
      chmod: 600
      contents: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAklOUpkDHrfHY17SbrmTIpNLTGK9Tj .... etc .... user@discourse
  - exec: cd $home/plugins && git clone git@github.com:SecretOrg/secret-plugin.git
  - exec: cd $home && sudo -E -u discourse bundle exec rake db:migrate
  - exec: cd $home && rm -fr tmp/cache
  - exec: cd $home &&  sudo -E -u discourse bundle exec rake assets:precompile
  - exec: rm /user/.ssh/id_rsa
  - exec: rm /user/.ssh/id_rsa.pub
cd /var/discourse
Your private plugin should be installed on your Discourse instance.
How to uninstall a plugin
To remove a plugin, simply remove the - git clone https://github.com/... line from your app.yml file and rebuild your site via
cd /var/discourse
173 лайка
Discourse Slackdoor Plugin
How to create a new plugins?
Site maintenance mode during rebuilds?
Discourse Version 1.2
Embed Etherpad Lite pads into Discourse
Solved Button Plugin
LDAP Setup for Discourse
Wild Apricot login plugin
About the Plugin category
Formatting toolbar
Quick Messages Plugin
Can Plugins Be Added To Basic Docker Install
Discourse Mark Plugin
Generating lots of Invite Tokens
Tickets Plugin :tickets:
"Onebox Assistant", crawl for those previews reliably!
Daemonite Material Theme
News Plugin :newspaper:
Installing Plugins with Git
Installing new plugins
Does this software allow admin to put Adsense ads in?
How do i install plugins after doing a fork?
Discourse Category Home :house:
Community Network Visualisation
Topic Ratings Plugin
LDAP Auth Missing from Plugins
Discourse BBCode
Introducing Discourse Chat (BETA)
How to ad banners?
Install plugins in your non-Docker development environment
User feedback plugin
Application Files after Digital Ocean Setup
Sign-In with Ethereum plugin
Admin Statistics Report
Update private plugin without rebuilding the application
Bump Reset plugin - Annotated to help new devs
Watching Categories based on on group in discourse
Projects management plugin
Discord-rolesync plugin
How do you add plugins?
Category Page Plugin
Pwned Passwords Validator
Launcher rebuild app does nothing
Business plugins and install on-premise
Private repo on Github
Discourse Dice Roller (RogerBW)
Should all plugins be cloned as the `discourse` user?
Any options for over-riding the username restrictions?
Collude - a collaborative text editor for Discourse
Turn Based Board Game
Can I access Discourse forum Database to use for PowerBI reporting?
Discourse Code Review
Discourse Poison Fountain
Custom Trust Level
Discourse Doc Categories
Advanced Google Analytics (v4)
Fatal: Not a git repository (or any parent up to mount point /discourse)
Meta Pixel & Conversions API
How to add a Leaderboard link to the hamburger menu?
I need someone who can install a voting plugin
Custom Wizard Plugin :mage:
Introducing Font Awesome 5 and SVG icons
What should appear on /admin/update page?
Click To Edit
Legal Compliance Plugin
Ballotage – secret black/white-ball ballots
Triggering account creation/login on external service when a user logs in on discourse
RSS Polling Onebox
Are plugins free using the open-source, self-host option?
ListenBrainz
Subscription Plugin not working (Error)
Discourse-a2a-bbcode
Error using discourse-oauth2-basic plugin with NeonCRM
Question Answer Plugin
How might we better structure #howto?
Discourse Posthog Plugin
Cannot install new plugins: structure needs cleaning
Calendar Core - Needs any special theme?
Discourse Notifier
How to hook up JWT Single Sign On to Discourse
Discourse CommonMark text highlighting?
Mumble -- VOIP Plugin for Discourse
Advice on Installing Plugins
Smallcaps formatting
Cannot install plugin - nothing happens
What else do I need to take care of when self hosting?
Humanmark for Discourse - Hardware-Backed Humanity Verification
Verifiable Credentials Plugin
Installing discourse-math.git
Discourse Image Filter
Discourse Linkify Google Sheets
Discourse Voting missing table on postgresql
Discourse Signatures
Discourse BBCode Color
Discourse Post Sorting Customizer
Unikname Connect plugin
Discourse Video Upload Plugin with YouTube and Vimeo
Quoting not working
User profile by ID instead of username
Error after update failed today: [rake themes:update assets:precompile]
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return
Votes don't Merge when we combine posts
Discourse Video Inline
Discourse User Feedback
Availability of OpenID Connect in hosted plans
Codebytes Plugin
Multiple Users posting under same User or Group name?
What makes a successful volunteer Discourse sysadmin?
Not able to install any Discourse plugins
How to install the lazy-yt plugin
Issue With Sitemap
Discourse Private Replies
Google One Tap Login/Signup
Landing Pages Blog :small_airplane:
Search Thumbnails
Group Invitation Plugin
Discourse Mailgun Routes
Word Cloud plugin
Geo Blocking plugin
Post folding
Signed Google Cloud CDN URLs
Google Groups Link Plugin
Discourse LinkedIn Authentication
Discourse VK Authentication (vkontakte)
Discourse OneDrive Picker
Discourse BCC
Discourse Prometheus
Discourse Dictionary Plugin :ab:
Category Restrictor plugin
Dumbcourse – Old-browser friendly UI at /dumb (D-pad + small screens)
Slack Bot Construction Kit :robot:
Discourse Authorship Plugin
Discourse Livestream
Locked out from WinSCP and can't Install Plugins!
Create custom Automations
Affiliate link functions - rewrite
Editing a table whose some rows don't start with a pipe duplicate these rows
How to: discourse-sitemap is deprecated and merged into Discourse's core. Please remove it from your app.yml file.?
How to update plugins manually from the command line?
Discourse Restricted Replies
Discourse Yearly Review
Discourse Saved Searches
Discourse Intercom (Advanced)
Discourse Salesforce
Discourse GitHub Verification
Discourse Algolia Search
Discourse Characters Required
Discourse No Bump
Discourse Teambuild
Installing Plugins in Discourse 101 for super-super dummies
Discourse Tooltips
Discourse Steam Login
Should I update my app.yml file?
Discourse Reach and Rights
Not enough space to rebuild
Landing Pages Plugin :small_airplane:
Configure OneLogin's SAML for Discourse
Voice recording plugin
Plugin to Post Anonymous Thread via PN or give anonymous Feedback
How to make a discourse forum look like forum.glamour.de
Migrate a phpBB3 forum to Discourse
Discourse Codeberg Login
Mentionables
Discourse hosting on Linode?
Can I use the Subscriptions plugin on my own server?
Embed comments from Discourse in your single page app
Discourse Confused About the Number of Posts in a Topic?
How to show Full Name in Embeds
Restrict users to post certain words per category
Microsoft Graph Mail Poller
Allow-pm-to-staff
Snapblocks
Discourse AI Topic Summary :robot:
Animated Avatar
Discourse Who's Online
Discourse Google Perspective API
Discourse Newsletter Integration
Discourse Docs
Gitcoin Passport Plugin
Discourse Math Editor
Rebuilding the container is constantly failing after following the standard instructions on plugin install
ActivityPub Plugin
Developing Discourse Plugins - Part 6 - Add acceptance tests
Modal Window
Silenced Avatar Flair
Discourse Staff Alias
Discourse GCS Helper
Discourse Another SMTP
Can more than one post be selected as the solution?
I need help on installing a plugin
Discourse Follow
Custom Topic Button (group)
Discourse FontAwesome Pro
Discourse Zoom
Rocket.Chat SSO + embed plugin
Discourse blog (article and comments)
Stop Forum Spam Plugin
Email Extension
NFT avatar
Discourse Mingle
How can I install my own plugin written in Ruby?
Discourse MusicBrainz Onebox
Custom Topic Button
No editor preview while editing after upgrading to 3.x
Better-Anonymous
Error during upgrading from Beta 3.1.x to latest
Signatures plugin not in the /admin/plugins page
Category Moderators Enhancer
Monero Subscriptions Plugin
:cn: Discourse Math 插件
Discourse Audio Message
Discourse Jira
Randomized Banner
🏆 Discourse Rich JSON-LD Microdata Plugin
Private Topics Plugin
Install discourse doc plugin from Git is failed
Discourse Restrict PMs to certain Groups
Discourse Chatbot :robot:
🖼️ Topic Gallery
Data Explorer Tutorial - Part 1 - Writing Your First Query
Homepage Filter plugin
Option for scheduled replies
Discourse Disable Browser History Experiment
Publish Direct Messages
Discourse Authentication Validations
Discourse Provide Full Name in Mentions
Disable Email Verification for Discourse Plugin
Discourse send PDF inline
Discourse Anonymous Post
Indisposable Email - block disposable email domains
Discourse-embed-bilibili(在discourse中插入哔哩哔哩视频)
Set user registration IP address API endpoint
Installing discourse follow plugin in development (boot_dev) setup — no app.yml file
User Response Times
Force specific users through moderation
Auto Bookmarks plugin
Babble Chat
Discourse mail daily summary plugin
Discourse Preset Topic Composer
Discourse Custom Topic Lists
Highest-Post Excerpts in Topic List
What to Expect When Rebuilding Discourse
Discourse Points Mall (Check-in, Shop, Orders, Makeup Cards, Ledger)
Seen lots of threads asking if Discourse is free when self hosted but nothing about the plugins
Rebuilding Forum (Restoring back-up works, rebuilding does not)
Discourse Surveys
Login Helper Plugin
Can't install reaction plugin
Error when installing Advertising
Globally replace translations
Discourse Retort
Discourse Translator
Discourse Category Experts
Discourse Chat Bridge (Telegram)
Trading Buttons
Discourse Disorder
Hubot Adapter for Discourse
Discourse No Bump
CJK Formatter Plugin
Self-hosting Index
SCIM Plugin
Journal Plugin
Problem installing docs
How to install and configure AI features step by step
Discourse Encrypt (deprecated)
Discourse Open Graph
Turbowarp plugin
Question about Docker Manager?
Moderation API Plugin
Discourse OpenID Connect (OIDC)
Dark Visitors
Discourse Dynamic Groups
Custom Summary Gist
Created as Default Sort Order
Truncate Digest
Topic List Previews (TLP)
Allow Title-Only Onebox
How to install the plugin on bitnami's repository
Discourse BBCode Tabs Plugin
Tag Intersection Navigator
📞 diskuz Call – Voice and video calls inside Discourse (P2P, no external apps)
I broke my site while updating it
Collections
Can Discourse ship frequent Docker images that do not need to be bootstrapped?
Push notifications for iPhone and Android apps
Automation script: Move topic on close
Error installing theme from Github
Discourse Amazon SNS notifications
Best practices of keeping track of feature requests
Contact Form
No Bump First Post Plugin
How to Install Discourse Plugins Hosted in Private Repositories Using SSH Key?
National Flags (fork)
What's yall's work-flow like?
Discourse Suggested Edits
Fixing problems with rebuild app
Custom Splash HTML Builder
VK ID OAuth 2.1 Authentication for Discourse
🔐 Yandex ID OAuth2 Authentication for Discourse
Discourse Daily Challenges
Discourse Bilibili Onebox
Buffer -- streamline sharing topics on social media
Discourse Member Application
Time Registration plugin
Plugin Cleaner
Communiteq Power Tools plugin
Category Event Policy
Calendar RSVP Posts
Contact Form
Workspace groups
ProxyTracer: VPN & Proxy Blocker
Discourse Ko-fi integration
ReplyGif
Telegram Auth Plugin (work with latest discourse version)
Discourse User Location
什么时候可以在管理后台直接安装插件?
Process Manager :left_right_arrow: - formerly "Discourse Workflow"
Gitee 码云登录插件
Upgrading Mathjax to version 4
Updates no longer in the Admin UI?
Group User Status
Discourse AI plugin with self hosted discourse site
Solution icon does not show in posts
Angus' Events Plugin :calendar:
Install Discourse for development using Docker
Slow Discourse Rebuild on a VM with slow disks
Trading Buttons
Why can't I install plugins locally?
MODELOC OneBox Plugin
How to install plugins without using a third-party host?
Event Duplicator: duplicate calendar events/topics into a new time period
JTech Tools: the one plugin behind JTech Forums (whispers, REQ-PM, Dumbcourse, Telegram bridge, our theme)
Formatting issues adding plugins to app.yml
DCS World Server Status Live Card Plugin
Crypto Ticker — live cryptocurrency prices (Bitcoin, Ethereum, Solana…) in your forum
"Your Docker installation is not using a supported storage driver."
Synchronizer-base for any backup provider
See TL Progress (TL1, 2, 3)
[Solved] Admin-upgrade page not showing up
Discourse-Telegram chat bridge
Bookmark Notes
Discord Sync: sync a Discourse forum with a Discord server
OAuth2 integration with Drupal
No option appears to choose better answer
Automatic Sitemap Linking
Discourse Avatar name_first_letter
Auto-suspend inactive users
Algolia plugin indexation
Telegram Notifications Plugin (discourse-telegram-notifications)
Trying to install plugin (But not working)
How to break 99k char limit?
How to edit plugins code?
I want to install a plugin for development, what should I do?
Locations Plugin :earth_africa:
Azure Blob Storage Plugin
./launcher rebuild app error './launcher: No such file or directory'
Discourse Wikilinks Plugin
Discourse-indexnow — Instantly notify Bing & Yandex when topics are created or edited
SSO for College Account
How I can add plugin to my discourse
Favorites - select your favorite categories
Why do I need a block storage?
Plugin for Preventing Malicious Linking
Discourse Fingerprint - Browser Fingerprinting Plugin
Solved Reminders Plugin
Unable to rebuild app - failed with exit code 1
Sidebar with categories
Merge Users Plugin
Discourse Bounce Guard plugin
Unable to find /plugins dir
Извините за глупый вопрос, но как мне узнать, обязательно ли включать sudo -E -u discourse для команды git clone или нет?
3 лайка
Как выглядит ваша строка docker_manager?
5 лайков
Ни в одном из других записей в моём app.yml не было части sudo, поэтому я её убрал, и пока всё работает.
5 лайков
Похоже, что этот метод больше не работает.
sh: 1: невозможно создать /user/.ssh/config: директория не существует
В случае с моим самодостаточным GIT-репозиторием я бы очень хотел использовать SSH-ключи.
3 лайка
В контейнере вам не нужен SSH-ключ, просто удалите это:
1 лайк
Извините, я, кажется, не совсем понял…
Мой репозиторий доступен по SSH. Как можно клонировать плагин без SSH-ключа?
1 лайк
Ох. Возможно, я ошибаюсь. Тогда, возможно, вам нужно создать эту директорию с правильными правами доступа.
1 лайк
Сбивает с толку то, что часть команд в примерах нужно выполнять от имени root, а часть — от пользователя discourse. Это кажется довольно несогласованным.
В отличие от
Я проведу небольшое расследование в оболочке работающего контейнера.
Установка этого плагина немного сложна. Было бы здорово, если бы её можно было сделать такой же, как установку темы.
2 лайка
Dashboard.literatecomputing.com установит плагины в несколько кликов. Вы можете использовать его бесплатно, присоединившись к группе бесплатной пробной версии.
4 лайка
@Discourse, если вы хотите обновить руководство, вот рабочий код:
Чтобы использовать свои собственные SSH-ключи для доступа к приватному репозиторию, выполните следующие шаги:
  1. Разместите приватный SSH-ключ в /var/discourse/shared/standalone/identity/id_rsa (или в другом месте, доступном для контейнера; если вы выберете другое расположение, не забудьте обновить путь в шаблоне ниже соответствующим образом).
  2. Используйте следующий шаблон для добавления ваших плагинов:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Настройка доступа к приватному репозиторию
          - chown $(whoami) /shared/identity/id_rsa && chmod 600 /shared/identity/id_rsa
          - git config --global core.sshCommand "ssh -o StrictHostKeyChecking=no -o IdentitiesOnly=yes -i /shared/identity/id_rsa"
          # Мои приватные плагины
          - git clone git@example.com:repo/private-discourse-plugin.git
          # Сброс доступа
          - git config --global --unset core.sshCommand
5 лайков
Спасибо за то, что мне не нужно, но я живу с простым оригиналом.
Хотите объяснить, почему мы должны использовать ваш пример? Это потому что:
используйте свои собственные SSH-ключи для доступа к частному репозиторию
1 лайк
Почему бы просто не использовать токен в URL?
1 лайк
Что ж, у нас есть инструменты, чтобы разгадать эту загадку :winking_face_with_tongue:
Понимание полезности фрагментов конфигурации контейнера ИИ
Jagster:
Почему кто-то захочет использовать этот фрагмент в container/app.yml?
gpt-4o:
Чтобы эффективно ответить на ваш вопрос, мне нужно понять контекст вокруг конкретного фрагмента в container/app.yml. Не могли бы вы предоставить больше деталей или сам фрагмент, о котором идет речь? Так я смогу дать вам точное и полезное объяснение.
Jagster:
Извините, но мне нужен был этот композер.
Вот фрагмент:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Сброс доступа
gpt-4o:
Спасибо за предоставленный фрагмент. Этот фрагмент YAML предназначен для включения в файл конфигурации container/app.yml для экземпляра Discourse. Давайте разберем, что он делает:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # Сброс доступа
Объяснение
  1. Установка каталога:
    cd: $home/plugins
    Это изменяет текущий рабочий каталог на место расположения плагинов ($home/plugins).
  2. Настройка доступа к приватному репозиторию:
    • Меняет владельца приватного SSH-ключа (id_rsa) на текущего пользователя и устанавливает его права доступа на 600.
    • Настраивает Git на использование пользовательской SSH-команды, которая использует указанный приватный ключ и отключает строгую проверку ключей хоста.
  3. Клонирование приватного репозитория:
    Клонирует приватный Git-репозиторий, содержащий плагин для Discourse.
  4. Сброс команды SSH:
    Сбрасывает конфигурацию команды SSH в Git до состояния по умолчанию.
Когда и зачем использовать этот фрагмент
  1. Приватные репозитории: Если у вас есть приватный репозиторий плагинов для Discourse, который не доступен публично и требует аутентификации по SSH-ключу.
  2. Автоматизация: Этот скрипт помогает автоматизировать процесс настройки доступа к приватному репозиторию, его клонирования и обеспечения сброса окружения после этого. Это полезно для настроек непрерывного развертывания или автоматической подготовки серверов.
  3. Управление безопасностью: Он безопасно обрабатывает SSH-ключи (устанавливая права доступа к файлам, а затем сбрасывая пользовательскую команду SSH), что критически важно для поддержания уровня безопасности при автоматических развертываниях.
Важные соображения
  • Убедитесь, что ваш приватный SSH-ключ (id_rsa) надежно управляется и не подвергается риску.
  • Проверьте, что владелец и права доступа установлены правильно в соответствии с вашей политикой безопасности.
Для получения более подробной информации и контекста о app.yml и хуках в Discourse вы можете ознакомиться с соответствующей документацией Discourse.
Если у вас есть дополнительные вопросы или вам нужны дополнительные детали по конфигурации, не стесняйтесь спрашивать!
3 лайка
Привет! Звучит отлично! Но я не знаю, что делать после присоединения к группе бесплатной пробной версии! Пожалуйста, @pfaffman, не могли бы вы мне помочь? Я хочу установить плагин SAML. Было бы здорово протестировать Literate Computing, чтобы установить его и запустить!
Спасибо!
2 лайка
Мой фрагмент шаблона предназначен для случаев, когда у вас нет других способов доступа к репозиторию Git, кроме SSH-ключа (например, при использовании самохостингового репозитория Git за SSH).
5 лайков
Мне помогло бы, если бы в этих инструкциях было написано что-то вроде: «Эй, новичок! Не запускай команду git clone из оболочки. Просто добавь команду в файл app.yml согласно примеру, убедись, что отступы правильные, сохрани файл, а затем запусти команду rebuild».
Также было бы полезнее пояснить, когда необходимы флаги -E -u, а когда — нет.
Прежде чем у меня всё получилось, я совершил ещё несколько глупых ошибок. Сейчас, глядя на инструкции, я понимаю, что они почти идеальны. Но я попал в несколько ловушек, которых мог бы избежать, если бы инструкции были написаны с учётом того, что их будут читать новички вроде меня.
6 лайков
Я не эксперт, так что потерпите меня…
Вчера я установил Discourse, и теперь пытаюсь установить плагин.
Нужно ли мне выполнить:
или можно просто выполнить:
./launcher destroy app
а затем
./launcher start app
Выполнение команды ./launcher rebuild app занимает много времени, и мой сайт перестаёт работать или становится очень медленным.
Переустановка — единственный способ установить плагины. Удаление и запуск используют только старую конфигурацию.
Но не удаляйте ничего до переустановки. Если переустановка не удастся, вы сможете вернуть старую версию в работу с помощью запуска.
У вас одна конфигурация с одним контейнером, верно? Тогда форум будет недоступен, так как первая переустановка остановит ваш контейнер. Да, переустановка занимает много времени.
Существует также конфигурация с двумя контейнерами, и в этом случае время простоя составляет несколько минут. Но не переходите на неё, пока не освоите эти базовые операции.
3 лайка
