在自托管网站上安装插件
:warning: This guide assumes that you have a self-hosted standard installation. We only support the standard method of install here, so these instructions assume you have a standard install.
:warning: This guide only applies to self-hosted Discourse instances. If you are using a managed hosting service, the available plugins are controlled by your hosting provider. For example, on our hosting these specific plugins are available by hosting tier.
In this tutorial, we’ll install the Discourse Solved plugin.
This tutorial requires an understanding of how to use GitHub repos, specifically, how to get or copy the git clone URL and how to edit YAML (*.yml) files via the terminal using nano, specifically how to save and exit on nano. YAML files strongly follow indentations, so be sure to respect these as you copy and paste and edit the necessary *.yml for your Discourse instance.
  • Copy the plugin’s GitHub git clone url.
  • Access your container’s app.yml file (present in /var/discourse/containers/)
    cd /var/discourse
    nano containers/app.yml
  • Add the plugin’s repository URL to your container’s app.yml file:
    hooks:
      after_code:
        - exec:
            cd: $home/plugins
            cmd:
              - sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git
              - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
    Add the plugin’s git clone url just below the line containing git clone https://github.com/discourse/docker_manager.git)
    Follow the existing format of the docker_manager.git line; if it does not contain sudo -E -u discourse then insert - git clone https://github.com/discourse/discourse-solved.git.
  • Rebuild the container:
    cd /var/discourse
    ./launcher rebuild app
    That’s it, you’ve successfully installed the Discourse Solved plugin on your Discourse instance!
If your plugin is hosted in a private repository
You must use an OAuth token:
With the OAuth token, you can install your plugin in the same way as a public repo, and you don’t need to create a SSH key.
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
              - sudo -E -u discourse git clone https://<token>@github.com/owner/repo.git
We strongly advise you to use OAuth tokens for plugins in private repositories. However, if you cannot, see below.
SSH Key Private Install Steps
run:
  - exec: cd /var/www/discourse && sudo -u discourse bundle install --deployment --without test --without development
  - exec: echo "Host github.com\n\tStrictHostKeyChecking no\n" >> /user/.ssh/config
  - file:
      path: /user/.ssh/id_rsa
      chmod: 600
      contents: |
        -----BEGIN RSA PRIVATE KEY-----
        MIIEogIBAAKCAQEArCQG213utzqE5YVjTVF5exGRCkE9OuM7LCp/FOuPdoHrFUXk
           .... etc ....
        -----END RSA PRIVATE KEY-----
  - file:
      path: /user/.ssh/id_rsa.pub
      chmod: 600
      contents: ssh-rsa AAAAB3NzaC1yc2EAAAABIwAAAQEAklOUpkDHrfHY17SbrmTIpNLTGK9Tj .... etc .... user@discourse
  - exec: cd $home/plugins && git clone git@github.com:SecretOrg/secret-plugin.git
  - exec: cd $home && sudo -E -u discourse bundle exec rake db:migrate
  - exec: cd $home && rm -fr tmp/cache
  - exec: cd $home &&  sudo -E -u discourse bundle exec rake assets:precompile
  - exec: rm /user/.ssh/id_rsa
  - exec: rm /user/.ssh/id_rsa.pub
cd /var/discourse
Your private plugin should be installed on your Discourse instance.
How to uninstall a plugin
To remove a plugin, simply remove the - git clone https://github.com/... line from your app.yml file and rebuild your site via
cd /var/discourse
173 个赞
Discourse Slackdoor Plugin
How to create a new plugins?
Site maintenance mode during rebuilds?
Discourse Version 1.2
Embed Etherpad Lite pads into Discourse
Solved Button Plugin
LDAP Setup for Discourse
About the Plugin category
Wild Apricot login plugin
Formatting toolbar
Quick Messages Plugin
Can Plugins Be Added To Basic Docker Install
Discourse Mark Plugin
News Plugin :newspaper:
Daemonite Material Theme
How do i install plugins after doing a fork?
Does this software allow admin to put Adsense ads in?
Installing new plugins
Tickets Plugin :tickets:
"Onebox Assistant", crawl for those previews reliably!
Installing Plugins with Git
How do you add plugins?
LDAP Auth Missing from Plugins
Topic Ratings Plugin
Install plugins in your non-Docker development environment
Discourse BBCode
Admin Statistics Report
Update private plugin without rebuilding the application
Discord-rolesync plugin
Projects management plugin
Bump Reset plugin - Annotated to help new devs
Watching Categories based on on group in discourse
How to ad banners?
Application Files after Digital Ocean Setup
User feedback plugin
Category Page Plugin
Discourse Category Home :house:
Generating lots of Invite Tokens
Discourse Code Review
Discourse Poison Fountain
Custom Trust Level
Discourse Doc Categories
Fatal: Not a git repository (or any parent up to mount point /discourse)
How to add a Leaderboard link to the hamburger menu?
I need someone who can install a voting plugin
Custom Wizard Plugin :mage:
Introducing Font Awesome 5 and SVG icons
Click To Edit
Legal Compliance Plugin
Triggering account creation/login on external service when a user logs in on discourse
Community Network Visualisation
ListenBrainz
Subscription Plugin not working (Error)
Discourse-a2a-bbcode
Error using discourse-oauth2-basic plugin with NeonCRM
Question Answer Plugin
How might we better structure #howto?
Discourse Posthog Plugin
Cannot install new plugins: structure needs cleaning
Slow Discourse Rebuild on a VM with slow disks
Calendar Core - Needs any special theme?
Discourse Notifier
Discourse CommonMark text highlighting?
Mumble -- VOIP Plugin for Discourse
Advice on Installing Plugins
Smallcaps formatting
Cannot install plugin - nothing happens
What else do I need to take care of when self hosting?
Humanmark for Discourse - Hardware-Backed Humanity Verification
Verifiable Credentials Plugin
Discourse Shared Edits
Install Discourse for development using Docker
Installing discourse-math.git
Discourse Image Filter
Discourse Linkify Google Sheets
Discourse Voting missing table on postgresql
Discourse Signatures
Discourse BBCode Color
Discourse Post Sorting Customizer
Unikname Connect plugin
Discourse Video Upload Plugin with YouTube and Vimeo
Quoting not working
User profile by ID instead of username
Error after update failed today: [rake themes:update assets:precompile]
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return
Votes don't Merge when we combine posts
Discourse Video Inline
Discourse User Feedback
Availability of OpenID Connect in hosted plans
Codebytes Plugin
Multiple Users posting under same User or Group name?
What makes a successful volunteer Discourse sysadmin?
Not able to install any Discourse plugins
How to install the lazy-yt plugin
Issue With Sitemap
Discourse Private Replies
Google One Tap Login/Signup
Landing Pages Blog :small_airplane:
Search Thumbnails
Group Invitation Plugin
Discourse Mailgun Routes
Word Cloud plugin
Geo Blocking plugin
Post folding
Signed Google Cloud CDN URLs
Google Groups Link Plugin
Discourse LinkedIn Authentication
Discourse VK Authentication (vkontakte)
Discourse OneDrive Picker
Discourse BCC
Discourse Prometheus
Discourse Dictionary Plugin :ab:
Category Restrictor plugin
Dumbcourse – Old-browser friendly UI at /dumb (D-pad + small screens)
Slack Bot Construction Kit :robot:
Discourse Authorship Plugin
Discourse Livestream
Locked out from WinSCP and can't Install Plugins!
Create custom Automations
Affiliate link functions - rewrite
🤖 Discourse llms.txt Generator Plugin
Editing a table whose some rows don't start with a pipe duplicate these rows
How to: discourse-sitemap is deprecated and merged into Discourse's core. Please remove it from your app.yml file.?
How to update plugins manually from the command line?
Introducing Discourse Chat (BETA)
Discourse Restricted Replies
Discourse Yearly Review
Discourse Saved Searches
Discourse Intercom (Advanced)
Discourse Salesforce
Sign-In with Ethereum plugin
Discourse GitHub Verification
Discourse Algolia Search
Discourse Characters Required
Discourse No Bump
Discourse Teambuild
Installing Plugins in Discourse 101 for super-super dummies
Discourse Tooltips
Discourse Steam Login
Should I update my app.yml file?
Discourse Reach and Rights
Not enough space to rebuild
Landing Pages Plugin :small_airplane:
Configure OneLogin's SAML for Discourse
Plugin to Post Anonymous Thread via PN or give anonymous Feedback
Migrate a phpBB3 forum to Discourse
Discourse Codeberg Login
Mentionables
Discourse hosting on Linode?
Can I use the Subscriptions plugin on my own server?
Embed comments from Discourse in your single page app
Discourse Confused About the Number of Posts in a Topic?
How to show Full Name in Embeds
Restrict users to post certain words per category
Microsoft Graph Mail Poller
Allow-pm-to-staff
Snapblocks
Discourse AI Topic Summary :robot:
Animated Avatar
Discourse Who's Online
Discourse Google Perspective API
Discourse Newsletter Integration
Discourse Docs
Gitcoin Passport Plugin
Discourse Math Editor
Rebuilding the container is constantly failing after following the standard instructions on plugin install
ActivityPub Plugin
Modal Window
Silenced Avatar Flair
Discourse Staff Alias
Discourse GCS Helper
Topic List Previews (TLP)
Discourse Another SMTP
Can more than one post be selected as the solution?
I need help on installing a plugin
Discourse Follow
Custom Topic Button (group)
Discourse FontAwesome Pro
Discourse Zoom
Rocket.Chat SSO + embed plugin
Discourse blog (article and comments)
Unable to rebuild app - failed with exit code 1
Email Extension
NFT avatar
Discourse Mingle
How can I install my own plugin written in Ruby?
Discourse MusicBrainz Onebox
Custom Topic Button
No editor preview while editing after upgrading to 3.x
Better-Anonymous
Error during upgrading from Beta 3.1.x to latest
Signatures plugin not in the /admin/plugins page
Category Moderators Enhancer
Are plugins free using the open-source, self-host option?
Monero Subscriptions Plugin
:cn: Discourse Math 插件
Discourse Audio Message
Discourse Jira
Randomized Banner
🏆 Discourse Rich JSON-LD Microdata Plugin
Private Topics Plugin
Install discourse doc plugin from Git is failed
Discourse Restrict PMs to certain Groups
Discourse Chatbot :robot:
🖼️ Topic Gallery
Data Explorer Tutorial - Part 1 - Writing Your First Query
Option for scheduled replies
Discourse Disable Browser History Experiment
Publish Direct Messages
Discourse Authentication Validations
Discourse Provide Full Name in Mentions
Disable Email Verification for Discourse Plugin
Discourse send PDF inline
Discourse Anonymous Post
Indisposable Email - block disposable email domains
Discourse-embed-bilibili(在discourse中插入哔哩哔哩视频)
Set user registration IP address API endpoint
Trading Buttons
Installing discourse follow plugin in development (boot_dev) setup — no app.yml file
Locations Plugin :earth_africa:
User Response Times
Contact Form
Babble Chat
Discourse mail daily summary plugin
Discourse Preset Topic Composer
Discourse Custom Topic Lists
Highest-Post Excerpts in Topic List
What to Expect When Rebuilding Discourse
Seen lots of threads asking if Discourse is free when self hosted but nothing about the plugins
Rebuilding Forum (Restoring back-up works, rebuilding does not)
Discourse Surveys
Login Helper Plugin
Can't install reaction plugin
Error when installing Advertising
Globally replace translations
Discourse Retort
Discourse Translator
Discourse Category Experts
Discourse Chat Bridge (Telegram)
Trading Buttons
Discourse Disorder
Discourse AI plugin with self hosted discourse site
Hubot Adapter for Discourse
Discourse No Bump
CJK Formatter Plugin
Self-hosting Index
SCIM Plugin
Journal Plugin
Problem installing docs
How to install and configure AI features step by step
Discourse Encrypt (deprecated)
Discourse Open Graph
Turbowarp plugin
Discourse Workflow
Question about Docker Manager?
Moderation API Plugin
Discourse OpenID Connect (OIDC)
Dark Visitors
Discourse Dynamic Groups
Custom Summary Gist
Created as Default Sort Order
Allow Title-Only Onebox
How to install the plugin on bitnami's repository
Discourse BBCode Tabs Plugin
Tag Intersection Navigator
I broke my site while updating it
Collections
Can Discourse ship frequent Docker images that do not need to be bootstrapped?
Push notifications for iPhone and Android apps
Automation script: Move topic on close
Error installing theme from Github
Discourse Amazon SNS notifications
Best practices of keeping track of feature requests
Contact Form
No Bump First Post Plugin
How to Install Discourse Plugins Hosted in Private Repositories Using SSH Key?
National Flags (fork)
VK ID OAuth 2.1 Authentication for Discourse
🔐 Yandex ID OAuth2 Authentication for Discourse
Discourse Bilibili Onebox
Time Registration plugin
Category Event Policy
Calendar RSVP Posts
ReplyGif
Discourse User Location
什么时候可以在管理后台直接安装插件?
Gitee 码云登录插件
Upgrading Mathjax to version 4
Updates no longer in the Admin UI?
Stop Forum Spam Plugin
How to make a discourse forum look like forum.glamour.de
[Solved] Admin-upgrade page not showing up
Synchronizer-base for any backup provider
"Your Docker installation is not using a supported storage driver."
Formatting issues adding plugins to app.yml
Solution icon does not show in posts
Fixing problems with rebuild app
Auto Bookmarks plugin
Force specific users through moderation
Homepage Filter plugin
Discourse Group User Status
Voice recording plugin
How to hook up JWT Single Sign On to Discourse
Should all plugins be cloned as the `discourse` user?
How I can add plugin to my discourse
OAuth2 integration with Drupal
Discord Sync: sync a Discourse forum with a Discord server
No option appears to choose better answer
Discourse Avatar name_first_letter
Auto-suspend inactive users
Algolia plugin indexation
Telegram Notifications Plugin (discourse-telegram-notifications)
Trying to install plugin (But not working)
How to break 99k char limit?
How to edit plugins code?
I want to install a plugin for development, what should I do?
Azure Blob Storage Plugin
./launcher rebuild app error './launcher: No such file or directory'
Discourse Wikilinks Plugin
SSO for College Account
Developing Discourse Plugins - Part 6 - Add acceptance tests
Favorites - select your favorite categories
Why do I need a block storage?
Plugin for Preventing Malicious Linking
Discourse Fingerprint - Browser Fingerprinting Plugin
Solved Reminders Plugin
Sidebar with categories
Merge Users Plugin
Events Plugin :calendar:
Unable to find /plugins dir
Pwned Passwords Validator
Launcher rebuild app does nothing
Business plugins and install on-premise
Private repo on Github
Discourse Dice Roller (RogerBW)
Any options for over-riding the username restrictions?
Collude - a collaborative text editor for Discourse
Can I access Discourse forum Database to use for PowerBI reporting?
我已更新指南,使用另一个示例插件替换 Discourse Spoiler Alert,该插件已捆绑到核心中。
我使用了 Discourse Solved,但如果使用其他插件效果更好,请告诉我。
9 个赞
我在 Digital Ocean 上托管了 discourse,当我使用该格式时,它显示了此错误。
FAILED
Pups::ExecError: cd /var/www/discourse/plugins && sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git failed with return #<Process::Status: pid 252 exit 129>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home/plugins", "cmd"=>["sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git - sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git"]}
bootstrap failed with exit code 129
2a49220a4ff35feac3c1a9a4a9c1cad1094bde4c9ba321975ebc9ae7ead2bbee
然后我使用了此格式
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - sudo -E -u discourse git clone https://github.com/discourse/docker_manager.git && sudo -E -u discourse git clone https://github.com/discourse/discourse-solved.git
而不是
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
4 个赞
8 篇帖子已拆分为新主题:Formatting issues adding plugins to app.yml
抱歉问了一个愚蠢的问题,但我该如何知道是否需要为 git clone 语句包含 sudo -E -u discourse
3 个赞
你的 docker_manager 行看起来是怎样的?
4 个赞
我的 app.yml 中的其他条目都没有 sudo 部分,所以我省略了它,到目前为止一切正常。
5 个赞
看起来这种方法不再有效了。
sh: 1: cannot create /user/.ssh/config: Directory nonexistent
对于我自托管的 GIT 存储库,我真的很想使用 SSH 密钥。
3 个赞
您不需要容器中的 ssh 密钥,只需删除此内容:
1 个赞
抱歉,我不太明白。
我的仓库可以通过 SSH 访问。如何在没有 SSH 密钥的情况下克隆插件?
1 个赞
哦。也许我错了。那么也许你需要创建那个具有正确权限的目录。m
1 个赞
令人困惑的是,示例中的部分命令需要以 root 用户身份运行,部分则需要以 discourse 用户身份运行。这似乎不太一致。
与此相对的是
我将在运行容器的 shell 中进行一些挖掘。
这个插件安装有点复杂。如果能和安装主题一样简单就好了。
2 个赞
Dashboard.literatecomputing.com 将通过几次点击安装插件。您可以通过加入免费试用组来免费使用它。
4 个赞
@Discourse,如果您想更新指南,这是可行的代码:
要使用您自己的 SSH 密钥访问私有存储库,请按照以下步骤操作:
  1. 将私有 SSH 密钥放在 /var/discourse/shared/standalone/identity/id_rsa(或容器可访问的其他位置;如果您选择其他位置,请记住在下面的模板中相应地更新路径)。
  2. 使用以下模板添加您的插件:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # 设置私有存储库访问
          - chown $(whoami) /shared/identity/id_rsa && chmod 600 /shared/identity/id_rsa
          - git config --global core.sshCommand "ssh -o StrictHostKeyChecking=no -o IdentitiesOnly=yes -i /shared/identity/id_rsa"
          # 我的私有插件
          - git clone git@example.com:repo/private-discourse-plugin.git
          # 取消设置访问
          - git config --global --unset core.sshCommand
5 个赞
感谢您提供的内容,但我不需要这个,我习惯使用简单的原始版本。
您想解释一下为什么我们应该使用您的示例吗?是因为这个原因吗:
使用您自己的 SSH 密钥来访问私有存储库
1 个赞
为什么不直接在 URL 中使用令牌?
1 个赞
嗯,我们有工具来解决这个谜题 :winking_face_with_tongue:
理解容器配置代码段的实用性 AI
Jagster:
为什么有人想在 container/app.ym 中使用这个代码段?
gpt-4o:
为了有效地回答您的问题,我需要了解 container/app.yml 中特定代码段的上下文。您能否提供更多详细信息或您所指的实际代码段?这样我才能给您一个精确且有用的解释。
Jagster:
抱歉,但我需要这个组合器。
这是代码段:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # 设置私有仓库访问
          # 我的私有插件
          # 取消设置访问
gpt-4o:
感谢您提供代码段。此 YAML 代码段旨在包含在 Discourse 实例的 container/app.yml 配置文件中。让我们分解一下它的作用:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          # 设置私有仓库访问
          # 我的私有插件
          # 取消设置访问
解释
  1. 设置目录
    cd: $home/plugins
    这会将工作目录更改为插件所在的位置($home/plugins)。
  2. 设置私有仓库访问
    • 将 SSH 私钥(id_rsa)的所有权更改为当前用户,并将其权限设置为 600
    • 配置 Git 使用自定义 SSH 命令,该命令使用指定的私钥并禁用严格的主机密钥检查。
  3. 克隆私有仓库
    克隆一个私有的 Git 仓库,其中包含一个 Discourse 插件。
  4. 取消设置 SSH 命令
    将 Git SSH 命令配置重置为默认状态。
何时以及为何使用此代码段
  1. 私有仓库:如果您有一个私有的 Discourse 插件仓库,该仓库无法公开访问,并且需要基于 SSH 密钥的身份验证。
  2. 自动化:此脚本有助于自动化设置私有仓库访问、克隆仓库以及之后确保环境重置的过程。这对于持续部署设置或自动化服务器配置非常有用。
  3. 安全管理:它安全地处理 SSH 密钥(设置文件权限,然后取消设置自定义 SSH 命令),这对于在自动化部署期间维护安全态势至关重要。
重要注意事项
  • 确保您的私有 SSH 密钥(id_rsa)得到安全管理,并且不会暴露。
  • 根据您的安全策略验证所有权和权限是否设置正确。
有关 app.yml 和 Discourse 中 hooks 的更详细信息和上下文,您可以查看相关的 Discourse 文档
如果您有任何其他问题或需要有关配置的更多详细信息,请随时提问!
3 个赞
您好!听起来很棒!但我不知道加入免费试用组后该如何进行!请问,@pfaffman,您能帮帮我吗?我想安装 SAML 插件。如果能测试 Literate Computing 来安装和运行它,那就太好了!
谢谢!
2 个赞
我的模板片段适用于您除了 SSH 密钥之外没有其他任何方式可以访问 Git 存储库(例如,对于自托管的、位于 SSH 后面的 Git 存储库)。
5 个赞
